[PATCH 6/6] user: Remove nit-picky warnings.
Wed Feb 27 06:42:54 UTC 2019
On 27/02/2019 07:30, Chris Johns wrote:
> diff --git a/README.txt b/README.txt
> index e002f60..115d08d 100644
> --- a/README.txt
> +++ b/README.txt
> @@ -415,14 +415,34 @@ existing documentation for an example and if unsure ask.
>         5  ^^^^^^ Sub-sub-sub-section
>         6  ~~~~~~ Sub-sub-sub-sub-section
> -5. For literal output, such as shell commands and code use '::' at the trailing
> -   edge of the previous paragraph. Use the '.. code-block::' with
> -   'c' for C code and 'shell' for shell code and terminal output. If you need
> -   line number use:
> +5. For literal output, such as shell commands and code do not use '::'
> +   at the trailing edge of the previous paragraph as it generates
> +   warnings as the autodetect fails to find a suitable format. Use the
> +   '.. code-block::' with a suitable lexical label. The lexers are:
> +http://pygments.org/docs/lexers/
> +   Use the short names. For C code use 'c' code and 'shell' for shell
> +   scripts and for terminal output use 'none'.
I would not use 'shell' for commands. For example in
.. code-block:: shell
     ../configure --enable-rtemsbsp=qoriq_e6500_32 \
         QORIQ_IS_HYPERVISOR_GUEST=1 \
         QORIQ_UART_0_ENABLE=0 \
         QORIQ_UART_1_ENABLE=0 \
         QORIQ_TLB1_ENTRY_COUNT=16
the "variables" QORIQ_IS_HYPERVISOR_GUEST, etc. are highlighted and the
numeric "values" 0, etc. are highlighted differently. Is this useful? I
don't think so.
In real shell scripts with variables, loops, conditions and whatever
maybe it makes sense to use syntax highlighting.
> If you need line number
> +   use:
>          :linenos:
It seems there is a difference between the HTML and PDF output in terms
of line numbering. In the PDF I see the line numbers event without this
option.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
