[PATCH v2] Raspberrypi: updated the console interface.
Christian Mauderer list at c-mauderer.de
Sat Dec 28 20:41:13 UTC 2019
On 28/12/2019 20:03, Niteesh wrote:
> I will start working on a patch that uses FDT. Instead of merging this
> I create a patch v3 that uses FDT. Shall I remove some files, I will be
> heavily using
> the imx and other FDT based drivers as a reference.
You can remove everything that is no longer used. I expect that it will
be mainly the files containing the table based selection and console
selection code.
> On Sun, Dec 29, 2019 at 12:27 AM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     On 28/12/2019 19:48, Niteesh wrote:
>     > Is bsp_console_select legacy? And the new way will be by linking
>     > the correct serial device to /dev/console in
>     console_initialization, right?
>     > If so, shall I add one?
>     The function is only called from legacy-console.c. So yes: This function
>     can be removed. The logic on the other hand should move to somewhere
>     else.
>     The console-termios-init.c creates a link named CONSOLE_DEVICE_NAME. So
>     you can't use that code and create your link manually. If you use the
>     table based approach (which is OK as a first step) you can't really
>     select the console.
>     I would suggest to either clean that patch up so it can be merged and
>     move to a fdt based approach simmilar to imx in a second patch. In that
>     case the console_initialize() function from console-termios-init.c will
>     be replaced by a custom function that searches the FDT for the devices.
>     The FDT will make it simpler to adapt to RPi3. Or if you prefere it you
>     can do that right now and create a patch v3 that directly uses FDT.
>     > On Sat, Dec 28, 2019 at 11:50 PM Niteesh <gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>
>     > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>> wrote:
>     >     I am sorry if this question sounds silly, but how can I access the
>     >     output_char_fb if it
>     >     is marked as static in console-select.c, currently the fb
>     context is
>     >     in console-config.c
>     >     Should I move the BSP_select_function to console-config? for
>     shall I
>     >     remove the static qualifier
>     >     from the function?
>     >     Currently, the console_select has 2 functions,
>     bsp_Is_Available and
>     >     bsp_console_select.
>     >     On Sat, Dec 28, 2019 at 11:30 PM Niteesh <gsnb.gn at gmail.com
>     >         On Sat, Dec 28, 2019 at 11:12 PM Christian Mauderer
>     >         <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>     >             On 28/12/2019 17:22, Niteesh wrote:
>     >             > I think you misunderstood, I was talking about the
>     casting
>     >             in the
>     >             > rtems_termios_device_handler
>     >             Yes, I misunderstood you there.
>     >             > const rtems_termios_device_handler fbcons_fns =
>     >             >   .first_open = fbcons_open,
>     >             >   .last_close = fbcons_close,
>     >             >   .poll_read = fbcons_inbyte_nonblocking_polled,
>     >             >   .write = (void (*)(rtems_termios_device_context *,
>     const
>     >             char *,
>     >             > size_t))fbcons_write_support_polled,
>     >             >   .set_attributes = fbcons_set_attributes,
>     >             >   .mode = TERMIOS_POLLED
>     >             > the write requires a function type of
>     >             >   *void (*write)(
>     >             >     rtems_termios_device_context *context,
>     >             >     const char *buf,
>     >             >     size_t len
>     >             > but the fbcons function is of type
>     >             > *static ssize_t fbcons_write_support_polled(
>     >             >   rtems_termios_device_context *base,
>     >             >   const char *buf,
>     >             >   size_t      len
>     >             > Well, if the above cast in the device handler causes a
>     >             problem, can you
>     >             > elaborate more on
>     >             > what kind of a problem would it be?
>     >             In that case it should work. But why do you need to
>     cast it
>     >             there?
>     >             Wouldn't it be simpler to just change the
>     >             function? It isn't used anywhere else or did I miss
>     something?
>     >         No, it is not used anywhere. I'll change the function.
>     >             > And for the BSP_output_char function, I used a function
>     >             pointer. The
>     >             > console_select assigns the
>     >             > appropriate function to the function pointer and the
>     >             output_char call's
>     >             > it by providing the context.
>     >             > static void output_char(char c)
>     >             >   const console_device *dev =
>     >             &console_device_table[console_select];
>     >             >   rtems_termios_device_context *con = dev->context;
>     >             >   console_instance(con, c);
>     >             > console_instance is the function pointer, which is
>     assigned to
>     >             > arm_pl011_write_polled  by
>     >             > default, or to fbcons_write_polled, if frame buffer is
>     >             decided to be used.
>     >             Yes it will work and it's resonable performant. We are
>     >             talking about a
>     >             slow serial interface in an exception case. But anyway I'm
>     >             not entirely
>     >             happy.
>     >             The compiler should make something like the following
>     out of it:
>     >             - Look up and call the value of BSP_output_char
>     >             - Load the context (start of table + console_select +
>     fixed
>     >             offset) into
>     >             "con"
>     >             - Look up and call the value of console_instance
>     >             If you use the way I suggested below you will have
>     about the
>     >             following:
>     >             - Look up and call the value of BSP_output_char (one
>     of the
>     >             wrappers)
>     >             - Call the right function with a fixed parameter
>     >             So it's a bit shorter and beneath that you save a global
>     >             variable.
>     >         Sure, will change it.
>     >             > On Sat, Dec 28, 2019 at 8:50 PM Christian Mauderer
>     >             > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de>>>>
>     >             wrote:
>     >             >     On 28/12/2019 14:10, G S Niteesh wrote:
>     >             >     > The patch updates the older console interface used
>     >             by the BSP,
>     >             >     > to newer one. It also replaces the custom
>     >             usart(PL011) driver
>     >             >     > with arm-pl011. The fb function's signatures where
>     >             also changed
>     >             >     > to accommodate with interface update.
>     >             >     > Update #3034
>     >             >     >  bsps/arm/raspberrypi/console/console-config.c
>     |  62
>     >             >     >  bsps/arm/raspberrypi/console/console_select.c
>     |  68
>     >             >     >  bsps/arm/raspberrypi/console/fbcons.c
>      |  71
>     >             >     >  bsps/arm/raspberrypi/console/usart.c
>     | 142
>     >             >     >  bsps/arm/raspberrypi/include/bsp/fbcons.h
>      |  19 ++-
>     >             >     >  .../arm/raspberrypi/include/bsp/raspberrypi.h
>     |  70
>     >             >     >  bsps/arm/raspberrypi/include/bsp/usart.h
>     |   5 +-
>     >             >     >  c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>     |   5 +-
>     >             >     >  8 files changed, 136 insertions(+), 306
>     deletions(-)
>     >             >     > diff --git
>     >             a/bsps/arm/raspberrypi/console/console-config.c
>     >             >     b/bsps/arm/raspberrypi/console/console-config.c
>     >             >     > index d2186c918b..f479e19d99 100644
>     >             >     > @@ -22,45 +22,47 @@
>     >             >     >  #include <libchip/serial.h>
>     >             >     > -#include <bspopts.h>
>     >             >     > -#include <bsp/irq.h>
>     >             >     > -#include <bsp/usart.h>
>     >             >     > +#include <bsp.h>
>     >             >     >  #include <bsp/raspberrypi.h>
>     >             >     > +#include <bsp/usart.h>
>     >             >     > +#include <bsp/arm-pl011.h>
>     >             >     >  #include <bsp/fbcons.h>
>     >             >     > +#include <bsp/console-termios.h>
>     >             >     > +#include <bspopts.h>
>     >             >     > -console_tbl Console_Configuration_Ports [] = {
>     >             >     > -      .sDeviceName = "/dev/ttyS0",
>     >             >     > -      .deviceType = SERIAL_CUSTOM,
>     >             >     > -      .pDeviceFns = &bcm2835_usart_fns,
>     >             >     > -      .deviceProbe = NULL,
>     >             >     > -      .pDeviceFlow = NULL,
>     >             >     > -      .ulCtrlPort1 = BCM2835_UART0_BASE,
>     >             >     > -      .ulCtrlPort2 = 0,
>     >             >     > -      .ulClock = USART0_DEFAULT_BAUD,
>     >             >     > -      .ulIntVector = BCM2835_IRQ_ID_UART
>     >             >     > -      .sDeviceName ="/dev/fbcons",
>     >             >     > -      .pDeviceFns = &fbcons_fns,
>     >             >     > -      .deviceProbe = fbcons_probe,
>     >             >     > +arm_pl011_context pl011_context = {
>     >             >     > +  .base =
>     >             RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
>     >             >     > +  .regs = (volatile pl011 *) BCM2835_PL011_BASE,
>     >             >     > +  .initial_baud = PL011_DEFAULT_BAUD
>     >             >     > -#define PORT_COUNT \
>     >             >     > -  (sizeof(Console_Configuration_Ports) \
>     >             >     > -    / sizeof(Console_Configuration_Ports [0]))
>     >             >     > +rpi_fb_context fb_context = {
>     >             >     > +  .base =
>     >             RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("FB")
>     >             >     > +const console_device console_device_table[] = {
>     >             >     > +    .device_file = "/dev/ttyS0",
>     >             >     > +    .probe = console_device_probe_default,
>     >             >     > +    .handler = &arm_pl011_fns,
>     >             >     > +    .context = &pl011_context.base
>     >             >     > +    .device_file = "/dev/fbcons",
>     >             >     > +    .probe = fbcons_probe,
>     >             >     > +    .handler = &fbcons_fns,
>     >             >     > +    .context = &fb_context.base
>     >             >     > -unsigned long Console_Configuration_Count =
>     PORT_COUNT;
>     >             >     > +const size_t console_device_count =
>     >             >     RTEMS_ARRAY_SIZE(console_device_table);
>     >             >     >  static void output_char(char c)
>     >             >     > -  const console_fns *con =
>     >             >     > -    Console_Configuration_Ports
>     >             [Console_Port_Minor].pDeviceFns;
>     >             >     > -  con->deviceWritePolled((int)
>     Console_Port_Minor, c);
>     >             >     > +  const console_device *dev =
>     >             >     > +  rtems_termios_device_context *con =
>     dev->context;
>     >             >     > +  console_instance(con, c);
>     >             >     I'm still not happy with that. What I had in
>     mind was
>     >             more or less:
>     >             >     static void output_char_serial(char c)
>     >             >       arm_pl011_write_polled(&pl011_context.base, c);
>     >             >     static void output_char_fb(char c)
>     >             >       fbcons_write_polled(&fb_context.base, c);
>     >             >     BSP_output_char_function_type BSP_output_char =
>     >             output_char_serial;
>     >             >     And if you decide that the frame buffer should
>     be used
>     >             in the select
>     >             >     function you do a
>     >             >         BSP_output_char = output_char_fb;
>     >             >     >  BSP_output_char_function_type BSP_output_char =
>     >             output_char;
>     >             >     > diff --git
>     >             a/bsps/arm/raspberrypi/console/console_select.c
>     >             >     b/bsps/arm/raspberrypi/console/console_select.c
>     >             >     > index bd246ca868..ea3325266f 100644
>     >             >     > @@ -15,69 +15,40 @@
>     >             >     >   *  http://www.rtems.org/license/LICENSE
>     >             >     >  #include <bsp.h>
>     >             >     > +#include <bsp/raspberrypi.h>
>     >             >     > +#include <bsp/fbcons.h>
>     >             >     > +#include <bsp/rpi-fb.h>
>     >             >     >  #include <bsp/fatal.h>
>     >             >     >  #include <rtems/libio.h>
>     >             >     >  #include <stdlib.h>
>     >             >     >  #include <string.h>
>     >             >     >  #include <assert.h>
>     >             >     >  #include <termios.h>
>     >             >     > -#include <rtems/termiostypes.h>
>     >             >     > -#include
>     "../../shared/dev/serial/legacy-console.h"
>     >             >     > -#include <bsp/rpi-fb.h>
>     >             >     > -rtems_device_minor_number BSPPrintkPort = 0;
>     >             >     > +int console_select = PL011;
>     >             >     > +console console_instance =
>     arm_pl011_write_polled;
>     >             >     > - * Method to return true if the device associated
>     >             with the
>     >             >     > - * minor number probs available.
>     >             >     > -static bool bsp_Is_Available(
>     >             rtems_device_minor_number minor )
>     >             >     > +static bool bsp_Is_Available( int index )
>     >             >     > -  console_tbl *cptr = Console_Port_Tbl[ minor ];
>     >             &console_device_table[index];
>     dev->context;
>     >             >     >     * First perform the configuration dependent
>     >             probe, then the
>     >             >     >     * device dependent probe
>     >             >     > -  if ( ( !cptr->deviceProbe || cptr->deviceProbe(
>     >             minor ) ) &&
>     >             >     > -       cptr->pDeviceFns->deviceProbe( minor ) ) {
>     >             >     > +  if ( ( !dev->probe || dev->probe( con ) ) ){
>     >             >     >      return true;
>     >             >     >    return false;
>     >             >     > - * Method to return the first available device.
>     >             >     > -static rtems_device_minor_number
>     >             bsp_First_Available_Device( void )
>     >             >     > -  rtems_device_minor_number minor;
>     >             >     > -  for ( minor = 0; minor < Console_Port_Count;
>     >             minor++ ) {
>     minor ];
>     >             >     > -     * First perform the configuration dependent
>     >             probe, then the
>     >             >     > -     * device dependent probe
>     cptr->deviceProbe(
>     >             minor ) ) &&
>     >             >     > -      return minor;
>     >             >     > -   *  Error No devices were found.  We will
>     want to
>     >             bail here.
>     >             >     > -  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>     >             >     >  void bsp_console_select( void )
>     >             >     > @@ -90,25 +61,18 @@ void bsp_console_select(
>     void )
>     >             >     >    const char *opt;
>     >             >     > -  Console_Port_Minor = BSP_CONSOLE_UART0;
>     >             >     > -  BSPPrintkPort = BSP_CONSOLE_UART0;
>     >             >     >    opt = rpi_cmdline_get_arg( "--console=" );
>     >             >     >    if ( opt ) {
>     >             >     >      if ( strncmp( opt, "fbcons", sizeof(
>     "fbcons" )
>     >             - 1 ) == 0 ) {
>     >             >     >        if ( rpi_video_is_initialized() > 0 ) {
>     >             >     > -        Console_Port_Minor = BSP_CONSOLE_FB;
>     >             >     > -        BSPPrintkPort = BSP_CONSOLE_FB;
>     >             >     > +        console_select = FB;
>     >             >     > +        console_instance = fbcons_write_polled;
>     >             >     > -   * If the device that was selected isn't
>     >             available then
>     >             >     > -   * let the user know and select the first
>     >             available device.
>     >             >     > -  if ( !bsp_Is_Available( Console_Port_Minor
>     bsp_First_Available_Device();
>     >             >     > +  if( !bsp_Is_Available( console_select ) ){
>     >             >     > +    bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>     >             >     > diff --git a/bsps/arm/raspberrypi/console/fbcons.c
>     >             >     b/bsps/arm/raspberrypi/console/fbcons.c
>     >             >     > index 3669ba458d..6e710e252d 100644
>     >             >     > --- a/bsps/arm/raspberrypi/console/fbcons.c
>     >             >     > +++ b/bsps/arm/raspberrypi/console/fbcons.c
>     >             >     > @@ -18,6 +18,7 @@
>     >             >     >  #include <rtems.h>
>     >             >     > +#include <rtems/termiostypes.h>
>     >             >     > @@ -29,15 +30,6 @@
>     >             >     >  #include <bsp/vc.h>
>     >             >     >  #include <bsp/rpi-fb.h>
>     >             >     > - *  fbcons_init
>     >             >     > - *  This function initializes the fb console to a
>     >             quiecsent state.
>     >             >     > -static void fbcons_init( int minor )
>     >             >     >   *  fbcons_open
>     >             >     > @@ -45,13 +37,14 @@ static void fbcons_init(
>     int minor )
>     >             >     >   *  Default state is 9600 baud, 8 bits, No
>     parity,
>     >             and 1 stop bit.
>     >             >     > -static int fbcons_open(
>     >             >     > -  int   major,
>     >             >     > -  int   minor,
>     >             >     > -  void *arg
>     >             >     > +static bool fbcons_open(
>     >             >     > +  struct rtems_termios_tty *tty,
>     >             >     > +  rtems_termios_device_context *base,
>     >             >     > +  struct termios *term,
>     >             >     > +  rtems_libio_open_close_args_t *args
>     >             >     > -  return RTEMS_SUCCESSFUL;
>     >             >     > +  return true;
>     >             >     > @@ -59,13 +52,12 @@ static int fbcons_open(
>     >             >     >   *  This function shuts down the requested port.
>     >             >     > -static int fbcons_close(
>     >             >     > -  int   major,
>     >             >     > -  int   minor,
>     >             >     > -  void *arg
>     >             >     > +static void fbcons_close(
>     >             >     > -  return ( RTEMS_SUCCESSFUL );
>     >             >     > @@ -73,8 +65,8 @@ static int fbcons_close(
>     >             >     >   *  This routine polls out the requested
>     character.
>     >             >     > -static void fbcons_write_polled(
>     >             >     > -  int  minor,
>     >             >     > +void fbcons_write_polled(
>     >             >     >    char c
>     >             >     > @@ -91,7 +83,7 @@ static void fbcons_write_polled(
>     >             >     >  static ssize_t fbcons_write_support_polled(
>     >             >     > -  int         minor,
>     >             >     >    const char *buf,
>     >             >     >    size_t      len
>     >             >     > @@ -102,7 +94,7 @@ static ssize_t
>     >             >     >     * poll each byte in the string out of the
>     port.
>     >             >     >    while ( nwrite < len ) {
>     >             >     > -    fbcons_write_polled( minor, *buf++ );
>     >             >     > +    fbcons_write_polled( base, *buf++ );
>     >             >     >      nwrite++;
>     >             >     > @@ -117,7 +109,9 @@ static ssize_t
>     >             >     >   *  Console Termios polling input entry point.
>     >             >     > -static int fbcons_inbyte_nonblocking_polled( int
>     >             minor )
>     >             >     > +int fbcons_inbyte_nonblocking_polled(
>     >             >     >    // if( rtems_kbpoll() ) {
>     >             >     >    //   int c = getch();
>     >             >     > @@ -133,15 +127,17 @@ static int
>     >             >     int minor )
>     >             >     >   *  This function sets the UART channel to
>     reflect
>     >             the requested
>     >             >     termios
>     >             >     >   *  port settings.
>     >             >     > -static int fbcons_set_attributes(
>     >             >     > -  int                   minor,
>     >             >     > +static bool fbcons_set_attributes(
>     >             >     >    const struct termios *t
>     >             >     > -  return 0;
>     >             >     > +  return true;
>     >             >     > -bool fbcons_probe( int minor )
>     >             >     > +bool fbcons_probe(
>     >             >     > +  rtems_termios_device_context *context
>     >             >     >    // rtems_status_code status;
>     >             >     >    static bool firstTime = true;
>     >             >     > @@ -163,15 +159,12 @@ bool fbcons_probe( int
>     minor )
>     >             >     >    return ret;
>     >             >     > -const console_fns fbcons_fns =
>     >             >     > +const rtems_termios_device_handler fbcons_fns =
>     >             >     > -  .deviceProbe = libchip_serial_default_probe,
>     >              /* deviceProbe */
>     >             >     > -  .deviceFirstOpen = fbcons_open,
>     >             >     deviceFirstOpen */
>     >             >     > -  .deviceLastClose = fbcons_close,
>     >             >     deviceLastClose */
>     >             >     > -  .deviceRead = fbcons_inbyte_nonblocking_polled,
>     >             /* deviceRead */
>     >             >     > -  .deviceWrite = fbcons_write_support_polled,
>     >              /* deviceWrite */
>     >             >     > -  .deviceInitialize = fbcons_init,
>     >             >     deviceInitialize */
>     >             >     > -  .deviceWritePolled = fbcons_write_polled,
>     >             >     deviceWritePolled */
>     >             >     > -  .deviceSetAttributes =
>     fbcons_set_attributes,   /*
>     >             >     deviceSetAttributes */
>     >             >     > -  .deviceOutputUsesInterrupts = FALSE,
>     >             >     deviceOutputUsesInterrupts*/
>     >             >     > +  .first_open = fbcons_open,
>     >             >     > +  .last_close = fbcons_close,
>     >             >     > +  .poll_read = fbcons_inbyte_nonblocking_polled,
>     >             >     > +  .write = (void (*)(rtems_termios_device_context
>     >             *, const char
>     >             >     *, size_t))fbcons_write_support_polled,
>     >             >     > +  .set_attributes = fbcons_set_attributes,
>     >             >     > +  .mode = TERMIOS_POLLED
>     >             >     > \ No newline at end of file
>     >             >     > diff --git a/bsps/arm/raspberrypi/console/usart.c
>     >             >     b/bsps/arm/raspberrypi/console/usart.c
>     >             >     > index 25fb523621..471d0c553f 100644
>     >             >     > --- a/bsps/arm/raspberrypi/console/usart.c
>     >             >     > +++ b/bsps/arm/raspberrypi/console/usart.c
>     >             >     > @@ -23,145 +23,3 @@
>     >             >     >  #include <bsp/usart.h>
>     >             >     >  #include <rtems/bspIo.h>
>     >             >     > -static void usart_delay(uint32_t n)
>     >             >     > - volatile uint32_t i = 0;
>     >             >     > - for(i = 0; i < n; i++)
>     >             >     > -#if 0
>     >             >     > - *  These will be useful when the driver supports
>     >             interrupt
>     >             >     driven IO.
>     >             >     > -static rtems_vector_number
>     >             usart_get_irq_number(const console_tbl
>     >             >     *ct)
>     >             >     > -  return ct->ulIntVector;
>     >             >     > -static uint32_t usart_get_baud(const
>     console_tbl *ct)
>     >             >     > -  return ct->ulClock;
>     >             >     > -#endif
>     >             >     > -static void usart_set_baud(int minor, int baud)
>     >             >     > -  * Nothing for now
>     >             >     > - return;
>     >             >     > -static void usart_initialize(int minor)
>     >             >     > -  unsigned int gpio_reg;
>     >             >     > -  ** Program GPIO pins for UART 0
>     >             >     > -  gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
>     >             >     > -  gpio_reg &= ~(7<<12);    /* gpio14 */
>     >             >     > -  gpio_reg |=  (4<<12);    /* alt0   */
>     >             >     > -  gpio_reg &= ~(7<<15);    /* gpio15 */
>     >             >     > -  gpio_reg |=  (4<<15);    /* alt0   */
>     >             >     > -  BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
>     >             >     > -  BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
>     >             >     > -  usart_delay(150);
>     >             >     > -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) =
>     >             (1<<14)|(1<<15);
>     >             >     > -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>     >             >     > -  ** Init the PL011 UART
>     >             >     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>     >             BCM2835_UART0_IMSC_RX;
>     >             >     > -  usart_set_baud(minor, 115000);
>     >             >     > -static int usart_first_open(int major, int minor,
>     >             void *arg)
>     >             >     > -  rtems_libio_open_close_args_t *oc =
>     >             >     (rtems_libio_open_close_args_t *) arg;
>     >             >     > -  struct rtems_termios_tty *tty = (struct
>     >             rtems_termios_tty *)
>     >             >     oc->iop->data1;
>     >             >     > -  const console_tbl *ct = Console_Port_Tbl
>     [minor];
>     >             >     > -  console_data *cd = &Console_Port_Data [minor];
>     >             >     > -  cd->termios_data = tty;
>     >             >     > -  rtems_termios_set_initial_baud(tty,
>     ct->ulClock);
>     >             >     > -  return 0;
>     >             >     > -static int usart_last_close(int major, int minor,
>     >             void *arg)
>     >             >     > -  return 0;
>     >             >     > -static int usart_read_polled(int minor)
>     >             >     > -  if (minor == 0) {
>     >             >     > -    if (((BCM2835_REG(BCM2835_UART0_FR)) &
>     >             BCM2835_UART0_FR_RXFE)
>     >             >     == 0) {
>     >             >     > -       return((BCM2835_REG(BCM2835_UART0_DR))
>     & 0xFF );
>     >             >     > -    } else {
>     >             >     > -      return -1;
>     >             >     > -  } else {
>     >             >     > -    printk("Unknown console minor number: %d\n",
>     >             minor);
>     >             >     > -    return -1;
>     >             >     > -static void usart_write_polled(int minor, char c)
>     >             >     > -   while (1) {
>     >             >     > -     if ((BCM2835_REG(BCM2835_UART0_FR) &
>     >             BCM2835_UART0_FR_TXFF)
>     >             >     == 0)
>     >             >     > -       break;
>     >             >     > -   BCM2835_REG(BCM2835_UART0_DR) = c;
>     >             >     > -static ssize_t usart_write_support_polled(
>     >             >     > -  int minor,
>     >             >     > -  const char *s,
>     >             >     > -  size_t n
>     >             >     > -  ssize_t i = 0;
>     >             >     > -  for (i = 0; i < n; ++i) {
>     >             >     > -    usart_write_polled(minor, s [i]);
>     >             >     > -  return n;
>     >             >     > -static int usart_set_attributes(int minor, const
>     >             struct termios
>     >             >     *term)
>     >             >     > -  return -1;
>     >             >     > -const console_fns bcm2835_usart_fns = {
>     >             >     > -  .deviceFirstOpen = usart_first_open,
>     >             >     > -  .deviceLastClose = usart_last_close,
>     >             >     > -  .deviceRead = usart_read_polled,
>     >             >     > -  .deviceWrite = usart_write_support_polled,
>     >             >     > -  .deviceInitialize = usart_initialize,
>     >             >     > -  .deviceWritePolled = usart_write_polled,
>     >             >     > -  .deviceSetAttributes = usart_set_attributes,
>     >             >     > -  .deviceOutputUsesInterrupts = false
>     >             >     > diff --git
>     a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>     >             >     b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>     >             >     > index d0e126699a..e3d9e69ff5 100644
>     >             >     > --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>     >             >     > +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>     >             >     > @@ -33,12 +33,27 @@ extern "C" {
>     >             >     >  #define FB_CONSOLE 0x50492835
>     >             >     > -bool fbcons_probe( int minor );
>     >             >     > +  char c
>     >             >     > +typedef struct {
>     >             >     > +    rtems_termios_device_context base;
>     >             >     > +} rpi_fb_context ;
>     >             >     >   * Driver function table
>     >             >     > -extern const console_fns fbcons_fns;
>     >             >     > +extern const rtems_termios_device_handler
>     fbcons_fns;
>     >             >     >  #ifdef __cplusplus
>     >             >     > diff --git
>     >             a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>     >             >     b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>     >             >     > index 40c80cf408..2ccc49846c 100644
>     >             >     > @@ -24,6 +24,7 @@
>     >             >     >  #include <bspopts.h>
>     >             >     >  #include <stdint.h>
>     >             >     >  #include <bsp/utility.h>
>     >             >     >   * @defgroup raspberrypi_reg Register Definitions
>     >             >     > @@ -60,6 +61,39 @@
>     >             >     >  #define RPI_PERIPHERAL_SIZE         0x01000000
>     >             >     > + * @name Console select definitions
>     >             >     > +#define PL011 0
>     >             >     > +#define FB    1
>     >             >     > +extern int console_select;
>     >             >     > +typedef void
>     >             (*console)(rtems_termios_device_context *, char c);
>     >             >     > +extern console console_instance;
>     >             >     >   * @name Internal ARM Timer Registers
>     >             >     > @@ -184,42 +218,6 @@
>     >             >     > - * @name UART 0 (PL011) Registers
>     >             >     > -#define BCM2835_UART0_BASE
>     >              (RPI_PERIPHERAL_BASE + 0x201000)
>     >             >     > -#define BCM2835_UART0_DR
>     >              (BCM2835_UART0_BASE + 0x00)
>     >             >     > -#define BCM2835_UART0_RSRECR
>     >              (BCM2835_UART0_BASE + 0x04)
>     >             >     > -#define BCM2835_UART0_FR
>     >              (BCM2835_UART0_BASE + 0x18)
>     >             >     > -#define BCM2835_UART0_ILPR
>     >              (BCM2835_UART0_BASE + 0x20)
>     >             >     > -#define BCM2835_UART0_IBRD
>     >              (BCM2835_UART0_BASE + 0x24)
>     >             >     > -#define BCM2835_UART0_FBRD
>     >              (BCM2835_UART0_BASE + 0x28)
>     >             >     > -#define BCM2835_UART0_LCRH
>     >              (BCM2835_UART0_BASE + 0x2C)
>     >             >     > -#define BCM2835_UART0_CR
>     >              (BCM2835_UART0_BASE + 0x30)
>     >             >     > -#define BCM2835_UART0_IFLS
>     >              (BCM2835_UART0_BASE + 0x34)
>     >             >     > -#define BCM2835_UART0_IMSC
>     >              (BCM2835_UART0_BASE + 0x38)
>     >             >     > -#define BCM2835_UART0_RIS
>     >             (BCM2835_UART0_BASE + 0x3C)
>     >             >     > -#define BCM2835_UART0_MIS
>     >             (BCM2835_UART0_BASE + 0x40)
>     >             >     > -#define BCM2835_UART0_ICR
>     >             (BCM2835_UART0_BASE + 0x44)
>     >             >     > -#define BCM2835_UART0_DMACR
>     >             (BCM2835_UART0_BASE + 0x48)
>     >             >     > -#define BCM2835_UART0_ITCR
>     >              (BCM2835_UART0_BASE + 0x80)
>     >             >     > -#define BCM2835_UART0_ITIP
>     >              (BCM2835_UART0_BASE + 0x84)
>     >             >     > -#define BCM2835_UART0_ITOP
>     >              (BCM2835_UART0_BASE + 0x88)
>     >             >     > -#define BCM2835_UART0_TDR
>     >             (BCM2835_UART0_BASE + 0x8C)
>     >             >     > -#define BCM2835_UART0_MIS_RX    0x10
>     >             >     > -#define BCM2835_UART0_MIS_TX    0x20
>     >             >     > -#define BCM2835_UART0_IMSC_RX   0x10
>     >             >     > -#define BCM2835_UART0_IMSC_TX   0x20
>     >             >     > -#define BCM2835_UART0_FR_RXFE   0x10
>     >             >     > -#define BCM2835_UART0_FR_TXFF   0x20
>     >             >     > -#define BCM2835_UART0_ICR_RX    0x10
>     >             >     > -#define BCM2835_UART0_ICR_TX    0x20
>     >             >     > diff --git
>     a/bsps/arm/raspberrypi/include/bsp/usart.h
>     >             >     b/bsps/arm/raspberrypi/include/bsp/usart.h
>     >             >     > index d3e710c5e9..abbf53626c 100644
>     >             >     > --- a/bsps/arm/raspberrypi/include/bsp/usart.h
>     >             >     > +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
>     >             >     > @@ -32,9 +32,8 @@
>     >             >     >  extern "C" {
>     >             >     >  #endif /* __cplusplus */
>     >             >     > -#define USART0_DEFAULT_BAUD 115000
>     >             >     > -extern const console_fns bcm2835_usart_fns;
>     >             >     > +#define PL011_DEFAULT_BAUD 115000
>     >             >     > +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE +
>     >             0x201000)
>     >             >     > diff --git
>     >             a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>     >             >     b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>     >             >     > index 11a22f89e3..ce91527f92 100644
>     >             >     > --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>     >             >     > +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>     >             >     > @@ -63,14 +63,15 @@ librtemsbsp_a_SOURCES +=
>      ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
>     >             >     >  librtemsbsp_a_SOURCES +=
>     >             >     ../../../../../../bsps/arm/raspberrypi/irq/irq.c
>     >             >     >  # Console
>     >             >     > -librtemsbsp_a_SOURCES +=
>      ../../../../../../bsps/shared/dev/serial/legacy-console.c
>       ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
>       ../../../../../../bsps/arm/raspberrypi/console/console-config.c
>       ../../../../../../bsps/arm/raspberrypi/console/console_select.c
>      ../../../../../../bsps/arm/raspberrypi/console/usart.c
>     >             >     ../../../../../../bsps/arm/raspberrypi/console/fb.c
>      ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
>      ../../../../../../bsps/arm/raspberrypi/console/outch.c
>     >             >     > +librtemsbsp_a_SOURCES +=
>      ../../../../../../bsps/shared/dev/serial/console-termios.c
>       ../../../../../../bsps/shared/dev/serial/console-termios-init.c
>     >             >     ../../../../../../bsps/arm/shared/serial/arm-pl011.c
>     >             >     >  # Mailbox
>      ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
