Break points with latest SIS
Jiri Gaisler jiri at gaisler.se
Thu Feb 7 11:43:09 UTC 2019
Works OK here:
$ sparc-rtems5-sis -leon3 -nouartrx -r -tlim 200 s -m 4  ./sparc-rtems5/c/leon3/testsuites/smptests/smpswitchextension01.exe
 SIS - SPARC/RISCV instruction simulator 2.11,  copyright Jiri Gaisler 1995
 Bug-reports to jiri at gaisler.se
 LEON3 emulation enabled, 4 cpus online, delta 50 clocks
*** BEGIN OF TEST SMPSWITCHEXTENSION 1 ***
*** TEST VERSION: 5.0.0.03fcbb15d24e2eec41bac9f5dee30bbf7dc888b8-modified
*** TEST STATE: EXPECTED-PASS
*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
*** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB c41b9d0df7e5b4a5056ca50c2534380a44e92769, Newlib 3e24fbf6f)
toggler 0
    toggles 174134
toggler 1
    toggles 174133
extension 0
    context switches 174437
extension 1
    context switches 174164
extension 2
    context switches 169718
extension switches 93650
*** END OF TEST SMPSWITCHEXTENSION 1 ***
I will rebuild RSB and RTEMS from git HEAD and try it again ...
Jiri.
On 2/7/19 12:20 PM, Sebastian Huber wrote:
> Hello,
> I get a NULL pointer exception in one of the tests:
> sparc-rtems5-sis -leon3 -nouartrx -r -tlim 200 s -m 4 smpswitchextension01.exe
> Waking CPU 1
> *** TEST VERSION: 5.0.0.e105ead93f8e7addf1c6bba731a1eb4da99f2e85
> *** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
> Unexpected trap ( 2) at address 0x00000000
> illegal instruction
> IU in error mode (0)
>  11360600  4001d9e0  12bffffe  bne  0x000000004001d9d8
> I tried to debug this issue:
> sparc-rtems5-gdb smpswitchextension01.exe
> GNU gdb (GDB) 8.2.1
> Copyright (C) 2018 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.
> Type "show copying" and "show warranty" for details.
> This GDB was configured as "--host=x86_64-linux-gnu --target=sparc-rtems5".
> Type "show configuration" for configuration details.
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>.
> Find the GDB manual and other documentation resources online at:
>     <http://www.gnu.org/software/gdb/documentation/>.
> For help, type "help".
> Type "apropos word" to search for commands related to "word"...
> No symbol table is loaded.  Use the "file" command.
> Reading symbols from smpswitchextension01.exe...done.
> (gdb) tar sim -leon3 -m 4
> Connected to the simulator.
> (gdb) load
> (gdb) b *0
> Breakpoint 1 at 0x0
> (gdb) r
> Starting program: /build/git-build/b-leon3/sparc-rtems5/c/leon3/testsuites/smptests/smpswitchextension01.exe
> Waking CPU 1
> Program received signal SIGTRAP, Trace/breakpoint trap.
> 0x40007070 in _API_Mutex_Is_owner (the_mutex=0x40026598 <_RTEMS_Allocator_Mutex>) at /home/EB/sebastian_h/git-rtems-5/c/src/../../cpukit/score/src/apimutexisowner.c:25
> 25        return the_mutex->Mutex._Mutex._Queue._owner == _Thread_Get_executing();
> (gdb) disas
> Dump of assembler code for function _API_Mutex_Is_owner:
>    0x4000706c <+0>:     ld  [ %o0 + 0xc ], %g1
> => 0x40007070 <+4>:     ld  [ %g6 + 0x20 ], %g2
>    0x40007074 <+8>:     xor  %g1, %g2, %g1
>    0x40007078 <+12>:    cmp  %g0, %g1
>    0x4000707c <+16>:    retl
>    0x40007080 <+20>:    subx  %g0, -1, %o0
> End of assembler dump.
> (gdb) info registers
> g0             0x0                 0
> g1             0x40027688          1073903240
> g2             0x40029b54          1073912660
> g3             0x8e                142
> g4             0x40029b54          1073912660
> g5             0x0                 0
> g6             0x40029640          1073911360
> g7             0x0                 0
> o0             0x40026598          1073898904
> o1             0x4002f300          1073935104
> o2             0x0                 0
> o3             0x40023800          1073887232
> o4             0x0                 0
> o5             0x40029640          1073911360
> sp             0x4002f2a8          0x4002f2a8
> o7             0x40008444          1073775684
> l0             0xf3400fc7          -213905465
> l1             0x4001add8          1073851864
> l2             0x4001addc          1073851868
> l3             0xf34000c7          -213909305
> l4             0x0                 0
> l5             0x0                 0
> l6             0x0                 0
> l7             0x0                 0
> i0             0x400263b4          1073898420
> i1             0x400269cc          1073899980
> i2             0x0                 0
> i3             0x40029c00          1073912832
> i4             0x40029b50          1073912656
> i5             0x40029b50          1073912656
> fp             0x4002f308          0x4002f308
> i7             0x4001170c          1073813260
> y              0x588               1416
> psr            0xf34000e7          [ ET PS S ]
> wim            0x8                 8
> tbr            0x400008a0          1073744032
> pc             0x40007070          0x40007070 <_API_Mutex_Is_owner+4>
> npc            0x40007074          0x40007074 <_API_Mutex_Is_owner+8>
> fsr            0x0                 [ ]
> csr            0x0                 0
> It seems the debugger doesn't stop at address 0, but somewhere else.
