[PATCH 1/2] README.txt: Fix typos
Wed Feb 13 22:26:14 UTC 2019
Both patches look good.
On 14/2/19 9:17 am, Joel Sherrill wrote:
>  README.txt | 4 ++--
>  1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/README.txt b/README.txt
> index d9fc4a6..b1a5978 100644
> --- a/README.txt
> +++ b/README.txt
> @@ -31,7 +31,7 @@ We allow the building of PDF documentation on hosts that do not have a fully
>  suitable texlive environment and this results in quality that is not at the
>  production level.
> -The hosts which produce production quality is:
> +The hosts which produce production quality are:
>   FreeBSD
>   CentOS 6 and 7 (if using texlive, not RPMs of texlive)
> @@ -79,7 +79,7 @@ Host Setup
>  HTML builds directly with Sphinx, PDF requires a full Latex (texlive) install,
>  and building a Single HTML page requires the 'inliner' tool. The
>  sphinxcontrib-bibtex extension is mandatory. PlantUML requres the Node.js
> -package called 'nde-plantuml' which installs the 'puml' command and Ditaa needs
> +package called 'node-plantuml' which installs the 'puml' command and Ditaa needs
>  the 'ditaa' command and package. Ditaa images are built using the 'puml'
>  command.
