[PATCH] RSB/gdb: upgrade sis to 2.11
Jiri Gaisler jiri at gaisler.se
Mon Feb 4 08:05:27 UTC 2019
On 2/4/19 8:58 AM, Sebastian Huber wrote:
> On 04/02/2019 08:00, Chris Johns wrote:
>> Are you OK if I add this patch to:
>>   https://devel.rtems.org/ticket/3460
>> as an attachment so I can create `rtems-gdb-8.2.1-1.cfg`? I ask because `bfin`
>> is broken with gdb-8.0.1 (in the sim code) on FreeBSD 12.0-p2 ..
>>   https://lists.rtems.org/pipermail/build/2019-February/001775.html
>> A gdb-8.2.1 with this patch builds for the bfin plus all the other architectures
>> in 5/rtems-all.:)
> Could we please update all standard targets to use GDB 8.2.1 in this case?
Sounds reasonable, I think SPARC is using the same git-xyz version as RISC-V ...
