[PATCH] testing/bsps: Add covoar commands in bsp ini file
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Thu Feb 14 07:31:30 UTC 2019
tester/rtems/testing/bsps/griscv-sis-cov.ini | 13 +++++++------
tester/rtems/testing/bsps/leon3-qemu-cov.ini | 1 +
2 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini b/tester/rtems/testing/bsps/griscv-sis-cov.ini
index 060bba7..7249af6 100644
--- a/tester/rtems/testing/bsps/griscv-sis-cov.ini
+++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
@@ -32,9 +32,10 @@
# The griscv BSP on sis with coverage
[griscv-sis-cov]
-bsp = griscv-sis
-arch = riscv
-tester = %{_rtscripts}/run.cfg
-target = riscv-rtems5
-bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
-bsp_run_opts = -nouartrx -r -tlim 300 s -m 4 -cov
+bsp = griscv-sis
+arch = riscv
+tester = %{_rtscripts}/run.cfg
+target = riscv-rtems5
+bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
+bsp_run_opts = -nouartrx -r -tlim 300 s -m 4 -cov
+bsp_covoar_cmd = -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
index 2f89117..f1cfe55 100644
--- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
+++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
@@ -38,3 +38,4 @@ target = sparc-rtems5
tester = %{_rtscripts}/qemu.cfg
bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
2.20.1
