[PATCH v4] Raspberrypi: updated the console interface.
Christian Mauderer list at c-mauderer.de
Tue Dec 31 20:59:56 UTC 2019
On 31/12/2019 19:41, Niteesh wrote:
> On Tue, Dec 31, 2019 at 10:56 PM Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>     On Tue, Dec 31, 2019 at 9:27 PM Niteesh <gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>> wrote:
>         I tried the above thing it doesn't work :(
>         Maybe lets stop with this. And try to get RTEMS working on rpi3
>         this way, it will also be easier for me to work. Did you take a
>         look at what
>         caused the secondary cpu's not to halt? Is there something that
>         I can do?
>         Or shall we continue with this? I kind of feel lost and not at
>         all happy with my progress.
>     Hi Niteesh,
>     (Not commenting on anything technical)
>     Just wanted to add a famous quote:
>     "The first 90 percent of the code accounts for the first 90 percent
>     of the
>     development time. The remaining 10 percent of the code accounts for the
>     other 90 percent of the development time" — Tom Cargill, Bell Labs
>     (Wikipedia explains this well
>     <https://en.wikipedia.org/wiki/Ninety-ninety_rule>)
True. Also I know it as a 90 / 10 rule: 90 percent of the code is
written in 10 percent of the time.
>     It always takes more time and much more debugging than it was
>     originally planned,
>     you have made quite good progress in figuring out stuff and came up
>     with the
>     implementation quite quickly. Seems like all that is left is
>     debugging, and with Christian
>     helping you, that will be solved quickly as well ;-)
>     Happy New year :)
> Great, I hope now we can get it working even faster. I have looked at
> your previous year GSOC
> work, it was great.
+1
>     PS: I have a pi3 as well, and would love to join the efforts on pi3
>     after the exams ;-)
Thanks Vijay. Would be great. By the way: You should think about
becoming a GSoC mentor this year.
> All the best for your exams.
+1
> Happy New year
Happy New year to all of you too (also I still have 2 hours till the new
year here).
>         On Tue, Dec 31, 2019 at 8:29 PM Niteesh <gsnb.gn at gmail.com
>             I have an idea to debug this, but not sure whether it will
>             work or not, I could
>             run raspbian on versatilepb using arm1176 as cpu and 256mb ram
>             this is very much similar to raspi1, I think this one also
>             uses pl011, I remember
>             seeing it in the linux bootup msgs.
>             I could run the examples using qemu using raspi2 as the
>             machine but the dtb
>             file never gets passed to it. The register r2 is 0.
>             qemu-system-arm -M raspi2 -m 1G -kernel fileio.exe -serial
>             mon:stdio -nographic -dtb bcm2709-rpi-2-b.dtb -S -s
>             This is the command I use to run my examples and connect to gdb.
I assume you load your application using gdb too? Then I would suggest
to just load the dtb via gdb too and ignore the -dtb parameter.
Basically the following gdb commands should work:
(gdb) load
(gdb) restore bcm2709-rpi-2-b.dtb binary 0x2ef00000
(gdb) set $r2=0x2ef00000
I checked that on my rpi2: The original bootloader loads the dtb to
0x2eff9900. I'm not sure why it uses such an odd address but I assume
it's calculated somehow. I used one a bit lower than that.
If you don't want to type that stuff every time you might want to add a
"start.gdb" script. That can for example contain the following:
define reset
        monitor system_reset
        load
        set $r2=0x2ef00000
end
target remote :2331
If you now start your gdb with
    arm-rtems5-gdb -x start.gdb path/to/your.exe
you should have a nice "reset" command that just restarts the system.
>             On Tue, Dec 31, 2019 at 7:31 PM Christian Mauderer
>             <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
>                 On 31/12/2019 14:56, Niteesh wrote:
>                 > If moving uart_probe to output char, then should I move
>                 > rtems_device_handler_install to console_initialize
>                 because, my guess
>                 > is that the IO initialization system would not be
>                 initialized properly
>                 > at that stage.
>                 The uart_probe in the output char function should do a
>                 really minimal
>                 initialization. Only what is necessary to get the polled
>                 uart working.
>                 That one will only be called if you have an exception at
>                 a very early
>                 stage. In that case you are working in an exception context.
>                 > When I rename the register_arm_pl011 to
>                 init_context_pl011 since it's is
>                 > only initializing
>                 > the pl011 context, rather than registering it.
>                 > On Tue, Dec 31, 2019 at 6:32 PM Christian Mauderer
>                 <mailto:list at c-mauderer.de>>> wrote:
>                 >     On 31/12/2019 13:22, Niteesh wrote:
>                 >     > It works now, the functions are getting called
>                 when used with
>                 >     fileio.exe.
>                 >     > The function bsp_start wants to print
>                 information about the board,
>                 >     That print maybe should be moved to a later point.
>                 It just fetches some
>                 >     information and prints it. It doesn't even do
>                 anything usefull
>                 >     besides that.
>                 >     > but
>                 >     > the console
>                 >     > initialization function is called after
>                 bsp_start, assuming that
>                 >     the FDT
>                 >     > works it still
>                 >     > crash since the console still isn't initialized,
>                 one way of fixing
>                 >     this
>                 >     > would be to add uart_probe into
>                 >     > output_char just like in imx, or we could move
>                 the printing to
>                 >     somewhere
>                 >     > else.
>                 >     That might would be a good idea regardless whether
>                 the print is moved or
>                 >     not. It would allow an early exception to print
>                 anything.
>                 >     > On Tue, Dec 31, 2019 at 4:08 PM Christian Mauderer
>                 <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>
>                 >     > <mailto:list at c-mauderer.de
>                 <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>                 <mailto:list at c-mauderer.de>>>> wrote:
>                 >     >     On 31/12/2019 11:37, Christian Mauderer wrote:
>                 >     >     > On 31/12/2019 06:11, Niteesh wrote:
>                 >     >     >> On Tue, Dec 31, 2019 at 1:13 AM Christian
>                 Mauderer
>                 >     >     <list at c-mauderer.de
>                 >     >     >> <mailto:list at c-mauderer.de
>                 <mailto:list at c-mauderer.de>>>>> wrote:
>                 >     >     >>     On 30/12/2019 19:32, Niteesh wrote:
>                 >     >     >>     > Just to make sure that
>                 console_initialize and uart_probe
>                 >     >     are being
>                 >     >     >>     > called, I manually initialized the
>                 pl011 context to print
>                 >     >     something on
>                 >     >     >>     > serial. But they never got called.
>                 Can you just make sure
>                 >     >     that if I am
>                 >     >     >>     > missing something?
>                 >     >     >>     I don't think that you are missing
>                 something but the
>                 >     >     executable is
>                 >     >     >>     missing something: The functions are
>                 not linked into it.
>                 >     >     >>     C linker can be an odd thing: It
>                 links only object
>                 >     files that are
>                 >     >     >>     referenced. You seem to have no
>                 reference to
>                 >     >     console-config.c/o from
>                 >     >     >>     anywhere else.
>                 >     >     >>     RTEMS_SYSINIT_ITEM(
>                 >     >     >>       uart_probe,
>                 >     >     >>       RTEMS_SYSINIT_BSP_START,
>                 >     >     >>       RTEMS_SYSINIT_ORDER_LAST
>                 >     >     >>     will be only added to the linker set
>                 if the file is
>                 >     linked in
>                 >     >     anyway.
>                 >     >     >>     That is a bit anoying. For the imx
>                 BSP there is a UART
>                 >     drain
>                 >     >     function
>                 >     >     >>     that is called from somewhere else.
>                 Thats enough to
>                 >     bring the
>                 >     >     file in.
>                 >     >     >>     I think you'll need to add a
>                 reference from somewhere
>                 >     or move
>                 >     >     that stuff
>                 >     >     >>     into another file that is referenced.
>                 >     >     >>     If you have some init function that
>                 has to be called in
>                 >     every
>                 >     >     case you
>                 >     >     >>     can call it from some other c file
>                 where it would fit too.
>                 >     >     >>     Otherwise it might is necessary to
>                 construct some odd
>                 >     stuff.
>                 >     >     I'm not
>                 >     >     >>     sure whether we already had a case
>                 like this. Most
>                 >     likely it
>                 >     >     would be
>                 >     >     >>     necessary to use a
>                 RTEMS_LINKER_ROSET_ITEM_REFERENCE
>                 >     for the
>                 >     >     >>     SYSINIT_ITEM. Maybe to define a new
>                 >     >     RTEMS_SYSINIT_ITEM_REFERENCE or
>                 >     >     >>     simmilar. This should be definitively
>                 a separate commit.
>                 >     >     Please ask
>                 >     >     >>     again if you have to go that way.
>                 >     >     >> I didn't understand the above part. So
>                 what I did was
>                 >     created a dummy
>                 >     >     >> function in console-config.c
>                 >     >     >> and referenced in places that I know
>                 we're going to be
>                 >     called. But
>                 >     >     >> still, it didn't work.
>                 >     >     > That's a really mean bug to find:
>                 >     >     > 1. My assumption was wrong. The file is
>                 linked in. Most
>                 >     likely due to
>                 >     >     > BSP_output_char which is defined in this file.
>                 >     >     > 2. Please remove console-termios-init.c.
>                 It would define the
>                 >     same
>                 >     >     > console_initialize() function.
>                 >     >     Just to be clear: Remove it from the
>                 >     >     c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>                 file.
>                 >     >     > 3. The real proble just caused a warning
>                 which was a bit
>                 >     hard to spot:
>                 >     >     > The compile doesn't know
>                 RTEMS_SYSINIT_ITEM. It thinks it's
>                 >     a function
>                 >     >     > body and warns that it defaults the return
>                 type to int. In other
>                 >     >     words:
>                 >     >     > You missed to include <rtems/sysinit.h>.
>                 If you add that the
>                 >     >     > RTEMS_SYSINIT_ITEM works and uart_probe is
>                 linked in.
>                 >     >     > 4. console_initialize is still not used.
>                 It is really hard
>                 >     to spot
>                 >     >     why:
>                 >     >     > Most of the tests only use the configuration:
>                  CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
>                 >     >     > This is a simplified polled console
>                 driver. From the samples
>                 >     only
>                 >     >     > capture, fileio and pppd are using the
>                 normal console with:
>                 >     >     >     CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>                 >     >     > So only for these three the
>                 console_initialize will be called.
>                 >     >     > By the way: You can use objdump to analyze
>                 your elf-files.
>                 >     For example
>                 >     >     > to get a symbol table use:
>                 >     >     >     arm-rtems5-objdump -t path/to/ticker.exe
>                 >     >     > To get the disassembled code with
>                 intermixed c-sources use
>                 >     >     >     arm-rtems5-objdump -dS path/to/ticker.exe
>                 >     >     > That's very usefull to find whether a
>                 symbol is linked in or
>                 >     not.
>                 >     >     >>     > While going through the messages
>                 from devel-request, Joel
>                 >     >     mentioned
>                 >     >     >>     > about qemu4 rsb package
>                 >     >     >>     > how is it different from the
>                 official qemu?
>                 >     >     >>     > On Mon, Dec 30, 2019 at 11:53 PM G
>                 S Niteesh
>                 >     >     <gsnb.gn at gmail.com
>                 <mailto:gsnb.gn at gmail.com> <mailto:gsnb.gn at gmail.com
>                 <mailto:gsnb.gn at gmail.com>>>
>                 >     >     >>     <mailto:gsnb.gn at gmail.com
>                 <mailto:gsnb.gn at gmail.com>>>>
>                 >     >     >>     > <mailto:gsnb.gn at gmail.com
>                 <mailto:gsnb.gn at gmail.com>>>>>> wrote:
>                 >     >     >>     >     The patch updates the older
>                 console interface used by
>                 >     >     the BSP,
>                 >     >     >>     >     to newer one. It also replaces
>                 the custom
>                 >     usart(PL011)
>                 >     >     driver
>                 >     >     >>     >     with arm-pl011. The fb
>                 function's signatures
>                 >     where also
>                 >     >     changed
>                 >     >     >>     >     to accommodate with interface
>                 update.
>                 >     >     >>     >     Update #3034
>                   bsps/arm/raspberrypi/console/console-config.c | 186
>                   bsps/arm/raspberrypi/console/console_select.c | 114
>                   bsps/arm/raspberrypi/console/fbcons.c         |  78
>                   bsps/arm/raspberrypi/console/usart.c          | 167
>                   bsps/arm/raspberrypi/include/bsp/fbcons.h     |
>                 >     21 +-
>                   .../arm/raspberrypi/include/bsp/raspberrypi.h |
>                 >     48 ++---
>                   bsps/arm/raspberrypi/include/bsp/usart.h      |
>                 >      5 +-
>                   c/src/lib/libbsp/arm/raspberrypi/Makefile.am  |
>                 >      8 +-
>                 >     >     >>     >      8 files changed, 220
>                 insertions(+), 407 deletions(-)
>                 >     >     >>     >      delete mode 100644
>                 >     >     bsps/arm/raspberrypi/console/console_select.c
>                 >     >     >>     >     diff --git
>                 >     a/bsps/arm/raspberrypi/console/console-config.c
>                  b/bsps/arm/raspberrypi/console/console-config.c
>                 >     >     >>     >     index d2186c918b..021428ff4b 100644
>                 >     >     >>     >     @@ -19,50 +19,164 @@
>                 >     >     >>     >      #include <rtems/bspIo.h>
>                 >     >     >>     >     +#include <rtems/console.h>
>                 >     >     >>     >     -#include <libchip/serial.h>
>                 >     >     >>     >     -#include <bspopts.h>
>                 >     >     >>     >     -#include <bsp/irq.h>
>                 >     >     >>     >     -#include <bsp/usart.h>
>                 >     >     >>     >     +#include <bsp.h>
>                 >     >     >>     >      #include <bsp/raspberrypi.h>
>                 >     >     >>     >     +#include <bsp/usart.h>
>                 >     >     >>     >     +#include <bsp/arm-pl011.h>
>                 >     >     >>     >      #include <bsp/fbcons.h>
>                 >     >     >>     >     +#include <bsp/console-termios.h>
>                 >     >     >>     >     +#include <bsp/fdt.h>
>                 >     >     >>     >     +#include <bsp/fatal.h>
>                 >     >     >>     >     +#include <bspopts.h>
>                 >     >     >>     >     +#include <libfdt.h>
>                 >     >     >>     >     +#include <libchip/serial.h>
>                 >     >     >>     >     +arm_pl011_context pl011_context;
>                 >     >     >>     >     +rpi_fb_context fb_context;
>                 >     >     >>     These could be static.
>                 >     >     >>     >     +static void
>                 output_char_serial(char c)
>                 arm_pl011_write_polled(&pl011_context.base, c);
>                 >     >     >>     >     +void output_char_fb(char c)
>                 fbcons_write_polled(&fb_context.base, c);
>                 >     >     >>     >     -console_tbl
>                 Console_Configuration_Ports [] = {
>                 >     >     >>     >     -      .sDeviceName = "/dev/ttyS0",
>                 >     >     >>     >     -      .deviceType = SERIAL_CUSTOM,
>                 >     >     >>     >     -      .pDeviceFns =
>                 &bcm2835_usart_fns,
>                 >     >     >>     >     -      .deviceProbe = NULL,
>                 >     >     >>     >     -      .pDeviceFlow = NULL,
>                 >     >     >>     >     -      .ulCtrlPort1 =
>                 BCM2835_UART0_BASE,
>                 >     >     >>     >     -      .ulCtrlPort2 = 0,
>                 >     >     >>     >     -      .ulClock =
>                 USART0_DEFAULT_BAUD,
>                 >     >     >>     >     -      .ulIntVector =
>                 BCM2835_IRQ_ID_UART
>                 >     >     >>     >     -      .sDeviceName ="/dev/fbcons",
>                 >     >     >>     >     -      .pDeviceFns = &fbcons_fns,
>                 >     >     >>     >     -      .deviceProbe = fbcons_probe,
>                 >     >     >>     >     -#define PORT_COUNT \
>                 (sizeof(Console_Configuration_Ports) \
>                 sizeof(Console_Configuration_Ports [0]))
>                 >     >     >>     >     -unsigned long
>                 Console_Configuration_Count =
>                 >     PORT_COUNT;
>                 >     >     >>     >     -static void output_char(char c)
>                 >     >     >>     >     +static void
>                 *get_reg_of_node(const void *fdt,
>                 >     int node)
>                 >     >     >>     >     -  const console_fns *con =
>                 >     >     >>     >     -    Console_Configuration_Ports
>                 >     >     [Console_Port_Minor].pDeviceFns;
>                 >     >     >>     >     +  int len;
>                 >     >     >>     >     +  const uint32_t *val;
>                 >     >     >>     >     +  val = fdt_getprop(fdt, node,
>                 "reg", &len);
>                 >     >     >>     >     +  if (val == NULL || len < 4) {
>                 >     >     >>     >     +    return NULL;
>                 >     >     >>     >     -  con->deviceWritePolled((int)
>                 >     Console_Port_Minor, c);
>                 >     >     >>     >     +  return (void *)
>                 fdt32_to_cpu(val[0]);
>                 >     >     >>     >     -BSP_output_char_function_type
>                 BSP_output_char =
>                 >     >     output_char;
>                 >     >     >>     >     +static void register_arm_pl011(
>                 >     >     >>     >     +  const void *fdt,
>                 >     >     >>     >     +  const char *serial
>                 >     >     >>     >     +  arm_pl011_context *ctx =
>                 &pl011_context;
>                 >     >     >>     >     +  int node;
>                 >     >     >>     >     +  if (strcmp(serial, "uart0")
>                 == 0) {
>                  rtems_termios_device_context_initialize(&ctx->base,
>                 "UART");
>                 >     >     >>     >     +    node =
>                 fdt_path_offset(fdt, serial);
>                 >     >     >>     >     +    ctx->regs =
>                 get_reg_of_node(fdt, node);
>                 >     >     >>     >     +  rtems_termios_device_install(
>                 >     >     >>     >     +    "/dev/ttyuart0",
>                 >     >     >>     >     +    &arm_pl011_fns,
>                 >     >     >>     >     +    NULL,
>                 >     >     >>     >     +    &pl011_context.base
>                 >     >     >>     >     +static void register_fb( void )
>                 >     >     >>     >     +  if
>                 (fbcons_probe(&fb_context.base) == true) {
>                 >     >     >>     >     +      "/dev/fbcons",
>                 >     >     >>     >     +      &fbcons_fns,
>                 >     >     >>     >     +      NULL,
>                 >     >     >>     >     +      &fb_context.base);
>                 >     >     >>     >     +static void console_select(
>                 const char *console )
>                 >     >     >>     >     +  const char *opt;
>                 >     >     >>     >     +  opt =
>                 rpi_cmdline_get_arg("--console=");
>                 >     >     >>     >     +  if ( opt ) {
>                 >     >     >>     >     +    if ( strncmp( opt,
>                 "fbcons", sizeof(
>                 >     "fbcons" ) -
>                 >     >     1 ) ==
>                 >     >     >>     0 ) {
>                 >     >     >>     >     +      if (
>                 rpi_video_is_initialized() > 0 ) {
>                 >     >     >>     >     +        BSP_output_char =
>                 output_char_fb;
>                 >     >     >>     >     +        link("/dev/fbcons",
>                 CONSOLE_DEVICE_NAME);
>                 >     >     >>     >     +    }else{
>                 >     >     >>     >     +      if ( console == NULL ){
>                 >     >     >>     >     +        bsp_fatal(
>                 BSP_FATAL_CONSOLE_NO_DEV );
>                 output_char_serial;
>                 >     >     >>     >     +      link("/dev/ttyuart0",
>                 >     >     >>     >     +static void uart_probe(void)
>                 >     >     >>     >     +  const void *fdt;
>                 >     >     >>     >     +  const char *console;
>                 >     >     >>     >     +  int node;
>                 >     >     >>     >     +  fdt = bsp_fdt_get();
>                 >     >     >>     >     +  node = fdt_path_offset(fdt,
>                 "/chosen");
>                 >     >     >>     >     +  console = fdt_getprop(fdt, node,
>                 >     "stdout-path", NULL);
>                 "/aliases");
>                 >     >     >>     >     +  int offset =
>                 fdt_first_property_offset(fdt, node);
>                 >     >     >>     >     +  while (offset >= 0) {
>                 >     >     >>     >     +    const struct fdt_property
>                 *prop;
>                 >     >     >>     >     +    prop =
>                 fdt_get_property_by_offset(fdt,
>                 >     offset, NULL);
>                 >     >     >>     >     +    if (prop != NULL) {
>                 >     >     >>     >     +      const char *name;
>                 >     >     >>     >     +      name = fdt_string(fdt,
>                 >     fdt32_to_cpu(prop->nameoff));
>                 >     >     >>     >     +      if(strstr(name,
>                 "serial") != NULL) {
>                 >     >     >>     >     +        const char *serial;
>                 >     >     >>     >     +        serial = prop->data;
>                 register_arm_pl011(fdt, serial);
>                 >     >     >>     >     +    offset =
>                 fdt_next_property_offset(fdt, offset);
>                 >     >     >>     >     +  console_select(console);
>                 >     >     >>     >     +rtems_status_code
>                 console_initialize(
>                 >     >     >>     >     +  rtems_device_major_number major,
>                 >     >     >>     >     +  rtems_device_minor_number minor,
>                 >     >     >>     >     +  void *arg
>                 >     >     >>     >     +  rtems_termios_initialize();
>                 >     >     >>     >     +  uart_probe();
>                 >     >     >>     >     +  register_fb();
>                 >     >     >>     >     +  return RTEMS_SUCCESSFUL;
>                 >     >     >>     >     +BSP_output_char_function_type
>                 BSP_output_char =
>                 >     >     >>     output_char_serial;
>                   BSP_polling_getchar_function_type BSP_poll_char
>                 >     = NULL;
>                 >     >     >>     >     +RTEMS_SYSINIT_ITEM(
>                 >     >     >>     >     +  uart_probe,
>                 >     >     >>     >     +  RTEMS_SYSINIT_BSP_START,
>                 >     >     >>     >     +  RTEMS_SYSINIT_ORDER_LAST
>                 >     >     >>     >     \ No newline at end of file
>                 >     >     >>     >     diff --git
>                 >     a/bsps/arm/raspberrypi/console/console_select.c
>                  b/bsps/arm/raspberrypi/console/console_select.c
>                 >     >     >>     >     deleted file mode 100644
>                 >     >     >>     >     index bd246ca868..0000000000
>                 >     >     >>     >     +++ /dev/null
>                 >     >     >>     >     @@ -1,114 +0,0 @@
>                 >     >     >>     >     - * @file
>                 >     >     >>     >     - * @ingroup raspberrypi_console
>                 >     >     >>     >     - * @brief console select
>                 >     >     >>     >     - * Copyright (c) 2015 Yang Qiao
>                 >     >     >>     >     - *  The license and
>                 distribution terms for this file
>                 >     >     may be
>                 >     >     >>     >     - *  found in the file LICENSE
>                 in this
>                 >     distribution or at
>                 http://www.rtems.org/license/LICENSE
>                 >     >     >>     >     -#include <bsp.h>
>                 >     >     >>     >     -#include <bsp/fatal.h>
>                 >     >     >>     >     -#include <rtems/libio.h>
>                 >     >     >>     >     -#include <stdlib.h>
>                 >     >     >>     >     -#include <string.h>
>                 >     >     >>     >     -#include <assert.h>
>                 >     >     >>     >     -#include <termios.h>
>                 >     >     >>     >     -#include <rtems/termiostypes.h>
>                 >     >     >>     >     -#include
>                 "../../shared/dev/serial/legacy-console.h"
>                 >     >     >>     >     -#include <bsp/rpi-fb.h>
>                 >     >     >>     >     -rtems_device_minor_number
>                 BSPPrintkPort = 0;
>                 >     >     >>     >     - * Method to return true if
>                 the device
>                 >     associated with the
>                 >     >     >>     >     - * minor number probs available.
>                 >     >     >>     >     -static bool bsp_Is_Available(
>                 >     >     rtems_device_minor_number minor )
>                 >     >     >>     >     -  console_tbl *cptr =
>                 Console_Port_Tbl[ minor ];
>                 >     >     >>     >     -   * First perform the
>                 configuration dependent
>                 >     probe,
>                 >     >     then the
>                 >     >     >>     >     -   * device dependent probe
>                 >     >     >>     >     -  if ( ( !cptr->deviceProbe ||
>                 cptr->deviceProbe(
>                 >     >     minor ) ) &&
>                  cptr->pDeviceFns->deviceProbe( minor ) ) {
>                 >     >     >>     >     -    return true;
>                 >     >     >>     >     -  return false;
>                 >     >     >>     >     - * Method to return the first
>                 available device.
>                 >     >     >>     >     -static rtems_device_minor_number
>                 >     >     bsp_First_Available_Device(
>                 >     >     >>     void )
>                 >     >     >>     >     -  rtems_device_minor_number minor;
>                 >     >     >>     >     -  for ( minor = 0; minor <
>                 Console_Port_Count;
>                 >     minor++ ) {
>                 >     >     probe, then the
>                 || cptr->deviceProbe(
>                 >     >     minor ) ) &&
>                 >     >     >>     >     -      return minor;
>                 >     >     >>     >     -   *  Error No devices were
>                 found.  We will want to
>                 >     >     bail here.
>                 >     >     >>     >     -  bsp_fatal(
>                 >     >     >>     >     -void bsp_console_select( void )
>                 >     >     >>     >     -   *  Reset Console_Port_Minor and
>                 >     >     >>     >     -   *  BSPPrintkPort here if
>                 desired.
>                 >     >     >>     >     -   *  This default version
>                 allows the bsp to set
>                 >     these
>                 >     >     >>     >     -   *  values at creation and
>                 will not touch them
>                 >     again
>                 >     >     >>     >     -   *  unless the selected port
>                 number is not
>                 >     available.
>                 >     >     >>     >     -  const char *opt;
>                 >     >     >>     >     -  Console_Port_Minor =
>                 BSP_CONSOLE_UART0;
>                 >     >     >>     >     -  BSPPrintkPort =
>                 BSP_CONSOLE_UART0;
>                 >     >     >>     >     -  opt = rpi_cmdline_get_arg(
>                 "--console=" );
>                 >     >     >>     >     -  if ( opt ) {
>                 >     >     >>     >     -    if ( strncmp( opt,
>                 "fbcons", sizeof(
>                 >     "fbcons" ) -
>                 >     >     1 ) ==
>                 >     >     >>     0 ) {
>                 >     >     >>     >     -      if (
>                 BSP_CONSOLE_FB;
>                 BSP_CONSOLE_FB;
>                 >     >     >>     >     -   * If the device that was
>                 selected isn't
>                 >     available then
>                 >     >     >>     >     -   * let the user know and
>                 select the first
>                 >     available
>                 >     >     device.
>                 >     >     >>     >     -  if ( !bsp_Is_Available(
>                 Console_Port_Minor ) ) {
>                 >     bsp_First_Available_Device();
>                 >     >     >>     >     diff --git
>                 a/bsps/arm/raspberrypi/console/fbcons.c
>                  b/bsps/arm/raspberrypi/console/fbcons.c
>                 >     >     >>     >     index 3669ba458d..0e6a430c54 100644
>                 >     >     >>     >     @@ -18,6 +18,7 @@
>                 >     >     >>     >      #include <rtems.h>
>                 >     >     >>     >      #include <rtems/libio.h>
>                 >     >     >>     >     +#include <rtems/termiostypes.h>
>                 >     >     >>     >      #include <stdlib.h>
>                 >     >     >>     >     @@ -29,15 +30,6 @@
>                 >     >     >>     >      #include <bsp/vc.h>
>                 >     >     >>     >      #include <bsp/rpi-fb.h>
>                 >     >     >>     >     - *  fbcons_init
>                 >     >     >>     >     - *  This function initializes
>                 the fb console to a
>                 >     >     quiecsent
>                 >     >     >>     state.
>                 >     >     >>     >     -static void fbcons_init( int
>                 minor )
>                 >     >     >>     >       *  fbcons_open
>                 >     >     >>     >     @@ -45,13 +37,14 @@ static void
>                 fbcons_init( int
>                 >     minor )
>                 >     >     >>     >       *  Default state is 9600
>                 baud, 8 bits, No
>                 >     parity, and
>                 >     >     1 stop
>                 >     >     >>     bit.
>                 >     >     >>     >     -static int fbcons_open(
>                 >     >     >>     >     -  int   major,
>                 >     >     >>     >     -  int   minor,
>                 >     >     >>     >     -  void *arg
>                 >     >     >>     >     +static bool fbcons_open(
>                 >     >     >>     >     +  struct rtems_termios_tty *tty,
>                 >     >     >>     >     +  rtems_termios_device_context
>                 *base,
>                 >     >     >>     >     +  struct termios *term,
>                 rtems_libio_open_close_args_t *args
>                 >     >     >>     >     -  return RTEMS_SUCCESSFUL;
>                 >     >     >>     >     +  return true;
>                 >     >     >>     >     @@ -59,13 +52,12 @@ static int
>                 fbcons_open(
>                 >     >     >>     >       *  This function shuts down
>                 the requested port.
>                 >     >     >>     >     -static int fbcons_close(
>                 >     >     >>     >     -  int   major,
>                 >     >     >>     >     -  int   minor,
>                 >     >     >>     >     -  void *arg
>                 >     >     >>     >     +static void fbcons_close(
>                 *base,
>                 >     >     >>     >     -  return ( RTEMS_SUCCESSFUL );
>                 >     >     >>     >     @@ -73,8 +65,8 @@ static int
>                 fbcons_close(
>                 >     >     >>     >       *  This routine polls out the
>                 requested character.
>                 >     >     >>     >     -static void fbcons_write_polled(
>                 >     >     >>     >     -  int  minor,
>                 >     >     >>     >     +void fbcons_write_polled(
>                 *base,
>                 >     >     >>     >        char c
>                 >     >     >>     >     @@ -90,8 +82,8 @@ static void
>                 >     >     >>     >       *  Console Termios output
>                 entry point when using
>                 >     >     polled output.
>                 >     >     >>     >     -static ssize_t
>                 fbcons_write_support_polled(
>                 >     >     >>     >     -  int         minor,
>                 >     >     >>     >     +static void
>                 *base,
>                 >     >     >>     >        const char *buf,
>                 >     >     >>     >        size_t      len
>                 >     >     >>     >     @@ -102,14 +94,9 @@ static ssize_t
>                 >     >     fbcons_write_support_polled(
>                 >     >     >>     >         * poll each byte in the
>                 string out of the port.
>                 >     >     >>     >        while ( nwrite < len ) {
>                 >     >     >>     >     -    fbcons_write_polled(
>                 minor, *buf++ );
>                 >     >     >>     >     +    fbcons_write_polled( base,
>                 *buf++ );
>                 >     >     >>     >          nwrite++;
>                 >     >     >>     >     -   * return the number of
>                 bytes written.
>                 >     >     >>     >     -  return nwrite;
>                 >     >     >>     >     @@ -117,7 +104,9 @@ static ssize_t
>                 >     >     >>     >       *  Console Termios polling
>                 input entry point.
>                 >     >     >>     >     -static int
>                 fbcons_inbyte_nonblocking_polled( int
>                 >     minor )
>                 >     >     >>     >     +int
>                 *base
>                 >     >     >>     >        // if( rtems_kbpoll() ) {
>                 >     >     >>     >        //   int c = getch();
>                 >     >     >>     >     @@ -133,15 +122,17 @@ static int
>                 >     >     fbcons_inbyte_nonblocking_polled(
>                 >     >     >>     >     int minor )
>                 >     >     >>     >       *  This function sets the
>                 UART channel to
>                 >     reflect the
>                 >     >     requested
>                 >     >     >>     >     termios
>                 >     >     >>     >       *  port settings.
>                 >     >     >>     >     -static int fbcons_set_attributes(
>                 >     >     >>     >     -  int                   minor,
>                 >     >     >>     >     +static bool fbcons_set_attributes(
>                 *base,
>                 >     >     >>     >        const struct termios *t
>                 >     >     >>     >     -  return 0;
>                 >     >     >>     >     -bool fbcons_probe( int minor )
>                 >     >     >>     >     +bool fbcons_probe(
>                 *context
>                 >     >     >>     >        // rtems_status_code status;
>                 >     >     >>     >        static bool firstTime = true;
>                 >     >     >>     >     @@ -163,15 +154,12 @@ bool
>                 >     >     >>     >        return ret;
>                 >     >     >>     >     -const console_fns fbcons_fns =
>                 >     >     >>     >     +const
>                 rtems_termios_device_handler fbcons_fns =
>                 libchip_serial_default_probe,
>                 >     >     >>     deviceProbe */
>                 >     >     >>     >     -  .deviceFirstOpen =
>                 fbcons_open,                 /*
>                 >     >     >>     deviceFirstOpen */
>                 >     >     >>     >     -  .deviceLastClose =
>                 fbcons_close,                /*
>                 >     >     >>     deviceLastClose */
>                 >     >     >>     >     -  .deviceRead =
>                 fbcons_inbyte_nonblocking_polled, /*
>                 >     >     >>     deviceRead */
>                 >     >     >>     >     -  .deviceWrite =
>                 fbcons_write_support_polled,     /*
>                 >     >     >>     deviceWrite */
>                 >     >     >>     >     -  .deviceInitialize =
>                 fbcons_init,                /*
>                 >     >     >>     >     deviceInitialize */
>                 >     >     >>     >     -  .deviceWritePolled =
>                 fbcons_write_polled,       /*
>                 >     >     >>     >     deviceWritePolled */
>                 >     >     >>     >     -  .deviceSetAttributes =
>                 fbcons_set_attributes,   /*
>                 >     >     >>     >     deviceSetAttributes */
>                 >     >     >>     >     -  .deviceOutputUsesInterrupts
>                 = FALSE,           /*
>                 >     >     >>     >     deviceOutputUsesInterrupts*/
>                 >     >     >>     >     +  .first_open = fbcons_open,
>                 >     >     >>     >     +  .last_close = fbcons_close,
>                 >     >     >>     >     +  .poll_read =
>                 >     >     >>     >     +  .write =
>                 >     >     >>     >     +  .set_attributes =
>                 >     >     >>     >     +  .mode = TERMIOS_POLLED
>                 >     >     >>     >     diff --git
>                 a/bsps/arm/raspberrypi/console/usart.c
>                  b/bsps/arm/raspberrypi/console/usart.c
>                 >     >     >>     >     index 25fb523621..0000000000
>                 >     >     >>     >     @@ -1,167 +0,0 @@
>                 >     >     >>     >     - * @file
>                 >     >     >>     >     - * @ingroup raspberrypi_usart
>                 >     >     >>     >     - * @brief USART support.
>                 >     >     >>     >     - * Copyright (c) 2013 Alan Cudmore
>                 >     >     may be
>                 in this
>                 >     distribution or at
>                 >     >     >>     >     -#include <libchip/sersupp.h>
>                 >     >     >>     >     -#include <bsp/raspberrypi.h>
>                 >     >     >>     >     -#include <rtems/bspIo.h>
>                 >     >     >>     >     -static void
>                 usart_delay(uint32_t n)
>                 >     >     >>     >     - volatile uint32_t i = 0;
>                 >     >     >>     >     - for(i = 0; i < n; i++)
>                 >     >     >>     >     -#if 0
>                 >     >     >>     >     - *  These will be useful when
>                 the driver supports
>                 >     >     interrupt
>                 >     >     >>     driven IO.
>                 >     >     >>     >     -static rtems_vector_number
>                 >     usart_get_irq_number(const
>                 >     >     >>     console_tbl *ct)
>                 >     >     >>     >     -  return ct->ulIntVector;
>                 >     >     >>     >     -static uint32_t
>                 usart_get_baud(const console_tbl
>                 >     *ct)
>                 >     >     >>     >     -  return ct->ulClock;
>                 >     >     >>     >     -#endif
>                 >     >     >>     >     -static void usart_set_baud(int
>                 minor, int baud)
>                 >     >     >>     >     -  * Nothing for now
>                 >     >     >>     >     - return;
>                 >     >     >>     >     -static void
>                 usart_initialize(int minor)
>                 >     >     >>     >     -  unsigned int gpio_reg;
>                 >     >     >>     >     -  ** Program GPIO pins for UART 0
>                 >     >     >>     >     -  gpio_reg =
>                 BCM2835_REG(BCM2835_GPIO_GPFSEL1);
>                 >     >     >>     >     -  gpio_reg &= ~(7<<12);    /*
>                 gpio14 */
>                 >     >     >>     >     -  gpio_reg |=  (4<<12);    /*
>                 alt0   */
>                 >     >     >>     >     -  gpio_reg &= ~(7<<15);    /*
>                 gpio15 */
>                 >     >     >>     >     -  gpio_reg |=  (4<<15);    /*
>                 alt0   */
>                 BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
>                 BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
>                 >     >     >>     >     -  usart_delay(150);
>                 BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) =
>                 >     (1<<14)|(1<<15);
>                 BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>                 >     >     >>     >     -  ** Init the PL011 UART
>                 BCM2835_REG(BCM2835_UART0_CR)   = 0;
>                 BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>                 BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>                 BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>                 BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>                 BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>                 BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>                 BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>                 >     BCM2835_UART0_IMSC_RX;
>                 >     >     >>     >     -  usart_set_baud(minor, 115000);
>                 >     >     >>     >     -static int
>                 usart_first_open(int major, int
>                 >     minor, void
>                 >     >     *arg)
>                 rtems_libio_open_close_args_t *oc =
>                 >     >     >>     >     (rtems_libio_open_close_args_t
>                 *) arg;
>                 >     >     >>     >     -  struct rtems_termios_tty
>                 *tty = (struct
>                 >     >     rtems_termios_tty *)
>                 >     >     >>     >     oc->iop->data1;
>                 >     >     >>     >     -  const console_tbl *ct =
>                 Console_Port_Tbl [minor];
>                 >     >     >>     >     -  console_data *cd =
>                 &Console_Port_Data [minor];
>                 >     >     >>     >     -  cd->termios_data = tty;
>                 rtems_termios_set_initial_baud(tty, ct->ulClock);
>                 >     >     >>     >     -  return 0;
>                 >     >     >>     >     -static int
>                 usart_last_close(int major, int
>                 >     minor, void
>                 >     >     *arg)
>                 >     >     >>     >     -  return 0;
>                 >     >     >>     >     -static int
>                 usart_read_polled(int minor)
>                 >     >     >>     >     -  if (minor == 0) {
>                 >     >     >>     >     -    if
>                 (((BCM2835_REG(BCM2835_UART0_FR)) &
>                 >     >     BCM2835_UART0_FR_RXFE)
>                 >     >     >>     >     == 0) {
>                  return((BCM2835_REG(BCM2835_UART0_DR)) &
>                 >     0xFF );
>                 >     >     >>     >     -    } else {
>                 >     >     >>     >     -      return -1;
>                 >     >     >>     >     -  } else {
>                 >     >     >>     >     -    printk("Unknown console
>                 minor number: %d\n",
>                 >     minor);
>                 >     >     >>     >     -    return -1;
>                 >     >     >>     >     -static void
>                 usart_write_polled(int minor, char c)
>                 >     >     >>     >     -   while (1) {
>                 >     >     >>     >     -     if
>                 ((BCM2835_REG(BCM2835_UART0_FR) &
>                 >     >     >>     BCM2835_UART0_FR_TXFF) == 0)
>                 >     >     >>     >     -       break;
>                  BCM2835_REG(BCM2835_UART0_DR) = c;
>                 usart_write_support_polled(
>                 >     >     >>     >     -  int minor,
>                 >     >     >>     >     -  const char *s,
>                 >     >     >>     >     -  size_t n
>                 >     >     >>     >     -  ssize_t i = 0;
>                 >     >     >>     >     -  for (i = 0; i < n; ++i) {
>                 >     >     >>     >     -    usart_write_polled(minor,
>                 s [i]);
>                 >     >     >>     >     -  return n;
>                 >     >     >>     >     -static int
>                 usart_set_attributes(int minor, const
>                 >     struct
>                 >     >     >>     termios *term)
>                 >     >     >>     >     -  return -1;
>                 bcm2835_usart_fns = {
>                 usart_first_open,
>                 usart_last_close,
>                 >     >     >>     >     -  .deviceRead = usart_read_polled,
>                 usart_write_support_polled,
>                 usart_initialize,
>                 usart_write_polled,
>                 usart_set_attributes,
>                 = false
>                 >     >     >>     >     diff --git
>                 >     a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>                  b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>                 >     >     >>     >     index d0e126699a..9bdb4b115e 100644
>                 >     >     >>     >     @@ -33,12 +33,29 @@ extern "C" {
>                 >     >     >>     >      #define FB_CONSOLE 0x50492835
>                 >     >     >>     >     -bool fbcons_probe( int minor );
>                 *base
>                 *base,
>                 >     >     >>     >     +  char c
>                 >     >     >>     >     +int
>                 *base
>                 >     >     >>     >     +void output_char_fb(char c);
>                 >     >     >>     >     +typedef struct {
>                 rtems_termios_device_context base;
>                 >     >     >>     >     +} rpi_fb_context ;
>                 >     >     >>     >       * Driver function table
>                 >     >     >>     >     -extern const console_fns
>                 fbcons_fns;
>                 >     >     >>     >     +extern const
>                 >     fbcons_fns;
>                 >     >     >>     >      #ifdef __cplusplus
>                 >     >     >>     >     diff --git
>                 >     a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>                  b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>                 >     >     >>     >     index 40c80cf408..e052c2becb 100644
>                 >     >     >>     >     @@ -24,6 +24,7 @@
>                 >     >     >>     >      #include <bspopts.h>
>                 >     >     >>     >      #include <stdint.h>
>                 >     >     >>     >      #include <bsp/utility.h>
>                 >     >     >>     >       * @defgroup raspberrypi_reg
>                 Register Definitions
>                 >     >     >>     >     @@ -60,6 +61,17 @@
>                 >     >     >>     >      #define RPI_PERIPHERAL_SIZE
>                      0x01000000
>                 >     >     >>     >     + * @name Console select
>                 definitions
>                 >     >     >>     >     +#define PL011 0
>                 >     >     >>     >     +#define FB    1
>                 >     >     >>     >       * @name Internal ARM Timer
>                 Registers
>                 >     >     >>     >     @@ -184,42 +196,6 @@
>                 >     >     >>     >     - * @name UART 0 (PL011) Registers
>                 >     >     >>     >     -#define BCM2835_UART0_BASE
>                 >      (RPI_PERIPHERAL_BASE
>                 >     >     + 0x201000)
>                 >     >     >>     >     -#define BCM2835_UART0_DR
>                 >      (BCM2835_UART0_BASE +
>                 >     >     0x00)
>                 >     >     >>     >     -#define BCM2835_UART0_RSRECR
>                 >     >     0x04)
>                 >     >     >>     >     -#define BCM2835_UART0_FR
>                 >     >     0x18)
>                 >     >     >>     >     -#define BCM2835_UART0_ILPR
>                 >     >     0x20)
>                 >     >     >>     >     -#define BCM2835_UART0_IBRD
>                 >     >     0x24)
>                 >     >     >>     >     -#define BCM2835_UART0_FBRD
>                 >     >     0x28)
>                 >     >     >>     >     -#define BCM2835_UART0_LCRH
>                 >     >     0x2C)
>                 >     >     >>     >     -#define BCM2835_UART0_CR
>                 >     >     0x30)
>                 >     >     >>     >     -#define BCM2835_UART0_IFLS
>                 >     >     0x34)
>                 >     >     >>     >     -#define BCM2835_UART0_IMSC
>                 >     >     0x38)
>                 >     >     >>     >     -#define BCM2835_UART0_RIS
>                 >     >     0x3C)
>                 >     >     >>     >     -#define BCM2835_UART0_MIS
>                 >     >     0x40)
>                 >     >     >>     >     -#define BCM2835_UART0_ICR
>                 >     >     0x44)
>                 >     >     >>     >     -#define BCM2835_UART0_DMACR
>                 >     >     0x48)
>                 >     >     >>     >     -#define BCM2835_UART0_ITCR
>                 >     >     0x80)
>                 >     >     >>     >     -#define BCM2835_UART0_ITIP
>                 >     >     0x84)
>                 >     >     >>     >     -#define BCM2835_UART0_ITOP
>                 >     >     0x88)
>                 >     >     >>     >     -#define BCM2835_UART0_TDR
>                 >     >     0x8C)
>                 >     >     >>     >     -#define BCM2835_UART0_MIS_RX
>                   0x10
>                 >     >     >>     >     -#define BCM2835_UART0_MIS_TX
>                   0x20
>                 >     >     >>     >     -#define BCM2835_UART0_IMSC_RX
>                  0x10
>                 >     >     >>     >     -#define BCM2835_UART0_IMSC_TX
>                  0x20
>                 >     >     >>     >     -#define BCM2835_UART0_FR_RXFE
>                  0x10
>                 >     >     >>     >     -#define BCM2835_UART0_FR_TXFF
>                  0x20
>                 >     >     >>     >     -#define BCM2835_UART0_ICR_RX
>                   0x10
>                 >     >     >>     >     -#define BCM2835_UART0_ICR_TX
>                   0x20
>                 >     >     >>     >     diff --git
>                 a/bsps/arm/raspberrypi/include/bsp/usart.h
>                  b/bsps/arm/raspberrypi/include/bsp/usart.h
>                 >     >     >>     >     index d3e710c5e9..abbf53626c 100644
>                 >     >     >>     >     @@ -32,9 +32,8 @@
>                 >     >     >>     >      extern "C" {
>                 >     >     >>     >      #endif /* __cplusplus */
>                 >     >     >>     >     -#define USART0_DEFAULT_BAUD 115000
>                 bcm2835_usart_fns;
>                 >     >     >>     >     +#define PL011_DEFAULT_BAUD 115000
>                 >     >     >>     >     +#define BCM2835_PL011_BASE
>                 (RPI_PERIPHERAL_BASE +
>                 >     >     0x201000)
>                 >     >     >>     >     diff --git
>                 >     a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>                  b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>                 >     >     >>     >     index 11a22f89e3..0e0d5bef67 100644
>                 >     >     >>     >     @@ -42,6 +42,7 @@
>                 librtemsbsp_a_SOURCES +=
>                   ../../../../../../bsps/shared/start/bspfatal-default.c
>                 >     >     >>     >      librtemsbsp_a_SOURCES +=
>                    ../../../../../../bsps/shared/dev/cpucounter/cpucounterfrequency.c
>                   ../../../../../../bsps/shared/dev/cpucounter/cpucounterread.c
>                  ../../../../../../bsps/shared/start/sbrk.c
>                 >     >     >>     >     +librtemsbsp_a_SOURCES +=
>                  ../../../../../../bsps/shared/start/bsp-fdt.c
>                  ../../../../../../bsps/shared/start/stackalloc.c
>                   ../../../../../../bsps/arm/shared/start/bsp-start-memcpy.S
>                   ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
>                 >     >     >>     >     @@ -63,14 +64,13 @@
>                   ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
>                  ../../../../../../bsps/arm/raspberrypi/irq/irq.c
>                 >     >     >>     >      # Console
>                 >     >     >>     >     -librtemsbsp_a_SOURCES +=
>                   ../../../../../../bsps/shared/dev/serial/legacy-console.c
>                   ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
>                   ../../../../../../bsps/arm/raspberrypi/console/console-config.c
>                   ../../../../../../bsps/arm/raspberrypi/console/console_select.c
>                   ../../../../../../bsps/arm/raspberrypi/console/usart.c
>                  ../../../../../../bsps/arm/raspberrypi/console/fb.c
>                   ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
>                   ../../../../../../bsps/arm/raspberrypi/console/outch.c
>                   ../../../../../../bsps/shared/dev/serial/console-termios.c
>                   ../../../../../../bsps/shared/dev/serial/console-termios-init.c
>                  ../../../../../../bsps/arm/shared/serial/arm-pl011.c
>                 >     >     >>     >      # Mailbox
>                   ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
>                 >     >     >>     >     2.17.1
>         _______________________________________________
>         devel mailing list
>         devel at rtems.org <mailto:devel at rtems.org>
>         http://lists.rtems.org/mailman/listinfo/devel
