[PATCH v2] Raspberrypi: updated the console interface.
Niteesh
gsnb.gn at gmail.com
Sat Dec 28 19:03:19 UTC 2019
I will start working on a patch that uses FDT. Instead of merging this
I create a patch v3 that uses FDT. Shall I remove some files, I will be
heavily using
the imx and other FDT based drivers as a reference.
On Sun, Dec 29, 2019 at 12:27 AM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 28/12/2019 19:48, Niteesh wrote:
> > Is bsp_console_select legacy? And the new way will be by linking
> > the correct serial device to /dev/console in console_initialization,
> right?
> > If so, shall I add one?
> The function is only called from legacy-console.c. So yes: This function
> can be removed. The logic on the other hand should move to somewhere else.
> The console-termios-init.c creates a link named CONSOLE_DEVICE_NAME. So
> you can't use that code and create your link manually. If you use the
> table based approach (which is OK as a first step) you can't really
> select the console.
> I would suggest to either clean that patch up so it can be merged and
> move to a fdt based approach simmilar to imx in a second patch. In that
> case the console_initialize() function from console-termios-init.c will
> be replaced by a custom function that searches the FDT for the devices.
> The FDT will make it simpler to adapt to RPi3. Or if you prefere it you
> can do that right now and create a patch v3 that directly uses FDT.
> > On Sat, Dec 28, 2019 at 11:50 PM Niteesh <gsnb.gn at gmail.com
> > <mailto:gsnb.gn at gmail.com>> wrote:
> > I am sorry if this question sounds silly, but how can I access the
> > output_char_fb if it
> > is marked as static in console-select.c, currently the fb context is
> > in console-config.c
> > Should I move the BSP_select_function to console-config? for shall I
> > remove the static qualifier
> > from the function?
> > Currently, the console_select has 2 functions, bsp_Is_Available and
> > bsp_console_select.
> > On Sat, Dec 28, 2019 at 11:30 PM Niteesh <gsnb.gn at gmail.com
> > On Sat, Dec 28, 2019 at 11:12 PM Christian Mauderer
> > <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
> > On 28/12/2019 17:22, Niteesh wrote:
> > > I think you misunderstood, I was talking about the casting
> > in the
> > > rtems_termios_device_handler
> > Yes, I misunderstood you there.
> > > const rtems_termios_device_handler fbcons_fns =
> > > .first_open = fbcons_open,
> > > .last_close = fbcons_close,
> > > .poll_read = fbcons_inbyte_nonblocking_polled,
> > > .write = (void (*)(rtems_termios_device_context *, const
> > char *,
> > > size_t))fbcons_write_support_polled,
> > > .set_attributes = fbcons_set_attributes,
> > > .mode = TERMIOS_POLLED
> > > the write requires a function type of
> > > *void (*write)(
> > > rtems_termios_device_context *context,
> > > const char *buf,
> > > size_t len
> > > but the fbcons function is of type
> > > *static ssize_t fbcons_write_support_polled(
> > > rtems_termios_device_context *base,
> > > const char *buf,
> > > size_t len
> > > Well, if the above cast in the device handler causes a
> > problem, can you
> > > elaborate more on
> > > what kind of a problem would it be?
> > In that case it should work. But why do you need to cast it
> > there?
> > Wouldn't it be simpler to just change the
> > function? It isn't used anywhere else or did I miss
> something?
> > No, it is not used anywhere. I'll change the function.
> > > And for the BSP_output_char function, I used a function
> > pointer. The
> > > console_select assigns the
> > > appropriate function to the function pointer and the
> > output_char call's
> > > it by providing the context.
> > > static void output_char(char c)
> > > const console_device *dev =
> > &console_device_table[console_select];
> > > rtems_termios_device_context *con = dev->context;
> > > console_instance(con, c);
> > > console_instance is the function pointer, which is
> assigned to
> > > arm_pl011_write_polled by
> > > default, or to fbcons_write_polled, if frame buffer is
> > decided to be used.
> > Yes it will work and it's resonable performant. We are
> > talking about a
> > slow serial interface in an exception case. But anyway I'm
> > not entirely
> > happy.
> > The compiler should make something like the following out of
> it:
> > - Look up and call the value of BSP_output_char
> > - Load the context (start of table + console_select + fixed
> > offset) into
> > "con"
> > - Look up and call the value of console_instance
> > If you use the way I suggested below you will have about the
> > following:
> > - Look up and call the value of BSP_output_char (one of the
> > wrappers)
> > - Call the right function with a fixed parameter
> > So it's a bit shorter and beneath that you save a global
> > variable.
> > Sure, will change it.
> > > On Sat, Dec 28, 2019 at 8:50 PM Christian Mauderer
> > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
> > wrote:
> > > On 28/12/2019 14:10, G S Niteesh wrote:
> > > > The patch updates the older console interface used
> > by the BSP,
> > > > to newer one. It also replaces the custom
> > usart(PL011) driver
> > > > with arm-pl011. The fb function's signatures where
> > also changed
> > > > to accommodate with interface update.
> > > > Update #3034
> > > > bsps/arm/raspberrypi/console/console-config.c | 62
> > > > bsps/arm/raspberrypi/console/console_select.c | 68
> > > > bsps/arm/raspberrypi/console/fbcons.c | 71
> > > > bsps/arm/raspberrypi/console/usart.c | 142
> > > > bsps/arm/raspberrypi/include/bsp/fbcons.h | 19
> > > > .../arm/raspberrypi/include/bsp/raspberrypi.h | 70
> > > > bsps/arm/raspberrypi/include/bsp/usart.h | 5
> > > > c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 5
> > > > 8 files changed, 136 insertions(+), 306 deletions(-)
> > > > diff --git
> > a/bsps/arm/raspberrypi/console/console-config.c
> > > b/bsps/arm/raspberrypi/console/console-config.c
> > > > index d2186c918b..f479e19d99 100644
> > > > --- a/bsps/arm/raspberrypi/console/console-config.c
> > > > +++ b/bsps/arm/raspberrypi/console/console-config.c
> > > > @@ -22,45 +22,47 @@
> > > > #include <libchip/serial.h>
> > > > -#include <bspopts.h>
> > > > -#include <bsp/irq.h>
> > > > -#include <bsp/usart.h>
> > > > +#include <bsp.h>
> > > > #include <bsp/raspberrypi.h>
> > > > +#include <bsp/usart.h>
> > > > +#include <bsp/arm-pl011.h>
> > > > #include <bsp/fbcons.h>
> > > > +#include <bsp/console-termios.h>
> > > > +#include <bspopts.h>
> > > > -console_tbl Console_Configuration_Ports [] = {
> > > > - .sDeviceName = "/dev/ttyS0",
> > > > - .deviceType = SERIAL_CUSTOM,
> > > > - .pDeviceFns = &bcm2835_usart_fns,
> > > > - .deviceProbe = NULL,
> > > > - .pDeviceFlow = NULL,
> > > > - .ulCtrlPort1 = BCM2835_UART0_BASE,
> > > > - .ulCtrlPort2 = 0,
> > > > - .ulClock = USART0_DEFAULT_BAUD,
> > > > - .ulIntVector = BCM2835_IRQ_ID_UART
> > > > - .sDeviceName ="/dev/fbcons",
> > > > - .pDeviceFns = &fbcons_fns,
> > > > - .deviceProbe = fbcons_probe,
> > > > +arm_pl011_context pl011_context = {
> > > > + .base =
> > RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
> > > > + .regs = (volatile pl011 *) BCM2835_PL011_BASE,
> > > > + .initial_baud = PL011_DEFAULT_BAUD
> > > > -#define PORT_COUNT \
> > > > - (sizeof(Console_Configuration_Ports) \
> > > > - / sizeof(Console_Configuration_Ports [0]))
> > > > +rpi_fb_context fb_context = {
> > > > + .base =
> > RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("FB")
> > > > +const console_device console_device_table[] = {
> > > > + .device_file = "/dev/ttyS0",
> > > > + .probe = console_device_probe_default,
> > > > + .handler = &arm_pl011_fns,
> > > > + .context = &pl011_context.base
> > > > + .device_file = "/dev/fbcons",
> > > > + .probe = fbcons_probe,
> > > > + .handler = &fbcons_fns,
> > > > + .context = &fb_context.base
> > > > -unsigned long Console_Configuration_Count =
> PORT_COUNT;
> > > > +const size_t console_device_count =
> > > RTEMS_ARRAY_SIZE(console_device_table);
> > > > - const console_fns *con =
> > > > - Console_Configuration_Ports
> > [Console_Port_Minor].pDeviceFns;
> > > > - con->deviceWritePolled((int) Console_Port_Minor,
> c);
> > > > + const console_device *dev =
> > > > + rtems_termios_device_context *con = dev->context;
> > > > + console_instance(con, c);
> > > I'm still not happy with that. What I had in mind was
> > more or less:
> > > static void output_char_serial(char c)
> > > arm_pl011_write_polled(&pl011_context.base, c);
> > > static void output_char_fb(char c)
> > > fbcons_write_polled(&fb_context.base, c);
> > > BSP_output_char_function_type BSP_output_char =
> > output_char_serial;
> > > And if you decide that the frame buffer should be used
> > in the select
> > > function you do a
> > > BSP_output_char = output_char_fb;
> > output_char;
> > > > diff --git
> > a/bsps/arm/raspberrypi/console/console_select.c
> > > b/bsps/arm/raspberrypi/console/console_select.c
> > > > index bd246ca868..ea3325266f 100644
> > > > --- a/bsps/arm/raspberrypi/console/console_select.c
> > > > +++ b/bsps/arm/raspberrypi/console/console_select.c
> > > > @@ -15,69 +15,40 @@
> > > > * http://www.rtems.org/license/LICENSE
> > > > #include <bsp.h>
> > > > +#include <bsp/raspberrypi.h>
> > > > +#include <bsp/fbcons.h>
> > > > +#include <bsp/rpi-fb.h>
> > > > #include <bsp/fatal.h>
> > > > #include <rtems/libio.h>
> > > > #include <stdlib.h>
> > > > #include <string.h>
> > > > #include <assert.h>
> > > > #include <termios.h>
> > > > -#include <rtems/termiostypes.h>
> > > > -#include "../../shared/dev/serial/legacy-console.h"
> > > > -#include <bsp/rpi-fb.h>
> > > > -rtems_device_minor_number BSPPrintkPort = 0;
> > > > +int console_select = PL011;
> > > > +console console_instance = arm_pl011_write_polled;
> > > > - * Method to return true if the device associated
> > with the
> > > > - * minor number probs available.
> > > > -static bool bsp_Is_Available(
> > rtems_device_minor_number minor )
> > > > +static bool bsp_Is_Available( int index )
> > > > - console_tbl *cptr = Console_Port_Tbl[ minor ];
> > &console_device_table[index];
> > > > * First perform the configuration dependent
> > probe, then the
> > > > * device dependent probe
> > > > - if ( ( !cptr->deviceProbe || cptr->deviceProbe(
> > minor ) ) &&
> > > > - cptr->pDeviceFns->deviceProbe( minor ) ) {
> > > > + if ( ( !dev->probe || dev->probe( con ) ) ){
> > > > return true;
> > > > return false;
> > > > - * Method to return the first available device.
> > > > -static rtems_device_minor_number
> > bsp_First_Available_Device( void )
> > > > - rtems_device_minor_number minor;
> > > > - for ( minor = 0; minor < Console_Port_Count;
> > minor++ ) {
> > > > - * First perform the configuration dependent
> > probe, then the
> > > > - * device dependent probe
> > minor ) ) &&
> > > > - return minor;
> > > > - * Error No devices were found. We will want to
> > bail here.
> > > > - bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> > > > void bsp_console_select( void )
> > > > @@ -90,25 +61,18 @@ void bsp_console_select( void )
> > > > const char *opt;
> > > > - Console_Port_Minor = BSP_CONSOLE_UART0;
> > > > - BSPPrintkPort = BSP_CONSOLE_UART0;
> > > > opt = rpi_cmdline_get_arg( "--console=" );
> > > > if ( opt ) {
> > > > if ( strncmp( opt, "fbcons", sizeof( "fbcons" )
> > - 1 ) == 0 ) {
> > > > if ( rpi_video_is_initialized() > 0 ) {
> > > > - Console_Port_Minor = BSP_CONSOLE_FB;
> > > > - BSPPrintkPort = BSP_CONSOLE_FB;
> > > > + console_select = FB;
> > > > + console_instance = fbcons_write_polled;
> > > > - * If the device that was selected isn't
> > available then
> > > > - * let the user know and select the first
> > available device.
> > > > - if ( !bsp_Is_Available( Console_Port_Minor ) ) {
> bsp_First_Available_Device();
> > > > + if( !bsp_Is_Available( console_select ) ){
> > > > + bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> > > > diff --git a/bsps/arm/raspberrypi/console/fbcons.c
> > > b/bsps/arm/raspberrypi/console/fbcons.c
> > > > index 3669ba458d..6e710e252d 100644
> > > > --- a/bsps/arm/raspberrypi/console/fbcons.c
> > > > +++ b/bsps/arm/raspberrypi/console/fbcons.c
> > > > @@ -18,6 +18,7 @@
> > > > #include <rtems.h>
> > > > +#include <rtems/termiostypes.h>
> > > > #include <stdlib.h>
> > > > @@ -29,15 +30,6 @@
> > > > #include <bsp/vc.h>
> > > > - * fbcons_init
> > > > - * This function initializes the fb console to a
> > quiecsent state.
> > > > -static void fbcons_init( int minor )
> > > > * fbcons_open
> > > > @@ -45,13 +37,14 @@ static void fbcons_init( int
> minor )
> > > > * Default state is 9600 baud, 8 bits, No parity,
> > and 1 stop bit.
> > > > -static int fbcons_open(
> > > > - int major,
> > > > - int minor,
> > > > - void *arg
> > > > +static bool fbcons_open(
> > > > + struct rtems_termios_tty *tty,
> > > > + rtems_termios_device_context *base,
> > > > + struct termios *term,
> > > > + rtems_libio_open_close_args_t *args
> > > > - return RTEMS_SUCCESSFUL;
> > > > + return true;
> > > > @@ -59,13 +52,12 @@ static int fbcons_open(
> > > > * This function shuts down the requested port.
> > > > -static int fbcons_close(
> > > > - int major,
> > > > - int minor,
> > > > - void *arg
> > > > +static void fbcons_close(
> > > > - return ( RTEMS_SUCCESSFUL );
> > > > @@ -73,8 +65,8 @@ static int fbcons_close(
> > > > * This routine polls out the requested character.
> > > > -static void fbcons_write_polled(
> > > > - int minor,
> > > > +void fbcons_write_polled(
> > > > char c
> > > > @@ -91,7 +83,7 @@ static void fbcons_write_polled(
> > > > - int minor,
> > > > const char *buf,
> > > > size_t len
> > > > @@ -102,7 +94,7 @@ static ssize_t
> > > > * poll each byte in the string out of the port.
> > > > while ( nwrite < len ) {
> > > > - fbcons_write_polled( minor, *buf++ );
> > > > + fbcons_write_polled( base, *buf++ );
> > > > nwrite++;
> > > > @@ -117,7 +109,9 @@ static ssize_t
> > > > * Console Termios polling input entry point.
> > > > -static int fbcons_inbyte_nonblocking_polled( int
> > minor )
> > > > +int fbcons_inbyte_nonblocking_polled(
> > > > // if( rtems_kbpoll() ) {
> > > > // int c = getch();
> > > > @@ -133,15 +127,17 @@ static int
> > > int minor )
> > > > * This function sets the UART channel to reflect
> > the requested
> > > termios
> > > > * port settings.
> > > > -static int fbcons_set_attributes(
> > > > - int minor,
> > > > +static bool fbcons_set_attributes(
> > > > const struct termios *t
> > > > - return 0;
> > > > + return true;
> > > > -bool fbcons_probe( int minor )
> > > > +bool fbcons_probe(
> > > > + rtems_termios_device_context *context
> > > > // rtems_status_code status;
> > > > static bool firstTime = true;
> > > > @@ -163,15 +159,12 @@ bool fbcons_probe( int minor )
> > > > return ret;
> > > > -const console_fns fbcons_fns =
> > > > +const rtems_termios_device_handler fbcons_fns =
> > > > - .deviceProbe = libchip_serial_default_probe,
> > /* deviceProbe */
> > > > - .deviceFirstOpen = fbcons_open, /*
> > > deviceFirstOpen */
> > > > - .deviceLastClose = fbcons_close, /*
> > > deviceLastClose */
> > > > - .deviceRead = fbcons_inbyte_nonblocking_polled,
> > /* deviceRead */
> > > > - .deviceWrite = fbcons_write_support_polled,
> > /* deviceWrite */
> > > > - .deviceInitialize = fbcons_init, /*
> > > deviceInitialize */
> > > > - .deviceWritePolled = fbcons_write_polled, /*
> > > deviceWritePolled */
> > > > - .deviceSetAttributes = fbcons_set_attributes, /*
> > > deviceSetAttributes */
> > > > - .deviceOutputUsesInterrupts = FALSE, /*
> > > deviceOutputUsesInterrupts*/
> > > > + .first_open = fbcons_open,
> > > > + .last_close = fbcons_close,
> > > > + .poll_read = fbcons_inbyte_nonblocking_polled,
> > > > + .write = (void (*)(rtems_termios_device_context
> > *, const char
> > > *, size_t))fbcons_write_support_polled,
> > > > + .set_attributes = fbcons_set_attributes,
> > > > + .mode = TERMIOS_POLLED
> > > > \ No newline at end of file
> > > > diff --git a/bsps/arm/raspberrypi/console/usart.c
> > > b/bsps/arm/raspberrypi/console/usart.c
> > > > index 25fb523621..471d0c553f 100644
> > > > --- a/bsps/arm/raspberrypi/console/usart.c
> > > > +++ b/bsps/arm/raspberrypi/console/usart.c
> > > > @@ -23,145 +23,3 @@
> > > > #include <rtems/bspIo.h>
> > > > -static void usart_delay(uint32_t n)
> > > > - volatile uint32_t i = 0;
> > > > - for(i = 0; i < n; i++)
> > > > -#if 0
> > > > - * These will be useful when the driver supports
> > interrupt
> > > driven IO.
> > > > -static rtems_vector_number
> > usart_get_irq_number(const console_tbl
> > > *ct)
> > > > - return ct->ulIntVector;
> > > > -static uint32_t usart_get_baud(const console_tbl
> *ct)
> > > > - return ct->ulClock;
> > > > -#endif
> > > > -static void usart_set_baud(int minor, int baud)
> > > > - * Nothing for now
> > > > - return;
> > > > -static void usart_initialize(int minor)
> > > > - unsigned int gpio_reg;
> > > > - ** Program GPIO pins for UART 0
> > > > - gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
> > > > - gpio_reg &= ~(7<<12); /* gpio14 */
> > > > - gpio_reg |= (4<<12); /* alt0 */
> > > > - gpio_reg &= ~(7<<15); /* gpio15 */
> > > > - gpio_reg |= (4<<15); /* alt0 */
> > > > - BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
> > > > - BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
> > > > - usart_delay(150);
> > > > - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) =
> > (1<<14)|(1<<15);
> > > > - usart_delay(150);
> > > > - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
> > > > - ** Init the PL011 UART
> > > > - BCM2835_REG(BCM2835_UART0_CR) = 0;
> > > > - BCM2835_REG(BCM2835_UART0_ICR) = 0x7FF;
> > > > - BCM2835_REG(BCM2835_UART0_IMSC) = 0;
> > > > - BCM2835_REG(BCM2835_UART0_IBRD) = 1;
> > > > - BCM2835_REG(BCM2835_UART0_FBRD) = 40;
> > > > - BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
> > > > - BCM2835_REG(BCM2835_UART0_RSRECR) = 0;
> > > > - BCM2835_REG(BCM2835_UART0_CR) = 0x301;
> > BCM2835_UART0_IMSC_RX;
> > > > - usart_set_baud(minor, 115000);
> > > > -static int usart_first_open(int major, int minor,
> > void *arg)
> > > > - rtems_libio_open_close_args_t *oc =
> > > (rtems_libio_open_close_args_t *) arg;
> > > > - struct rtems_termios_tty *tty = (struct
> > rtems_termios_tty *)
> > > oc->iop->data1;
> > > > - const console_tbl *ct = Console_Port_Tbl [minor];
> > > > - console_data *cd = &Console_Port_Data [minor];
> > > > - cd->termios_data = tty;
> > > > - rtems_termios_set_initial_baud(tty, ct->ulClock);
> > > > - return 0;
> > > > -static int usart_last_close(int major, int minor,
> > void *arg)
> > > > - return 0;
> > > > -static int usart_read_polled(int minor)
> > > > - if (minor == 0) {
> > > > - if (((BCM2835_REG(BCM2835_UART0_FR)) &
> > BCM2835_UART0_FR_RXFE)
> > > == 0) {
> > > > - return((BCM2835_REG(BCM2835_UART0_DR)) &
> 0xFF );
> > > > - } else {
> > > > - return -1;
> > > > - } else {
> > > > - printk("Unknown console minor number: %d\n",
> > minor);
> > > > - return -1;
> > > > -static void usart_write_polled(int minor, char c)
> > > > - while (1) {
> > > > - if ((BCM2835_REG(BCM2835_UART0_FR) &
> > BCM2835_UART0_FR_TXFF)
> > > == 0)
> > > > - break;
> > > > - BCM2835_REG(BCM2835_UART0_DR) = c;
> > > > -static ssize_t usart_write_support_polled(
> > > > - int minor,
> > > > - const char *s,
> > > > - size_t n
> > > > - ssize_t i = 0;
> > > > - for (i = 0; i < n; ++i) {
> > > > - usart_write_polled(minor, s [i]);
> > > > - return n;
> > > > -static int usart_set_attributes(int minor, const
> > struct termios
> > > *term)
> > > > - return -1;
> > > > -const console_fns bcm2835_usart_fns = {
> > > > - .deviceFirstOpen = usart_first_open,
> > > > - .deviceLastClose = usart_last_close,
> > > > - .deviceRead = usart_read_polled,
> > > > - .deviceWrite = usart_write_support_polled,
> > > > - .deviceInitialize = usart_initialize,
> > > > - .deviceWritePolled = usart_write_polled,
> > > > - .deviceSetAttributes = usart_set_attributes,
> > > > - .deviceOutputUsesInterrupts = false
> > > > diff --git
> a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> > > b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> > > > index d0e126699a..e3d9e69ff5 100644
> > > > --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> > > > +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> > > > @@ -33,12 +33,27 @@ extern "C" {
> > > > #define FB_CONSOLE 0x50492835
> > > > -bool fbcons_probe( int minor );
> > > > +bool fbcons_probe(
> > > > + char c
> > > > +typedef struct {
> > > > + rtems_termios_device_context base;
> > > > +} rpi_fb_context ;
> > > > * Driver function table
> > > > -extern const console_fns fbcons_fns;
> > > > +extern const rtems_termios_device_handler
> fbcons_fns;
> > > > #ifdef __cplusplus
> > > > diff --git
> > a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> > > b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> > > > index 40c80cf408..2ccc49846c 100644
> > > > --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> > > > +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> > > > @@ -24,6 +24,7 @@
> > > > #include <stdint.h>
> > > > #include <bsp/utility.h>
> > > > * @defgroup raspberrypi_reg Register Definitions
> > > > @@ -60,6 +61,39 @@
> > > > #define RPI_PERIPHERAL_SIZE 0x01000000
> > > > + * @name Console select definitions
> > > > +#define PL011 0
> > > > +#define FB 1
> > > > +extern int console_select;
> > > > +typedef void
> > (*console)(rtems_termios_device_context *, char c);
> > > > +extern console console_instance;
> > > > * @name Internal ARM Timer Registers
> > > > @@ -184,42 +218,6 @@
> > > > - * @name UART 0 (PL011) Registers
> > > > -#define BCM2835_UART0_BASE
> > (RPI_PERIPHERAL_BASE + 0x201000)
> > > > -#define BCM2835_UART0_DR
> > (BCM2835_UART0_BASE + 0x00)
> > > > -#define BCM2835_UART0_RSRECR
> > (BCM2835_UART0_BASE + 0x04)
> > > > -#define BCM2835_UART0_FR
> > (BCM2835_UART0_BASE + 0x18)
> > > > -#define BCM2835_UART0_ILPR
> > (BCM2835_UART0_BASE + 0x20)
> > > > -#define BCM2835_UART0_IBRD
> > (BCM2835_UART0_BASE + 0x24)
> > > > -#define BCM2835_UART0_FBRD
> > (BCM2835_UART0_BASE + 0x28)
> > > > -#define BCM2835_UART0_LCRH
> > (BCM2835_UART0_BASE + 0x2C)
> > > > -#define BCM2835_UART0_CR
> > (BCM2835_UART0_BASE + 0x30)
> > > > -#define BCM2835_UART0_IFLS
> > (BCM2835_UART0_BASE + 0x34)
> > > > -#define BCM2835_UART0_IMSC
> > (BCM2835_UART0_BASE + 0x38)
> > > > -#define BCM2835_UART0_RIS
> > (BCM2835_UART0_BASE + 0x3C)
> > > > -#define BCM2835_UART0_MIS
> > (BCM2835_UART0_BASE + 0x40)
> > > > -#define BCM2835_UART0_ICR
> > (BCM2835_UART0_BASE + 0x44)
> > > > -#define BCM2835_UART0_DMACR
> > (BCM2835_UART0_BASE + 0x48)
> > > > -#define BCM2835_UART0_ITCR
> > (BCM2835_UART0_BASE + 0x80)
> > > > -#define BCM2835_UART0_ITIP
> > (BCM2835_UART0_BASE + 0x84)
> > > > -#define BCM2835_UART0_ITOP
> > (BCM2835_UART0_BASE + 0x88)
> > > > -#define BCM2835_UART0_TDR
> > (BCM2835_UART0_BASE + 0x8C)
> > > > -#define BCM2835_UART0_MIS_RX 0x10
> > > > -#define BCM2835_UART0_MIS_TX 0x20
> > > > -#define BCM2835_UART0_IMSC_RX 0x10
> > > > -#define BCM2835_UART0_IMSC_TX 0x20
> > > > -#define BCM2835_UART0_FR_RXFE 0x10
> > > > -#define BCM2835_UART0_FR_TXFF 0x20
> > > > -#define BCM2835_UART0_ICR_RX 0x10
> > > > -#define BCM2835_UART0_ICR_TX 0x20
> > > > diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
> > > b/bsps/arm/raspberrypi/include/bsp/usart.h
> > > > index d3e710c5e9..abbf53626c 100644
> > > > --- a/bsps/arm/raspberrypi/include/bsp/usart.h
> > > > +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
> > > > @@ -32,9 +32,8 @@
> > > > extern "C" {
> > > > #endif /* __cplusplus */
> > > > -#define USART0_DEFAULT_BAUD 115000
> > > > -extern const console_fns bcm2835_usart_fns;
> > > > +#define PL011_DEFAULT_BAUD 115000
> > > > +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE +
> > 0x201000)
> > > > #ifdef __cplusplus
> > > > diff --git
> > a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> > > b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> > > > index 11a22f89e3..ce91527f92 100644
> > > > --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> > > > +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> > > > @@ -63,14 +63,15 @@ librtemsbsp_a_SOURCES +=
> > > ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
> > > ../../../../../../bsps/arm/raspberrypi/irq/irq.c
> > > > # Console
> > > > -librtemsbsp_a_SOURCES +=
> ../../../../../../bsps/shared/dev/serial/legacy-console.c
> ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
> ../../../../../../bsps/arm/raspberrypi/console/console-config.c
> ../../../../../../bsps/arm/raspberrypi/console/console_select.c
> > > ../../../../../../bsps/arm/raspberrypi/console/usart.c
> > > ../../../../../../bsps/arm/raspberrypi/console/fb.c
> > > ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
> > > ../../../../../../bsps/arm/raspberrypi/console/outch.c
> > > > +librtemsbsp_a_SOURCES +=
> ../../../../../../bsps/shared/dev/serial/console-termios.c
> ../../../../../../bsps/shared/dev/serial/console-termios-init.c
> > > ../../../../../../bsps/arm/shared/serial/arm-pl011.c
> > > > # Mailbox
> > > ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191229/6d767c59/attachment-0001.html>
