[PATCH v2 11/11] libdl: Add powerpc large memory and small data support.
chrisj at rtems.org chrisj at rtems.org
Thu Feb 7 18:08:14 UTC 2019
- Add support for architecure sections that can be handled by the
  architecture back end.
- Add trampoline/fixup support for PowerPC. This means the PowerPC
  now supports large memory loading of applications.
- Add a bit allocator to manage small block based regions of memory.
- Add small data (sdata/sbss) support for the PowerPC. The support
  makes the linker allocated small data region of memory a global
  resource available to libdl loaded object files.
Updates #3687
Updates #3685
 bsps/powerpc/psim/start/linkcmds              |   4 +-
 bsps/powerpc/qoriq/start/linkcmds.qoriq_e500  |   5 +
 .../qoriq/start/linkcmds.qoriq_e6500_32       |   5 +
 bsps/powerpc/shared/start/linkcmds.base       |  13 +
 cpukit/Makefile.am                            |   1 +
 cpukit/include/rtems/rtl/rtl-obj.h            |  69 +++-
 cpukit/include/rtems/rtl/rtl-trace.h          |   1 +
 cpukit/libdl/rtl-archive.c                    |   7 +-
 cpukit/libdl/rtl-bit-alloc.c                  | 197 ++++++++++
 cpukit/libdl/rtl-bit-alloc.h                  |  82 ++++
 cpukit/libdl/rtl-elf.c                        |  59 ++-
 cpukit/libdl/rtl-elf.h                        |  41 +-
 cpukit/libdl/rtl-error.c                      |   1 +
 cpukit/libdl/rtl-mdreloc-arm.c                |  38 +-
 cpukit/libdl/rtl-mdreloc-bfin.c               |  32 ++
 cpukit/libdl/rtl-mdreloc-h8300.c              |  32 ++
 cpukit/libdl/rtl-mdreloc-i386.c               |  32 ++
 cpukit/libdl/rtl-mdreloc-lm32.c               |  32 ++
 cpukit/libdl/rtl-mdreloc-m68k.c               |  36 +-
 cpukit/libdl/rtl-mdreloc-mips.c               |  32 ++
 cpukit/libdl/rtl-mdreloc-moxie.c              |  32 ++
 cpukit/libdl/rtl-mdreloc-powerpc.c            | 359 ++++++++++++++----
 cpukit/libdl/rtl-mdreloc-sparc.c              |  32 ++
 cpukit/libdl/rtl-mdreloc-v850.c               |  32 ++
 cpukit/libdl/rtl-obj.c                        |  77 ++--
 cpukit/libdl/rtl-shell.c                      |   2 +-
 cpukit/libdl/rtl-unresolved.c                 |   2 +-
 testsuites/libtests/Makefile.am               |   7 +-
 testsuites/libtests/dl01/dl-load.c            |   1 +
 testsuites/libtests/dl02/dl-load.c            |  16 +-
 testsuites/libtests/dl02/dl-o1.c              |  10 +-
 testsuites/libtests/dl02/dl-o2.c              |  10 +-
 testsuites/libtests/dl03/dl-bit-alloc.c       | 262 +++++++++++++
 testsuites/libtests/dl03/dl-bit-alloc.h       |  14 +
 testsuites/libtests/dl03/init.c               |   4 +
 testsuites/libtests/dl05/dl-load.c            |  22 +-
 testsuites/libtests/dl07/dl-load.c            |  27 +-
 testsuites/libtests/dl07/dl-o1.c              |  16 +-
 testsuites/libtests/dl07/dl-o2.c              |  26 +-
 testsuites/libtests/dl07/dl-o3.c              |  48 +--
 testsuites/libtests/dl07/dl-o4.c              |  28 +-
 testsuites/libtests/dl07/dl-o5.c              |  26 +-
 testsuites/libtests/dl07/init.c               |   2 +-
 testsuites/libtests/dl08/dl-o1.c              |  16 +-
 testsuites/libtests/dl08/dl-o2.c              |  10 +-
 testsuites/libtests/dl08/dl-o3.c              |  22 +-
 testsuites/libtests/dl08/dl-o4.c              |  12 +-
 testsuites/libtests/dl08/dl-o5.c              |  10 +-
 .../libtests/dl08/dl-o6-123456789-123456789.c |  10 +-
 testsuites/libtests/dl09/dl-load.c            |   4 +-
 testsuites/libtests/dl09/dl-o1.c              |  19 +-
 testsuites/libtests/dl09/dl-o2.c              |  15 +-
 testsuites/libtests/dl09/dl-o3.c              |  25 +-
 testsuites/libtests/dl09/dl-o4.c              |  21 +-
 testsuites/libtests/dl09/dl-o5.c              |  13 +-
 55 files changed, 1643 insertions(+), 308 deletions(-)
 create mode 100644 cpukit/libdl/rtl-bit-alloc.c
 create mode 100644 cpukit/libdl/rtl-bit-alloc.h
 create mode 100644 testsuites/libtests/dl03/dl-bit-alloc.c
 create mode 100644 testsuites/libtests/dl03/dl-bit-alloc.h
diff --git a/bsps/powerpc/psim/start/linkcmds b/bsps/powerpc/psim/start/linkcmds
index d5e61f9425..48700b6dcc 100644
--- a/bsps/powerpc/psim/start/linkcmds
+++ b/bsps/powerpc/psim/start/linkcmds
@@ -38,8 +38,8 @@ PROVIDE (PSIM_INSTRUCTIONS_PER_MICROSECOND = 10000);
 PSIM = 0x0c000000;
- * Allocate the maximum memory to the sdata/sbss section.
+ * Allocate the all maximum size to the small data sdata/sbss section.
-bsp_section_sdata_bss_maximum_size = 1;
+bsp_section_set_sdata_sbss_size = 65536;
 INCLUDE linkcmds.base
diff --git a/bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 b/bsps/powerpc/qoriq/start/linkcmds.qoriq_e500
index 5328e73c5b..396cf55327 100644
--- a/bsps/powerpc/qoriq/start/linkcmds.qoriq_e500
+++ b/bsps/powerpc/qoriq/start/linkcmds.qoriq_e500
@@ -35,4 +35,9 @@ bsp_section_robarrier_align = 0x1000000;
 bsp_section_rwbarrier_align = 0x1000000;
 qoriq = 0xffe00000;
diff --git a/bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 b/bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32
index 4f8bbdfdbc..36d1ffe26f 100644
--- a/bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32
+++ b/bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32
@@ -38,4 +38,9 @@ qoriq = 0xffe000000;
 qoriq_bman_portal = 0xff4000000;
 qoriq_qman_portal = 0xff6000000;
diff --git a/bsps/powerpc/shared/start/linkcmds.base b/bsps/powerpc/shared/start/linkcmds.base
index 4ad302e86b..642f0bf7e1 100644
--- a/bsps/powerpc/shared/start/linkcmds.base
+++ b/bsps/powerpc/shared/start/linkcmds.base
@@ -293,20 +293,33 @@ SECTIONS {
 		KEEP (*(SORT(.rtemsrwset.*)))
 	} > REGION_DATA AT > REGION_DATA_LOAD
 	.sdata : ALIGN_WITH_INPUT {
+		bsp_section_sdata_begin = .;
 		PROVIDE (_SDA_BASE_ = 32768);
 		*(.sdata .sdata.* .gnu.linkonce.s.*)
+		bsp_section_sdata_end = .;
 		bsp_section_data_end = .;
+	bsp_section_sdata_size = bsp_section_sdata_end - bsp_section_sdata_begin;
 	bsp_section_data_size = bsp_section_data_end - bsp_section_data_begin;
 	bsp_section_data_load_begin = LOADADDR (.data);
 	bsp_section_data_load_end = bsp_section_data_load_begin + bsp_section_data_size;
+	 * Set bsp_section_set_sdata_bss_size to the system's sdata and bss data size, eg:
+	 *  bsp_section_set_sdata_sbss_size = 65536;
+	bsp_section_sdata_sbss_size = DEFINED(bsp_section_set_sdata_sbss_size) ?
+							bsp_section_set_sdata_sbss_size : 0;
 	.sbss : ALIGN_WITH_INPUT {
 		bsp_section_sbss_begin = .;
 		*(.dynsbss)
 		*(.sbss .sbss.* .gnu.linkonce.sb.*)
 		*(.scommon)
 		bsp_section_sbss_end = .;
+		bsp_section_sdata_libdl_begin = .;
+		. += bsp_section_sdata_sbss_size - (bsp_section_sdata_size + bsp_section_sbss_size);
+		bsp_section_sdata_libdl_end = .;
 	bsp_section_sbss_size = bsp_section_sbss_end - bsp_section_sbss_begin;
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 8ea7cbbfb0..51ab18ca05 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1141,6 +1141,7 @@ librtemscpu_a_SOURCES += libdl/rap-shell.c
 librtemscpu_a_SOURCES += libdl/rtl-allocator.c
 librtemscpu_a_SOURCES += libdl/rtl-alloc-heap.c
 librtemscpu_a_SOURCES += libdl/rtl-archive.c
+librtemscpu_a_SOURCES += libdl/rtl-bit-alloc.c
 librtemscpu_a_SOURCES += libdl/rtl.c
 librtemscpu_a_SOURCES += libdl/rtl-chain-iterator.c
 librtemscpu_a_SOURCES += libdl/rtl-debugger.c
diff --git a/cpukit/include/rtems/rtl/rtl-obj.h b/cpukit/include/rtems/rtl/rtl-obj.h
index e01af20957..9c2b4f0300 100644
--- a/cpukit/include/rtems/rtl/rtl-obj.h
+++ b/cpukit/include/rtems/rtl/rtl-obj.h
@@ -87,25 +87,26 @@ typedef struct rtems_rtl_loader_table
  * Flags for the various section types.
-#define RTEMS_RTL_OBJ_SECT_TEXT  (1 << 0)  /**< Section holds program text. */
-#define RTEMS_RTL_OBJ_SECT_CONST (1 << 1)  /**< Section holds program text. */
-#define RTEMS_RTL_OBJ_SECT_DATA  (1 << 2)  /**< Section holds program data. */
-#define RTEMS_RTL_OBJ_SECT_BSS   (1 << 3)  /**< Section holds program bss. */
-#define RTEMS_RTL_OBJ_SECT_EH    (1 << 4)  /**< Section holds exception data. */
-#define RTEMS_RTL_OBJ_SECT_TLS   (1 << 5)  /**< Section holds TLS data. */
-#define RTEMS_RTL_OBJ_SECT_REL   (1 << 6)  /**< Section holds relocation recs. */
-#define RTEMS_RTL_OBJ_SECT_RELA  (1 << 7)  /**< Section holds reloc addend recs. */
-#define RTEMS_RTL_OBJ_SECT_SYM   (1 << 8)  /**< Section holds symbols. */
-#define RTEMS_RTL_OBJ_SECT_STR   (1 << 9)  /**< Section holds strings. */
-#define RTEMS_RTL_OBJ_SECT_ALLOC (1 << 10  /**< Section allocates runtime memory. */
-#define RTEMS_RTL_OBJ_SECT_LOAD  (1 << 11) /**< Section is loaded from object file. */
-#define RTEMS_RTL_OBJ_SECT_WRITE (1 << 12) /**< Section is writable, ie data. */
-#define RTEMS_RTL_OBJ_SECT_EXEC  (1 << 13) /**< Section is executable. */
-#define RTEMS_RTL_OBJ_SECT_ZERO  (1 << 14) /**< Section is preset to zero. */
-#define RTEMS_RTL_OBJ_SECT_LINK  (1 << 15) /**< Section is link-ordered. */
-#define RTEMS_RTL_OBJ_SECT_CTOR  (1 << 16) /**< Section contains constructors. */
-#define RTEMS_RTL_OBJ_SECT_DTOR  (1 << 17) /**< Section contains destructors. */
-#define RTEMS_RTL_OBJ_SECT_LOCD  (1 << 18) /**< Section has been located. */
+#define RTEMS_RTL_OBJ_SECT_TEXT       (1 << 0)  /**< Section holds program text. */
+#define RTEMS_RTL_OBJ_SECT_CONST      (1 << 1)  /**< Section holds program text. */
+#define RTEMS_RTL_OBJ_SECT_DATA       (1 << 2)  /**< Section holds program data. */
+#define RTEMS_RTL_OBJ_SECT_BSS        (1 << 3)  /**< Section holds program bss. */
+#define RTEMS_RTL_OBJ_SECT_EH         (1 << 4)  /**< Section holds exception data. */
+#define RTEMS_RTL_OBJ_SECT_TLS        (1 << 5)  /**< Section holds TLS data. */
+#define RTEMS_RTL_OBJ_SECT_REL        (1 << 6)  /**< Section holds relocation recs. */
+#define RTEMS_RTL_OBJ_SECT_RELA       (1 << 7)  /**< Section holds reloc addend recs. */
+#define RTEMS_RTL_OBJ_SECT_SYM        (1 << 8)  /**< Section holds symbols. */
+#define RTEMS_RTL_OBJ_SECT_STR        (1 << 9)  /**< Section holds strings. */
+#define RTEMS_RTL_OBJ_SECT_ALLOC      (1 << 10  /**< Section allocates runtime memory. */
+#define RTEMS_RTL_OBJ_SECT_LOAD       (1 << 11) /**< Section is loaded from object file. */
+#define RTEMS_RTL_OBJ_SECT_WRITE      (1 << 12) /**< Section is writable, ie data. */
+#define RTEMS_RTL_OBJ_SECT_EXEC       (1 << 13) /**< Section is executable. */
+#define RTEMS_RTL_OBJ_SECT_ZERO       (1 << 14) /**< Section is preset to zero. */
+#define RTEMS_RTL_OBJ_SECT_LINK       (1 << 15) /**< Section is link-ordered. */
+#define RTEMS_RTL_OBJ_SECT_CTOR       (1 << 16) /**< Section contains constructors. */
+#define RTEMS_RTL_OBJ_SECT_DTOR       (1 << 17) /**< Section contains destructors. */
+#define RTEMS_RTL_OBJ_SECT_LOCD       (1 << 18) /**< Section has been located. */
+#define RTEMS_RTL_OBJ_SECT_ARCH_ALLOC (1 << 19) /**< Section use arch allocator. */
  * Section types mask.
@@ -237,7 +238,7 @@ struct rtems_rtl_obj
  * A section handler is called once for each section that needs to be
- * processed by this handler.
+ * processed by this handler. The handler is specific to a task.
  * @param obj The object file's descriptor the section belongs too.
  * @param fd The file descriptor of the object file beling loaded.
@@ -376,6 +377,17 @@ static inline bool rtems_rtl_obj_has_ramp_space (const rtems_rtl_obj* obj,
           ((obj->tramp_brk - obj->trampoline) + size) <= obj->tramp_size);
+ * Does the section require architecture specific allocations?
+ * @param sect The section.
+ * @retval bool Returns @true if the section requires arch allocation.
+static inline bool rtems_rtl_obj_sect_is_arch_alloc (rtems_rtl_obj_sect* sect)
+  return (sect->flags & RTEMS_RTL_OBJ_SECT_ARCH_ALLOC) != 0;
  * Allocate an object structure on the heap.
@@ -728,6 +740,23 @@ bool rtems_rtl_obj_load_symbols (rtems_rtl_obj*             obj,
                                  rtems_rtl_obj_sect_handler handler,
                                  void*                      data);
+ * Allocate the sections. If a handler is provided (not NULL) it is called for
+ * all section.
+ * @param obj The object file's descriptor.
+ * @param fd The object file's file descriptor.
+ * @param handler The object file's format specific allocation handler.
+ * @param data User specific data handle.
+ * @retval true The object has been sucessfully loaded.
+ * @retval false The load failed. The RTL error has been set.
+bool
+rtems_rtl_obj_alloc_sections (rtems_rtl_obj*             obj,
+                              int                        fd,
+                              rtems_rtl_obj_sect_handler handler,
+                              void*                      data);
  * Load the sections that have been allocated memory in the target. The bss
  * type section does not load any data, it is set to 0. The text and data
diff --git a/cpukit/include/rtems/rtl/rtl-trace.h b/cpukit/include/rtems/rtl/rtl-trace.h
index 6905e02245..cd3921400c 100644
--- a/cpukit/include/rtems/rtl/rtl-trace.h
+++ b/cpukit/include/rtems/rtl/rtl-trace.h
@@ -51,6 +51,7 @@ typedef uint32_t rtems_rtl_trace_mask;
 #define RTEMS_RTL_TRACE_ARCHIVES               (1UL << 12)
 #define RTEMS_RTL_TRACE_ARCHIVE_SYMS           (1UL << 13)
 #define RTEMS_RTL_TRACE_DEPENDENCY             (1UL << 14)
+#define RTEMS_RTL_TRACE_BIT_ALLOC              (1UL << 15)
 #define RTEMS_RTL_TRACE_ALL                    (0xffffffffUL & ~(RTEMS_RTL_TRACE_CACHE | \
        RTEMS_RTL_TRACE_GLOBAL_SYM | \
        RTEMS_RTL_TRACE_ARCHIVE_SYMS))
diff --git a/cpukit/libdl/rtl-archive.c b/cpukit/libdl/rtl-archive.c
index be1199f62f..07d40187e1 100644
--- a/cpukit/libdl/rtl-archive.c
+++ b/cpukit/libdl/rtl-archive.c
@@ -21,6 +21,7 @@
 #include <dirent.h>
 #include <fnmatch.h>
+#include <inttypes.h>
@@ -572,7 +573,7 @@ rtems_rtl_archives_close (rtems_rtl_archives* archives)
   rtems_chain_node* node;
   if (rtems_rtl_trace (RTEMS_RTL_TRACE_ARCHIVES))
-    printf ("rtl: archive: close: count=%ds\n",
+    printf ("rtl: archive: close: count=%zu\n",
             rtems_chain_node_count_unprotected (&archives->archives));
   node = rtems_chain_first (&archives->archives);
   while (!rtems_chain_is_tail (&archives->archives, node))
@@ -591,7 +592,7 @@ rtems_rtl_archives_remove (rtems_rtl_archives* archives)
   rtems_chain_node* node = rtems_chain_first (&archives->archives);
-    printf ("rtl: archive: refresh: remove: checking %d archive(s)\n",
+    printf ("rtl: archive: refresh: remove: checking %zu archive(s)\n",
@@ -716,7 +717,7 @@ rtems_rtl_archive_loader (rtems_rtl_archive* archive, void* data)
                 archive->symbols.base,
                 archive->symbols.entries,
                 archive->symbols.names,
-                (archive->symbols.entries + 1) * 4,
+                (unsigned int) (archive->symbols.entries + 1) * 4,
                 archive->symbols.symbols);
       if (rtems_rtl_trace (RTEMS_RTL_TRACE_ARCHIVE_SYMS) &&
diff --git a/cpukit/libdl/rtl-bit-alloc.c b/cpukit/libdl/rtl-bit-alloc.c
new file mode 100644
index 0000000000..b7871f227b
--- /dev/null
+++ b/cpukit/libdl/rtl-bit-alloc.c
@@ -0,0 +1,197 @@
+ *  COPYRIGHT (c) 2019 Chris Johns <chrisj at rtems.org>
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+ * @file
+ * @ingroup rtems_rtld
+ * @brief RTEMS Run-Time Link Editor Bit Allocator
+ * A configurable allocator for small peices of memory where embedding
+ * control blocks into the memory are not viable. The amount of memory
+ * should be small and the minimum allocator a 32bit work or higher.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <errno.h>
+#include <stdio.h>
+#include <string.h>
+#include <rtems/rtl/rtl-allocator.h>
+#include "rtl-bit-alloc.h"
+#include "rtl-error.h"
+#include <rtems/rtl/rtl-trace.h>
+#define BITS_PER_WORD (sizeof (uint32_t) * 8)
+static size_t
+bit_blocks (rtems_rtl_bit_alloc* balloc, size_t size)
+  if (size == 0)
+    return 0;
+  return ((size - 1) / balloc->block_size) + 1;
+static size_t
+bit_word (size_t bit)
+  return bit / BITS_PER_WORD;
+static size_t
+bit_offset (size_t bit)
+  return bit % (sizeof (uint32_t) * 8);
+static uint32_t
+bit_mask (size_t bit)
+  return 1 << bit_offset (bit);
+static void
+bit_set (rtems_rtl_bit_alloc* balloc, size_t start, size_t bits)
+  size_t b;
+  for (b = start; b < (start + bits); ++b)
+    balloc->bits[bit_word (b)] |= bit_mask (b);
+static void
+bit_clear (rtems_rtl_bit_alloc* balloc, size_t start, size_t bits)
+  size_t b;
+    balloc->bits[bit_word (b)] &= ~bit_mask (b);
+static ssize_t
+bit_find_clear (rtems_rtl_bit_alloc* balloc, size_t blocks)
+  size_t base = 0;
+  size_t clear = 0;
+  size_t b;
+  for (b = 0; b < balloc->blocks; ++b)
+    if (balloc->bits[b] != 0xffffffff)
+      uint32_t word = balloc->bits[b];
+      size_t   o;
+      for (o = 0; o < BITS_PER_WORD; ++o, word >>= 1)
+        if ((word & 1) == 0)
+          if (clear == 0)
+            base = (b * BITS_PER_WORD) + o;
+          ++clear;
+          if (clear == blocks)
+            return base;
+        else
+          clear = 0;
+          base = 0;
+    else
+      clear = 0;
+      base = 0;
+  return -1;
+rtems_rtl_bit_alloc*
+rtems_rtl_bit_alloc_open (void* base, size_t size, size_t block_size, size_t used)
+  rtems_rtl_bit_alloc* balloc;
+  const size_t         base_size = base == NULL ? size : 0;;
+  const size_t         blocks = (size / block_size) / BITS_PER_WORD;
+  const size_t         bit_bytes = blocks * sizeof(uint32_t);
+  if (rtems_rtl_trace (RTEMS_RTL_TRACE_BIT_ALLOC))
+    printf ("rtl: balloc: open: base=%p size=%zu" \
+            " block-size=%zu blocks=%zu used=%zu\n",
+            base, size, block_size, blocks, used);
+  if (size == 0)
+    rtems_rtl_set_error (ENOMEM, "bit allocator size is 0");
+    return false;
+  if (used > size)
+    rtems_rtl_set_error (ENOMEM, "bad bit allocator used value");
+    return false;
+  balloc = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_OBJECT,
+                                sizeof (rtems_rtl_bit_alloc) + bit_bytes + base_size,
+                                true);
+  if (balloc == NULL)
+    rtems_rtl_set_error (ENOMEM, "not bit allocator memory");
+    return NULL;
+  balloc->base =
+    base == NULL ? ((void*) balloc) + sizeof (rtems_rtl_bit_alloc) + bit_bytes: base;
+  balloc->size = size;
+  balloc->bits = ((void*) balloc) + sizeof (rtems_rtl_bit_alloc);
+  balloc->block_size = block_size;
+  balloc->blocks = blocks;
+  bit_set (balloc, 0, bit_blocks (balloc, used));
+  return balloc;
+void
+rtems_rtl_bit_alloc_close (rtems_rtl_bit_alloc* balloc)
+    printf ("rtl: balloc: close: base=%p size=%zu\n",
+            balloc->base, balloc->size);
+  rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_OBJECT, balloc);
+void*
+rtems_rtl_bit_alloc_balloc (rtems_rtl_bit_alloc* balloc, size_t size)
+  size_t  blocks = bit_blocks (balloc, size);
+  ssize_t block = bit_find_clear (balloc, blocks);
+  if (block < 0)
+    return NULL;
+    printf ("rtl: balloc: balloc: size=%zu blocks=%zu block=%zi\n",
+            size, blocks, block);
+  bit_set (balloc, block, blocks);
+  return (void*) (balloc->base + (block * balloc->block_size));
+void
+rtems_rtl_bit_alloc_bfree (rtems_rtl_bit_alloc* balloc, void* addr, size_t size)
+  const uint8_t* a = (const uint8_t*) addr;
+  if (addr != NULL && a >= balloc->base && a < balloc->base + balloc->size)
+    size_t block = bit_blocks (balloc, a - balloc->base);
+    bit_clear (balloc, block, blocks);
diff --git a/cpukit/libdl/rtl-bit-alloc.h b/cpukit/libdl/rtl-bit-alloc.h
index 0000000000..d977473a96
--- /dev/null
+++ b/cpukit/libdl/rtl-bit-alloc.h
@@ -0,0 +1,82 @@
+ * @file
+ * @brief RTEMS Run-Time Linker Bit Allocator Header
+#if !defined (_RTEMS_RTL_BIT_ALLOC_H_)
+#define _RTEMS_RTL_BIT_ALLOC_H_
+#include <rtems/rtl/rtl-fwd.h>
+#include <rtems/rtl/rtl-obj-fwd.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * Bit Allocator data
+typedef struct rtems_rtl_bit_alloc
+  uint8_t*  base;       /**< The memory being allocated. */
+  size_t    size;       /**< The number of bytes of memory being managed. */
+  uint32_t* bits;       /**< The bit map indicating which blocks are allocated. */
+  size_t    block_size; /**< The size of a block, the minimum allocation unit. */
+  size_t    blocks;     /**< The number of blocks in the memory. */
+} rtems_rtl_bit_alloc;
+ * Open a bit allocator. The allocator allocates block_size pieces of the memory
+ * being managed.
+ * @param base The memory to managem NULL to allocate a piece of memory.
+ * @param size The size of the memory being managed in bytes.
+ * @param block_size The minimum allocation unit in bytes.
+ * @param used The amount of memory already in use in bytes.
+ * @retval rtems_rtl_bit_alloc The bit allocator structure.
+rtems_rtl_bit_alloc* rtems_rtl_bit_alloc_open (void*  base,
+                                               size_t size,
+                                               size_t block_size,
+                                               size_t used);
+ * Close the bit allocator.
+ * @param balloc The allocator to close.
+void rtems_rtl_bit_alloc_close (rtems_rtl_bit_alloc* balloc);
+ * Allocate a piece of memory being managed. The size is in bytes are is rounded
+ * up the next block size.
+ * @param balloc The allocator.
+ * @param size Number of bytes to allocate.
+ * @return void* The memory if the allocation is successful else NULL if there
+ *               is no more memory.
+void* rtems_rtl_bit_alloc_balloc (rtems_rtl_bit_alloc* balloc, size_t size);
+ * Free an allocated memory block. The size is required because the allocator does not
+ * contain any state information.
+void rtems_rtl_bit_alloc_bfree (rtems_rtl_bit_alloc* balloc, void* addr, size_t size);
+#ifdef __cplusplus
+#endif
diff --git a/cpukit/libdl/rtl-elf.c b/cpukit/libdl/rtl-elf.c
index e65c70308d..54ea1464cc 100644
--- a/cpukit/libdl/rtl-elf.c
+++ b/cpukit/libdl/rtl-elf.c
@@ -474,7 +474,6 @@ rtems_rtl_elf_relocs_parser (rtems_rtl_obj*      obj,
   bool r = rtems_rtl_elf_relocate_worker (obj, fd, sect,
                                           rtems_rtl_elf_reloc_parser, data);
-  rtems_rtl_obj_update_flags (RTEMS_RTL_OBJ_RELOC_TAG, 0);
   return r;
@@ -603,10 +602,11 @@ rtems_rtl_elf_common (rtems_rtl_obj*      obj,
          (ELF_ST_TYPE (symbol.st_info) == STT_COMMON)))
       if (rtems_rtl_trace (RTEMS_RTL_TRACE_SYMBOL))
-        printf ("rtl: com:elf:%-2d bind:%-2d type:%-2d size:%d value:%d\n",
+        printf ("rtl: com:elf:%-2d bind:%-2d type:%-2d size:%d value:%d name:%d\n",
                 sym, (int) ELF_ST_BIND (symbol.st_info),
                 (int) ELF_ST_TYPE (symbol.st_info),
-                (int) symbol.st_size, (int) symbol.st_value);
+                (int) symbol.st_size, (int) symbol.st_value,
+                (int) symbol.st_name);
        * If the size is zero this is the first entry, it defines the common
        * section's aligment. The symbol's value is the alignment.
@@ -952,6 +952,36 @@ rtems_rtl_elf_symbols (rtems_rtl_obj*      obj,
   return true;
+static bool
+rtems_rtl_elf_arch_alloc (rtems_rtl_obj*      obj,
+                          int                 fd,
+                          rtems_rtl_obj_sect* sect,
+                          void*               data)
+  if (rtems_rtl_obj_sect_is_arch_alloc (sect))
+    return rtems_rtl_elf_arch_section_alloc (obj, sect);
+  return true;
+static bool
+rtems_rtl_elf_arch_free (rtems_rtl_obj* obj)
+  int index = -1;
+  while (true)
+    rtems_rtl_obj_sect* sect;
+    sect = rtems_rtl_obj_find_section_by_mask (obj,
+                                               index,
+                                               RTEMS_RTL_OBJ_SECT_ARCH_ALLOC);
+    if (sect == NULL)
+      break;
+    if (!rtems_rtl_elf_arch_section_free (obj, sect))
+      return false;
+    index = sect->section;
+  return true;
 static bool
 rtems_rtl_elf_loader (rtems_rtl_obj*      obj,
                       int                 fd,
@@ -1168,6 +1198,22 @@ rtems_rtl_elf_parse_sections (rtems_rtl_obj* obj, int fd, Elf_Ehdr* ehdr)
         flags |= RTEMS_RTL_OBJ_SECT_EH;
+       * Architecture specific parsing. Modified or extends the flags.
+      flags = rtems_rtl_elf_arch_parse_section (obj, section, name, &shdr, flags);
+      if (flags == 0)
+        if (rtems_rtl_trace (RTEMS_RTL_TRACE_WARNING))
+          printf ("rtl: unsupported section: %2d: type=%02d flags=%02x\n",
+                  section, (int) shdr.sh_type, (int) shdr.sh_flags);
+        rtems_rtl_set_error (ENOMEM, "invalid architecture section: %s", name);
+        return false;
+       * Add the section.
       if (!rtems_rtl_obj_add_section (obj, section, name,
                                       shdr.sh_size, shdr.sh_offset,
                                       shdr.sh_addralign, shdr.sh_link,
@@ -1410,6 +1456,12 @@ rtems_rtl_elf_file_load (rtems_rtl_obj* obj, int fd)
   obj->entry = (void*)(uintptr_t) ehdr.e_entry;
+  if (!rtems_rtl_obj_alloc_sections (obj, fd, rtems_rtl_elf_arch_alloc, &ehdr))
+    return false;
    * Load the sections and symbols and then relocation to the base address.
@@ -1453,6 +1505,7 @@ rtems_rtl_elf_file_load (rtems_rtl_obj* obj, int fd)
 bool
 rtems_rtl_elf_file_unload (rtems_rtl_obj* obj)
+  rtems_rtl_elf_arch_free (obj);
   rtems_rtl_elf_unwind_deregister (obj);
   return true;
diff --git a/cpukit/libdl/rtl-elf.h b/cpukit/libdl/rtl-elf.h
index d781bfb3a4..73d1e01bb1 100644
--- a/cpukit/libdl/rtl-elf.h
+++ b/cpukit/libdl/rtl-elf.h
@@ -70,7 +70,7 @@ typedef struct rtems_rtl_mdreloc_trmap
  * Architecture specific handler to translate unknown section flags to RTL
- * section flags.
+ * section flags. If this function returns 0 an error is raised.
  * @param obj The object file being relocated.
  * @param shdr The ELF section header.
@@ -80,6 +80,45 @@ typedef struct rtems_rtl_mdreloc_trmap
 uint32_t rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
                                       const Elf_Shdr*      shdr);
+ * Architecture specific handler to parse the section and add any flags that
+ * may be need to handle the section.
+ * @param obj The object file being relocated.
+ * @param seciton The section index.
+ * @param name The name of the section
+ * @param shdr The ELF section header.
+ * @param flags The standard ELF parsed flags.
+ * @retval uint32_t Extra RTL object file flags.
+uint32_t rtems_rtl_elf_arch_parse_section (const rtems_rtl_obj* obj,
+                                           int                  section,
+                                           const char*          name,
+                                           const Elf_Shdr*      shdr,
+                                           const uint32_t       flags);
+ * Architecture specific handler to allocate a section. Some sections are
+ * specific to an architecture and need special allocators.
+ * @param sect The section data.
+ * @retval true The allocator was successful.
+bool rtems_rtl_elf_arch_section_alloc (const rtems_rtl_obj* obj,
+                                       rtems_rtl_obj_sect* sect);
+ * Architecture specific handler to free a section. Some sections are
+bool rtems_rtl_elf_arch_section_free (const rtems_rtl_obj* obj,
  * Architecture specific handler to check is a relocation record's type is
  * required to resolve a symbol.
diff --git a/cpukit/libdl/rtl-error.c b/cpukit/libdl/rtl-error.c
index 7b72c0a26d..acd89ac07d 100644
--- a/cpukit/libdl/rtl-error.c
+++ b/cpukit/libdl/rtl-error.c
@@ -44,6 +44,7 @@ rtems_rtl_get_error (char* message, size_t max_message)
   if (rtl != NULL)
     int last_errno = rtl->last_errno;
+    rtl->last_errno = 0;
     strlcpy (message, rtl->last_error, max_message);
     rtems_rtl_unlock ();
     return last_errno;
diff --git a/cpukit/libdl/rtl-mdreloc-arm.c b/cpukit/libdl/rtl-mdreloc-arm.c
index 19a5904a25..b0c55c257a 100644
--- a/cpukit/libdl/rtl-mdreloc-arm.c
+++ b/cpukit/libdl/rtl-mdreloc-arm.c
@@ -109,6 +109,38 @@ rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
   return flags;
+uint32_t
+rtems_rtl_elf_arch_parse_section (const rtems_rtl_obj* obj,
+                                  int                  section,
+                                  const char*          name,
+  (void) obj;
+  (void) section;
+  (void) name;
+  (void) shdr;
+  return flags;
+bool
+rtems_rtl_elf_arch_section_alloc (const rtems_rtl_obj* obj,
+  (void) obj;
+  (void) sect;
+  return false;
+bool
+rtems_rtl_elf_arch_section_free (const rtems_rtl_obj* obj,
+  (void) obj;
+  (void) sect;
+  return false;
 bool
 rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
@@ -152,7 +184,7 @@ rtems_rtl_elf_relocate_rela (rtems_rtl_obj*            obj,
 static bool
-rtems_rtl_elf_relor_rel (rtems_rtl_obj*            obj,
+rtems_rtl_elf_reloc_rel (rtems_rtl_obj*            obj,
                          const Elf_Rel*            rel,
                          const rtems_rtl_obj_sect* sect,
                          const char*               symname,
@@ -493,7 +525,7 @@ rtems_rtl_elf_relocate_rel_tramp (rtems_rtl_obj*            obj,
                                   const Elf_Byte            syminfo,
                                   const Elf_Word            symvalue)
-  return rtems_rtl_elf_relor_rel (obj,
+  return rtems_rtl_elf_reloc_rel (obj,
                                   rel,
                                   sect,
                                   symname,
@@ -510,7 +542,7 @@ rtems_rtl_elf_relocate_rel (rtems_rtl_obj*            obj,
                                   rel,
                                   sect,
                                   symname,
diff --git a/cpukit/libdl/rtl-mdreloc-bfin.c b/cpukit/libdl/rtl-mdreloc-bfin.c
index b4c20fac24..af130276a4 100644
--- a/cpukit/libdl/rtl-mdreloc-bfin.c
+++ b/cpukit/libdl/rtl-mdreloc-bfin.c
@@ -16,6 +16,38 @@ rtems_rtl_elf_section_flags (const rtems_rtl_obj_t* obj,
   return 0;
+uint32_t
+                                  int                  section,
+                                  const char*          name,
+  (void) obj;
+  (void) section;
+  (void) name;
+  (void) shdr;
+  return flags;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-h8300.c b/cpukit/libdl/rtl-mdreloc-h8300.c
index e0cb826dc8..4a12f34f36 100644
--- a/cpukit/libdl/rtl-mdreloc-h8300.c
+++ b/cpukit/libdl/rtl-mdreloc-h8300.c
@@ -19,6 +19,38 @@ rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
   return 0;
+uint32_t
+                                  int                  section,
+                                  const char*          name,
+  (void) obj;
+  (void) section;
+  (void) name;
+  (void) shdr;
+  return flags;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-i386.c b/cpukit/libdl/rtl-mdreloc-i386.c
index 016f99f379..576914cf04 100644
--- a/cpukit/libdl/rtl-mdreloc-i386.c
+++ b/cpukit/libdl/rtl-mdreloc-i386.c
@@ -26,6 +26,38 @@ rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
   return 0;
+uint32_t
+                                  int                  section,
+                                  const char*          name,
+  (void) obj;
+  (void) section;
+  (void) name;
+  (void) shdr;
+  return flags;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-lm32.c b/cpukit/libdl/rtl-mdreloc-lm32.c
index cf64ea8fb3..9f4606ebad 100644
--- a/cpukit/libdl/rtl-mdreloc-lm32.c
+++ b/cpukit/libdl/rtl-mdreloc-lm32.c
   return 0;
+uint32_t
+                                  int                  section,
+                                  const char*          name,
+  (void) obj;
+  (void) section;
+  (void) name;
+  (void) shdr;
+  return flags;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-m68k.c b/cpukit/libdl/rtl-mdreloc-m68k.c
index 1981e93d56..21a60ee62a 100644
--- a/cpukit/libdl/rtl-mdreloc-m68k.c
+++ b/cpukit/libdl/rtl-mdreloc-m68k.c
@@ -39,6 +39,38 @@ rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
   return 0;
+uint32_t
+                                  int                  section,
+                                  const char*          name,
+  (void) obj;
+  (void) section;
+  (void) name;
+  (void) shdr;
+  return flags;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
 bool
@@ -156,12 +188,12 @@ rtems_rtl_elf_relocate_rela (rtems_rtl_obj*            obj,
 			break;
 		default:
-      printf ("rtl: reloc unknown: sym = %lu, type = %lu, offset = %p, "
+      printf ("rtl: reloc unknown: sym = %u, type = %u, offset = %p, "
               "contents = %p\n",
               ELF_R_SYM(rela->r_info), (uint32_t) ELF_R_TYPE(rela->r_info),
               (void *)rela->r_offset, (void *)*where);
       rtems_rtl_set_error (EINVAL,
-                           "%s: Unsupported relocation type %ld "
+                           "%s: Unsupported relocation type %d "
                            "in non-PLT relocations",
                            sect->name, (uint32_t) ELF_R_TYPE(rela->r_info));
       return false;
diff --git a/cpukit/libdl/rtl-mdreloc-mips.c b/cpukit/libdl/rtl-mdreloc-mips.c
index 4860fdfe72..f01a6552a5 100644
--- a/cpukit/libdl/rtl-mdreloc-mips.c
+++ b/cpukit/libdl/rtl-mdreloc-mips.c
   return 0;
+uint32_t
+                                  int                  section,
+                                  const char*          name,
+  (void) obj;
+  (void) section;
+  (void) name;
+  (void) shdr;
+  return flags;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-moxie.c b/cpukit/libdl/rtl-mdreloc-moxie.c
index cc0558eaa5..68fa2d2a16 100644
--- a/cpukit/libdl/rtl-mdreloc-moxie.c
+++ b/cpukit/libdl/rtl-mdreloc-moxie.c
@@ -20,6 +20,38 @@ rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
   return 0;
+uint32_t
+                                  int                  section,
+                                  const char*          name,
+  (void) obj;
+  (void) section;
+  (void) name;
+  (void) shdr;
+  return flags;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-powerpc.c b/cpukit/libdl/rtl-mdreloc-powerpc.c
index b205ed5215..5c52823a0f 100644
--- a/cpukit/libdl/rtl-mdreloc-powerpc.c
+++ b/cpukit/libdl/rtl-mdreloc-powerpc.c
@@ -13,6 +13,7 @@
 #include <sys/stat.h>
 #include <rtems/rtl/rtl.h>
 #include "rtl-elf.h"
@@ -23,6 +24,57 @@
                  ((u_int32_t)(x) + 0x10000) : (u_int32_t)(x)) >> 16)
 #define l(x) ((u_int32_t)(x) & 0xffff)
+ * SDATA allocator.
+static rtems_rtl_bit_alloc* sdata;
+static Elf_Addr
+get_sda_base (void)
+  uint32_t sda_base;
+  __asm__ volatile (" mr %0, 13\n" : "=r" (sda_base));
+  return sda_base;
+ *  Access the variables via asm statements to avoid any fix up issues
+ *  generated by the C compiler which thinks they belong in the .sdata
+ *  section.
+#define GET_ADDR(_l, _v) \
+  __asm__ volatile (" lis %0, " #_l "@h\n" \
+                    " ori %0, %0, " #_l "@l\n" : "=r" (_v))
+static void*
+get_sdata_start (void)
+  Elf_Addr addr;
+  GET_ADDR(__SDATA_START__, addr);
+  return (void*) addr;
+static size_t
+get_sdata_sbss_size (void)
+  Elf_Addr sdata_begin;
+  Elf_Addr sbss_end;
+  GET_ADDR(bsp_section_sdata_begin, sdata_begin);
+  GET_ADDR(bsp_section_sbss_end, sbss_end);
+  return sbss_end - sdata_begin;
+static size_t
+get_sdata_libdl_size (void)
+  Elf_Addr begin;
+  Elf_Addr end;
+  GET_ADDR(bsp_section_sdata_libdl_begin, begin);
+  GET_ADDR(bsp_section_sdata_libdl_end, end);
+  return end - begin;
 uint32_t
@@ -30,6 +82,75 @@ rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
   return 0;
+uint32_t
+                                  int                  section,
+                                  const char*          name,
+  struct {
+    const char* label;
+    size_t      len;
+  } prefix[] = {
+    #define SEPARATED_PREFIX(_p) { _p, sizeof (_p) - 1 }
+    SEPARATED_PREFIX (".sdata"),
+    SEPARATED_PREFIX (".sbss"),
+  const size_t prefixes = sizeof (prefix) / sizeof (prefix[0]);
+  size_t       p;
+  for (p = 0; p < prefixes; ++p)
+    if (strncmp (name, prefix[p].label, prefix[p].len) == 0)
+      return flags | RTEMS_RTL_OBJ_SECT_ARCH_ALLOC;
+  return flags;
+bool
+  if (rtems_rtl_trace (RTEMS_RTL_TRACE_DETAIL))
+    printf ("rtl: section: arch: alloc: name=%s size=%zu flags=%08" PRIx32 \
+            " order=%i link=%d info=%d\n",
+            sect->name, sect->size, sect->flags, sect->load_order,
+            sect->link, sect->info);
+  if (sdata == NULL)
+    sdata = rtems_rtl_bit_alloc_open (get_sdata_start (),
+                                      get_sdata_libdl_size (),
+                                      sizeof (uint32_t),
+                                      get_sdata_sbss_size ());
+      rtems_rtl_set_error (ENOMEM, "no memory for sdata allocator");
+      return false;
+  sect->base = rtems_rtl_bit_alloc_balloc (sdata, sect->size);
+  if (sect->base == NULL)
+    rtems_rtl_set_error (ENOMEM, "no .sdata memory: %s", sect->name);
+    return false;
+  return true;
+bool
+    printf ("rtl: section: arch: free: name=%s size=%zu\n", sect->name, sect->size);
+  if (sdata != NULL)
+    rtems_rtl_bit_alloc_bfree (sdata, sect->base, sect->size);
+  return true;
 bool
@@ -40,35 +161,51 @@ size_t
 rtems_rtl_elf_relocate_tramp_max_size (void)
-   * Disable by returning 0.
+   * We have 4 instructions and each instruction is 32bits.
-  return 0;
+  return 4 * 4;
-bool
-rtems_rtl_elf_relocate_rela_tramp (rtems_rtl_obj*            obj,
-                                   const Elf_Rela*           rela,
-                                   const rtems_rtl_obj_sect* sect,
-                                   const char*               symname,
-                                   const Elf_Byte            syminfo,
-                                   const Elf_Word            symvalue)
+static void*
+set_veneer (void* tramopline, Elf_Addr target)
-  (void) obj;
-  (void) rela;
-  (void) sect;
-  (void) symname;
-  (void) syminfo;
-  (void) symvalue;
-  return true;
+   * http://shell-storm.org/online/Online-Assembler-and-Disassembler/
+   *  lis   12,0x1234
+   *  ori   12,12,0x5678
+   *  mtctr 12
+   *  bctr
+#if COMPILE_ASM
+  asm volatile (" lis   12,0x1234\n" \
+                " ori   12,12,0x5678\n" \
+                " mtctr 12\n" \
+                " bctr\n");
+#endif
+  uint32_t* tramp = (uint32_t*) tramopline;
+  *tramp++ = 0x3d800000 | (target >> 16);
+  *tramp++ = 0x618c0000 | (target & 0xffff);
+  *tramp++ = 0x7d8903a6;
+  *tramp++ = 0x4e800420;
+  return tramp;
-bool
-rtems_rtl_elf_relocate_rela (rtems_rtl_obj*            obj,
+static size_t
+get_veneer_size (int type)
+  (void) type;
+  return rtems_rtl_elf_relocate_tramp_max_size ();
+static bool
+rtems_rtl_elf_reloc_rela (rtems_rtl_obj*            obj,
+                          const Elf_Rela*           rela,
+                          const rtems_rtl_obj_sect* sect,
+                          const char*               symname,
+                          const Elf_Byte            syminfo,
+                          const Elf_Word            symvalue,
+                          const bool                parsing)
   Elf_Addr* where;
   Elf_Word tmp;
@@ -84,10 +221,12 @@ rtems_rtl_elf_relocate_rela (rtems_rtl_obj*            obj,
        * value:1; Field: word32; Expression: S + A
-      *where = symvalue + rela->r_addend;
-      if (rtems_rtl_trace (RTEMS_RTL_TRACE_RELOC))
-        printf ("rtl: ADDR32 %p @ %p in %s\n",
-                (void *)*(where), where, rtems_rtl_obj_oname (obj));
+      if (!parsing) {
+        *where = symvalue + rela->r_addend;
+        if (rtems_rtl_trace (RTEMS_RTL_TRACE_RELOC))
+          printf ("rtl: ADDR32 %p @ %p in %s\n",
+                  (void *)*(where), where, rtems_rtl_obj_oname (obj));
       break;
     case R_TYPE(14):
@@ -107,47 +246,67 @@ rtems_rtl_elf_relocate_rela (rtems_rtl_obj*            obj,
       tmp = (symvalue + rela->r_addend) >> 2;
       if (tmp > ((1<<bits) - 1 )) {
-        printf("Overflow ADDR14/ADDR24\n");
-        return false;
+        Elf_Word tramp_addr;
+        size_t   tramp_size = get_veneer_size(ELF_R_TYPE(rela->r_info));
+        if (parsing) {
+          obj->tramp_size += tramp_size;
+          return true;
+        tramp_addr = (Elf_Addr) obj->tramp_brk;
+        obj->tramp_brk = set_veneer(obj->tramp_brk,
+                                    symvalue + rela->r_addend);
+        tmp = *where;
+        tmp &= ~mask;
+        tmp |= (tramp_addr + rela->r_addend) & mask;
+      else {
+        tmp = *where;
+        tmp &= ~mask;
+        tmp |= (symvalue + rela->r_addend) & mask;
+      if (!parsing) {
+        *where = tmp;
+          printf ("rtl: ADDR14/ADDR24 %p @ %p in %s\n",
+                  (void *)*where, where, rtems_rtl_obj_oname (obj));
-      tmp = *where;
-      tmp &= ~mask;
-      tmp |= (symvalue + rela->r_addend) & mask;
-      *where = tmp;
-        printf ("rtl: ADDR14/ADDR24 %p @ %p in %s\n",
-                (void *)*where, where, rtems_rtl_obj_oname (obj));
       break;
     case R_TYPE(16_HA):
        * value:6; Field:half16; Expression: #ha(S+A)
-      tmp = symvalue + rela->r_addend;
-      *(uint16_t *)where = (((tmp >> 16) + ((tmp & 0x8000) ? 1: 0)) & 0xffff);
-        printf ("rtl: 16_HA %p @ %p in %s\n",
+      if (!parsing) {
+        tmp = symvalue + rela->r_addend;
+        *(uint16_t *)where = (((tmp >> 16) + ((tmp & 0x8000) ? 1: 0)) & 0xffff);
+          printf ("rtl: 16_HA %p @ %p in %s\n",
       break;
     case R_TYPE(16_HI):
        * value:5; Field:half16; Expression: #hi(S+A)
-      *(uint16_t *)where = ((symvalue + rela->r_addend) >> 16) & 0xffff;
-        printf ("rtl: 16_HI %p @ %p in %s\n",
+      if (!parsing) {
+        *(uint16_t *)where = ((symvalue + rela->r_addend) >> 16) & 0xffff;
+          printf ("rtl: 16_HI %p @ %p in %s\n",
       break;
     case R_TYPE(16_LO):
        * value:4; Field:half16; Expression: #lo(S+A)
-      *(uint16_t *)where = (symvalue + (rela->r_addend)) & 0xffff;
-        printf ("rtl: 16_LO %p @ %p in %s\n",
+      if (!parsing) {
+        *(uint16_t *)where = (symvalue + (rela->r_addend)) & 0xffff;
+          printf ("rtl: 16_LO %p @ %p in %s\n",
       break;
     case R_TYPE(REL14):
@@ -170,27 +329,44 @@ rtems_rtl_elf_relocate_rela (rtems_rtl_obj*            obj,
       tmp =((int) (symvalue + rela->r_addend - (Elf_Addr)where)) >> 2;
       if (((Elf_Sword)tmp > ((1<<(bits-1)) - 1)) ||
           ((Elf_Sword)tmp < -(1<<(bits-1)))) {
-        printf("Overflow REL14/REL24\n");
-        return false;
+        if (parsing) {
+          return true;
+        tmp = *where;
+        tmp &= ~mask;
+        tmp |= (tramp_addr + rela->r_addend - (Elf_Addr)where) & mask;
+      else
+        tmp = *where;
+        tmp &= ~mask;
+        tmp |= (symvalue + rela->r_addend - (Elf_Addr)where) & mask;
-      tmp = *where;
-      tmp &= ~mask;
-      tmp |= (symvalue + rela->r_addend - (Elf_Addr)where) & mask;
-      *where = tmp;
-        printf ("rtl: REL24/REL14 %p @ %p in %s\n",
+      if (!parsing) {
+        *where = tmp;
+          printf ("rtl: REL24/REL14 %p @ %p in %s\n",
       break;
     case R_TYPE(REL32):
        * value:26; Field:word32*; Expression:S+A-P
-      *where = symvalue + rela->r_addend - (Elf_Addr)where;
-        printf ("rtl: REL32 %p @ %p in %s\n",
+      if (!parsing) {
+        *where = symvalue + rela->r_addend - (Elf_Addr)where;
+          printf ("rtl: REL32 %p @ %p in %s\n",
       break;
     case R_TYPE(SDAREL16):
@@ -198,19 +374,22 @@ rtems_rtl_elf_relocate_rela (rtems_rtl_obj*            obj,
        * A sign-extended 16 bit value relative to _SDA_BASE_, for use with
        * small data items.
-      mask = 0xffff;
-      tmp = *((Elf32_Half*) where);
-      tmp &= ~mask;
-      *((Elf32_Half*) where) = tmp;
-        printf ("rtl: SDAREL16 %p @ %p in %s\n",
-                (void *) (uintptr_t) *((Elf32_Half*) where),
-                where, rtems_rtl_obj_oname (obj));
+      if (!parsing) {
+        Elf_Addr sda_base = get_sda_base ();
+        mask = 0xffff;
+        tmp = *((Elf32_Half*) where);
+        tmp &= ~mask;
+        tmp |= (symvalue + rela->r_addend - sda_base) & mask;
+        *((Elf32_Half*) where) = tmp;
+          printf ("rtl: SDAREL16 %p @ %p in %s\n",
+                  (void *) (uintptr_t) *((Elf32_Half*) where),
+                  where, rtems_rtl_obj_oname (obj));
       break;
     default:
-      printf ("rtl: reloc unknown: sym = %lu, type = %" PRIu32 ", offset = %p, "
+      printf ("rtl: reloc unknown: sym = %" PRIu32 ", type = %" PRIu32 ", offset = %p, "
               "contents = %p\n",
@@ -223,6 +402,40 @@ rtems_rtl_elf_relocate_rela (rtems_rtl_obj*            obj,
   return true;
+bool
+rtems_rtl_elf_relocate_rela_tramp (rtems_rtl_obj*            obj,
+                                   const Elf_Word            symvalue)
+  return rtems_rtl_elf_reloc_rela (obj,
+                                   rela,
+                                   sect,
+                                   symname,
+                                   syminfo,
+                                   symvalue,
+                                   true);
+bool
+rtems_rtl_elf_relocate_rela (rtems_rtl_obj*            obj,
+                                   rela,
+                                   sect,
+                                   symname,
+                                   syminfo,
+                                   symvalue,
+                                   false);
 bool
                                   const Elf_Rel*            rel,
diff --git a/cpukit/libdl/rtl-mdreloc-sparc.c b/cpukit/libdl/rtl-mdreloc-sparc.c
index bc05392659..f76da575e4 100644
--- a/cpukit/libdl/rtl-mdreloc-sparc.c
+++ b/cpukit/libdl/rtl-mdreloc-sparc.c
@@ -138,6 +138,38 @@ rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
   return 0;
+uint32_t
+                                  int                  section,
+                                  const char*          name,
+  (void) obj;
+  (void) section;
+  (void) name;
+  (void) shdr;
+  return flags;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-v850.c b/cpukit/libdl/rtl-mdreloc-v850.c
index 2aca5e0270..93e531b40e 100644
--- a/cpukit/libdl/rtl-mdreloc-v850.c
+++ b/cpukit/libdl/rtl-mdreloc-v850.c
   return 0;
+uint32_t
+                                  int                  section,
+                                  const char*          name,
+  (void) obj;
+  (void) section;
+  (void) name;
+  (void) shdr;
+  return flags;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
+bool
+  (void) obj;
+  (void) sect;
+  return false;
 bool
diff --git a/cpukit/libdl/rtl-obj.c b/cpukit/libdl/rtl-obj.c
index 0a7763b3b2..15e5bf1137 100644
--- a/cpukit/libdl/rtl-obj.c
+++ b/cpukit/libdl/rtl-obj.c
@@ -300,11 +300,14 @@ typedef struct
 static bool
 rtems_rtl_obj_sect_summer (rtems_chain_node* node, void* data)
-  rtems_rtl_obj_sect*             sect = (rtems_rtl_obj_sect*) node;
-  rtems_rtl_obj_sect_summer_data* summer = data;
-  if ((sect->flags & summer->mask) == summer->mask)
-    summer->size =
-      rtems_rtl_obj_align (summer->size, sect->alignment) + sect->size;
+  rtems_rtl_obj_sect* sect = (rtems_rtl_obj_sect*) node;
+  if ((sect->flags & RTEMS_RTL_OBJ_SECT_ARCH_ALLOC) == 0)
+    rtems_rtl_obj_sect_summer_data* summer = data;
+    if ((sect->flags & summer->mask) == summer->mask)
+      summer->size =
+        rtems_rtl_obj_align (summer->size, sect->alignment) + sect->size;
   return true;
@@ -821,7 +824,9 @@ rtems_rtl_obj_relocate (rtems_rtl_obj*             obj,
   const uint32_t flags = (RTEMS_RTL_OBJ_SECT_LOAD |
                           RTEMS_RTL_OBJ_SECT_REL |
                           RTEMS_RTL_OBJ_SECT_RELA);
-  return rtems_rtl_obj_section_handler (flags, obj, fd, handler, data);
+  bool r = rtems_rtl_obj_section_handler (flags, obj, fd, handler, data);
+  rtems_rtl_obj_update_flags (RTEMS_RTL_OBJ_RELOC_TAG, 0);
+  return r;
@@ -993,7 +998,7 @@ rtems_rtl_obj_sections_link_order (uint32_t mask, rtems_rtl_obj* obj)
-static size_t
+static bool
 rtems_rtl_obj_sections_loader (uint32_t                   mask,
                                rtems_rtl_obj*             obj,
                                int                        fd,
@@ -1004,26 +1009,27 @@ rtems_rtl_obj_sections_loader (uint32_t                   mask,
   rtems_chain_control* sections = &obj->sections;
   rtems_chain_node*    node = rtems_chain_first (sections);
   size_t               base_offset = 0;
-  bool                 first = true;
   int                  order = 0;
+  if (rtems_rtl_trace (RTEMS_RTL_TRACE_LOAD_SECT))
+    printf ("rtl: loading section: mask:%08" PRIx32 " base:%p\n", mask, base);
   while (!rtems_chain_is_tail (sections, node))
-    if ((sect->size != 0) && ((sect->flags & mask) != 0))
+    if ((sect->size != 0) && ((sect->flags & mask) == mask))
       if (sect->load_order == order)
-        if (!first)
           base_offset = rtems_rtl_obj_align (base_offset, sect->alignment);
-        first = false;
-        sect->base = base + base_offset;
+          sect->base = base + base_offset;
-          printf ("rtl: loading:%2d: %s -> %8p (s:%zi f:%04" PRIx32
+          printf ("rtl: loading:%2d: %s -> %p (s:%zi f:%04" PRIx32
                   " a:%" PRIu32 " l:%02d)\n",
                   order, sect->name, sect->base, sect->size,
                   sect->flags, sect->alignment, sect->link);
@@ -1038,7 +1044,7 @@ rtems_rtl_obj_sections_loader (uint32_t                   mask,
         else if ((sect->flags & RTEMS_RTL_OBJ_SECT_ZERO) == RTEMS_RTL_OBJ_SECT_ZERO)
-          memset (base + base_offset, 0, sect->size);
+          memset (sect->base, 0, sect->size);
         else
@@ -1065,10 +1071,10 @@ rtems_rtl_obj_sections_loader (uint32_t                   mask,
 bool
-rtems_rtl_obj_load_sections (rtems_rtl_obj*             obj,
-                             int                        fd,
-                             rtems_rtl_obj_sect_handler handler,
-                             void*                      data)
+                              int                        fd,
+                              void*                      data)
   size_t text_size;
   size_t const_size;
@@ -1091,6 +1097,22 @@ rtems_rtl_obj_load_sections (rtems_rtl_obj*             obj,
   obj->eh_size    = eh_size;
   obj->bss_size   = bss_size;
+   * Perform any specific allocations for sections.
+  if (handler != NULL)
+    if (!rtems_rtl_obj_section_handler (RTEMS_RTL_OBJ_SECT_TYPES,
+                                        obj,
+                                        fd,
+                                        handler,
+                                        data))
+      obj->exec_size = 0;
+      return false;
    * Let the allocator manage the actual allocation. The user can use the
    * standard heap or provide a specific allocator with memory protection.
@@ -1129,10 +1151,21 @@ rtems_rtl_obj_load_sections (rtems_rtl_obj*             obj,
   rtems_rtl_obj_sections_link_order (RTEMS_RTL_OBJ_SECT_CONST, obj);
   rtems_rtl_obj_sections_link_order (RTEMS_RTL_OBJ_SECT_EH,    obj);
   rtems_rtl_obj_sections_link_order (RTEMS_RTL_OBJ_SECT_DATA,  obj);
+  rtems_rtl_obj_sections_link_order (RTEMS_RTL_OBJ_SECT_BSS,   obj);
+  return true;
+bool
+rtems_rtl_obj_load_sections (rtems_rtl_obj*             obj,
+                             int                        fd,
+                             void*                      data)
-   * Load all text then data then bss sections in seperate operations so each
-   * type of section is grouped together.
+   * Load all text, data and bsssections in seperate operations so each type of
+   * section is grouped together. Finish by loading any architecure specific
+   * sections.
   if (!rtems_rtl_obj_sections_loader (RTEMS_RTL_OBJ_SECT_TEXT,
                                       obj, fd, obj->text_base, handler, data) ||
diff --git a/cpukit/libdl/rtl-shell.c b/cpukit/libdl/rtl-shell.c
index ab5553174b..7458fb5608 100644
--- a/cpukit/libdl/rtl-shell.c
+++ b/cpukit/libdl/rtl-shell.c
@@ -175,7 +175,7 @@ rtems_rtl_dependencies (rtems_rtl_obj* obj,
   rtems_rtl_dep_data* dd = (rtems_rtl_dep_data*) data;
   if (!dd->first)
-    printf ("\n%-*c: ", dd->indent, ' ');
+    printf ("\n%-*c: ", (int) dd->indent, ' ');
   else
     dd->first = false;
   printf ("%s", dependent->oname);
diff --git a/cpukit/libdl/rtl-unresolved.c b/cpukit/libdl/rtl-unresolved.c
index 0e70c5dacf..7ee572c351 100644
--- a/cpukit/libdl/rtl-unresolved.c
+++ b/cpukit/libdl/rtl-unresolved.c
@@ -700,7 +700,7 @@ rtems_rtl_unresolved_dump_iterator (rtems_rtl_unresolv_rec* rec,
     break;
   case rtems_rtl_unresolved_symbol:
     ++dd->names;
-    printf (" %3zu: 1:  name: %3d refs:%4d: flags:%04x %s (%d)\n",
+    printf (" %3zu: 1:  name: %3zu refs:%4d: flags:%04x %s (%d)\n",
             dd->rec, dd->names,
             rec->rec.name.refs,
             rec->rec.name.flags,
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index 166f45e21b..789380ce72 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -390,8 +390,9 @@ if TEST_dl03
 lib_tests += dl03
 lib_screens += dl03/dl03.scn
 lib_docs += dl03/dl03.doc
-dl03_SOURCES = dl03/init.c dl03/dl-cache.c
-dl03_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_dl03) $(support_includes)
+dl03_SOURCES = dl03/init.c dl03/dl-cache.c dl03/dl-bit-alloc.c
+dl03_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_dl03) $(support_includes) \
+	-I$(top_srcdir)/../../cpukit/libdl
 endif
 endif
@@ -533,7 +534,7 @@ dl07-o3.o: dl07/dl-o3.c Makefile
 dl07-o4.o: dl07/dl-o4.c Makefile
 	$(AM_V_CC)$(COMPILE) -c -o $@ $<
 dl07-o5.o: dl07/dl-o5.c Makefile
-	$(AM_V_CC)$(COMPILE) -c -o $@ $<
+	$(AM_V_CC) $(COMPILE) -c -o $@ $<
 dl07.tar: dl07-o1.o dl07-o2.o dl07-o3.o dl07-o4.o dl07-o5.o
 	@rm -f $@
 	$(AM_V_GEN)$(PAX) -w -f $@ $+
diff --git a/testsuites/libtests/dl01/dl-load.c b/testsuites/libtests/dl01/dl-load.c
index d93550d15b..f807d2a060 100644
--- a/testsuites/libtests/dl01/dl-load.c
+++ b/testsuites/libtests/dl01/dl-load.c
@@ -26,6 +26,7 @@
                       RTEMS_RTL_TRACE_ALLOCATOR | \
                       RTEMS_RTL_TRACE_UNRESOLVED | \
                       RTEMS_RTL_TRACE_ARCHIVES | \
+                      RTEMS_RTL_TRACE_GLOBAL_SYM | \
                       RTEMS_RTL_TRACE_DEPENDENCY)
  #define DL_DEBUG_TRACE DEBUG_TRACE /* RTEMS_RTL_TRACE_ALL */
  #define DL_RTL_CMDS    1
diff --git a/testsuites/libtests/dl02/dl-load.c b/testsuites/libtests/dl02/dl-load.c
index 0fa897d5a0..2e76c2dea6 100644
--- a/testsuites/libtests/dl02/dl-load.c
+++ b/testsuites/libtests/dl02/dl-load.c
@@ -15,8 +15,14 @@
 #include <rtems/rtl/rtl-shell.h>
-#define DL02_DEBUG_TRACE 0 /* RTEMS_RTL_TRACE_ALL */
-#define DL02_RTL_CMDS    0
+#define TEST_TRACE 0
+#if TEST_TRACE
+ #define DL_DEBUG_TRACE (RTEMS_RTL_TRACE_ALL & ~RTEMS_RTL_TRACE_ALLOCATOR)
+ #define DL_RTL_CMDS    1
+#else
+ #define DL_DEBUG_TRACE 0
+ #define DL_RTL_CMDS    0
+#endif
 typedef int (*call_t)(int argc, const char* argv[]);
@@ -55,8 +61,8 @@ int dl_load_test(void)
   int    call_ret;
   int    ret;
-#if DL02_DEBUG_TRACE
-  rtems_rtl_trace_set_mask (DL02_DEBUG_TRACE);
+#if DL_DEBUG_TRACE
+  rtems_rtl_trace_set_mask (DL_DEBUG_TRACE);
 #endif
   o1 = dl_load_obj("/dl02-o1.o");
@@ -66,7 +72,7 @@ int dl_load_test(void)
   if (!o1)
     return 1;
-#if DL02_RTL_CMDS
+#if DL_RTL_CMDS
     char* list[] = { "rtl", "list", NULL };
     rtems_rtl_shell_command (2, list);
diff --git a/testsuites/libtests/dl02/dl-o1.c b/testsuites/libtests/dl02/dl-o1.c
index a4355d6e37..2afb618800 100644
--- a/testsuites/libtests/dl02/dl-o1.c
+++ b/testsuites/libtests/dl02/dl-o1.c
@@ -36,9 +36,12 @@ static int dl_o1_callback(const char* message, int count)
 int rtems_main (int argc, const char* argv[]);
+#define PDOUBLE(_d) ((int) (_d)), (int) ((_d) * 100.0) % 100
   func1_t f1;
+  double  f2_ret;
   int     arg;
   int     ret;
@@ -56,9 +59,12 @@ int rtems_main (int argc, const char* argv[])
     return 0;
-  if (dl_o2_func2 (7.1, 33.0) != (7.1 * 33.0))
+  f2_ret = dl_o2_func2 (7.1, 33.0);
+  printf("rtems_main: dl_o2_func2 returned: %d.%02d\n",
+         PDOUBLE(f2_ret));
+  if (f2_ret != (7.1 * 33.0))
-    printf("rtems_main: dl_o2_func1 returned bad value\n");
+    printf("rtems_main: dl_o2_func2 returned a bad\n");
     return 0;
diff --git a/testsuites/libtests/dl02/dl-o2.c b/testsuites/libtests/dl02/dl-o2.c
index 4c1a918dea..507333535b 100644
--- a/testsuites/libtests/dl02/dl-o2.c
+++ b/testsuites/libtests/dl02/dl-o2.c
@@ -10,7 +10,7 @@
 #include <rtems/test.h>
-#define printf(...) rtems_printf(&rtems_test_printer, __VA_ARGS__);
+#define printf(...) rtems_printf(&rtems_test_printer, __VA_ARGS__)
 int dl_o2_func1 (int argc, char* argv[])
@@ -21,13 +21,17 @@ int dl_o2_func1 (int argc, char* argv[])
   return argc;
+#define PDOUBLE(_d) ((int) (_d)), (int) (((_d) + 0.005) * 100.0) % 100
 double dl_o2_func2 (double d1, double d2)
-  return d1 * d2;
+  double ret = d1 * d2;
+  printf("dl_o2_func2: d1=%d.%02d d2=%d.%d ret=%d.%02d\n",
+	 PDOUBLE(d1), PDOUBLE(d2), PDOUBLE(ret));
+  return ret;
 int dl_o2_func3 (dl_o2_call_t callback, int count)
   return callback ("string in dl_o2", count + 1);
diff --git a/testsuites/libtests/dl03/dl-bit-alloc.c b/testsuites/libtests/dl03/dl-bit-alloc.c
index 0000000000..210f826f03
--- /dev/null
+++ b/testsuites/libtests/dl03/dl-bit-alloc.c
@@ -0,0 +1,262 @@
+ * Copyright (c) 2016, 2018 Chris Johns <chrisj at rtems.org>.  All rights reserved.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include "tmacros.h"
+#include <sys/types.h>
+#include <unistd.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <rtems.h>
+#include <rtems/dumpbuf.h>
+#include <rtems/rtl/rtl.h>
+#include "dl-bit-alloc.h"
+#define NUM(m) (sizeof(m) / sizeof(m[0]))
+typedef struct
+  size_t          size;
+  const uint32_t* map;
+  size_t          map_size;
+} alloc_check;
+const uint32_t map_1[] = {
+  0x0000003f,
+  0x00000000,
+  0x00000000,
+  0x00000000
+const uint32_t map_a_1[] = {
+  0xffffffff,
+  0x00000000,
+  0x00000000,
+  0x00000000
+const uint32_t map_a_2[] = {
+  0xffffffff,
+  0x00000001,
+  0x00000000,
+  0x00000000
+const uint32_t map_a_3[] = {
+  0xffffffff,
+  0x00000007,
+  0x00000000,
+  0x00000000
+const uint32_t map_a_4[] = {
+  0xffffffff,
+  0x00000fff,
+  0x00000000,
+  0x00000000
+const uint32_t map_a_5[] = {
+  0xffffffff,
+  0x00001fff,
+  0x00000000,
+  0x00000000
+const uint32_t map_a_6[] = {
+  0xffffffff,
+  0x00007fff,
+  0x00000000,
+  0x00000000
+const uint32_t map_a_7[] = {
+  0xffffffff,
+  0x0007ffff,
+  0x00000000,
+  0x00000000
+const uint32_t map_a_8[] = {
+  0xffffffff,
+  0x07ffffff,
+  0x00000000,
+  0x00000000
+const uint32_t map_b_1[] = {
+  0xffffffff,
+  0x07ffffff,
+  0x00000000,
+  0x00000000
+const uint32_t map_b_2[] = {
+  0xffffffff,
+  0x07ffffff,
+  0x00000000,
+  0x00000000
+const uint32_t map_b_3[] = {
+  0xffffffff,
+  0x07ffffff,
+  0x00000000,
+  0x00000000
+const uint32_t map_b_4[] = {
+  0xffffffff,
+  0x07ffffff,
+  0x00000000,
+  0x00000000
+const uint32_t map_free_1[] = {
+  0xffffffff,
+  0x07ffffff,
+  0x00000000,
+  0x00000000
+alloc_check a_allocs[] = {
+  { 26 * sizeof(uint32_t), map_a_1, NUM(map_a_1) },
+  { 4,                     map_a_2, NUM(map_a_2) },
+  { 8,                     map_a_3, NUM(map_a_3) },
+  { 34,                    map_a_4, NUM(map_a_4) },
+  { 4,                     map_a_5, NUM(map_a_5) },
+  { 8,                     map_a_6, NUM(map_a_6) },
+  { 16,                    map_a_7, NUM(map_a_7) },
+  { 32,                    map_a_8, NUM(map_a_8) }
+alloc_check b_allocs[] = {
+  { 24, map_b_1, NUM(map_b_1) },
+  { 30, map_b_2, NUM(map_b_2) },
+  { 8,  map_b_3, NUM(map_b_3) },
+  { 4,  map_b_4, NUM(map_b_4) }
+static bool check_bit_map(rtems_rtl_bit_alloc* balloc,
+                          const uint32_t*      map,
+                          size_t               size)
+  size_t i;
+  rtems_print_buffer ((const unsigned char *) balloc->bits, size * sizeof(uint32_t));
+  for (i = 0; i < size; ++i)
+    if (balloc->bits[i] != map[i])
+      printf("bit-map mismatch: %zu: %08" PRIx32 "\n", i, map[i]);
+      return false;
+  return true;
+static void delta_bit_map(rtems_rtl_bit_alloc* balloc, uint32_t* last, size_t size)
+  size_t i;
+    last[i] = last[i] ^ balloc->bits[i];
+  printf("Delta:\n");
+  rtems_print_buffer ((const unsigned char *) last, size * sizeof(uint32_t));
+  memcpy(last, balloc->bits, size * sizeof(uint32_t));
+static void dl_init_rtl(void)
+   * Check the RTL object is created and can be locked and unlocked.
+  rtems_test_assert(rtems_rtl_lock () != NULL);
+  rtems_rtl_unlock ();
+  rtems_test_assert(rtems_rtl_data_unprotected () != NULL);
+  rtems_rtl_trace_set_mask(RTEMS_RTL_TRACE_ALL | RTEMS_RTL_TRACE_CACHE);
+int dl_bit_alloc_test(void)
+  void*                a[NUM(a_allocs)];
+  void*                b[NUM(b_allocs)];
+  uint32_t             last_map[4] = { 0 };
+  size_t               i;
+   * Make sure the RTL can initialise.
+  dl_init_rtl();
+  printf("bit-alloc: open\n");
+  balloc = rtems_rtl_bit_alloc_open(NULL, 64 * 1024, sizeof(uint32_t), 21);
+  rtems_test_assert(balloc != NULL);
+  rtems_test_assert(check_bit_map(balloc, map_1, NUM(map_1)));
+  for (i = 0; i < NUM(a_allocs); ++i)
+    printf("balloc: %zu\n", a_allocs[i].size);
+    a[i] = rtems_rtl_bit_alloc_balloc(balloc, a_allocs[i].size);
+    rtems_test_assert(a[i] != NULL);
+    printf("balloc: a[%zu] %zu %p\n", i, a_allocs[i].size, a[i]);
+    rtems_test_assert(check_bit_map(balloc, a_allocs[i].map, a_allocs[i].map_size));
+    delta_bit_map(balloc, last_map, NUM(last_map));
+  printf("bfree: %p %zu\n", a[3], a_allocs[3].size);
+  rtems_rtl_bit_alloc_bfree(balloc, a[3], a_allocs[3].size);
+  a[3] = NULL;
+  for (i = 0; i < NUM(b_allocs); ++i)
+    printf("balloc: %zu\n", b_allocs[i].size);
+    b[i] = rtems_rtl_bit_alloc_balloc(balloc, b_allocs[i].size);
+    rtems_test_assert(b[i] != NULL);
+    printf("balloc: b[%zu] %zu %p\n", i, b_allocs[i].size, b[i]);
+    rtems_print_buffer ((const unsigned char *) balloc->bits, 8 * sizeof(uint32_t));
+    if (a[i] != NULL)
+      printf("bfree: a[%zu] %p %zu\n", i, a[i], a_allocs[i].size);
+      rtems_rtl_bit_alloc_bfree(balloc, a[i], a_allocs[i].size);
+    if (b[i] != NULL)
+      printf("bfree: b[%zu] %p %zu\n", i, b[i], b_allocs[i].size);
+      rtems_rtl_bit_alloc_bfree(balloc, b[i], b_allocs[i].size);
+  printf("bit-alloc: close\n");
+  rtems_rtl_bit_alloc_close(balloc);
+  return 0;
diff --git a/testsuites/libtests/dl03/dl-bit-alloc.h b/testsuites/libtests/dl03/dl-bit-alloc.h
index 0000000000..5795570397
--- /dev/null
+++ b/testsuites/libtests/dl03/dl-bit-alloc.h
@@ -0,0 +1,14 @@
+ * Copyright (c) 2018 Chris Johns <chrisj at rtems.org>.  All rights reserved.
+#if !defined(_DL_BIT_ALLOC_H_)
+#define _DL_BIT_ALLOC_H_
+int dl_bit_alloc_test(void);
+#endif
diff --git a/testsuites/libtests/dl03/init.c b/testsuites/libtests/dl03/init.c
index 618f29ac2f..6d83762413 100644
--- a/testsuites/libtests/dl03/init.c
+++ b/testsuites/libtests/dl03/init.c
@@ -18,6 +18,7 @@
 #include <unistd.h>
 #include "dl-cache.h"
 const char rtems_test_name[] = "libdl (RTL) 3";
@@ -28,6 +29,9 @@ static int test(void)
   int ret;
   ret = dl_cache_test();
+  if (ret)
+    rtems_test_exit(ret);
+  ret = dl_bit_alloc_test();
   if (ret)
   return 0;
diff --git a/testsuites/libtests/dl05/dl-load.c b/testsuites/libtests/dl05/dl-load.c
index 5ef64577cc..58704c4d14 100644
--- a/testsuites/libtests/dl05/dl-load.c
+++ b/testsuites/libtests/dl05/dl-load.c
@@ -20,6 +20,24 @@
 #include "dl-load.h"
+#if TEST_TRACE
+ #define DEBUG_TRACE (RTEMS_RTL_TRACE_DETAIL | \
+                      RTEMS_RTL_TRACE_WARNING | \
+                      RTEMS_RTL_TRACE_LOAD | \
+                      RTEMS_RTL_TRACE_UNLOAD | \
+                      RTEMS_RTL_TRACE_SYMBOL | \
+                      RTEMS_RTL_TRACE_RELOC | \
+                      RTEMS_RTL_TRACE_ALLOCATOR | \
+                      RTEMS_RTL_TRACE_UNRESOLVED | \
+                      RTEMS_RTL_TRACE_ARCHIVES | \
+                      RTEMS_RTL_TRACE_DEPENDENCY)
+ #define DL_DEBUG_TRACE DEBUG_TRACE /* RTEMS_RTL_TRACE_ALL */
+#else
+#endif
   void*       handle;
@@ -34,7 +52,9 @@ int dl_load_test(void)
   bool        throw_runtime = true;
 #endif
-  rtems_rtl_trace_set_mask(RTEMS_RTL_TRACE_ALL);
+#if DL_DEBUG_TRACE
+#endif
   handle = dlopen("/dl05-o5.o", RTLD_GLOBAL | RTLD_NOW);
   if (handle == NULL)
diff --git a/testsuites/libtests/dl07/dl-load.c b/testsuites/libtests/dl07/dl-load.c
index b0f8bd9dac..b92a745f42 100644
--- a/testsuites/libtests/dl07/dl-load.c
+++ b/testsuites/libtests/dl07/dl-load.c
@@ -7,8 +7,25 @@
-#define DL07_DEBUG_TRACE 0 /* RTEMS_RTL_TRACE_ALL */
-#define DL07_RTL_CMDS    0
+#if TEST_TRACE
+#else
+#endif
 #include <dlfcn.h>
@@ -23,7 +40,7 @@ typedef int (*call_sig)(void);
 static void dl_load_dump (void)
-#if DL07_RTL_CMDS
+#if DL_RTL_CMDS
   char* sym[] = { "rtl", "sym", NULL };
   printf ("RTL List:\n");
@@ -107,8 +124,8 @@ int dl_load_test(void)
   printf ("Test source (link in strstr): %s\n", dl_localise_file (__FILE__));
-#if DL07_DEBUG_TRACE
-  rtems_rtl_trace_set_mask (DL07_DEBUG_TRACE);
+#if DL_DEBUG_TRACE
 #endif
   o1 = dl_load_obj("/dl07-o1.o", false);
diff --git a/testsuites/libtests/dl07/dl-o1.c b/testsuites/libtests/dl07/dl-o1.c
index af5ad1bd17..e3a9cec6cf 100644
--- a/testsuites/libtests/dl07/dl-o1.c
+++ b/testsuites/libtests/dl07/dl-o1.c
@@ -43,14 +43,14 @@ int rtems_main_o1 (void);
   printf (DL_NAME ": module: %s\n", dl_localise_file (__FILE__));
-  printf (DL_NAME ":         dl01_bss1: %4u: %p: %d\n",   PAINT_VAR (dl01_bss1));
-  printf (DL_NAME ":         dl01_bss2: %4u: %p: %f\n",   PAINT_VAR (dl01_bss2[0]));
-  printf (DL_NAME ":         dl01_bss3: %4u: %p: %02x\n", PAINT_VAR (dl01_bss3[0]));
-  printf (DL_NAME ":        dl01_data1: %4u: %p: %d\n",   PAINT_VAR (dl01_data1));
+  printf (DL_NAME ":         dl01_bss1: %4zu: %p: %d\n",   PAINT_VAR (dl01_bss1));
+  printf (DL_NAME ":         dl01_bss2: %4zu: %p: %f\n",   PAINT_VAR (dl01_bss2[0]));
+  printf (DL_NAME ":         dl01_bss3: %4zu: %p: %02x\n", PAINT_VAR (dl01_bss3[0]));
+  printf (DL_NAME ":        dl01_data1: %4zu: %p: %d\n",   PAINT_VAR (dl01_data1));
   /* no  %f in the rtems test printer */
-  printf (DL_NAME ":        dl01_data2: %4u: %p: %f\n",   PAINT_VAR (dl01_data2));
-  printf (DL_NAME ":       dl01_const1: %4u: %p: %d\n",   PAINT_VAR (dl01_const1));
-  printf (DL_NAME ":       dl01_const2: %4u: %p: %f\n",   PAINT_VAR (dl01_const2));
-  printf (DL_NAME ":        dl01_func1: %4u: %p\n",       sizeof(dl01_func1), &dl01_func1);
+  printf (DL_NAME ":        dl01_data2: %4zu: %p: %f\n",   PAINT_VAR (dl01_data2));
+  printf (DL_NAME ":       dl01_const1: %4zu: %p: %d\n",   PAINT_VAR (dl01_const1));
+  printf (DL_NAME ":       dl01_const2: %4zu: %p: %f\n",   PAINT_VAR (dl01_const2));
+  printf (DL_NAME ":        dl01_func1: %4zu: %p\n",       sizeof(dl01_func1), &dl01_func1);
   return 0;
diff --git a/testsuites/libtests/dl07/dl-o2.c b/testsuites/libtests/dl07/dl-o2.c
index 423f05a16a..bbb493ef21 100644
--- a/testsuites/libtests/dl07/dl-o2.c
+++ b/testsuites/libtests/dl07/dl-o2.c
@@ -32,20 +32,20 @@ int rtems_main_o2 (int argc, const char* argv[]);
-  printf (DL_NAME ":         dl02_bss1: %4u: %p: %d\n",   PAINT_VAR (dl02_bss1));
-  printf (DL_NAME ":         dl02_bss2: %4u: %p: %f\n",   PAINT_VAR (dl02_bss2[0]));
-  printf (DL_NAME ":         dl02_bss3: %4u: %p: %02x\n", PAINT_VAR (dl02_bss3[0]));
-  printf (DL_NAME ":        dl02_data1: %4u: %p: %d\n",   PAINT_VAR (dl02_data1));
+  printf (DL_NAME ":         dl02_bss1: %4zu: %p: %d\n",   PAINT_VAR (dl02_bss1));
+  printf (DL_NAME ":         dl02_bss2: %4zu: %p: %f\n",   PAINT_VAR (dl02_bss2[0]));
+  printf (DL_NAME ":         dl02_bss3: %4zu: %p: %02x\n", PAINT_VAR (dl02_bss3[0]));
+  printf (DL_NAME ":        dl02_data1: %4zu: %p: %d\n",   PAINT_VAR (dl02_data1));
-  printf (DL_NAME ":        dl02_data2: %4u: %p: %f\n",   PAINT_VAR (dl02_data2));
+  printf (DL_NAME ":        dl02_data2: %4zu: %p: %f\n",   PAINT_VAR (dl02_data2));
   return 0;
diff --git a/testsuites/libtests/dl07/dl-o3.c b/testsuites/libtests/dl07/dl-o3.c
index 573e3df1a0..c499f6cab7 100644
--- a/testsuites/libtests/dl07/dl-o3.c
+++ b/testsuites/libtests/dl07/dl-o3.c
@@ -29,31 +29,31 @@ int rtems_main_o3 (int argc, const char* argv[]);
-  printf (DL_NAME ":   dl04_unresolv_1: %4u: %p: %d\n",          PAINT_VAR (dl04_unresolv_1));
-  printf (DL_NAME ":   dl04_unresolv_2: %4u: %p: %f\n",          PAINT_VAR (dl04_unresolv_2));
-  printf (DL_NAME ":   dl04_unresolv_3: %4u: %p: %02x\n",        PAINT_VAR (dl04_unresolv_3));
-  printf (DL_NAME ":   dl04_unresolv_4: %4u: %p: %p\n",          PAINT_VAR (dl04_unresolv_4));
-  printf (DL_NAME ":   dl04_unresolv_5: %4u: %p: %d\n",          PAINT_VAR (dl04_unresolv_5));
-  printf (DL_NAME ":   dl04_unresolv_6: %4u: %p: %s\n",          PAINT_VAR (dl04_unresolv_6));
-  printf (DL_NAME ":   dl05_unresolv_1: %4u: %p: %" PRIu64 "\n", PAINT_VAR (dl05_unresolv_1));
-  printf (DL_NAME ":   dl05_unresolv_2: %4u: %p: %" PRIu16 "\n", PAINT_VAR (dl05_unresolv_2));
-  printf (DL_NAME ":   dl05_unresolv_3: %4u: %p: %" PRIu32 "\n", PAINT_VAR (dl05_unresolv_3));
-  printf (DL_NAME ":   dl05_unresolv_4: %4u: %p: %" PRIu8  "\n", PAINT_VAR (dl05_unresolv_4));
-  printf (DL_NAME ":   dl05_unresolv_5: %4u: %p: %" PRIi64 "\n", PAINT_VAR (dl05_unresolv_5));
+  printf (DL_NAME ":   dl04_unresolv_1: %4zu: %p: %d\n",          PAINT_VAR (dl04_unresolv_1));
+  printf (DL_NAME ":   dl04_unresolv_2: %4zu: %p: %f\n",          PAINT_VAR (dl04_unresolv_2));
+  printf (DL_NAME ":   dl04_unresolv_3: %4zu: %p: %02x\n",        PAINT_VAR (dl04_unresolv_3));
+  printf (DL_NAME ":   dl04_unresolv_4: %4zu: %p: %p\n",          PAINT_VAR (dl04_unresolv_4));
+  printf (DL_NAME ":   dl04_unresolv_5: %4zu: %p: %d\n",          PAINT_VAR (dl04_unresolv_5));
+  printf (DL_NAME ":   dl04_unresolv_6: %4zu: %p: %s\n",          PAINT_VAR (dl04_unresolv_6));
+  printf (DL_NAME ":   dl05_unresolv_1: %4zu: %p: %" PRIu64 "\n", PAINT_VAR (dl05_unresolv_1));
+  printf (DL_NAME ":   dl05_unresolv_2: %4zu: %p: %" PRIu16 "\n", PAINT_VAR (dl05_unresolv_2));
+  printf (DL_NAME ":   dl05_unresolv_3: %4zu: %p: %" PRIu32 "\n", PAINT_VAR (dl05_unresolv_3));
+  printf (DL_NAME ":   dl05_unresolv_4: %4zu: %p: %" PRIu8  "\n", PAINT_VAR (dl05_unresolv_4));
+  printf (DL_NAME ":   dl05_unresolv_5: %4zu: %p: %" PRIi64 "\n", PAINT_VAR (dl05_unresolv_5));
   return 0;
diff --git a/testsuites/libtests/dl07/dl-o4.c b/testsuites/libtests/dl07/dl-o4.c
index a3cb1fb6c5..c9028ae808 100644
--- a/testsuites/libtests/dl07/dl-o4.c
+++ b/testsuites/libtests/dl07/dl-o4.c
@@ -34,20 +34,20 @@ int rtems_main_o4 (int argc, const char* argv[]);
   return 0;
diff --git a/testsuites/libtests/dl07/dl-o5.c b/testsuites/libtests/dl07/dl-o5.c
index 49502b3247..fc56fd31a2 100644
--- a/testsuites/libtests/dl07/dl-o5.c
+++ b/testsuites/libtests/dl07/dl-o5.c
@@ -34,19 +34,19 @@ int rtems_main_o5 (int argc, const char* argv[]);
   return 0;
diff --git a/testsuites/libtests/dl07/init.c b/testsuites/libtests/dl07/init.c
index 7c482c4944..e398b58b63 100644
--- a/testsuites/libtests/dl07/init.c
+++ b/testsuites/libtests/dl07/init.c
@@ -56,7 +56,7 @@ static void Init(rtems_task_argument arg)
     exit (1);
-  for (i = 0; i < 100; ++i)
+  for (i = 0; i < 1; ++i)
     printf ("--------------------------------------------------\n");
     printf (" Run: %d\n", i);
diff --git a/testsuites/libtests/dl08/dl-o1.c b/testsuites/libtests/dl08/dl-o1.c
index 22b839a438..e6173f3a78 100644
--- a/testsuites/libtests/dl08/dl-o1.c
+++ b/testsuites/libtests/dl08/dl-o1.c
@@ -45,15 +45,15 @@ int rtems_main_o1 (void);
   rtems_main_o2 ();
diff --git a/testsuites/libtests/dl08/dl-o2.c b/testsuites/libtests/dl08/dl-o2.c
index 907fe9a268..e58c8750e9 100644
--- a/testsuites/libtests/dl08/dl-o2.c
+++ b/testsuites/libtests/dl08/dl-o2.c
@@ -26,12 +26,12 @@ float dl02_data2;
 int rtems_main_o2 (void)
   rtems_main_o3 ();
diff --git a/testsuites/libtests/dl08/dl-o3.c b/testsuites/libtests/dl08/dl-o3.c
index 4333f34057..c84b3d72ad 100644
--- a/testsuites/libtests/dl08/dl-o3.c
+++ b/testsuites/libtests/dl08/dl-o3.c
@@ -22,17 +22,17 @@
 int rtems_main_o3 ()
   rtems_main_o4 ();
diff --git a/testsuites/libtests/dl08/dl-o4.c b/testsuites/libtests/dl08/dl-o4.c
index 60ada7ac68..72dfbc6850 100644
--- a/testsuites/libtests/dl08/dl-o4.c
+++ b/testsuites/libtests/dl08/dl-o4.c
@@ -27,12 +27,12 @@ const char* dl04_unresolv_6 = "dl-O4";
 int rtems_main_o4 (void)
   rtems_main_o5 ();
diff --git a/testsuites/libtests/dl08/dl-o5.c b/testsuites/libtests/dl08/dl-o5.c
index 28bee5a03d..9257a684d7 100644
--- a/testsuites/libtests/dl08/dl-o5.c
+++ b/testsuites/libtests/dl08/dl-o5.c
@@ -27,11 +27,11 @@ int64_t  dl05_unresolv_5;
 int rtems_main_o5 (void)
   rtems_main_o6 ();
diff --git a/testsuites/libtests/dl08/dl-o6-123456789-123456789.c b/testsuites/libtests/dl08/dl-o6-123456789-123456789.c
index d308b85f1a..4aee277a3d 100644
--- a/testsuites/libtests/dl08/dl-o6-123456789-123456789.c
+++ b/testsuites/libtests/dl08/dl-o6-123456789-123456789.c
@@ -29,11 +29,11 @@ void dl06_destructor (void) __attribute__ ((destructor));
 void dl06_constructor (void)
   printf (DL_NAME ": CONSTRUCTOR: %s\n", dl_localise_file (__FILE__));
-  printf (DL_NAME ":   dl06_unresolv_1: %4u: %p: %" PRIu64 "\n", PAINT_VAR (dl06_unresolv_1));
-  printf (DL_NAME ":   dl06_unresolv_2: %4u: %p: %" PRIu16 "\n", PAINT_VAR (dl06_unresolv_2));
-  printf (DL_NAME ":   dl06_unresolv_3: %4u: %p: %" PRIu32 "\n", PAINT_VAR (dl06_unresolv_3));
-  printf (DL_NAME ":   dl06_unresolv_4: %4u: %p: %" PRIu8  "\n", PAINT_VAR (dl06_unresolv_4));
-  printf (DL_NAME ":   dl06_unresolv_5: %4u: %p: %" PRIi64 "\n", PAINT_VAR (dl06_unresolv_5));
+  printf (DL_NAME ":   dl06_unresolv_1: %4zu: %p: %" PRIu64 "\n", PAINT_VAR (dl06_unresolv_1));
+  printf (DL_NAME ":   dl06_unresolv_2: %4zu: %p: %" PRIu16 "\n", PAINT_VAR (dl06_unresolv_2));
+  printf (DL_NAME ":   dl06_unresolv_3: %4zu: %p: %" PRIu32 "\n", PAINT_VAR (dl06_unresolv_3));
+  printf (DL_NAME ":   dl06_unresolv_4: %4zu: %p: %" PRIu8  "\n", PAINT_VAR (dl06_unresolv_4));
+  printf (DL_NAME ":   dl06_unresolv_5: %4zu: %p: %" PRIi64 "\n", PAINT_VAR (dl06_unresolv_5));
diff --git a/testsuites/libtests/dl09/dl-load.c b/testsuites/libtests/dl09/dl-load.c
index 160f8157d9..ab9a0df85b 100644
--- a/testsuites/libtests/dl09/dl-load.c
+++ b/testsuites/libtests/dl09/dl-load.c
@@ -18,7 +18,9 @@
-                      RTEMS_RTL_TRACE_DEPENDENCY)
+                      RTEMS_RTL_TRACE_DEPENDENCY | \
+                      RTEMS_RTL_TRACE_LOAD_SECT | \
+                      RTEMS_RTL_TRACE_BIT_ALLOC)
  #define DL09_DEBUG_TRACE DEBUG_TRACE /* RTEMS_RTL_TRACE_ALL */
  #define DL09_RTL_CMDS    1
 #else
diff --git a/testsuites/libtests/dl09/dl-o1.c b/testsuites/libtests/dl09/dl-o1.c
index 22b839a438..438c05eee9 100644
--- a/testsuites/libtests/dl09/dl-o1.c
+++ b/testsuites/libtests/dl09/dl-o1.c
@@ -44,16 +44,17 @@ int rtems_main_o1 (void);
-  printf (DL_NAME ": module: %s\n", dl_localise_file (__FILE__));
+  printf (DL_NAME ": module: %s @ %p\n",
+	  dl_localise_file (__FILE__), rtems_main_o1);
   rtems_main_o2 ();
diff --git a/testsuites/libtests/dl09/dl-o2.c b/testsuites/libtests/dl09/dl-o2.c
index 907fe9a268..4b9f15cd28 100644
--- a/testsuites/libtests/dl09/dl-o2.c
+++ b/testsuites/libtests/dl09/dl-o2.c
@@ -17,7 +17,7 @@
 int   dl02_bss1;
 float dl02_bss2[7];
 char  dl02_bss3[21];
-int   dl02_data1;
+int   dl02_data1 = 0x12345678;
 float dl02_data2;
 #define DL_NAME       "dlo2"
@@ -25,13 +25,14 @@ float dl02_data2;
+	  dl_localise_file (__FILE__), rtems_main_o2);
+  printf (DL_NAME ":        dl02_data1: %4zu: %p: %08x\n", PAINT_VAR (dl02_data1));
   rtems_main_o3 ();
diff --git a/testsuites/libtests/dl09/dl-o3.c b/testsuites/libtests/dl09/dl-o3.c
index 4333f34057..7f8f419bb1 100644
--- a/testsuites/libtests/dl09/dl-o3.c
+++ b/testsuites/libtests/dl09/dl-o3.c
@@ -21,18 +21,19 @@
+  printf (DL_NAME ": module: %s : %p\n",
+	  dl_localise_file (__FILE__), rtems_main_o3);
   rtems_main_o4 ();
diff --git a/testsuites/libtests/dl09/dl-o4.c b/testsuites/libtests/dl09/dl-o4.c
index 60ada7ac68..9fea2e5d5c 100644
--- a/testsuites/libtests/dl09/dl-o4.c
+++ b/testsuites/libtests/dl09/dl-o4.c
@@ -14,10 +14,10 @@
-int         dl04_unresolv_1;
+int         dl04_unresolv_1 = 12345;
 float       dl04_unresolv_2;
-char        dl04_unresolv_3;
-char*       dl04_unresolv_4;
+char        dl04_unresolv_3 = 'z';
+char*       dl04_unresolv_4 = "aBcDeF";
 const int   dl04_unresolv_5 = 4;
@@ -26,13 +26,14 @@ const char* dl04_unresolv_6 = "dl-O4";
+	  dl_localise_file (__FILE__), rtems_main_o4);
+  printf (DL_NAME ":   dl04_unresolv_4: %4zu: %p: %s\n",   PAINT_VAR (dl04_unresolv_4));
   rtems_main_o5 ();
diff --git a/testsuites/libtests/dl09/dl-o5.c b/testsuites/libtests/dl09/dl-o5.c
index fc02e19272..fb1169256c 100644
--- a/testsuites/libtests/dl09/dl-o5.c
+++ b/testsuites/libtests/dl09/dl-o5.c
@@ -26,12 +26,13 @@ int64_t  dl05_unresolv_5;
+	  dl_localise_file (__FILE__), rtems_main_o5);
   return 0;
2.19.1
