[PATCH] libdl: Allocator does not unlock and lock memory on loading.
chrisj at rtems.org
chrisj at rtems.org
Thu Feb 14 03:01:00 UTC 2019
Close #3692
cpukit/include/rtems/rtl/rtl-allocator.h | 70 +++++++++++++++++++-
cpukit/libdl/rtl-alloc-heap.c | 6 +-
cpukit/libdl/rtl-alloc-heap.h | 4 +-
cpukit/libdl/rtl-allocator.c | 84 +++++++++++++++++++++---
cpukit/libdl/rtl-obj.c | 11 ++++
5 files changed, 158 insertions(+), 17 deletions(-)
diff --git a/cpukit/include/rtems/rtl/rtl-allocator.h b/cpukit/include/rtems/rtl/rtl-allocator.h
index c5b3d4ec72..1a5d615582 100644
--- a/cpukit/include/rtems/rtl/rtl-allocator.h
+++ b/cpukit/include/rtems/rtl/rtl-allocator.h
@@ -44,6 +44,21 @@ enum rtems_rtl_alloc_tags {
typedef enum rtems_rtl_alloc_tags rtems_rtl_alloc_tag;
+ * Define the allocation command the loader requires.
+enum rtems_rtl_alloc_cmd {
+ RTEMS_RTL_ALLOC_NEW, /**< Allocate new memory. */
+ RTEMS_RTL_ALLOC_DEL, /**< Delete allocated memory. */
+ RTEMS_RTL_ALLOC_WR_ENABLE, /**< Enable writes to the memory. */
+ RTEMS_RTL_ALLOC_WR_DISABLE, /**< Disable writes to the memory. */
+ * The allocator command type.
+typedef enum rtems_rtl_alloc_cmd rtems_rtl_alloc_cmd;
* The number of tags.
@@ -53,7 +68,7 @@ typedef enum rtems_rtl_alloc_tags rtems_rtl_alloc_tag;
* Allocator handler handles all RTL allocations. It can be hooked and
* overridded for customised allocation schemes or memory maps.
- * @param allocation If true the request is to allocate memory else free.
+ * @param allocation The request command.
* @param tag The type of allocation request.
* @param address Pointer to the memory address. If an allocation the value is
* unspecific on entry and the allocated address or NULL on
@@ -63,7 +78,7 @@ typedef enum rtems_rtl_alloc_tags rtems_rtl_alloc_tag;
* @param size The size of the allocation if an allocation request and
* not used if deleting or freeing a previous allocation.
-typedef void (*rtems_rtl_allocator)(bool allocate,
+typedef void (*rtems_rtl_allocator)(rtems_rtl_alloc_cmd cmd,
rtems_rtl_alloc_tag tag,
void** address,
size_t size);
@@ -106,6 +121,22 @@ void* rtems_rtl_alloc_new (rtems_rtl_alloc_tag tag, size_t size, bool zero);
void rtems_rtl_alloc_del (rtems_rtl_alloc_tag tag, void* address);
+ * The Runtime Loader allocator enable write on a bloc of allocated memory.
+ * @param tag The type of allocation request. Must match the address.
+ * @param address The memory address to write enable. A NULL is ignored.
+void rtems_rtl_alloc_wr_enable (rtems_rtl_alloc_tag tag, void* address);
+ * The Runtime Loader allocator disable write on a bloc of allocated memory.
+ * @param address The memory address to write disable. A NULL is ignored.
+void rtems_rtl_alloc_wr_disable (rtems_rtl_alloc_tag tag, void* address);
* Hook the Runtime Loader allocatior. A handler can call the previous handler
* in the chain to use it for specific tags. The default handler uses the
@@ -137,6 +168,41 @@ void rtems_rtl_alloc_indirect_new (rtems_rtl_alloc_tag tag,
void rtems_rtl_alloc_indirect_del (rtems_rtl_alloc_tag tag,
rtems_rtl_ptr* handle);
+ * Return the default tag for text sections.
+ * @return The text tag.
+rtems_rtl_alloc_tag rtems_rtl_alloc_text_tag (void);
+ * Return the default tag for const sections.
+ * @return The const tag.
+rtems_rtl_alloc_tag rtems_rtl_alloc_const_tag (void);
+ * Return the default tag for exception sections.
+ * @return The eh tag.
+rtems_rtl_alloc_tag rtems_rtl_alloc_eh_tag (void);
+ * Return the default tag for data sections.
+ * @return The data tag.
+rtems_rtl_alloc_tag rtems_rtl_alloc_data_tag (void);
+ * Return the default tag for bss sections.
+ * @return The bss tag.
+rtems_rtl_alloc_tag rtems_rtl_alloc_bss_tag (void);
* Allocate the memory for a module given the size of the text, const, data and
* bss sections. If any part of the allocation fails the no memory is
diff --git a/cpukit/libdl/rtl-alloc-heap.c b/cpukit/libdl/rtl-alloc-heap.c
index 2483e89fed..4ffdaf23b1 100644
--- a/cpukit/libdl/rtl-alloc-heap.c
+++ b/cpukit/libdl/rtl-alloc-heap.c
@@ -18,14 +18,14 @@
#include "rtl-alloc-heap.h"
void
-rtems_rtl_alloc_heap (bool allocate,
+rtems_rtl_alloc_heap (rtems_rtl_alloc_cmd cmd,
void** address,
size_t size)
- if (allocate)
+ if (cmd == RTEMS_RTL_ALLOC_NEW)
*address = malloc (size);
- else
+ else if (cmd == RTEMS_RTL_ALLOC_DEL)
free (*address);
*address = NULL;
diff --git a/cpukit/libdl/rtl-alloc-heap.h b/cpukit/libdl/rtl-alloc-heap.h
index befcad19b0..6b7018b400 100644
--- a/cpukit/libdl/rtl-alloc-heap.h
+++ b/cpukit/libdl/rtl-alloc-heap.h
@@ -25,7 +25,7 @@ extern "C" {
* Allocator handler for the standard libc heap.
+ * @param cmd The allocation command.
@@ -35,7 +35,7 @@ extern "C" {
-void rtems_rtl_alloc_heap(bool allocate,
+void rtems_rtl_alloc_heap(rtems_rtl_alloc_cmd cmd,
void** address,
size_t size);
diff --git a/cpukit/libdl/rtl-allocator.c b/cpukit/libdl/rtl-allocator.c
index 605cdbde83..01ce9e580f 100644
--- a/cpukit/libdl/rtl-allocator.c
+++ b/cpukit/libdl/rtl-allocator.c
@@ -57,8 +57,8 @@ rtems_rtl_alloc_new (rtems_rtl_alloc_tag tag, size_t size, bool zero)
* Obtain memory from the allocator. The address field is set by the
* allocator.
- if (rtl)
- rtl->allocator.allocator (true, tag, &address, size);
+ if (rtl != NULL)
+ rtl->allocator.allocator (RTEMS_RTL_ALLOC_NEW, tag, &address, size);
rtems_rtl_unlock ();
@@ -69,7 +69,7 @@ rtems_rtl_alloc_new (rtems_rtl_alloc_tag tag, size_t size, bool zero)
* Only zero the memory if asked to and the allocation was successful.
- if (address && zero)
+ if (address != NULL && zero)
memset (address, 0, size);
return address;
@@ -84,8 +84,42 @@ rtems_rtl_alloc_del (rtems_rtl_alloc_tag tag, void* address)
printf ("rtl: alloc: del: %s addr=%p\n",
rtems_rtl_trace_tag_label (tag), address);
- if (rtl && address)
- rtl->allocator.allocator (false, tag, &address, 0);
+ if (rtl != NULL && address != NULL)
+ rtl->allocator.allocator (RTEMS_RTL_ALLOC_DEL, tag, &address, 0);
+ rtems_rtl_unlock ();
+void
+rtems_rtl_alloc_wr_enable (rtems_rtl_alloc_tag tag, void* address)
+ rtems_rtl_data* rtl = rtems_rtl_lock ();
+ if (rtems_rtl_trace (RTEMS_RTL_TRACE_ALLOCATOR))
+ printf ("rtl: alloc: wr-enable: addr=%p\n", address);
+ rtl->allocator.allocator (RTEMS_RTL_ALLOC_WR_ENABLE,
+ tag,
+ address,
+ 0);
+void
+rtems_rtl_alloc_wr_disable (rtems_rtl_alloc_tag tag, void* address)
+ rtl->allocator.allocator (RTEMS_RTL_ALLOC_WR_DISABLE,
+ tag,
+ address,
+ 0);
@@ -150,6 +184,36 @@ rtems_rtl_alloc_indirect_del (rtems_rtl_alloc_tag tag,
+rtems_rtl_alloc_text_tag (void)
+ return RTEMS_RTL_ALLOC_READ_EXEC;
+rtems_rtl_alloc_const_tag (void)
+ return RTEMS_RTL_ALLOC_READ;
+rtems_rtl_alloc_eh_tag (void)
+rtems_rtl_alloc_data_tag (void)
+ return RTEMS_RTL_ALLOC_READ_WRITE;
+rtems_rtl_alloc_bss_tag (void)
bool
rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
void** const_base, size_t const_size,
@@ -161,7 +225,7 @@ rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
if (text_size)
- *text_base = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_READ_EXEC,
+ *text_base = rtems_rtl_alloc_new (rtems_rtl_alloc_text_tag (),
text_size, false);
if (!*text_base)
@@ -171,7 +235,7 @@ rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
if (const_size)
- *const_base = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_READ,
+ *const_base = rtems_rtl_alloc_new (rtems_rtl_alloc_const_tag (),
const_size, false);
if (!*const_base)
@@ -183,7 +247,7 @@ rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
if (eh_size)
- *eh_base = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_READ,
+ *eh_base = rtems_rtl_alloc_new (rtems_rtl_alloc_eh_tag (),
eh_size, false);
if (!*eh_base)
@@ -195,7 +259,7 @@ rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
if (data_size)
- *data_base = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_READ_WRITE,
+ *data_base = rtems_rtl_alloc_new (rtems_rtl_alloc_data_tag (),
data_size, false);
if (!*data_base)
@@ -207,7 +271,7 @@ rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
if (bss_size)
- *bss_base = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_READ_WRITE,
+ *bss_base = rtems_rtl_alloc_new (rtems_rtl_alloc_bss_tag (),
bss_size, false);
if (!*bss_base)
diff --git a/cpukit/libdl/rtl-obj.c b/cpukit/libdl/rtl-obj.c
index 15e5bf1137..378678435d 100644
--- a/cpukit/libdl/rtl-obj.c
+++ b/cpukit/libdl/rtl-obj.c
@@ -1000,6 +1000,7 @@ rtems_rtl_obj_sections_link_order (uint32_t mask, rtems_rtl_obj* obj)
static bool
rtems_rtl_obj_sections_loader (uint32_t mask,
+ rtems_rtl_alloc_tag tag,
rtems_rtl_obj* obj,
int fd,
uint8_t* base,
@@ -1014,6 +1015,8 @@ rtems_rtl_obj_sections_loader (uint32_t mask,
if (rtems_rtl_trace (RTEMS_RTL_TRACE_LOAD_SECT))
printf ("rtl: loading section: mask:%08" PRIx32 " base:%p\n", mask, base);
+ rtems_rtl_alloc_wr_enable (tag, base);
while (!rtems_chain_is_tail (sections, node))
rtems_rtl_obj_sect* sect = (rtems_rtl_obj_sect*) node;
@@ -1039,6 +1042,7 @@ rtems_rtl_obj_sections_loader (uint32_t mask,
if (!handler (obj, fd, sect, data))
sect->base = 0;
+ rtems_rtl_alloc_wr_disable (tag, base);
return false;
@@ -1067,6 +1071,8 @@ rtems_rtl_obj_sections_loader (uint32_t mask,
node = rtems_chain_next (node);
return true;
@@ -1168,14 +1174,19 @@ rtems_rtl_obj_load_sections (rtems_rtl_obj* obj,
* sections.
if (!rtems_rtl_obj_sections_loader (RTEMS_RTL_OBJ_SECT_TEXT,
+ rtems_rtl_alloc_text_tag (),
obj, fd, obj->text_base, handler, data) ||
!rtems_rtl_obj_sections_loader (RTEMS_RTL_OBJ_SECT_CONST,
+ rtems_rtl_alloc_const_tag (),
obj, fd, obj->const_base, handler, data) ||
!rtems_rtl_obj_sections_loader (RTEMS_RTL_OBJ_SECT_EH,
+ rtems_rtl_alloc_eh_tag (),
obj, fd, obj->eh_base, handler, data) ||
!rtems_rtl_obj_sections_loader (RTEMS_RTL_OBJ_SECT_DATA,
+ rtems_rtl_alloc_data_tag (),
obj, fd, obj->data_base, handler, data) ||
!rtems_rtl_obj_sections_loader (RTEMS_RTL_OBJ_SECT_BSS,
+ rtems_rtl_alloc_bss_tag (),
obj, fd, obj->bss_base, handler, data))
rtems_rtl_alloc_module_del (&obj->text_base, &obj->const_base, &obj->eh_base,
2.19.1
