[PATCH] libdl/alloc: Add a locking interface to the allocator.
    chrisj at rtems.org
    chrisj at rtems.org
    Mon Feb 18 00:49:23 UTC 2019
- Allow an allocator to lock the allocations. This is needed to
  lock the heap allocator so the text and trampoline table are
  as close together as possible to allow for the largest possible
  object file size.
- Update the default heap allocator to lock the heap allocator.
- Update ELF loading to lock the allocator.
Updates #3685
 cpukit/include/rtems/rtl/rtl-allocator.h | 20 ++++++++++++++
 cpukit/libdl/rtl-alloc-heap.c            | 23 ++++++++++++----
 cpukit/libdl/rtl-allocator.c             | 34 ++++++++++++++++++++++++
 cpukit/libdl/rtl-elf.c                   | 11 ++++++++
 4 files changed, 83 insertions(+), 5 deletions(-)
diff --git a/cpukit/include/rtems/rtl/rtl-allocator.h b/cpukit/include/rtems/rtl/rtl-allocator.h
index 1a5d615582..da221fef68 100644
--- a/cpukit/include/rtems/rtl/rtl-allocator.h
+++ b/cpukit/include/rtems/rtl/rtl-allocator.h
@@ -50,6 +50,8 @@ typedef enum rtems_rtl_alloc_tags rtems_rtl_alloc_tag;
 enum rtems_rtl_alloc_cmd {
   RTEMS_RTL_ALLOC_NEW,        /**< Allocate new memory. */
   RTEMS_RTL_ALLOC_DEL,        /**< Delete allocated memory. */
+  RTEMS_RTL_ALLOC_LOCK,       /**< Lock the allocator. */
+  RTEMS_RTL_ALLOC_UNLOCK,     /**< Unlock the allocator. */
   RTEMS_RTL_ALLOC_WR_ENABLE,  /**< Enable writes to the memory. */
   RTEMS_RTL_ALLOC_WR_DISABLE, /**< Disable writes to the memory. */
@@ -121,6 +123,24 @@ void* rtems_rtl_alloc_new (rtems_rtl_alloc_tag tag, size_t size, bool zero);
 void rtems_rtl_alloc_del (rtems_rtl_alloc_tag tag, void* address);
+ * The Runtime Loader allocator lock. An allocator that depends on a
+ * separate allocation process, for example the heap, may need to be
+ * locked during loading of an object file to make sure the locality
+ * of the memory. This call be used to lock such an allocator.
+ *  Allocator calls in this interface are protected by the RTL lock.
+void rtems_rtl_alloc_lock (void);
+ * The Runtime Loader allocator unlock. An allocator that depends on a
+ * of the memory. This call can be used to unlock such an allocator.
+void rtems_rtl_alloc_unlock (void);
  * The Runtime Loader allocator enable write on a bloc of allocated memory.
diff --git a/cpukit/libdl/rtl-alloc-heap.c b/cpukit/libdl/rtl-alloc-heap.c
index 4ffdaf23b1..f1bdcca507 100644
--- a/cpukit/libdl/rtl-alloc-heap.c
+++ b/cpukit/libdl/rtl-alloc-heap.c
@@ -17,17 +17,30 @@
 #include "rtl-alloc-heap.h"
+#include <rtems/score/apimutex.h>
 void
 rtems_rtl_alloc_heap (rtems_rtl_alloc_cmd cmd,
                       void**              address,
                       size_t              size)
-  if (cmd == RTEMS_RTL_ALLOC_NEW)
-    *address = malloc (size);
-  else if (cmd == RTEMS_RTL_ALLOC_DEL)
+  switch (cmd)
-    free (*address);
-    *address = NULL;
+    case RTEMS_RTL_ALLOC_NEW:
+      *address = malloc (size);
+      break;
+    case RTEMS_RTL_ALLOC_DEL:
+      free (*address);
+      *address = NULL;
+      break;
+    case RTEMS_RTL_ALLOC_LOCK:
+      _RTEMS_Lock_allocator();
+      break;
+    case RTEMS_RTL_ALLOC_UNLOCK:
+      _RTEMS_Unlock_allocator();
+      break;
+    default:
+      break;
diff --git a/cpukit/libdl/rtl-allocator.c b/cpukit/libdl/rtl-allocator.c
index 01ce9e580f..0dca6b2f9a 100644
--- a/cpukit/libdl/rtl-allocator.c
+++ b/cpukit/libdl/rtl-allocator.c
@@ -107,6 +107,40 @@ rtems_rtl_alloc_wr_enable (rtems_rtl_alloc_tag tag, void* address)
   rtems_rtl_unlock ();
+void
+rtems_rtl_alloc_lock (void)
+  rtems_rtl_data* rtl = rtems_rtl_lock ();
+  if (rtems_rtl_trace (RTEMS_RTL_TRACE_ALLOCATOR))
+    printf ("rtl: alloc: lock\n");
+  if (rtl != NULL)
+    rtl->allocator.allocator (RTEMS_RTL_ALLOC_LOCK,
+                              RTEMS_RTL_ALLOC_OBJECT, /* should be ignored */
+                              NULL,
+                              0);
+  rtems_rtl_unlock ();
+void
+rtems_rtl_alloc_unlock (void)
+    printf ("rtl: alloc: unlock\n");
+  if (rtl != NULL)
+    rtl->allocator.allocator (RTEMS_RTL_ALLOC_UNLOCK,
+                              NULL,
+                              0);
 void
 rtems_rtl_alloc_wr_disable (rtems_rtl_alloc_tag tag, void* address)
diff --git a/cpukit/libdl/rtl-elf.c b/cpukit/libdl/rtl-elf.c
index 54ea1464cc..963cb4b2f4 100644
--- a/cpukit/libdl/rtl-elf.c
+++ b/cpukit/libdl/rtl-elf.c
@@ -1456,6 +1456,12 @@ rtems_rtl_elf_file_load (rtems_rtl_obj* obj, int fd)
   obj->entry = (void*)(uintptr_t) ehdr.e_entry;
+   * Lock the allocator so the section memory and the trampoline memory are as
+   * clock as possible.
+  rtems_rtl_alloc_lock ();
    * Allocate the sections.
@@ -1481,6 +1487,11 @@ rtems_rtl_elf_file_load (rtems_rtl_obj* obj, int fd)
   if (!rtems_rtl_elf_alloc_trampoline (obj, relocs.unresolved))
     return false;
+   * Unlock the allocator.
+  rtems_rtl_alloc_unlock ();
   if (!rtems_rtl_obj_load_symbols (obj, fd, rtems_rtl_elf_symbols, &ehdr))
     return false;
2.19.1
