rtems-test crash
    Joel Sherrill
    joel at rtems.org
    Wed Feb 20 15:25:06 UTC 2019
Hi
rtems-test crashes for me on Centos 7. I did check that rtems-tools was up
to date. This set of command line arguments has worked in the past.
+  /home/joel/rtems-work/rtems-tools//tester/rtems-test
--rtems-tools=/home/joel/rtems-work/tools/5 --rtems-bsp=leon3 --log=run.log
--mail --mail-from=joel at rtems.org --mail-to=build at rtems.org .
Traceback (most recent call last):
  File "/home/joel/rtems-work/rtems-tools/tester/rt/cmd-test.py", line 42,
in <module>
    test.run(sys.argv[1:], command_path = base)
  File "/home/joel/rtems-work/rtems-tools/tester/rt/test.py", line 247, in
run
    smtp_host = mail.smtp_host()
  File "/home/joel/rtems-work/rtems-tools/rtemstoolkit/mailer.py", line
122, in smtp_host
    host = self._get_arg('--smtp-host')
  File "/home/joel/rtems-work/rtems-tools/rtemstoolkit/mailer.py", line 70,
in _get_arg
    value = self.opts.find_arg(arg)[1]
TypeError: 'NoneType' object has no attribute '__getitem__'
Hopefully it is something simple.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190220/62cafe77/attachment.html>
