[PATCH 1/2] waf: Remove as many sys path hacks as we can.
chrisj at rtems.org
chrisj at rtems.org
Tue Feb 12 23:52:31 UTC 2019
There are still sys.path hacks in the conf.py files. They cannot
be removed because the instance of python running the sphinx-build
command does not see our top level path hacks. I looked at using
PYTHONPATH but I could not figure out how to set a process environ
var for a waf build instance.
bsp-howto/wscript | 18 +++++++-----------
c-user/wscript | 18 +++++++-----------
cpu-supplement/wscript | 18 +++++++-----------
develenv/wscript | 18 +++++++-----------
eclipse/wscript | 18 +++++++-----------
eng/wscript | 18 +++++++-----------
filesystem/wscript | 18 +++++++-----------
images/wscript | 10 +++-------
networking/wscript | 18 +++++++-----------
porting/wscript | 18 +++++++-----------
posix-compliance/wscript | 18 +++++++-----------
posix-users/wscript | 18 +++++++-----------
rtemsconfig/wscript | 18 +++++++-----------
shell/wscript | 18 +++++++-----------
wscript | 14 ++++++++++----
16 files changed, 111 insertions(+), 165 deletions(-)
diff --git a/bsp-howto/wscript b/bsp-howto/wscript
index 1cb5736..4063cd4 100644
--- a/bsp-howto/wscript
+++ b/bsp-howto/wscript
@@ -1,11 +1,7 @@
-from sys import path
-from os.path import abspath
-path.insert(0, abspath('../common/'))
-from waf import cmd_configure as configure
-from waf import cmd_build as build
-from waf import cmd_options as options
-from waf import spell
-from waf import cmd_spell
-from waf import linkcheck
-from waf import cmd_linkcheck
+from common.waf import cmd_configure as configure
+from common.waf import cmd_build as build
+from common.waf import cmd_options as options
+from common.waf import spell
+from common.waf import cmd_spell
+from common.waf import linkcheck
+from common.waf import cmd_linkcheck
diff --git a/c-user/wscript b/c-user/wscript
--- a/c-user/wscript
+++ b/c-user/wscript
@@ -1,11 +1,7 @@
diff --git a/cpu-supplement/wscript b/cpu-supplement/wscript
--- a/cpu-supplement/wscript
+++ b/cpu-supplement/wscript
@@ -1,11 +1,7 @@
diff --git a/develenv/wscript b/develenv/wscript
--- a/develenv/wscript
+++ b/develenv/wscript
@@ -1,11 +1,7 @@
diff --git a/eclipse/wscript b/eclipse/wscript
--- a/eclipse/wscript
+++ b/eclipse/wscript
@@ -1,11 +1,7 @@
diff --git a/eng/wscript b/eng/wscript
--- a/eng/wscript
+++ b/eng/wscript
@@ -1,11 +1,7 @@
diff --git a/filesystem/wscript b/filesystem/wscript
--- a/filesystem/wscript
+++ b/filesystem/wscript
@@ -1,11 +1,7 @@
diff --git a/images/wscript b/images/wscript
index 142b150..179938b 100644
--- a/images/wscript
+++ b/images/wscript
@@ -1,7 +1,3 @@
-from waf import cmd_build_images as build
+from common.waf import cmd_build_images as build
diff --git a/networking/wscript b/networking/wscript
--- a/networking/wscript
+++ b/networking/wscript
@@ -1,11 +1,7 @@
diff --git a/porting/wscript b/porting/wscript
--- a/porting/wscript
+++ b/porting/wscript
@@ -1,11 +1,7 @@
diff --git a/posix-compliance/wscript b/posix-compliance/wscript
index 7ff4013..eae2174 100644
--- a/posix-compliance/wscript
+++ b/posix-compliance/wscript
@@ -1,14 +1,10 @@
-from waf import cmd_build as doc_build
+from common.waf import cmd_build as doc_build
import posix_rst
diff --git a/posix-users/wscript b/posix-users/wscript
--- a/posix-users/wscript
+++ b/posix-users/wscript
@@ -1,11 +1,7 @@
diff --git a/rtemsconfig/wscript b/rtemsconfig/wscript
--- a/rtemsconfig/wscript
+++ b/rtemsconfig/wscript
@@ -1,11 +1,7 @@
diff --git a/shell/wscript b/shell/wscript
--- a/shell/wscript
+++ b/shell/wscript
@@ -1,11 +1,7 @@
diff --git a/user/wscript b/user/wscript
--- a/user/wscript
+++ b/user/wscript
@@ -1,11 +1,7 @@
diff --git a/wscript b/wscript
index f10fcb4..7cdda9a 100644
--- a/wscript
+++ b/wscript
@@ -5,17 +5,23 @@
import sys
import os.path
-sys.path.insert(0, os.path.abspath('common'))
import waflib
-import waf as docs_waf
-import version
+from common import waf as docs_waf
+from common import version
# Branch version
rtems_major_version = '5'
+# Set Python's system path to `common` from the top level so the
+# conf.py modules in subdirectories can be found. See xml_catalogue in
+# common/waf.py.
+sys.path.append(os.path.abspath('common'))
# The documents to build.
2.19.1
