Error while building the rtems-libbsd
Christian Mauderer
list at c-mauderer.de
Tue Dec 31 12:58:18 UTC 2019
On 31/12/2019 12:41, Utkarsh Rai wrote:
> My host system has an x-86_64 architecture with ubuntu-18.04 running on
> top of it, I have a python2 installed.
> Interestingly enough, when I clean up the libbsd directory and try to
> build as a super-user, I have two observations:-
Please note that building as super user is generally not a good idea for
any sane build environment. Although I have to say that in this case it
provided an interesting error output ...
> 1. The build fails with the following error message:-
> [1/4] Creating
> ///h/o/m/e///u/r/1/0///s/a/n/d/b/o/x///r/t/e/m/s/-/l/i/b/b/s/d///b/u/i/l/d///a/r/m/-/r/t/e/m/s/5/-/b/e/a/g/l/e/b/o/n/e/b/l/a/c/k/-/d/e/f/a/u/l/t/build-include/rtems/bsd/modules.h
... here. That looks like some join went horrible wrong. I assume that
there is some location in the build system where an array of paths
should be joined but only one is given. Looks like a bug.
> [2/4] Compiling rtemsbsd/rtems/generate_kvm_symbols
> [3/4] Compiling testsuite/include/rtems/bsd/test/network-config.h.in
> <http://network-config.h.in>
> /bin/sh: 1:
> .//home/ur10/sandbox/rtems-libbsd/rtemsbsd/rtems/generate_kvm_symbols:
The ./ in front is a bit odd here. Looks like an absolute path which
(for some reason) has been forced to be local...
> not found
> Now I have checked, and the file in question is present at its location.
> 2. The traceback of the last calls is something like this:-
> File
> "/home/ur10/sandbox/rtems-libbsd/.waf-2.0.13-4c5a17779813574907c253ab5418388d/waflib/Build.py",
> line 100, in execute_build
> self.compile()
> File
> line 174, in compile
> self.store()
> File
> line 153, in store
> Utils.writef(db+'.tmp',x,m='wb')
> File
> "/home/ur10/sandbox/rtems-libbsd/.waf-2.0.13-4c5a17779813574907c253ab5418388d/waflib/Utils.py",
> line 155, in writef
> with open(fname,m)as f:
> IOError: [Errno 2] No such file or directory:
> u'/home/ur10/sandbox/rtems-libbsd/build/arm-rtems5-beagleboneblack-default/.wafpickle-linux2-34017264-20.tmp'
> If I am correct, this is a python exception for invalid file handling.
> Since I have already removed the 'build' directory, I suppose the call
> should be 'w+' or 'wb+' but this does not seem to be the case. (I am
> going out on a limb with this assumption, I may be wrong !)
You are right that it's a python exception. Most likely it's a follow up
bug due to the wrong paths further up.
> It would be very helpful if you could provide your views on the problem
> and as to how I should proceed to resolve this.
The solution is to find the bug in the path handling from further above.
As a workaround could you try to use python3? Some string handling is
different there so it might work or give a better error message. Just use
python3 ./waf ...
instead of only "waf" in every waf command line.
> On Mon, Dec 30, 2019 at 7:19 PM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
> On 28/12/2019 18:43, Utkarsh Rai wrote:
> > Hi,
> > While building the rtems-libbsd as described here
> <https://devel.rtems.org/browser/rtems-libbsd/README.waf?rev=b83012a9f9f1551d9d223c3126d0f43aba79db62> I
> > was able to successfully configure the waf file as:-
> > waf configure
> > --prefix="/home/ur10/sandbox/rtems/5"
> > --rtems-bsps=arm/beagleboneblack
> > --buildset=buildset/default.ini
> > But the build fails on the "waf" instruction with the error - "Could
> > not create the directory ///h".
> > My path for the build is PATH="~/sandbox/rtems/bin:$PATH", with the
> > tools and the rtems-libbsd in the sandbox directory.
> > It would be very kind of you if someone could point out as to what
> is it
> > that I am doing wrong.
> > Thank You, Regards.
> Hello Utkarsh Rai,
> I now have seen that bug about two or three times on the list. But I've
> never been able to reproduce it. What host system are you using? Do you
> have a python2 or a python3 as default python?
> Sometimes it works to clean up the libbsd directory. Remove the "build"
> directory and the ".waf2..." or ".waf3..." directory. Also remove any
> "__pycache__" directories.
> >From your call it seems that you use waf from your host system. Can you
> try to use the waf version delivered with libbsd instead (using "./waf
> configure ...")?
> Best regards
> Christian
