[PATCH v3] Coverage : Add coverage support for RISCV
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Feb 5 16:45:44 UTC 2019
tester/covoar/TargetFactory.cc | 2 +
tester/covoar/Target_riscv.cc | 83 +++++++++++++++++
tester/covoar/Target_riscv.h | 95 ++++++++++++++++++++
tester/covoar/wscript | 3 +-
tester/rtems/testing/bsps/griscv-sis-cov.ini | 40 +++++++++
5 files changed, 222 insertions(+), 1 deletion(-)
create mode 100644 tester/covoar/Target_riscv.cc
create mode 100644 tester/covoar/Target_riscv.h
create mode 100644 tester/rtems/testing/bsps/griscv-sis-cov.ini
diff --git a/tester/covoar/TargetFactory.cc b/tester/covoar/TargetFactory.cc
index fc9c30b..12de94d 100644
--- a/tester/covoar/TargetFactory.cc
+++ b/tester/covoar/TargetFactory.cc
@@ -23,6 +23,7 @@
#include "Target_powerpc.h"
#include "Target_lm32.h"
#include "Target_sparc.h"
+#include "Target_riscv.h"
namespace Target {
@@ -56,6 +57,7 @@ namespace Target {
{ "m68k", Target_m68k_Constructor },
{ "powerpc", Target_powerpc_Constructor },
{ "sparc", Target_sparc_Constructor },
+ { "riscv", Target_riscv_Constructor },
{ "TBD", NULL },
diff --git a/tester/covoar/Target_riscv.cc b/tester/covoar/Target_riscv.cc
new file mode 100644
index 0000000..279dc6a
--- /dev/null
+++ b/tester/covoar/Target_riscv.cc
@@ -0,0 +1,83 @@
+ * RTEMS Tools Project (http://www.rtems.org/)
+ * Copyright 2019 Vijay K. Banerjee <vijaykumar9597 at gmail.com>
+ * All rights reserved.
+ * This file is part of the RTEMS Tools package in 'rtems-tools'.
+ * modification, are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+/*! @file Target_riscv.cc
+ * @brief Target_riscv Implementation
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+namespace Target {
+ Target_riscv::Target_riscv( std::string targetName ):
+ TargetBase( targetName )
+ branchInstructions.push_back("beqz");
+ branchInstructions.push_back("bnez");
+ branchInstructions.push_back("blez");
+ branchInstructions.push_back("bgez");
+ branchInstructions.push_back("bltz");
+ branchInstructions.push_back("bgt");
+ branchInstructions.push_back("bgtz");
+ branchInstructions.push_back("ble");
+ branchInstructions.push_back("bgtu");
+ branchInstructions.push_back("bleu");
+ branchInstructions.sort();
+ Target_riscv::~Target_riscv()
+ bool Target_riscv::isNopLine(
+ const char* const line,
+ int& size
+ if (!strcmp( &line[strlen(line)-3], "nop")){
+ size = 4;
+ return true;
+ return false;
+ TargetBase *Target_riscv_Constructor(
+ std::string targetName
+ return new Target_riscv( targetName );
diff --git a/tester/covoar/Target_riscv.h b/tester/covoar/Target_riscv.h
index 0000000..c1cf7ab
--- /dev/null
+++ b/tester/covoar/Target_riscv.h
@@ -0,0 +1,95 @@
+/*! @file Target_riscv.h
+ * @brief Target_riscv Specification
+ * This file contains the specification of the Target_riscv class.
+#ifndef __TARGET_RISCV_H__
+#define __TARGET_RISCV_H__
+#include <list>
+#include <string>
+#include "TargetBase.h"
+namespace Target {
+ /*! @class Target_riscv
+ * This is the class for the riscv target.
+ class Target_riscv: public TargetBase {
+ public:
+ * Target_riscv constructor
+ Target_riscv( std::string targetName );
+ virtual ~Target_riscv();
+ * This method determines nop instruction.
+ * @param[in] line contains the object dump line to check
+ * @param[out] size is set to the size in bytes of the nop
+ * @return Returns True if the instruction is nop, False otherwise.
+ bool isNopLine(
+ int& size
+ * This method determines if it's a branch instruction
+ * @param[in] instruction
+ * @return Returns True if the instruction is a branch instruction, False otherwise.
+ bool isBranch(
+ const char* const instruction
+ private:
+#endif
diff --git a/tester/covoar/wscript b/tester/covoar/wscript
index a3730ea..6f722c2 100644
--- a/tester/covoar/wscript
+++ b/tester/covoar/wscript
@@ -105,7 +105,8 @@ def build(bld):
'Target_lm32.cc',
'Target_m68k.cc',
'Target_powerpc.cc',
- 'Target_sparc.cc'],
+ 'Target_sparc.cc',
+ 'Target_riscv.cc'],
cflags = ['-O2', '-g', '-Wall'],
cxxflags = ['-std=c++11', '-O2', '-g', '-Wall'],
includes = ['.'] + rtl_includes)
diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini b/tester/rtems/testing/bsps/griscv-sis-cov.ini
index 0000000..060bba7
--- /dev/null
+++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
@@ -0,0 +1,40 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2019 Vijay K. Banerjee (vijaykumar9597 at gmail.com)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The griscv BSP on sis with coverage
+[griscv-sis-cov]
+bsp = griscv-sis
+arch = riscv
+tester = %{_rtscripts}/run.cfg
+target = riscv-rtems5
+bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
+bsp_run_opts = -nouartrx -r -tlim 300 s -m 4 -cov
2.17.2
