[PATCH] bsp/lpc1768_mbed: Disable unsupported tests
Tue Feb 26 06:50:54 UTC 2019
On 26/02/2019 00:03, Joel Sherrill wrote:
>     > OPERATION_COUNT is usually the number of objects (e.g. tasks,
>     semaphores,
>     > etc) created so it is the maximum object count. For example,
>     tm03 has this:
>     https://git.rtems.org/rtems/tree/testsuites/tmtests/tm03/system.h#n29
>     > |#define CONFIGURE_MAXIMUM_TASKS (3 + OPERATION_COUNT) |
>     > So when Sebastian changed this,  it went from a run-time to a
>     link time failure.
>     Ah ok, it is nice to see the error on these targets at link time.
Yes, the space for fixed count objects (not unlimited) is now allocated
by the linker. So, an INTERNAL_ERROR_TOO_LITTLE_WORKSPACE changed into a
linker error.
>     > The intent of OPERATION_COUNT was to be able to scale the timing
>     tests down
>     > to the hardware platform. Dropping OPERATION_COUNT to 10 for
>     these BSPs
>     > will resolve almost all of the tm and psxtm linking issues from
>     what I can tell.
>     What about a way to set this value in the `.tcfg` files and then
>     provide it on
>     the command line as a compile option?
> This would be awesome! OPERATION_COUNT is an area where our old
> build system person didn't want to tread. Much like the entire tcfg
> system.
Yes, moving the test suite specific OPERATION_COUNT from the bsp.h to
the *.tcfg would be good. However, I would like to resolve the build
errors as soon as possible. So, change the patch to define
OPERATION_COUNT to 10 and adjust the *.tcfg accordingly?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
