[PATCH v3] Raspberrypi: updated the console interface.
G S Niteesh gsnb.gn at gmail.com
Sun Dec 29 14:34:19 UTC 2019
The patch updates the older console interface used by the BSP,
to newer one. It also replaces the custom usart(PL011) driver
with arm-pl011. The fb function's signatures where also changed
to accommodate with interface update.
Update #3034
 bsps/arm/raspberrypi/console/console-config.c | 182 ++++++++++++++----
 bsps/arm/raspberrypi/console/console_select.c |  97 +---------
 bsps/arm/raspberrypi/console/fbcons.c         |  79 ++++----
 bsps/arm/raspberrypi/console/usart.c          | 167 ----------------
 bsps/arm/raspberrypi/include/bsp/fbcons.h     |  21 +-
 .../arm/raspberrypi/include/bsp/raspberrypi.h |  48 ++---
 bsps/arm/raspberrypi/include/bsp/usart.h      |   5 +-
 c/src/lib/libbsp/arm/raspberrypi/Makefile.am  |   5 +-
 8 files changed, 225 insertions(+), 379 deletions(-)
 delete mode 100644 bsps/arm/raspberrypi/console/usart.c
diff --git a/bsps/arm/raspberrypi/console/console-config.c b/bsps/arm/raspberrypi/console/console-config.c
index d2186c918b..52859656f4 100644
--- a/bsps/arm/raspberrypi/console/console-config.c
+++ b/bsps/arm/raspberrypi/console/console-config.c
@@ -19,50 +19,162 @@
 #include <rtems/bspIo.h>
+#include <rtems/console.h>
 #include <libchip/serial.h>
-#include <bspopts.h>
-#include <bsp/irq.h>
-#include <bsp/usart.h>
+#include <bsp.h>
 #include <bsp/raspberrypi.h>
+#include <bsp/usart.h>
+#include <bsp/arm-pl011.h>
 #include <bsp/fbcons.h>
+#include <bsp/console-termios.h>
+#include <bsp/fatal.h>
+#include <bspopts.h>
+#include <libfdt.h>
+arm_pl011_context pl011_context;
+rpi_fb_context fb_context;
+static void output_char_serial(char c)
+  arm_pl011_write_polled(&pl011_context.base, c);
+void output_char_fb(char c)
+  fbcons_write_polled(&fb_context.base, c);
+static void *get_reg_of_node(const void *fdt, int node)
+  int len;
+  const uint32_t *val;
+  val = fdt_getprop(fdt, node, "reg", &len);
+  if (val == NULL || len < 4) {
+    return NULL;
+  return (void *) fdt32_to_cpu(val[0]);
+static bool register_arm_pl011(const void *fdt, const char *serial, const char *path)
+  arm_pl011_context *ctx = &pl011_context;
+  int node;
+  if (strcmp(serial, "uart0")) {
+    rtems_termios_device_context_initialize(&ctx->base, "UART");
+    node = fdt_path_offset(fdt, serial);
+    ctx->regs = get_reg_of_node(fdt, node);
+    rtems_termios_device_install(
+      path,
+      &arm_pl011_fns,
+      NULL,
+      &pl011_context.base
+    return true;
+  return false;
-console_tbl Console_Configuration_Ports [] = {
-      .sDeviceName = "/dev/ttyS0",
-      .deviceType = SERIAL_CUSTOM,
-      .pDeviceFns = &bcm2835_usart_fns,
-      .deviceProbe = NULL,
-      .pDeviceFlow = NULL,
-      .ulCtrlPort1 = BCM2835_UART0_BASE,
-      .ulCtrlPort2 = 0,
-      .ulClock = USART0_DEFAULT_BAUD,
-      .ulIntVector = BCM2835_IRQ_ID_UART
-      .sDeviceName ="/dev/fbcons",
-      .pDeviceFns = &fbcons_fns,
-      .deviceProbe = fbcons_probe,
-#define PORT_COUNT \
-  (sizeof(Console_Configuration_Ports) \
-    / sizeof(Console_Configuration_Ports [0]))
-unsigned long Console_Configuration_Count = PORT_COUNT;
-static void output_char(char c)
+static bool register_fb()
-  const console_fns *con =
-    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
+  if( !fbcons_probe(&fb_context.base) ) {
+    return false;
+    "/dev/fbcons",
+    &fbcons_fns,
+    NULL,
+    &fb_context.base);
+  return true;
+static void uart_probe(const void *fdt, int node)
+  char path[] = "/dev/ttyS?";
+  size_t i = 0;
+  int offset = fdt_first_property_offset(fdt, node);
+  while (offset >= 0) {
+    const struct fdt_property *prop;
+    prop = fdt_get_property_by_offset(fdt, offset, NULL);
+    if (prop != NULL) {
+      const char *name;
+      name = fdt_string(fdt, fdt32_to_cpu(prop->nameoff));
+      if(strstr(name, "serial") != NULL) {
+        const char *serial;
+        serial = prop->data;
+        path[sizeof(path) - 2] = (char) ('0' + i);
+        register_arm_pl011(fdt, serial, path);
+        i++;
+    offset = fdt_get_property_by_offset(fdt, offset, NULL);
+static void console_select( const char *console )
+  const char *opt;
+  opt = rpi_cmdline_get_arg("--console=");
+  if ( opt ) {
+    if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
+      if ( rpi_video_is_initialized() > 0 ) {
+        link("/dev/fbcons", CONSOLE_DEVICE_NAME);
+        BSP_output_char = output_char_fb;
+    }else{
+      if ( console == NULL ){
+        bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
+      path[strlen(path) - 1] = console[strlen(console) - 1];
+      link(path, CONSOLE_DEVICE_NAME);
+rtems_status_code console_initialize(
+  rtems_device_major_number major,
+  rtems_device_minor_number minor,
+  void *arg
+  const void *fdt;
+  const char *console;
+  int node;
+  fdt = bsp_fdt_get();
+  node = fdt_path_offset(fdt, "/chosen");
+  console = fdt_getprop(fdt, node, "stdout-path", NULL);
+  node = fdt_path_offset(fdt, "/aliases");
+  rtems_termios_initialize();
+  uart_probe(fdt, node);
+  register_fb();
-  con->deviceWritePolled((int) Console_Port_Minor, c);
+  console_select(console);
-BSP_output_char_function_type BSP_output_char = output_char;
+BSP_output_char_function_type BSP_output_char = output_char_serial;
 BSP_polling_getchar_function_type BSP_poll_char = NULL;
diff --git a/bsps/arm/raspberrypi/console/console_select.c b/bsps/arm/raspberrypi/console/console_select.c
index bd246ca868..85f664b65c 100644
--- a/bsps/arm/raspberrypi/console/console_select.c
+++ b/bsps/arm/raspberrypi/console/console_select.c
@@ -15,100 +15,19 @@
  *  http://www.rtems.org/license/LICENSE
 #include <bsp.h>
+#include <bsp/raspberrypi.h>
+#include <bsp/fbcons.h>
+#include <bsp/rpi-fb.h>
 #include <rtems/libio.h>
+#include <rtems/bspIo.h>
 #include <assert.h>
 #include <termios.h>
-#include <rtems/termiostypes.h>
-#include <libchip/serial.h>
-#include "../../shared/dev/serial/legacy-console.h"
-#include <bsp/rpi-fb.h>
-rtems_device_minor_number BSPPrintkPort = 0;
- * Method to return true if the device associated with the
- * minor number probs available.
-static bool bsp_Is_Available( rtems_device_minor_number minor )
-  console_tbl *cptr = Console_Port_Tbl[ minor ];
-   * First perform the configuration dependent probe, then the
-   * device dependent probe
-  if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
-       cptr->pDeviceFns->deviceProbe( minor ) ) {
-    return true;
-  return false;
- * Method to return the first available device.
-static rtems_device_minor_number bsp_First_Available_Device( void )
-  rtems_device_minor_number minor;
-  for ( minor = 0; minor < Console_Port_Count; minor++ ) {
-      return minor;
-   *  Error No devices were found.  We will want to bail here.
-  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
-void bsp_console_select( void )
-   *  Reset Console_Port_Minor and
-   *  BSPPrintkPort here if desired.
-   *  This default version allows the bsp to set these
-   *  values at creation and will not touch them again
-   *  unless the selected port number is not available.
-  const char *opt;
-  Console_Port_Minor = BSP_CONSOLE_UART0;
-  BSPPrintkPort = BSP_CONSOLE_UART0;
-  opt = rpi_cmdline_get_arg( "--console=" );
-  if ( opt ) {
-    if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
-      if ( rpi_video_is_initialized() > 0 ) {
-        Console_Port_Minor = BSP_CONSOLE_FB;
-        BSPPrintkPort = BSP_CONSOLE_FB;
-   * If the device that was selected isn't available then
-   * let the user know and select the first available device.
-  if ( !bsp_Is_Available( Console_Port_Minor ) ) {
-    Console_Port_Minor = bsp_First_Available_Device();
+#include <libchip/serial.h>
\ No newline at end of file
diff --git a/bsps/arm/raspberrypi/console/fbcons.c b/bsps/arm/raspberrypi/console/fbcons.c
index 3669ba458d..f98583bbe7 100644
--- a/bsps/arm/raspberrypi/console/fbcons.c
+++ b/bsps/arm/raspberrypi/console/fbcons.c
@@ -18,6 +18,8 @@
+#include <rtems/termiostypes.h>
+#include <rtems/status.h>
@@ -29,15 +31,6 @@
 #include <bsp/vc.h>
- *  fbcons_init
- *  This function initializes the fb console to a quiecsent state.
-static void fbcons_init( int minor )
  *  fbcons_open
@@ -45,13 +38,14 @@ static void fbcons_init( int minor )
  *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
-static int fbcons_open(
-  int   major,
-  int   minor,
-  void *arg
+static bool fbcons_open(
+  struct rtems_termios_tty *tty,
+  rtems_termios_device_context *base,
+  struct termios *term,
+  rtems_libio_open_close_args_t *args
-  return RTEMS_SUCCESSFUL;
+  return true;
@@ -59,13 +53,12 @@ static int fbcons_open(
  *  This function shuts down the requested port.
-static int fbcons_close(
-  int   major,
-  int   minor,
-  void *arg
+static void fbcons_close(
-  return ( RTEMS_SUCCESSFUL );
@@ -73,8 +66,8 @@ static int fbcons_close(
  *  This routine polls out the requested character.
-static void fbcons_write_polled(
-  int  minor,
+void fbcons_write_polled(
   char c
@@ -90,8 +83,8 @@ static void fbcons_write_polled(
  *  Console Termios output entry point when using polled output.
-static ssize_t fbcons_write_support_polled(
-  int         minor,
+static void fbcons_write_support_polled(
   const char *buf,
   size_t      len
@@ -102,14 +95,9 @@ static ssize_t fbcons_write_support_polled(
    * poll each byte in the string out of the port.
   while ( nwrite < len ) {
-    fbcons_write_polled( minor, *buf++ );
+    fbcons_write_polled( base, *buf++ );
     nwrite++;
-   * return the number of bytes written.
-  return nwrite;
@@ -117,7 +105,9 @@ static ssize_t fbcons_write_support_polled(
  *  Console Termios polling input entry point.
-static int fbcons_inbyte_nonblocking_polled( int minor )
+int fbcons_inbyte_nonblocking_polled(
   // if( rtems_kbpoll() ) {
   //   int c = getch();
@@ -133,15 +123,17 @@ static int fbcons_inbyte_nonblocking_polled( int minor )
  *  This function sets the UART channel to reflect the requested termios
  *  port settings.
-static int fbcons_set_attributes(
-  int                   minor,
+static bool fbcons_set_attributes(
   const struct termios *t
-  return 0;
+  return true;
-bool fbcons_probe( int minor )
+bool fbcons_probe(
+  rtems_termios_device_context *context
   // rtems_status_code status;
   static bool firstTime = true;
@@ -163,15 +155,12 @@ bool fbcons_probe( int minor )
   return ret;
-const console_fns fbcons_fns =
+const rtems_termios_device_handler fbcons_fns =
-  .deviceProbe = libchip_serial_default_probe,     /* deviceProbe */
-  .deviceFirstOpen = fbcons_open,                 /* deviceFirstOpen */
-  .deviceLastClose = fbcons_close,                /* deviceLastClose */
-  .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead */
-  .deviceWrite = fbcons_write_support_polled,     /* deviceWrite */
-  .deviceInitialize = fbcons_init,                /* deviceInitialize */
-  .deviceWritePolled = fbcons_write_polled,       /* deviceWritePolled */
-  .deviceSetAttributes = fbcons_set_attributes,   /* deviceSetAttributes */
-  .deviceOutputUsesInterrupts = FALSE,           /* deviceOutputUsesInterrupts*/
+  .first_open = fbcons_open,
+  .last_close = fbcons_close,
+  .poll_read = fbcons_inbyte_nonblocking_polled,
+  .write = fbcons_write_support_polled,
+  .set_attributes = fbcons_set_attributes,
+  .mode = TERMIOS_POLLED
diff --git a/bsps/arm/raspberrypi/console/usart.c b/bsps/arm/raspberrypi/console/usart.c
deleted file mode 100644
index 25fb523621..0000000000
--- a/bsps/arm/raspberrypi/console/usart.c
+++ /dev/null
@@ -1,167 +0,0 @@
- * @file
- * @ingroup raspberrypi_usart
- * @brief USART support.
- * Copyright (c) 2013 Alan Cudmore
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE
-#include <libchip/sersupp.h>
-#include <bsp.h>
-#include <bsp/raspberrypi.h>
-#include <rtems/bspIo.h>
-static void usart_delay(uint32_t n)
- volatile uint32_t i = 0;
- for(i = 0; i < n; i++)
-#if 0
- *  These will be useful when the driver supports interrupt driven IO.
-static rtems_vector_number usart_get_irq_number(const console_tbl *ct)
-  return ct->ulIntVector;
-static uint32_t usart_get_baud(const console_tbl *ct)
-  return ct->ulClock;
-#endif
-static void usart_set_baud(int minor, int baud)
-  * Nothing for now
- return;
-static void usart_initialize(int minor)
-  unsigned int gpio_reg;
-  ** Program GPIO pins for UART 0
-  gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
-  gpio_reg &= ~(7<<12);    /* gpio14 */
-  gpio_reg |=  (4<<12);    /* alt0   */
-  gpio_reg &= ~(7<<15);    /* gpio15 */
-  gpio_reg |=  (4<<15);    /* alt0   */
-  BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
-  BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
-  usart_delay(150);
-  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
-  usart_delay(150);
-  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
-  ** Init the PL011 UART
-  BCM2835_REG(BCM2835_UART0_CR)   = 0;
-  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
-  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
-  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
-  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
-  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
-  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
-  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
-  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
-  usart_set_baud(minor, 115000);
-static int usart_first_open(int major, int minor, void *arg)
-  rtems_libio_open_close_args_t *oc = (rtems_libio_open_close_args_t *) arg;
-  struct rtems_termios_tty *tty = (struct rtems_termios_tty *) oc->iop->data1;
-  const console_tbl *ct = Console_Port_Tbl [minor];
-  console_data *cd = &Console_Port_Data [minor];
-  cd->termios_data = tty;
-  rtems_termios_set_initial_baud(tty, ct->ulClock);
-  return 0;
-static int usart_last_close(int major, int minor, void *arg)
-  return 0;
-static int usart_read_polled(int minor)
-  if (minor == 0) {
-    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE) == 0) {
-       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
-    } else {
-      return -1;
-  } else {
-    printk("Unknown console minor number: %d\n", minor);
-    return -1;
-static void usart_write_polled(int minor, char c)
-   while (1) {
-     if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF) == 0)
-       break;
-   BCM2835_REG(BCM2835_UART0_DR) = c;
-static ssize_t usart_write_support_polled(
-  int minor,
-  const char *s,
-  size_t n
-  ssize_t i = 0;
-  for (i = 0; i < n; ++i) {
-    usart_write_polled(minor, s [i]);
-  return n;
-static int usart_set_attributes(int minor, const struct termios *term)
-  return -1;
-const console_fns bcm2835_usart_fns = {
-  .deviceFirstOpen = usart_first_open,
-  .deviceLastClose = usart_last_close,
-  .deviceRead = usart_read_polled,
-  .deviceWrite = usart_write_support_polled,
-  .deviceInitialize = usart_initialize,
-  .deviceWritePolled = usart_write_polled,
-  .deviceSetAttributes = usart_set_attributes,
-  .deviceOutputUsesInterrupts = false
diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h b/bsps/arm/raspberrypi/include/bsp/fbcons.h
index d0e126699a..9bdb4b115e 100644
--- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
+++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
@@ -33,12 +33,29 @@ extern "C" {
 #define FB_CONSOLE 0x50492835
-bool fbcons_probe( int minor );
+bool fbcons_probe(
+  char c
+void output_char_fb(char c);
+typedef struct {
+    rtems_termios_device_context base;
+} rpi_fb_context ;
  * Driver function table
-extern const console_fns fbcons_fns;
+extern const rtems_termios_device_handler fbcons_fns;
 #ifdef __cplusplus
diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
index 40c80cf408..e052c2becb 100644
--- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
+++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
@@ -24,6 +24,7 @@
 #include <stdint.h>
 #include <bsp/utility.h>
  * @defgroup raspberrypi_reg Register Definitions
@@ -60,6 +61,17 @@
 #define RPI_PERIPHERAL_SIZE         0x01000000
+ * @name Console select definitions
+#define PL011 0
+#define FB    1
  * @name Internal ARM Timer Registers
@@ -184,42 +196,6 @@
- * @name UART 0 (PL011) Registers
-#define BCM2835_UART0_BASE       (RPI_PERIPHERAL_BASE + 0x201000)
-#define BCM2835_UART0_DR         (BCM2835_UART0_BASE + 0x00)
-#define BCM2835_UART0_RSRECR     (BCM2835_UART0_BASE + 0x04)
-#define BCM2835_UART0_FR         (BCM2835_UART0_BASE + 0x18)
-#define BCM2835_UART0_ILPR       (BCM2835_UART0_BASE + 0x20)
-#define BCM2835_UART0_IBRD       (BCM2835_UART0_BASE + 0x24)
-#define BCM2835_UART0_FBRD       (BCM2835_UART0_BASE + 0x28)
-#define BCM2835_UART0_LCRH       (BCM2835_UART0_BASE + 0x2C)
-#define BCM2835_UART0_CR         (BCM2835_UART0_BASE + 0x30)
-#define BCM2835_UART0_IFLS       (BCM2835_UART0_BASE + 0x34)
-#define BCM2835_UART0_IMSC       (BCM2835_UART0_BASE + 0x38)
-#define BCM2835_UART0_RIS        (BCM2835_UART0_BASE + 0x3C)
-#define BCM2835_UART0_MIS        (BCM2835_UART0_BASE + 0x40)
-#define BCM2835_UART0_ICR        (BCM2835_UART0_BASE + 0x44)
-#define BCM2835_UART0_DMACR      (BCM2835_UART0_BASE + 0x48)
-#define BCM2835_UART0_ITCR       (BCM2835_UART0_BASE + 0x80)
-#define BCM2835_UART0_ITIP       (BCM2835_UART0_BASE + 0x84)
-#define BCM2835_UART0_ITOP       (BCM2835_UART0_BASE + 0x88)
-#define BCM2835_UART0_TDR        (BCM2835_UART0_BASE + 0x8C)
-#define BCM2835_UART0_MIS_RX    0x10
-#define BCM2835_UART0_MIS_TX    0x20
-#define BCM2835_UART0_IMSC_RX   0x10
-#define BCM2835_UART0_IMSC_TX   0x20
-#define BCM2835_UART0_FR_RXFE   0x10
-#define BCM2835_UART0_FR_TXFF   0x20
-#define BCM2835_UART0_ICR_RX    0x10
-#define BCM2835_UART0_ICR_TX    0x20
diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h b/bsps/arm/raspberrypi/include/bsp/usart.h
index d3e710c5e9..abbf53626c 100644
--- a/bsps/arm/raspberrypi/include/bsp/usart.h
+++ b/bsps/arm/raspberrypi/include/bsp/usart.h
@@ -32,9 +32,8 @@
 extern "C" {
 #endif /* __cplusplus */
-#define USART0_DEFAULT_BAUD 115000
-extern const console_fns bcm2835_usart_fns;
+#define PL011_DEFAULT_BAUD 115000
+#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index 11a22f89e3..ce91527f92 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -63,14 +63,15 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/irq/irq.c
 # Console
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/console-config.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/console_select.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/usart.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/fb.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/console/outch.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios-init.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/serial/arm-pl011.c
 # Mailbox
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
2.17.1
