[PATCH 1/2] arm/beagle: SPI driver
Wed Feb 27 07:49:31 UTC 2019
On 26/02/2019 22:24, pierre-louis garnier wrote:
> Hello Sebastian,
>> It would be great if you could convert your new driver to use this
>> framework. In case you have no time for this, then we can still add
>> this driver as is.
> I don't know how I missed the new framework.
Which documents did you read before you started the driver development?
> Unfortunately I won't have the time to port the driver to the new
> framework in the near future.
>> New code should use the BSD-2-Clause license:
> I agree to license the code as such. Here's a patch to change that.
I just saw the "based on" lines in the files. I checked in the patches
as is.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
