Error while building the rtems-libbsd
Utkarsh Rai
utkarsh.rai60 at gmail.com
Sat Dec 28 17:43:49 UTC 2019
Hi,
While building the rtems-libbsd as described here
<https://devel.rtems.org/browser/rtems-libbsd/README.waf?rev=b83012a9f9f1551d9d223c3126d0f43aba79db62>
I
was able to successfully configure the waf file as:-
waf configure
--prefix="/home/ur10/sandbox/rtems/5"
--rtems-bsps=arm/beagleboneblack
--buildset=buildset/default.ini
But the build fails on the "waf" instruction with the error - "Could not
create the directory ///h".
My path for the build is PATH="~/sandbox/rtems/bin:$PATH", with the tools
and the rtems-libbsd in the sandbox directory.
It would be very kind of you if someone could point out as to what is it
that I am doing wrong.
Thank You, Regards.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191228/5eef672c/attachment.html>
