[PATCH v3] Coverage : Add coverage support for RISCV
    Vijay Kumar Banerjee
    vijaykumar9597 at gmail.com
    Mon Feb 11 07:04:19 UTC 2019
ping :)
On Tue, 5 Feb 2019 at 22:15, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
>  tester/covoar/TargetFactory.cc               |  2 +
>  tester/covoar/Target_riscv.cc                | 83 +++++++++++++++++
>  tester/covoar/Target_riscv.h                 | 95 ++++++++++++++++++++
>  tester/covoar/wscript                        |  3 +-
>  tester/rtems/testing/bsps/griscv-sis-cov.ini | 40 +++++++++
>  5 files changed, 222 insertions(+), 1 deletion(-)
>  create mode 100644 tester/covoar/Target_riscv.cc
>  create mode 100644 tester/covoar/Target_riscv.h
>  create mode 100644 tester/rtems/testing/bsps/griscv-sis-cov.ini
> diff --git a/tester/covoar/TargetFactory.cc
> b/tester/covoar/TargetFactory.cc
> index fc9c30b..12de94d 100644
> --- a/tester/covoar/TargetFactory.cc
> +++ b/tester/covoar/TargetFactory.cc
> @@ -23,6 +23,7 @@
>  #include "Target_powerpc.h"
>  #include "Target_lm32.h"
>  #include "Target_sparc.h"
> +#include "Target_riscv.h"
>  namespace Target {
> @@ -56,6 +57,7 @@ namespace Target {
>      { "m68k",    Target_m68k_Constructor },
>      { "powerpc", Target_powerpc_Constructor },
>      { "sparc",   Target_sparc_Constructor },
> +    { "riscv",   Target_riscv_Constructor },
>      { "TBD",     NULL },
> diff --git a/tester/covoar/Target_riscv.cc b/tester/covoar/Target_riscv.cc
> new file mode 100644
> index 0000000..279dc6a
> --- /dev/null
> +++ b/tester/covoar/Target_riscv.cc
> @@ -0,0 +1,83 @@
> + * RTEMS Tools Project (http://www.rtems.org/)
> + * Copyright 2019 Vijay K. Banerjee <vijaykumar9597 at gmail.com>
> + * All rights reserved.
> + * This file is part of the RTEMS Tools package in 'rtems-tools'.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions are
> met:
> + * 1. Redistributions of source code must retain the above copyright
> notice,
> + * this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> notice,
> + * this list of conditions and the following disclaimer in the
> documentation
> + * and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +/*! @file Target_riscv.cc
> + *  @brief Target_riscv Implementation
> +#include <stdio.h>
> +#include <stdlib.h>
> +#include <string.h>
> +#include <unistd.h>
> +namespace Target {
> +  Target_riscv::Target_riscv( std::string targetName ):
> +    TargetBase( targetName )
> +    branchInstructions.push_back("beqz");
> +    branchInstructions.push_back("bnez");
> +    branchInstructions.push_back("blez");
> +    branchInstructions.push_back("bgez");
> +    branchInstructions.push_back("bltz");
> +    branchInstructions.push_back("bgt");
> +    branchInstructions.push_back("bgtz");
> +    branchInstructions.push_back("ble");
> +    branchInstructions.push_back("bgtu");
> +    branchInstructions.push_back("bleu");
> +    branchInstructions.sort();
> +  Target_riscv::~Target_riscv()
> +  bool Target_riscv::isNopLine(
> +    const char* const line,
> +    int&              size
> +    if (!strcmp( &line[strlen(line)-3], "nop")){
> +        size = 4;
> +        return true;
> +  return false;
> +  TargetBase *Target_riscv_Constructor(
> +    std::string        targetName
> +      return new Target_riscv( targetName );
> diff --git a/tester/covoar/Target_riscv.h b/tester/covoar/Target_riscv.h
> index 0000000..c1cf7ab
> --- /dev/null
> +++ b/tester/covoar/Target_riscv.h
> @@ -0,0 +1,95 @@
> met:
> notice,
> notice,
> documentation
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +/*! @file Target_riscv.h
> + *  @brief Target_riscv Specification
> + *  This file contains the specification of the Target_riscv class.
> +#ifndef __TARGET_RISCV_H__
> +#define __TARGET_RISCV_H__
> +#include <list>
> +#include <string>
> +#include "TargetBase.h"
> +namespace Target {
> +  /*!  @class Target_riscv
> +   * This is the class for the riscv target.
> +  class Target_riscv: public TargetBase {
> +  public:
> +   *  Target_riscv constructor
> +  Target_riscv( std::string targetName );
> +  virtual ~Target_riscv();
> +   *  This method determines nop instruction.
> +   *  @param[in] line contains the object dump line to check
> +   *  @param[out] size is set to the size in bytes of the nop
> +   *  @return Returns True if the instruction is nop, False otherwise.
> +  bool isNopLine(
> +       int&              size
> +   *  This method determines if it's a branch instruction
> +   *  @param[in] instruction
> +   *  @return Returns True if the instruction is a branch instruction,
> False otherwise.
> +  bool isBranch(
> +    const char* const instruction
> + private:
> +#endif
> diff --git a/tester/covoar/wscript b/tester/covoar/wscript
> index a3730ea..6f722c2 100644
> --- a/tester/covoar/wscript
> +++ b/tester/covoar/wscript
> @@ -105,7 +105,8 @@ def build(bld):
>                          'Target_lm32.cc',
>                          'Target_m68k.cc',
>                          'Target_powerpc.cc',
> -                        'Target_sparc.cc'],
> +                        'Target_sparc.cc',
> +                        'Target_riscv.cc'],
>                cflags = ['-O2', '-g', '-Wall'],
>                cxxflags = ['-std=c++11', '-O2', '-g', '-Wall'],
>                includes = ['.'] + rtl_includes)
> diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini
> b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> index 0000000..060bba7
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> @@ -0,0 +1,40 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2019 Vijay K. Banerjee (vijaykumar9597 at gmail.com)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are
> met:
> +# 1. Redistributions of source code must retain the above copyright
> notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> +# this list of conditions and the following disclaimer in the
> documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
> IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
> BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# The griscv BSP on sis with coverage
> +[griscv-sis-cov]
> +bsp          = griscv-sis
> +arch         = riscv
> +tester       = %{_rtscripts}/run.cfg
> +target       = riscv-rtems5
> +bsp_run_cmd  = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
> +bsp_run_opts = -nouartrx -r -tlim 300 s -m 4 -cov
> 2.17.2
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190211/f51077e8/attachment-0002.html>
