[PATCH v4] Raspberrypi: updated the console interface.
Christian Mauderer
list at c-mauderer.de
Mon Dec 30 19:45:41 UTC 2019
On 30/12/2019 20:43, Christian Mauderer wrote:
> On 30/12/2019 19:32, Niteesh wrote:
>> Just to make sure that console_initialize and uart_probe are being
>> called, I manually initialized the pl011 context to print something on
>> serial. But they never got called. Can you just make sure that if I am
>> missing something?
> I don't think that you are missing something but the executable is
> missing something: The functions are not linked into it.
> C linker can be an odd thing: It links only object files that are
> referenced. You seem to have no reference to console-config.c/o from
> anywhere else.
> RTEMS_SYSINIT_ITEM(
> uart_probe,
> RTEMS_SYSINIT_BSP_START,
> RTEMS_SYSINIT_ORDER_LAST
> will be only added to the linker set if the file is linked in anyway.
> That is a bit anoying. For the imx BSP there is a UART drain function
> that is called from somewhere else. Thats enough to bring the file in.
> I think you'll need to add a reference from somewhere or move that stuff
> into another file that is referenced.
> If you have some init function that has to be called in every case you
> can call it from some other c file where it would fit too.
> Otherwise it might is necessary to construct some odd stuff. I'm not
> sure whether we already had a case like this. Most likely it would be
> necessary to use a RTEMS_LINKER_ROSET_ITEM_REFERENCE for the
> SYSINIT_ITEM. Maybe to define a new RTEMS_SYSINIT_ITEM_REFERENCE or
> simmilar. This should be definitively a separate commit. Please ask
> again if you have to go that way.
>> While going through the messages from devel-request, Joel mentioned
>> about qemu4 rsb package
>> how is it different from the official qemu?
Sorry: I forgot to answer that question.
I haven't had a detailled look but I assume the following: Qemu is a
very, very active project. A version provided by a distribution is most
likely quite out of date except if you use a distribution that is
_really_ fast with packet updates. I assume that the qemu from RSB is
quite a bit newer.
>> On Mon, Dec 30, 2019 at 11:53 PM G S Niteesh <gsnb.gn at gmail.com
>> <mailto:gsnb.gn at gmail.com>> wrote:
>> The patch updates the older console interface used by the BSP,
>> to newer one. It also replaces the custom usart(PL011) driver
>> with arm-pl011. The fb function's signatures where also changed
>> to accommodate with interface update.
>> Update #3034
>> bsps/arm/raspberrypi/console/console-config.c | 186 ++++++++++++++----
>> bsps/arm/raspberrypi/console/console_select.c | 114 -----------
>> bsps/arm/raspberrypi/console/fbcons.c | 78 ++++----
>> bsps/arm/raspberrypi/console/usart.c | 167 ----------------
>> bsps/arm/raspberrypi/include/bsp/fbcons.h | 21 +-
>> .../arm/raspberrypi/include/bsp/raspberrypi.h | 48 ++---
>> bsps/arm/raspberrypi/include/bsp/usart.h | 5 +-
>> c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 8 +-
>> 8 files changed, 220 insertions(+), 407 deletions(-)
>> delete mode 100644 bsps/arm/raspberrypi/console/console_select.c
>> delete mode 100644 bsps/arm/raspberrypi/console/usart.c
>> diff --git a/bsps/arm/raspberrypi/console/console-config.c
>> b/bsps/arm/raspberrypi/console/console-config.c
>> index d2186c918b..021428ff4b 100644
>> --- a/bsps/arm/raspberrypi/console/console-config.c
>> +++ b/bsps/arm/raspberrypi/console/console-config.c
>> @@ -19,50 +19,164 @@
>> #include <rtems/bspIo.h>
>> +#include <rtems/console.h>
>> -#include <libchip/serial.h>
>> -#include <bspopts.h>
>> -#include <bsp/irq.h>
>> -#include <bsp/usart.h>
>> +#include <bsp.h>
>> #include <bsp/raspberrypi.h>
>> +#include <bsp/usart.h>
>> +#include <bsp/arm-pl011.h>
>> #include <bsp/fbcons.h>
>> +#include <bsp/console-termios.h>
>> +#include <bsp/fdt.h>
>> +#include <bsp/fatal.h>
>> +#include <bspopts.h>
>> +#include <libfdt.h>
>> +#include <libchip/serial.h>
>> +arm_pl011_context pl011_context;
>> +rpi_fb_context fb_context;
> These could be static.
>> +static void output_char_serial(char c)
>> + arm_pl011_write_polled(&pl011_context.base, c);
>> +void output_char_fb(char c)
>> + fbcons_write_polled(&fb_context.base, c);
>> -console_tbl Console_Configuration_Ports [] = {
>> - .sDeviceName = "/dev/ttyS0",
>> - .deviceType = SERIAL_CUSTOM,
>> - .pDeviceFns = &bcm2835_usart_fns,
>> - .deviceProbe = NULL,
>> - .pDeviceFlow = NULL,
>> - .ulCtrlPort1 = BCM2835_UART0_BASE,
>> - .ulCtrlPort2 = 0,
>> - .ulClock = USART0_DEFAULT_BAUD,
>> - .ulIntVector = BCM2835_IRQ_ID_UART
>> - .sDeviceName ="/dev/fbcons",
>> - .pDeviceFns = &fbcons_fns,
>> - .deviceProbe = fbcons_probe,
>> -#define PORT_COUNT \
>> - (sizeof(Console_Configuration_Ports) \
>> - / sizeof(Console_Configuration_Ports [0]))
>> -unsigned long Console_Configuration_Count = PORT_COUNT;
>> -static void output_char(char c)
>> +static void *get_reg_of_node(const void *fdt, int node)
>> - const console_fns *con =
>> - Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
>> + int len;
>> + const uint32_t *val;
>> + val = fdt_getprop(fdt, node, "reg", &len);
>> + if (val == NULL || len < 4) {
>> + return NULL;
>> - con->deviceWritePolled((int) Console_Port_Minor, c);
>> + return (void *) fdt32_to_cpu(val[0]);
>> -BSP_output_char_function_type BSP_output_char = output_char;
>> +static void register_arm_pl011(
>> + const void *fdt,
>> + const char *serial
>> + arm_pl011_context *ctx = &pl011_context;
>> + int node;
>> + if (strcmp(serial, "uart0") == 0) {
>> + rtems_termios_device_context_initialize(&ctx->base, "UART");
>> + node = fdt_path_offset(fdt, serial);
>> + ctx->regs = get_reg_of_node(fdt, node);
>> + rtems_termios_device_install(
>> + "/dev/ttyuart0",
>> + &arm_pl011_fns,
>> + NULL,
>> + &pl011_context.base
>> +static void register_fb( void )
>> + if (fbcons_probe(&fb_context.base) == true) {
>> + "/dev/fbcons",
>> + &fbcons_fns,
>> + NULL,
>> + &fb_context.base);
>> +static void console_select( const char *console )
>> + const char *opt;
>> + opt = rpi_cmdline_get_arg("--console=");
>> + if ( opt ) {
>> + if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
>> + if ( rpi_video_is_initialized() > 0 ) {
>> + BSP_output_char = output_char_fb;
>> + link("/dev/fbcons", CONSOLE_DEVICE_NAME);
>> + }else{
>> + if ( console == NULL ){
>> + bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>> + BSP_output_char = output_char_serial;
>> + link("/dev/ttyuart0", CONSOLE_DEVICE_NAME);
>> +static void uart_probe(void)
>> + const void *fdt;
>> + const char *console;
>> + int node;
>> + fdt = bsp_fdt_get();
>> + node = fdt_path_offset(fdt, "/chosen");
>> + console = fdt_getprop(fdt, node, "stdout-path", NULL);
>> + node = fdt_path_offset(fdt, "/aliases");
>> + int offset = fdt_first_property_offset(fdt, node);
>> + while (offset >= 0) {
>> + const struct fdt_property *prop;
>> + prop = fdt_get_property_by_offset(fdt, offset, NULL);
>> + if (prop != NULL) {
>> + const char *name;
>> + name = fdt_string(fdt, fdt32_to_cpu(prop->nameoff));
>> + if(strstr(name, "serial") != NULL) {
>> + const char *serial;
>> + serial = prop->data;
>> + register_arm_pl011(fdt, serial);
>> + offset = fdt_next_property_offset(fdt, offset);
>> + console_select(console);
>> +rtems_status_code console_initialize(
>> + rtems_device_major_number major,
>> + rtems_device_minor_number minor,
>> + void *arg
>> + rtems_termios_initialize();
>> + uart_probe();
>> + register_fb();
>> + return RTEMS_SUCCESSFUL;
>> +BSP_output_char_function_type BSP_output_char = output_char_serial;
>> BSP_polling_getchar_function_type BSP_poll_char = NULL;
>> +RTEMS_SYSINIT_ITEM(
>> + uart_probe,
>> + RTEMS_SYSINIT_BSP_START,
>> + RTEMS_SYSINIT_ORDER_LAST
>> \ No newline at end of file
>> diff --git a/bsps/arm/raspberrypi/console/console_select.c
>> b/bsps/arm/raspberrypi/console/console_select.c
>> deleted file mode 100644
>> index bd246ca868..0000000000
>> --- a/bsps/arm/raspberrypi/console/console_select.c
>> +++ /dev/null
>> @@ -1,114 +0,0 @@
>> - * @file
>> - * @ingroup raspberrypi_console
>> - * @brief console select
>> - * Copyright (c) 2015 Yang Qiao
>> - * The license and distribution terms for this file may be
>> - * found in the file LICENSE in this distribution or at
>> - * http://www.rtems.org/license/LICENSE
>> -#include <bsp.h>
>> -#include <bsp/fatal.h>
>> -#include <rtems/libio.h>
>> -#include <stdlib.h>
>> -#include <string.h>
>> -#include <assert.h>
>> -#include <termios.h>
>> -#include <rtems/termiostypes.h>
>> -#include "../../shared/dev/serial/legacy-console.h"
>> -#include <bsp/rpi-fb.h>
>> -rtems_device_minor_number BSPPrintkPort = 0;
>> - * Method to return true if the device associated with the
>> - * minor number probs available.
>> -static bool bsp_Is_Available( rtems_device_minor_number minor )
>> - console_tbl *cptr = Console_Port_Tbl[ minor ];
>> - * First perform the configuration dependent probe, then the
>> - * device dependent probe
>> - if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
>> - cptr->pDeviceFns->deviceProbe( minor ) ) {
>> - return true;
>> - return false;
>> - * Method to return the first available device.
>> -static rtems_device_minor_number bsp_First_Available_Device( void )
>> - rtems_device_minor_number minor;
>> - for ( minor = 0; minor < Console_Port_Count; minor++ ) {
>> - return minor;
>> - * Error No devices were found. We will want to bail here.
>> - bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>> -void bsp_console_select( void )
>> - * Reset Console_Port_Minor and
>> - * BSPPrintkPort here if desired.
>> - * This default version allows the bsp to set these
>> - * values at creation and will not touch them again
>> - * unless the selected port number is not available.
>> - const char *opt;
>> - Console_Port_Minor = BSP_CONSOLE_UART0;
>> - BSPPrintkPort = BSP_CONSOLE_UART0;
>> - opt = rpi_cmdline_get_arg( "--console=" );
>> - if ( opt ) {
>> - if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
>> - if ( rpi_video_is_initialized() > 0 ) {
>> - Console_Port_Minor = BSP_CONSOLE_FB;
>> - BSPPrintkPort = BSP_CONSOLE_FB;
>> - * If the device that was selected isn't available then
>> - * let the user know and select the first available device.
>> - if ( !bsp_Is_Available( Console_Port_Minor ) ) {
>> - Console_Port_Minor = bsp_First_Available_Device();
>> diff --git a/bsps/arm/raspberrypi/console/fbcons.c
>> b/bsps/arm/raspberrypi/console/fbcons.c
>> index 3669ba458d..0e6a430c54 100644
>> --- a/bsps/arm/raspberrypi/console/fbcons.c
>> +++ b/bsps/arm/raspberrypi/console/fbcons.c
>> @@ -18,6 +18,7 @@
>> #include <rtems.h>
>> +#include <rtems/termiostypes.h>
>> #include <stdlib.h>
>> @@ -29,15 +30,6 @@
>> #include <bsp/vc.h>
>> - * fbcons_init
>> - * This function initializes the fb console to a quiecsent state.
>> -static void fbcons_init( int minor )
>> * fbcons_open
>> @@ -45,13 +37,14 @@ static void fbcons_init( int minor )
>> * Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
>> -static int fbcons_open(
>> - int major,
>> - int minor,
>> - void *arg
>> +static bool fbcons_open(
>> + struct rtems_termios_tty *tty,
>> + rtems_termios_device_context *base,
>> + struct termios *term,
>> + rtems_libio_open_close_args_t *args
>> - return RTEMS_SUCCESSFUL;
>> + return true;
>> @@ -59,13 +52,12 @@ static int fbcons_open(
>> * This function shuts down the requested port.
>> -static int fbcons_close(
>> - int major,
>> - int minor,
>> - void *arg
>> +static void fbcons_close(
>> - return ( RTEMS_SUCCESSFUL );
>> @@ -73,8 +65,8 @@ static int fbcons_close(
>> * This routine polls out the requested character.
>> -static void fbcons_write_polled(
>> - int minor,
>> +void fbcons_write_polled(
>> char c
>> @@ -90,8 +82,8 @@ static void fbcons_write_polled(
>> * Console Termios output entry point when using polled output.
>> -static ssize_t fbcons_write_support_polled(
>> - int minor,
>> +static void fbcons_write_support_polled(
>> const char *buf,
>> size_t len
>> @@ -102,14 +94,9 @@ static ssize_t fbcons_write_support_polled(
>> * poll each byte in the string out of the port.
>> while ( nwrite < len ) {
>> - fbcons_write_polled( minor, *buf++ );
>> + fbcons_write_polled( base, *buf++ );
>> nwrite++;
>> - * return the number of bytes written.
>> - return nwrite;
>> @@ -117,7 +104,9 @@ static ssize_t fbcons_write_support_polled(
>> * Console Termios polling input entry point.
>> -static int fbcons_inbyte_nonblocking_polled( int minor )
>> +int fbcons_inbyte_nonblocking_polled(
>> // if( rtems_kbpoll() ) {
>> // int c = getch();
>> @@ -133,15 +122,17 @@ static int fbcons_inbyte_nonblocking_polled(
>> int minor )
>> * This function sets the UART channel to reflect the requested
>> termios
>> * port settings.
>> -static int fbcons_set_attributes(
>> - int minor,
>> +static bool fbcons_set_attributes(
>> const struct termios *t
>> - return 0;
>> + return true;
>> -bool fbcons_probe( int minor )
>> +bool fbcons_probe(
>> + rtems_termios_device_context *context
>> // rtems_status_code status;
>> static bool firstTime = true;
>> @@ -163,15 +154,12 @@ bool fbcons_probe( int minor )
>> return ret;
>> -const console_fns fbcons_fns =
>> +const rtems_termios_device_handler fbcons_fns =
>> - .deviceProbe = libchip_serial_default_probe, /* deviceProbe */
>> - .deviceFirstOpen = fbcons_open, /* deviceFirstOpen */
>> - .deviceLastClose = fbcons_close, /* deviceLastClose */
>> - .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead */
>> - .deviceWrite = fbcons_write_support_polled, /* deviceWrite */
>> - .deviceInitialize = fbcons_init, /*
>> deviceInitialize */
>> - .deviceWritePolled = fbcons_write_polled, /*
>> deviceWritePolled */
>> - .deviceSetAttributes = fbcons_set_attributes, /*
>> deviceSetAttributes */
>> - .deviceOutputUsesInterrupts = FALSE, /*
>> deviceOutputUsesInterrupts*/
>> + .first_open = fbcons_open,
>> + .last_close = fbcons_close,
>> + .poll_read = fbcons_inbyte_nonblocking_polled,
>> + .write = fbcons_write_support_polled,
>> + .set_attributes = fbcons_set_attributes,
>> + .mode = TERMIOS_POLLED
>> diff --git a/bsps/arm/raspberrypi/console/usart.c
>> b/bsps/arm/raspberrypi/console/usart.c
>> index 25fb523621..0000000000
>> --- a/bsps/arm/raspberrypi/console/usart.c
>> +++ /dev/null
>> @@ -1,167 +0,0 @@
>> - * @file
>> - * @ingroup raspberrypi_usart
>> - * @brief USART support.
>> - * Copyright (c) 2013 Alan Cudmore
>> -#include <libchip/sersupp.h>
>> -#include <bsp.h>
>> -#include <bsp/raspberrypi.h>
>> -#include <rtems/bspIo.h>
>> -static void usart_delay(uint32_t n)
>> - volatile uint32_t i = 0;
>> - for(i = 0; i < n; i++)
>> -#if 0
>> - * These will be useful when the driver supports interrupt driven IO.
>> -static rtems_vector_number usart_get_irq_number(const console_tbl *ct)
>> - return ct->ulIntVector;
>> -static uint32_t usart_get_baud(const console_tbl *ct)
>> - return ct->ulClock;
>> -#endif
>> -static void usart_set_baud(int minor, int baud)
>> - * Nothing for now
>> - return;
>> -static void usart_initialize(int minor)
>> - unsigned int gpio_reg;
>> - ** Program GPIO pins for UART 0
>> - gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
>> - gpio_reg &= ~(7<<12); /* gpio14 */
>> - gpio_reg |= (4<<12); /* alt0 */
>> - gpio_reg &= ~(7<<15); /* gpio15 */
>> - gpio_reg |= (4<<15); /* alt0 */
>> - BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
>> - BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
>> - usart_delay(150);
>> - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
>> - usart_delay(150);
>> - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>> - ** Init the PL011 UART
>> - BCM2835_REG(BCM2835_UART0_CR) = 0;
>> - BCM2835_REG(BCM2835_UART0_ICR) = 0x7FF;
>> - BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>> - BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>> - BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>> - BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>> - BCM2835_REG(BCM2835_UART0_RSRECR) = 0;
>> - BCM2835_REG(BCM2835_UART0_CR) = 0x301;
>> - BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
>> - usart_set_baud(minor, 115000);
>> -static int usart_first_open(int major, int minor, void *arg)
>> - rtems_libio_open_close_args_t *oc =
>> (rtems_libio_open_close_args_t *) arg;
>> - struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
>> oc->iop->data1;
>> - const console_tbl *ct = Console_Port_Tbl [minor];
>> - console_data *cd = &Console_Port_Data [minor];
>> - cd->termios_data = tty;
>> - rtems_termios_set_initial_baud(tty, ct->ulClock);
>> - return 0;
>> -static int usart_last_close(int major, int minor, void *arg)
>> - return 0;
>> -static int usart_read_polled(int minor)
>> - if (minor == 0) {
>> - if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE)
>> == 0) {
>> - return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>> - } else {
>> - return -1;
>> - } else {
>> - printk("Unknown console minor number: %d\n", minor);
>> - return -1;
>> -static void usart_write_polled(int minor, char c)
>> - while (1) {
>> - if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF) == 0)
>> - break;
>> - BCM2835_REG(BCM2835_UART0_DR) = c;
>> -static ssize_t usart_write_support_polled(
>> - int minor,
>> - const char *s,
>> - size_t n
>> - ssize_t i = 0;
>> - for (i = 0; i < n; ++i) {
>> - usart_write_polled(minor, s [i]);
>> - return n;
>> -static int usart_set_attributes(int minor, const struct termios *term)
>> - return -1;
>> -const console_fns bcm2835_usart_fns = {
>> - .deviceFirstOpen = usart_first_open,
>> - .deviceLastClose = usart_last_close,
>> - .deviceRead = usart_read_polled,
>> - .deviceWrite = usart_write_support_polled,
>> - .deviceInitialize = usart_initialize,
>> - .deviceWritePolled = usart_write_polled,
>> - .deviceSetAttributes = usart_set_attributes,
>> - .deviceOutputUsesInterrupts = false
>> diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>> b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>> index d0e126699a..9bdb4b115e 100644
>> --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>> +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>> @@ -33,12 +33,29 @@ extern "C" {
>> #define FB_CONSOLE 0x50492835
>> -bool fbcons_probe( int minor );
>> +bool fbcons_probe(
>> + char c
>> +void output_char_fb(char c);
>> +typedef struct {
>> + rtems_termios_device_context base;
>> +} rpi_fb_context ;
>> * Driver function table
>> -extern const console_fns fbcons_fns;
>> +extern const rtems_termios_device_handler fbcons_fns;
>> #ifdef __cplusplus
>> diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>> b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>> index 40c80cf408..e052c2becb 100644
>> --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>> +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>> @@ -24,6 +24,7 @@
>> #include <stdint.h>
>> #include <bsp/utility.h>
>> * @defgroup raspberrypi_reg Register Definitions
>> @@ -60,6 +61,17 @@
>> #define RPI_PERIPHERAL_SIZE 0x01000000
>> + * @name Console select definitions
>> +#define PL011 0
>> +#define FB 1
>> * @name Internal ARM Timer Registers
>> @@ -184,42 +196,6 @@
>> - * @name UART 0 (PL011) Registers
>> -#define BCM2835_UART0_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>> -#define BCM2835_UART0_DR (BCM2835_UART0_BASE + 0x00)
>> -#define BCM2835_UART0_RSRECR (BCM2835_UART0_BASE + 0x04)
>> -#define BCM2835_UART0_FR (BCM2835_UART0_BASE + 0x18)
>> -#define BCM2835_UART0_ILPR (BCM2835_UART0_BASE + 0x20)
>> -#define BCM2835_UART0_IBRD (BCM2835_UART0_BASE + 0x24)
>> -#define BCM2835_UART0_FBRD (BCM2835_UART0_BASE + 0x28)
>> -#define BCM2835_UART0_LCRH (BCM2835_UART0_BASE + 0x2C)
>> -#define BCM2835_UART0_CR (BCM2835_UART0_BASE + 0x30)
>> -#define BCM2835_UART0_IFLS (BCM2835_UART0_BASE + 0x34)
>> -#define BCM2835_UART0_IMSC (BCM2835_UART0_BASE + 0x38)
>> -#define BCM2835_UART0_RIS (BCM2835_UART0_BASE + 0x3C)
>> -#define BCM2835_UART0_MIS (BCM2835_UART0_BASE + 0x40)
>> -#define BCM2835_UART0_ICR (BCM2835_UART0_BASE + 0x44)
>> -#define BCM2835_UART0_DMACR (BCM2835_UART0_BASE + 0x48)
>> -#define BCM2835_UART0_ITCR (BCM2835_UART0_BASE + 0x80)
>> -#define BCM2835_UART0_ITIP (BCM2835_UART0_BASE + 0x84)
>> -#define BCM2835_UART0_ITOP (BCM2835_UART0_BASE + 0x88)
>> -#define BCM2835_UART0_TDR (BCM2835_UART0_BASE + 0x8C)
>> -#define BCM2835_UART0_MIS_RX 0x10
>> -#define BCM2835_UART0_MIS_TX 0x20
>> -#define BCM2835_UART0_IMSC_RX 0x10
>> -#define BCM2835_UART0_IMSC_TX 0x20
>> -#define BCM2835_UART0_FR_RXFE 0x10
>> -#define BCM2835_UART0_FR_TXFF 0x20
>> -#define BCM2835_UART0_ICR_RX 0x10
>> -#define BCM2835_UART0_ICR_TX 0x20
>> diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
>> b/bsps/arm/raspberrypi/include/bsp/usart.h
>> index d3e710c5e9..abbf53626c 100644
>> --- a/bsps/arm/raspberrypi/include/bsp/usart.h
>> +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
>> @@ -32,9 +32,8 @@
>> extern "C" {
>> #endif /* __cplusplus */
>> -#define USART0_DEFAULT_BAUD 115000
>> -extern const console_fns bcm2835_usart_fns;
>> +#define PL011_DEFAULT_BAUD 115000
>> +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>> #ifdef __cplusplus
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> index 11a22f89e3..0e0d5bef67 100644
>> --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> @@ -42,6 +42,7 @@ librtemsbsp_a_SOURCES +=
>> ../../../../../../bsps/shared/start/bspfatal-default.c
>> ../../../../../../bsps/shared/dev/cpucounter/cpucounterfrequency.c
>> ../../../../../../bsps/shared/dev/cpucounter/cpucounterread.c
>> librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
>> +librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bsp-fdt.c
>> ../../../../../../bsps/shared/start/stackalloc.c
>> ../../../../../../bsps/arm/shared/start/bsp-start-memcpy.S
>> ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
>> @@ -63,14 +64,13 @@ librtemsbsp_a_SOURCES +=
>> ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
>> ../../../../../../bsps/arm/raspberrypi/irq/irq.c
>> # Console
>> -librtemsbsp_a_SOURCES +=
>> ../../../../../../bsps/shared/dev/serial/legacy-console.c
>> ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
>> ../../../../../../bsps/arm/raspberrypi/console/console-config.c
>> ../../../../../../bsps/arm/raspberrypi/console/console_select.c
>> ../../../../../../bsps/arm/raspberrypi/console/usart.c
>> ../../../../../../bsps/arm/raspberrypi/console/fb.c
>> ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
>> ../../../../../../bsps/arm/raspberrypi/console/outch.c
>> ../../../../../../bsps/shared/dev/serial/console-termios.c
>> ../../../../../../bsps/shared/dev/serial/console-termios-init.c
>> ../../../../../../bsps/arm/shared/serial/arm-pl011.c
>> # Mailbox
>> ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
>> 2.17.1
> devel mailing list
> devel at rtems.org
