[PATCH v4] Raspberrypi: updated the console interface.
Niteesh
gsnb.gn at gmail.com
Tue Dec 31 18:41:23 UTC 2019
On Tue, Dec 31, 2019 at 10:56 PM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> On Tue, Dec 31, 2019 at 9:27 PM Niteesh <gsnb.gn at gmail.com> wrote:
>> I tried the above thing it doesn't work :(
>> Maybe lets stop with this. And try to get RTEMS working on rpi3
>> this way, it will also be easier for me to work. Did you take a look at
>> what
>> caused the secondary cpu's not to halt? Is there something that I can do?
>> Or shall we continue with this? I kind of feel lost and not at all happy
>> with my progress.
>> Hi Niteesh,
> (Not commenting on anything technical)
> Just wanted to add a famous quote:
> "The first 90 percent of the code accounts for the first 90 percent of the
> development time. The remaining 10 percent of the code accounts for the
> other 90 percent of the development time" — Tom Cargill, Bell Labs
> (Wikipedia explains this well
> <https://en.wikipedia.org/wiki/Ninety-ninety_rule>)
> It always takes more time and much more debugging than it was originally
> planned,
> you have made quite good progress in figuring out stuff and came up with
> the
> implementation quite quickly. Seems like all that is left is debugging,
> and with Christian
> helping you, that will be solved quickly as well ;-)
> Happy New year :)
Great, I hope now we can get it working even faster. I have looked at your
previous year GSOC
work, it was great.
> PS: I have a pi3 as well, and would love to join the efforts on pi3 after
> the exams ;-)
All the best for your exams.
Happy New year
> On Tue, Dec 31, 2019 at 8:29 PM Niteesh <gsnb.gn at gmail.com> wrote:
>>> I have an idea to debug this, but not sure whether it will work or not,
>>> I could
>>> run raspbian on versatilepb using arm1176 as cpu and 256mb ram
>>> this is very much similar to raspi1, I think this one also uses pl011, I
>>> remember
>>> seeing it in the linux bootup msgs.
>>> I could run the examples using qemu using raspi2 as the machine but the
>>> dtb
>>> file never gets passed to it. The register r2 is 0.
>>> qemu-system-arm -M raspi2 -m 1G -kernel fileio.exe -serial mon:stdio
>>> -nographic -dtb bcm2709-rpi-2-b.dtb -S -s
>>> This is the command I use to run my examples and connect to gdb.
>>> On Tue, Dec 31, 2019 at 7:31 PM Christian Mauderer <list at c-mauderer.de>
>>> wrote:
>>>> On 31/12/2019 14:56, Niteesh wrote:
>>>> > If moving uart_probe to output char, then should I move
>>>> > rtems_device_handler_install to console_initialize because, my guess
>>>> > is that the IO initialization system would not be initialized properly
>>>> > at that stage.
>>>> The uart_probe in the output char function should do a really minimal
>>>> initialization. Only what is necessary to get the polled uart working.
>>>> That one will only be called if you have an exception at a very early
>>>> stage. In that case you are working in an exception context.
>>>> > When I rename the register_arm_pl011 to init_context_pl011 since it's
>>>> is
>>>> > only initializing
>>>> > the pl011 context, rather than registering it.
>>>> > On Tue, Dec 31, 2019 at 6:32 PM Christian Mauderer <
>>>> > <mailto:list at c-mauderer.de>> wrote:
>>>> > On 31/12/2019 13:22, Niteesh wrote:
>>>> > > It works now, the functions are getting called when used with
>>>> > fileio.exe.
>>>> > > The function bsp_start wants to print information about the
>>>> board,
>>>> > That print maybe should be moved to a later point. It just
>>>> fetches some
>>>> > information and prints it. It doesn't even do anything usefull
>>>> > besides that.
>>>> > > but
>>>> > > the console
>>>> > > initialization function is called after bsp_start, assuming that
>>>> > the FDT
>>>> > > works it still
>>>> > > crash since the console still isn't initialized, one way of
>>>> fixing
>>>> > this
>>>> > > would be to add uart_probe into
>>>> > > output_char just like in imx, or we could move the printing to
>>>> > somewhere
>>>> > > else.
>>>> > That might would be a good idea regardless whether the print is
>>>> moved or
>>>> > not. It would allow an early exception to print anything.
>>>> > > On Tue, Dec 31, 2019 at 4:08 PM Christian Mauderer
>>>> > <list at c-mauderer.de <mailto:list at c-mauderer.de>
>>>> > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>>>> > > On 31/12/2019 11:37, Christian Mauderer wrote:
>>>> > > > On 31/12/2019 06:11, Niteesh wrote:
>>>> > > >> On Tue, Dec 31, 2019 at 1:13 AM Christian Mauderer
>>>> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>>>> > > >> On 30/12/2019 19:32, Niteesh wrote:
>>>> > > >> > Just to make sure that console_initialize and
>>>> uart_probe
>>>> > > are being
>>>> > > >> > called, I manually initialized the pl011 context
>>>> to print
>>>> > > something on
>>>> > > >> > serial. But they never got called. Can you just
>>>> make sure
>>>> > > that if I am
>>>> > > >> > missing something?
>>>> > > >> I don't think that you are missing something but the
>>>> > > executable is
>>>> > > >> missing something: The functions are not linked into
>>>> it.
>>>> > > >> C linker can be an odd thing: It links only object
>>>> > files that are
>>>> > > >> referenced. You seem to have no reference to
>>>> > > console-config.c/o from
>>>> > > >> anywhere else.
>>>> > > >> RTEMS_SYSINIT_ITEM(
>>>> > > >> uart_probe,
>>>> > > >> RTEMS_SYSINIT_BSP_START,
>>>> > > >> RTEMS_SYSINIT_ORDER_LAST
>>>> > > >> will be only added to the linker set if the file is
>>>> > linked in
>>>> > > anyway.
>>>> > > >> That is a bit anoying. For the imx BSP there is a
>>>> UART
>>>> > drain
>>>> > > function
>>>> > > >> that is called from somewhere else. Thats enough to
>>>> > bring the
>>>> > > file in.
>>>> > > >> I think you'll need to add a reference from somewhere
>>>> > or move
>>>> > > that stuff
>>>> > > >> into another file that is referenced.
>>>> > > >> If you have some init function that has to be called
>>>> in
>>>> > every
>>>> > > case you
>>>> > > >> can call it from some other c file where it would
>>>> fit too.
>>>> > > >> Otherwise it might is necessary to construct some odd
>>>> > stuff.
>>>> > > I'm not
>>>> > > >> sure whether we already had a case like this. Most
>>>> > likely it
>>>> > > would be
>>>> > > >> necessary to use a RTEMS_LINKER_ROSET_ITEM_REFERENCE
>>>> > for the
>>>> > > >> SYSINIT_ITEM. Maybe to define a new
>>>> > > RTEMS_SYSINIT_ITEM_REFERENCE or
>>>> > > >> simmilar. This should be definitively a separate
>>>> commit.
>>>> > > Please ask
>>>> > > >> again if you have to go that way.
>>>> > > >> I didn't understand the above part. So what I did was
>>>> > created a dummy
>>>> > > >> function in console-config.c
>>>> > > >> and referenced in places that I know we're going to be
>>>> > called. But
>>>> > > >> still, it didn't work.
>>>> > > > That's a really mean bug to find:
>>>> > > > 1. My assumption was wrong. The file is linked in. Most
>>>> > likely due to
>>>> > > > BSP_output_char which is defined in this file.
>>>> > > > 2. Please remove console-termios-init.c. It would define
>>>> the
>>>> > same
>>>> > > > console_initialize() function.
>>>> > > Just to be clear: Remove it from the
>>>> > > c/src/lib/libbsp/arm/raspberrypi/Makefile.am file.
>>>> > > > 3. The real proble just caused a warning which was a bit
>>>> > hard to spot:
>>>> > > > The compile doesn't know RTEMS_SYSINIT_ITEM. It thinks
>>>> it's
>>>> > a function
>>>> > > > body and warns that it defaults the return type to int.
>>>> In other
>>>> > > words:
>>>> > > > You missed to include <rtems/sysinit.h>. If you add that
>>>> the
>>>> > > > RTEMS_SYSINIT_ITEM works and uart_probe is linked in.
>>>> > > > 4. console_initialize is still not used. It is really hard
>>>> > to spot
>>>> > > why:
>>>> > > > Most of the tests only use the configuration:
>>>> > > > CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
>>>> > > > This is a simplified polled console driver. From the
>>>> samples
>>>> > only
>>>> > > > capture, fileio and pppd are using the normal console
>>>> with:
>>>> > > > CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>>> > > > So only for these three the console_initialize will be
>>>> called.
>>>> > > > By the way: You can use objdump to analyze your elf-files.
>>>> > For example
>>>> > > > to get a symbol table use:
>>>> > > > arm-rtems5-objdump -t path/to/ticker.exe
>>>> > > > To get the disassembled code with intermixed c-sources use
>>>> > > > arm-rtems5-objdump -dS path/to/ticker.exe
>>>> > > > That's very usefull to find whether a symbol is linked in
>>>> or
>>>> > not.
>>>> > > >> > While going through the messages from
>>>> devel-request, Joel
>>>> > > mentioned
>>>> > > >> > about qemu4 rsb package
>>>> > > >> > how is it different from the official qemu?
>>>> > > >> > On Mon, Dec 30, 2019 at 11:53 PM G S Niteesh
>>>> > > <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>>>> > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>
>>>> > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>
>>>> > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>>> wrote:
>>>> > > >> > The patch updates the older console interface
>>>> used by
>>>> > > the BSP,
>>>> > > >> > to newer one. It also replaces the custom
>>>> > usart(PL011)
>>>> > > driver
>>>> > > >> > with arm-pl011. The fb function's signatures
>>>> > where also
>>>> > > changed
>>>> > > >> > to accommodate with interface update.
>>>> > > >> > Update #3034
>>>> > > >> > bsps/arm/raspberrypi/console/console-config.c
>>>> | 186
>>>> > > >> > bsps/arm/raspberrypi/console/console_select.c
>>>> | 114
>>>> > > >> > bsps/arm/raspberrypi/console/fbcons.c
>>>> | 78
>>>> > > >> > bsps/arm/raspberrypi/console/usart.c
>>>> | 167
>>>> > > >> > bsps/arm/raspberrypi/include/bsp/fbcons.h
>>>> > 21 +-
>>>> > > >> > .../arm/raspberrypi/include/bsp/raspberrypi.h
>>>> > 48 ++---
>>>> > > >> > bsps/arm/raspberrypi/include/bsp/usart.h
>>>> > 5 +-
>>>> > 8 +-
>>>> > > >> > 8 files changed, 220 insertions(+), 407
>>>> deletions(-)
>>>> > > >> > delete mode 100644
>>>> > > >> > delete mode 100644
>>>> > > >> > diff --git
>>>> > a/bsps/arm/raspberrypi/console/console-config.c
>>>> > > >> > b/bsps/arm/raspberrypi/console/console-config.c
>>>> > > >> > index d2186c918b..021428ff4b 100644
>>>> > > >> > @@ -19,50 +19,164 @@
>>>> > > >> > #include <rtems/bspIo.h>
>>>> > > >> > +#include <rtems/console.h>
>>>> > > >> > -#include <libchip/serial.h>
>>>> > > >> > -#include <bspopts.h>
>>>> > > >> > -#include <bsp/irq.h>
>>>> > > >> > -#include <bsp/usart.h>
>>>> > > >> > +#include <bsp.h>
>>>> > > >> > #include <bsp/raspberrypi.h>
>>>> > > >> > +#include <bsp/usart.h>
>>>> > > >> > +#include <bsp/arm-pl011.h>
>>>> > > >> > #include <bsp/fbcons.h>
>>>> > > >> > +#include <bsp/console-termios.h>
>>>> > > >> > +#include <bsp/fdt.h>
>>>> > > >> > +#include <bsp/fatal.h>
>>>> > > >> > +#include <bspopts.h>
>>>> > > >> > +#include <libfdt.h>
>>>> > > >> > +#include <libchip/serial.h>
>>>> > > >> > +arm_pl011_context pl011_context;
>>>> > > >> > +rpi_fb_context fb_context;
>>>> > > >> These could be static.
>>>> > > >> > +static void output_char_serial(char c)
>>>> > > >> > + arm_pl011_write_polled(&pl011_context.base,
>>>> c);
>>>> > > >> > +void output_char_fb(char c)
>>>> > > >> > + fbcons_write_polled(&fb_context.base, c);
>>>> > > >> > -console_tbl Console_Configuration_Ports [] = {
>>>> > > >> > - .sDeviceName = "/dev/ttyS0",
>>>> > > >> > - .deviceType = SERIAL_CUSTOM,
>>>> > > >> > - .pDeviceFns = &bcm2835_usart_fns,
>>>> > > >> > - .deviceProbe = NULL,
>>>> > > >> > - .pDeviceFlow = NULL,
>>>> > > >> > - .ulCtrlPort1 = BCM2835_UART0_BASE,
>>>> > > >> > - .ulCtrlPort2 = 0,
>>>> > > >> > - .ulClock = USART0_DEFAULT_BAUD,
>>>> > > >> > - .ulIntVector = BCM2835_IRQ_ID_UART
>>>> > > >> > - .sDeviceName ="/dev/fbcons",
>>>> > > >> > - .pDeviceFns = &fbcons_fns,
>>>> > > >> > - .deviceProbe = fbcons_probe,
>>>> > > >> > -#define PORT_COUNT \
>>>> > > >> > - (sizeof(Console_Configuration_Ports) \
>>>> > > >> > - / sizeof(Console_Configuration_Ports [0]))
>>>> > > >> > -unsigned long Console_Configuration_Count =
>>>> > PORT_COUNT;
>>>> > > >> > -static void output_char(char c)
>>>> > > >> > +static void *get_reg_of_node(const void *fdt,
>>>> > int node)
>>>> > > >> > - const console_fns *con =
>>>> > > >> > - Console_Configuration_Ports
>>>> > > [Console_Port_Minor].pDeviceFns;
>>>> > > >> > + int len;
>>>> > > >> > + const uint32_t *val;
>>>> > > >> > + val = fdt_getprop(fdt, node, "reg", &len);
>>>> > > >> > + if (val == NULL || len < 4) {
>>>> > > >> > + return NULL;
>>>> > > >> > - con->deviceWritePolled((int)
>>>> > Console_Port_Minor, c);
>>>> > > >> > + return (void *) fdt32_to_cpu(val[0]);
>>>> > > >> > -BSP_output_char_function_type BSP_output_char
>>>> > > output_char;
>>>> > > >> > +static void register_arm_pl011(
>>>> > > >> > + const void *fdt,
>>>> > > >> > + const char *serial
>>>> > > >> > + arm_pl011_context *ctx = &pl011_context;
>>>> > > >> > + int node;
>>>> > > >> > + if (strcmp(serial, "uart0") == 0) {
>>>> > > rtems_termios_device_context_initialize(&ctx->base, "UART");
>>>> > > >> > + node = fdt_path_offset(fdt, serial);
>>>> > > >> > + ctx->regs = get_reg_of_node(fdt, node);
>>>> > > >> > + rtems_termios_device_install(
>>>> > > >> > + "/dev/ttyuart0",
>>>> > > >> > + &arm_pl011_fns,
>>>> > > >> > + NULL,
>>>> > > >> > + &pl011_context.base
>>>> > > >> > +static void register_fb( void )
>>>> > > >> > + if (fbcons_probe(&fb_context.base) == true)
>>>> > > >> > + "/dev/fbcons",
>>>> > > >> > + &fbcons_fns,
>>>> > > >> > + NULL,
>>>> > > >> > + &fb_context.base);
>>>> > > >> > +static void console_select( const char
>>>> *console )
>>>> > > >> > + const char *opt;
>>>> > > >> > + opt = rpi_cmdline_get_arg("--console=");
>>>> > > >> > + if ( opt ) {
>>>> > > >> > + if ( strncmp( opt, "fbcons", sizeof(
>>>> > "fbcons" ) -
>>>> > > 1 ) ==
>>>> > > >> 0 ) {
>>>> > > >> > + if ( rpi_video_is_initialized() > 0 ) {
>>>> > > >> > + BSP_output_char = output_char_fb;
>>>> > > >> > + link("/dev/fbcons",
>>>> CONSOLE_DEVICE_NAME);
>>>> > > >> > + }else{
>>>> > > >> > + if ( console == NULL ){
>>>> > > >> > + bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>>>> > > >> > + BSP_output_char = output_char_serial;
>>>> > > >> > + link("/dev/ttyuart0",
>>>> > > >> > +static void uart_probe(void)
>>>> > > >> > + const void *fdt;
>>>> > > >> > + const char *console;
>>>> > > >> > + int node;
>>>> > > >> > + fdt = bsp_fdt_get();
>>>> > > >> > + node = fdt_path_offset(fdt, "/chosen");
>>>> > > >> > + console = fdt_getprop(fdt, node,
>>>> > "stdout-path", NULL);
>>>> > > >> > + node = fdt_path_offset(fdt, "/aliases");
>>>> > > >> > + int offset = fdt_first_property_offset(fdt,
>>>> node);
>>>> > > >> > + while (offset >= 0) {
>>>> > > >> > + const struct fdt_property *prop;
>>>> > > >> > + prop = fdt_get_property_by_offset(fdt,
>>>> > offset, NULL);
>>>> > > >> > + if (prop != NULL) {
>>>> > > >> > + const char *name;
>>>> > > >> > + name = fdt_string(fdt,
>>>> > fdt32_to_cpu(prop->nameoff));
>>>> > > >> > + if(strstr(name, "serial") != NULL) {
>>>> > > >> > + const char *serial;
>>>> > > >> > + serial = prop->data;
>>>> > > >> > + register_arm_pl011(fdt, serial);
>>>> > > >> > + offset = fdt_next_property_offset(fdt,
>>>> offset);
>>>> > > >> > + console_select(console);
>>>> > > >> > +rtems_status_code console_initialize(
>>>> > > >> > + rtems_device_major_number major,
>>>> > > >> > + rtems_device_minor_number minor,
>>>> > > >> > + void *arg
>>>> > > >> > + rtems_termios_initialize();
>>>> > > >> > + uart_probe();
>>>> > > >> > + register_fb();
>>>> > > >> > + return RTEMS_SUCCESSFUL;
>>>> > > >> > +BSP_output_char_function_type BSP_output_char
>>>> > > >> output_char_serial;
>>>> > > >> > BSP_polling_getchar_function_type
>>>> BSP_poll_char
>>>> > = NULL;
>>>> > > >> > +RTEMS_SYSINIT_ITEM(
>>>> > > >> > + uart_probe,
>>>> > > >> > + RTEMS_SYSINIT_BSP_START,
>>>> > > >> > + RTEMS_SYSINIT_ORDER_LAST
>>>> > > >> > \ No newline at end of file
>>>> > > >> > diff --git
>>>> > a/bsps/arm/raspberrypi/console/console_select.c
>>>> > > >> > b/bsps/arm/raspberrypi/console/console_select.c
>>>> > > >> > deleted file mode 100644
>>>> > > >> > index bd246ca868..0000000000
>>>> > > >> > +++ /dev/null
>>>> > > >> > @@ -1,114 +0,0 @@
>>>> > > >> > - * @file
>>>> > > >> > - * @ingroup raspberrypi_console
>>>> > > >> > - * @brief console select
>>>> > > >> > - * Copyright (c) 2015 Yang Qiao
>>>> > > >> > - * The license and distribution terms for
>>>> this file
>>>> > > may be
>>>> > > >> > - * found in the file LICENSE in this
>>>> > distribution or at
>>>> > > >> > - * http://www.rtems.org/license/LICENSE
>>>> > > >> > -#include <bsp.h>
>>>> > > >> > -#include <bsp/fatal.h>
>>>> > > >> > -#include <rtems/libio.h>
>>>> > > >> > -#include <stdlib.h>
>>>> > > >> > -#include <string.h>
>>>> > > >> > -#include <assert.h>
>>>> > > >> > -#include <termios.h>
>>>> > > >> > -#include <rtems/termiostypes.h>
>>>> > > >> > -#include
>>>> "../../shared/dev/serial/legacy-console.h"
>>>> > > >> > -#include <bsp/rpi-fb.h>
>>>> > > >> > -rtems_device_minor_number BSPPrintkPort = 0;
>>>> > > >> > - * Method to return true if the device
>>>> > associated with the
>>>> > > >> > - * minor number probs available.
>>>> > > >> > -static bool bsp_Is_Available(
>>>> > > rtems_device_minor_number minor )
>>>> > > >> > - console_tbl *cptr = Console_Port_Tbl[ minor
>>>> > > >> > - * First perform the configuration dependent
>>>> > probe,
>>>> > > then the
>>>> > > >> > - * device dependent probe
>>>> > > >> > - if ( ( !cptr->deviceProbe ||
>>>> cptr->deviceProbe(
>>>> > > minor ) ) &&
>>>> > > >> > - cptr->pDeviceFns->deviceProbe( minor )
>>>> > > >> > - return true;
>>>> > > >> > - return false;
>>>> > > >> > - * Method to return the first available
>>>> device.
>>>> > > >> > -static rtems_device_minor_number
>>>> > > bsp_First_Available_Device(
>>>> > > >> void )
>>>> > > >> > - rtems_device_minor_number minor;
>>>> > > >> > - for ( minor = 0; minor < Console_Port_Count;
>>>> > minor++ ) {
>>>> minor ];
>>>> dependent
>>>> > > probe, then the
>>>> cptr->deviceProbe(
>>>> > > minor ) ) &&
>>>> > > >> > - return minor;
>>>> > > >> > - * Error No devices were found. We will
>>>> want to
>>>> > > bail here.
>>>> > > >> > - bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>>>> > > >> > -void bsp_console_select( void )
>>>> > > >> > - * Reset Console_Port_Minor and
>>>> > > >> > - * BSPPrintkPort here if desired.
>>>> > > >> > - * This default version allows the bsp to
>>>> set
>>>> > these
>>>> > > >> > - * values at creation and will not touch
>>>> them
>>>> > again
>>>> > > >> > - * unless the selected port number is not
>>>> > available.
>>>> > > >> > - const char *opt;
>>>> > > >> > - Console_Port_Minor = BSP_CONSOLE_UART0;
>>>> > > >> > - BSPPrintkPort = BSP_CONSOLE_UART0;
>>>> > > >> > - opt = rpi_cmdline_get_arg( "--console=" );
>>>> > > >> > - if ( opt ) {
>>>> > > >> > - if ( strncmp( opt, "fbcons", sizeof(
>>>> > "fbcons" ) -
>>>> > > 1 ) ==
>>>> > > >> 0 ) {
>>>> > > >> > - if ( rpi_video_is_initialized() > 0 ) {
>>>> > > >> > - Console_Port_Minor = BSP_CONSOLE_FB;
>>>> > > >> > - BSPPrintkPort = BSP_CONSOLE_FB;
>>>> > > >> > - * If the device that was selected isn't
>>>> > available then
>>>> > > >> > - * let the user know and select the first
>>>> > available
>>>> > > device.
>>>> > > >> > - if ( !bsp_Is_Available( Console_Port_Minor
>>>> > bsp_First_Available_Device();
>>>> > > >> > diff --git
>>>> a/bsps/arm/raspberrypi/console/fbcons.c
>>>> > > >> > b/bsps/arm/raspberrypi/console/fbcons.c
>>>> > > >> > index 3669ba458d..0e6a430c54 100644
>>>> > > >> > --- a/bsps/arm/raspberrypi/console/fbcons.c
>>>> > > >> > +++ b/bsps/arm/raspberrypi/console/fbcons.c
>>>> > > >> > @@ -18,6 +18,7 @@
>>>> > > >> > #include <rtems.h>
>>>> > > >> > +#include <rtems/termiostypes.h>
>>>> > > >> > #include <stdlib.h>
>>>> > > >> > @@ -29,15 +30,6 @@
>>>> > > >> > #include <bsp/vc.h>
>>>> > > >> > - * fbcons_init
>>>> > > >> > - * This function initializes the fb console
>>>> to a
>>>> > > quiecsent
>>>> > > >> state.
>>>> > > >> > -static void fbcons_init( int minor )
>>>> > > >> > * fbcons_open
>>>> > > >> > @@ -45,13 +37,14 @@ static void fbcons_init(
>>>> int
>>>> > minor )
>>>> > > >> > * Default state is 9600 baud, 8 bits, No
>>>> > parity, and
>>>> > > 1 stop
>>>> > > >> bit.
>>>> > > >> > -static int fbcons_open(
>>>> > > >> > - int major,
>>>> > > >> > - int minor,
>>>> > > >> > - void *arg
>>>> > > >> > +static bool fbcons_open(
>>>> > > >> > + struct rtems_termios_tty *tty,
>>>> > > >> > + rtems_termios_device_context *base,
>>>> > > >> > + struct termios *term,
>>>> > > >> > + rtems_libio_open_close_args_t *args
>>>> > > >> > - return RTEMS_SUCCESSFUL;
>>>> > > >> > + return true;
>>>> > > >> > @@ -59,13 +52,12 @@ static int fbcons_open(
>>>> > > >> > * This function shuts down the requested
>>>> port.
>>>> > > >> > -static int fbcons_close(
>>>> > > >> > - int major,
>>>> > > >> > - int minor,
>>>> > > >> > - void *arg
>>>> > > >> > +static void fbcons_close(
>>>> > > >> > - return ( RTEMS_SUCCESSFUL );
>>>> > > >> > @@ -73,8 +65,8 @@ static int fbcons_close(
>>>> > > >> > * This routine polls out the requested
>>>> character.
>>>> > > >> > -static void fbcons_write_polled(
>>>> > > >> > - int minor,
>>>> > > >> > +void fbcons_write_polled(
>>>> > > >> > char c
>>>> > > >> > @@ -90,8 +82,8 @@ static void
>>>> > > >> > * Console Termios output entry point when
>>>> using
>>>> > > polled output.
>>>> > > >> > -static ssize_t fbcons_write_support_polled(
>>>> > > >> > - int minor,
>>>> > > >> > +static void fbcons_write_support_polled(
>>>> > > >> > const char *buf,
>>>> > > >> > size_t len
>>>> > > >> > @@ -102,14 +94,9 @@ static ssize_t
>>>> > > >> > * poll each byte in the string out of the
>>>> port.
>>>> > > >> > while ( nwrite < len ) {
>>>> > > >> > - fbcons_write_polled( minor, *buf++ );
>>>> > > >> > + fbcons_write_polled( base, *buf++ );
>>>> > > >> > nwrite++;
>>>> > > >> > - * return the number of bytes written.
>>>> > > >> > - return nwrite;
>>>> > > >> > @@ -117,7 +104,9 @@ static ssize_t
>>>> > > >> > * Console Termios polling input entry point.
>>>> > > >> > -static int fbcons_inbyte_nonblocking_polled(
>>>> int
>>>> > minor )
>>>> > > >> > +int fbcons_inbyte_nonblocking_polled(
>>>> > > >> > // if( rtems_kbpoll() ) {
>>>> > > >> > // int c = getch();
>>>> > > >> > @@ -133,15 +122,17 @@ static int
>>>> > > >> > int minor )
>>>> > > >> > * This function sets the UART channel to
>>>> > reflect the
>>>> > > requested
>>>> > > >> > termios
>>>> > > >> > * port settings.
>>>> > > >> > -static int fbcons_set_attributes(
>>>> > > >> > - int minor,
>>>> > > >> > +static bool fbcons_set_attributes(
>>>> > > >> > const struct termios *t
>>>> > > >> > - return 0;
>>>> > > >> > + return true;
>>>> > > >> > -bool fbcons_probe( int minor )
>>>> > > >> > +bool fbcons_probe(
>>>> > > >> > + rtems_termios_device_context *context
>>>> > > >> > // rtems_status_code status;
>>>> > > >> > static bool firstTime = true;
>>>> > > >> > @@ -163,15 +154,12 @@ bool fbcons_probe( int
>>>> minor )
>>>> > > >> > return ret;
>>>> > > >> > -const console_fns fbcons_fns =
>>>> > > >> > +const rtems_termios_device_handler fbcons_fns
>>>> > > >> > - .deviceProbe =
>>>> libchip_serial_default_probe,
>>>> > > >> deviceProbe */
>>>> > > >> > - .deviceFirstOpen = fbcons_open,
>>>> > > >> deviceFirstOpen */
>>>> > > >> > - .deviceLastClose = fbcons_close,
>>>> > > >> deviceLastClose */
>>>> > > >> > - .deviceRead =
>>>> fbcons_inbyte_nonblocking_polled, /*
>>>> > > >> deviceRead */
>>>> > > >> > - .deviceWrite =
>>>> fbcons_write_support_polled, /*
>>>> > > >> deviceWrite */
>>>> > > >> > - .deviceInitialize = fbcons_init,
>>>> > > >> > deviceInitialize */
>>>> > > >> > - .deviceWritePolled = fbcons_write_polled,
>>>> > > >> > deviceWritePolled */
>>>> > > >> > - .deviceSetAttributes =
>>>> fbcons_set_attributes, /*
>>>> > > >> > deviceSetAttributes */
>>>> > > >> > - .deviceOutputUsesInterrupts = FALSE,
>>>> > > >> > deviceOutputUsesInterrupts*/
>>>> > > >> > + .first_open = fbcons_open,
>>>> > > >> > + .last_close = fbcons_close,
>>>> > > >> > + .poll_read =
>>>> > > >> > + .write = fbcons_write_support_polled,
>>>> > > >> > + .set_attributes = fbcons_set_attributes,
>>>> > > >> > + .mode = TERMIOS_POLLED
>>>> > > >> > diff --git
>>>> a/bsps/arm/raspberrypi/console/usart.c
>>>> > > >> > b/bsps/arm/raspberrypi/console/usart.c
>>>> > > >> > index 25fb523621..0000000000
>>>> > > >> > --- a/bsps/arm/raspberrypi/console/usart.c
>>>> > > >> > +++ /dev/null
>>>> > > >> > @@ -1,167 +0,0 @@
>>>> > > >> > - * @file
>>>> > > >> > - * @ingroup raspberrypi_usart
>>>> > > >> > - * @brief USART support.
>>>> > > >> > - * Copyright (c) 2013 Alan Cudmore
>>>> this file
>>>> > > may be
>>>> > distribution or at
>>>> > > >> > -#include <libchip/sersupp.h>
>>>> > > >> > -#include <bsp.h>
>>>> > > >> > -#include <bsp/raspberrypi.h>
>>>> > > >> > -#include <rtems/bspIo.h>
>>>> > > >> > -static void usart_delay(uint32_t n)
>>>> > > >> > - volatile uint32_t i = 0;
>>>> > > >> > - for(i = 0; i < n; i++)
>>>> > > >> > -#if 0
>>>> > > >> > - * These will be useful when the driver
>>>> supports
>>>> > > interrupt
>>>> > > >> driven IO.
>>>> > > >> > -static rtems_vector_number
>>>> > usart_get_irq_number(const
>>>> > > >> console_tbl *ct)
>>>> > > >> > - return ct->ulIntVector;
>>>> > > >> > -static uint32_t usart_get_baud(const
>>>> console_tbl
>>>> > *ct)
>>>> > > >> > - return ct->ulClock;
>>>> > > >> > -#endif
>>>> > > >> > -static void usart_set_baud(int minor, int
>>>> baud)
>>>> > > >> > - * Nothing for now
>>>> > > >> > - return;
>>>> > > >> > -static void usart_initialize(int minor)
>>>> > > >> > - unsigned int gpio_reg;
>>>> > > >> > - ** Program GPIO pins for UART 0
>>>> > > >> > - gpio_reg =
>>>> BCM2835_REG(BCM2835_GPIO_GPFSEL1);
>>>> > > >> > - gpio_reg &= ~(7<<12); /* gpio14 */
>>>> > > >> > - gpio_reg |= (4<<12); /* alt0 */
>>>> > > >> > - gpio_reg &= ~(7<<15); /* gpio15 */
>>>> > > >> > - gpio_reg |= (4<<15); /* alt0 */
>>>> > > >> > - BCM2835_REG(BCM2835_GPIO_GPFSEL1) =
>>>> gpio_reg;
>>>> > > >> > - BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
>>>> > > >> > - usart_delay(150);
>>>> > > >> > - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) =
>>>> > (1<<14)|(1<<15);
>>>> > > >> > - usart_delay(150);
>>>> > > >> > - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>>>> > > >> > - ** Init the PL011 UART
>>>> > > >> > - BCM2835_REG(BCM2835_UART0_CR) = 0;
>>>> > > >> > - BCM2835_REG(BCM2835_UART0_ICR) = 0x7FF;
>>>> > > >> > - BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>>>> > > >> > - BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>>>> > > >> > - BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>>>> > > >> > - BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>>>> > > >> > - BCM2835_REG(BCM2835_UART0_RSRECR) = 0;
>>>> > > >> > - BCM2835_REG(BCM2835_UART0_CR) = 0x301;
>>>> > BCM2835_UART0_IMSC_RX;
>>>> > > >> > - usart_set_baud(minor, 115000);
>>>> > > >> > -static int usart_first_open(int major, int
>>>> > minor, void
>>>> > > *arg)
>>>> > > >> > - rtems_libio_open_close_args_t *oc =
>>>> > > >> > (rtems_libio_open_close_args_t *) arg;
>>>> > > >> > - struct rtems_termios_tty *tty = (struct
>>>> > > rtems_termios_tty *)
>>>> > > >> > oc->iop->data1;
>>>> > > >> > - const console_tbl *ct = Console_Port_Tbl
>>>> [minor];
>>>> > > >> > - console_data *cd = &Console_Port_Data
>>>> [minor];
>>>> > > >> > - cd->termios_data = tty;
>>>> > > >> > - rtems_termios_set_initial_baud(tty,
>>>> ct->ulClock);
>>>> > > >> > - return 0;
>>>> > > >> > -static int usart_last_close(int major, int
>>>> > minor, void
>>>> > > *arg)
>>>> > > >> > - return 0;
>>>> > > >> > -static int usart_read_polled(int minor)
>>>> > > >> > - if (minor == 0) {
>>>> > > >> > - if (((BCM2835_REG(BCM2835_UART0_FR)) &
>>>> > > BCM2835_UART0_FR_RXFE)
>>>> > > >> > == 0) {
>>>> > > >> > - return((BCM2835_REG(BCM2835_UART0_DR))
>>>> > 0xFF );
>>>> > > >> > - } else {
>>>> > > >> > - return -1;
>>>> > > >> > - } else {
>>>> > > >> > - printk("Unknown console minor number:
>>>> %d\n",
>>>> > minor);
>>>> > > >> > - return -1;
>>>> > > >> > -static void usart_write_polled(int minor,
>>>> char c)
>>>> > > >> > - while (1) {
>>>> > > >> > - if ((BCM2835_REG(BCM2835_UART0_FR) &
>>>> > > >> BCM2835_UART0_FR_TXFF) == 0)
>>>> > > >> > - break;
>>>> > > >> > - BCM2835_REG(BCM2835_UART0_DR) = c;
>>>> > > >> > -static ssize_t usart_write_support_polled(
>>>> > > >> > - int minor,
>>>> > > >> > - const char *s,
>>>> > > >> > - size_t n
>>>> > > >> > - ssize_t i = 0;
>>>> > > >> > - for (i = 0; i < n; ++i) {
>>>> > > >> > - usart_write_polled(minor, s [i]);
>>>> > > >> > - return n;
>>>> > > >> > -static int usart_set_attributes(int minor,
>>>> const
>>>> > struct
>>>> > > >> termios *term)
>>>> > > >> > - return -1;
>>>> > > >> > -const console_fns bcm2835_usart_fns = {
>>>> > > >> > - .deviceProbe = libchip_serial_default_probe,
>>>> > > >> > - .deviceFirstOpen = usart_first_open,
>>>> > > >> > - .deviceLastClose = usart_last_close,
>>>> > > >> > - .deviceRead = usart_read_polled,
>>>> > > >> > - .deviceWrite = usart_write_support_polled,
>>>> > > >> > - .deviceInitialize = usart_initialize,
>>>> > > >> > - .deviceWritePolled = usart_write_polled,
>>>> > > >> > - .deviceSetAttributes = usart_set_attributes,
>>>> > > >> > - .deviceOutputUsesInterrupts = false
>>>> > > >> > diff --git
>>>> > a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>>>> > > >> > b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>>>> > > >> > index d0e126699a..9bdb4b115e 100644
>>>> > > >> > --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>>>> > > >> > +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>>>> > > >> > @@ -33,12 +33,29 @@ extern "C" {
>>>> > > >> > #define FB_CONSOLE 0x50492835
>>>> > > >> > -bool fbcons_probe( int minor );
>>>> > > >> > +bool fbcons_probe(
>>>> > > >> > + char c
>>>> > > >> > +void output_char_fb(char c);
>>>> > > >> > +typedef struct {
>>>> > > >> > + rtems_termios_device_context base;
>>>> > > >> > +} rpi_fb_context ;
>>>> > > >> > * Driver function table
>>>> > > >> > -extern const console_fns fbcons_fns;
>>>> > > >> > +extern const rtems_termios_device_handler
>>>> > fbcons_fns;
>>>> > > >> > #ifdef __cplusplus
>>>> > > >> > diff --git
>>>> > a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>>>> b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>>>> > > >> > index 40c80cf408..e052c2becb 100644
>>>> > > >> > @@ -24,6 +24,7 @@
>>>> > > >> > #include <stdint.h>
>>>> > > >> > #include <bsp/utility.h>
>>>> > > >> > * @defgroup raspberrypi_reg Register
>>>> Definitions
>>>> > > >> > @@ -60,6 +61,17 @@
>>>> > > >> > #define RPI_PERIPHERAL_SIZE 0x01000000
>>>> > > >> > + * @name Console select definitions
>>>> > > >> > +#define PL011 0
>>>> > > >> > +#define FB 1
>>>> > > >> > * @name Internal ARM Timer Registers
>>>> > > >> > @@ -184,42 +196,6 @@
>>>> > > >> > - * @name UART 0 (PL011) Registers
>>>> > > >> > -#define BCM2835_UART0_BASE
>>>> > (RPI_PERIPHERAL_BASE
>>>> > > + 0x201000)
>>>> > > >> > -#define BCM2835_UART0_DR
>>>> > (BCM2835_UART0_BASE +
>>>> > > 0x00)
>>>> > > >> > -#define BCM2835_UART0_RSRECR
>>>> > > 0x04)
>>>> > > >> > -#define BCM2835_UART0_FR
>>>> > > 0x18)
>>>> > > >> > -#define BCM2835_UART0_ILPR
>>>> > > 0x20)
>>>> > > >> > -#define BCM2835_UART0_IBRD
>>>> > > 0x24)
>>>> > > >> > -#define BCM2835_UART0_FBRD
>>>> > > 0x28)
>>>> > > >> > -#define BCM2835_UART0_LCRH
>>>> > > 0x2C)
>>>> > > >> > -#define BCM2835_UART0_CR
>>>> > > 0x30)
>>>> > > >> > -#define BCM2835_UART0_IFLS
>>>> > > 0x34)
>>>> > > >> > -#define BCM2835_UART0_IMSC
>>>> > > 0x38)
>>>> > > >> > -#define BCM2835_UART0_RIS
>>>> > > 0x3C)
>>>> > > >> > -#define BCM2835_UART0_MIS
>>>> > > 0x40)
>>>> > > >> > -#define BCM2835_UART0_ICR
>>>> > > 0x44)
>>>> > > >> > -#define BCM2835_UART0_DMACR
>>>> > > 0x48)
>>>> > > >> > -#define BCM2835_UART0_ITCR
>>>> > > 0x80)
>>>> > > >> > -#define BCM2835_UART0_ITIP
>>>> > > 0x84)
>>>> > > >> > -#define BCM2835_UART0_ITOP
>>>> > > 0x88)
>>>> > > >> > -#define BCM2835_UART0_TDR
>>>> > > 0x8C)
>>>> > > >> > -#define BCM2835_UART0_MIS_RX 0x10
>>>> > > >> > -#define BCM2835_UART0_MIS_TX 0x20
>>>> > > >> > -#define BCM2835_UART0_IMSC_RX 0x10
>>>> > > >> > -#define BCM2835_UART0_IMSC_TX 0x20
>>>> > > >> > -#define BCM2835_UART0_FR_RXFE 0x10
>>>> > > >> > -#define BCM2835_UART0_FR_TXFF 0x20
>>>> > > >> > -#define BCM2835_UART0_ICR_RX 0x10
>>>> > > >> > -#define BCM2835_UART0_ICR_TX 0x20
>>>> > > >> > diff --git
>>>> a/bsps/arm/raspberrypi/include/bsp/usart.h
>>>> > > >> > b/bsps/arm/raspberrypi/include/bsp/usart.h
>>>> > > >> > index d3e710c5e9..abbf53626c 100644
>>>> > > >> > --- a/bsps/arm/raspberrypi/include/bsp/usart.h
>>>> > > >> > +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
>>>> > > >> > @@ -32,9 +32,8 @@
>>>> > > >> > extern "C" {
>>>> > > >> > #endif /* __cplusplus */
>>>> > > >> > -#define USART0_DEFAULT_BAUD 115000
>>>> > > >> > -extern const console_fns bcm2835_usart_fns;
>>>> > > >> > +#define PL011_DEFAULT_BAUD 115000
>>>> > > >> > +#define BCM2835_PL011_BASE
>>>> (RPI_PERIPHERAL_BASE +
>>>> > > 0x201000)
>>>> > > >> > #ifdef __cplusplus
>>>> > > >> > diff --git
>>>> > a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>>> > > >> > b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>>> > > >> > index 11a22f89e3..0e0d5bef67 100644
>>>> > > >> > @@ -42,6 +42,7 @@ librtemsbsp_a_SOURCES +=
>>>> > ../../../../../../bsps/shared/start/bspfatal-default.c
>>>> ../../../../../../bsps/shared/dev/cpucounter/cpucounterfrequency.c
>>>> ../../../../../../bsps/shared/dev/cpucounter/cpucounterread.c
>>>> > > >> ../../../../../../bsps/shared/start/sbrk.c
>>>> > > >> > +librtemsbsp_a_SOURCES +=
>>>> > > >> ../../../../../../bsps/shared/start/bsp-fdt.c
>>>> ../../../../../../bsps/shared/start/stackalloc.c
>>>> > ../../../../../../bsps/arm/shared/start/bsp-start-memcpy.S
>>>> ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
>>>> > > >> > @@ -63,14 +64,13 @@ librtemsbsp_a_SOURCES +=
>>>> > ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
>>>> ../../../../../../bsps/arm/raspberrypi/irq/irq.c
>>>> > > >> > # Console
>>>> > > >> > -librtemsbsp_a_SOURCES +=
>>>> > ../../../../../../bsps/shared/dev/serial/legacy-console.c
>>>> ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
>>>> ../../../../../../bsps/arm/raspberrypi/console/console-config.c
>>>> ../../../../../../bsps/arm/raspberrypi/console/console_select.c
>>>> > ../../../../../../bsps/arm/raspberrypi/console/usart.c
>>>> ../../../../../../bsps/arm/raspberrypi/console/fb.c
>>>> > ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
>>>> > ../../../../../../bsps/arm/raspberrypi/console/outch.c
>>>> > ../../../../../../bsps/shared/dev/serial/console-termios.c
>>>> ../../../../../../bsps/shared/dev/serial/console-termios-init.c
>>>> ../../../../../../bsps/arm/shared/serial/arm-pl011.c
>>>> > > >> > # Mailbox
>>>> > ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
>>>> > > >> > 2.17.1
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200101/98949d9c/attachment-0001.html>
