[PATCH] Coverage : Add coverage support for RISCV
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Feb 5 16:20:23 UTC 2019
On Tue, 5 Feb 2019 at 21:33, Hesham Almatary <hesham.almatary at cl.cam.ac.uk>
wrote:
> On Fri, 1 Feb 2019 at 14:53, Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com> wrote:
> > tester/covoar/TargetFactory.cc | 2 +
> > tester/covoar/Target_riscv.cc | 82 ++++++++++++++++
> > tester/covoar/Target_riscv.h | 98 ++++++++++++++++++++
> > tester/covoar/wscript | 3 +-
> > tester/rtems/testing/bsps/griscv-sis-cov.ini | 40 ++++++++
> > 5 files changed, 224 insertions(+), 1 deletion(-)
> > create mode 100644 tester/covoar/Target_riscv.cc
> > create mode 100644 tester/covoar/Target_riscv.h
> > create mode 100644 tester/rtems/testing/bsps/griscv-sis-cov.ini
> > diff --git a/tester/covoar/TargetFactory.cc
> b/tester/covoar/TargetFactory.cc
> > index fc9c30b..50e92a6 100644
> > --- a/tester/covoar/TargetFactory.cc
> > +++ b/tester/covoar/TargetFactory.cc
> > @@ -23,6 +23,7 @@
> > #include "Target_powerpc.h"
> > #include "Target_lm32.h"
> > #include "Target_sparc.h"
> > +#include "Target_riscv.h"
> > namespace Target {
> > @@ -56,6 +57,7 @@ namespace Target {
> > { "m68k", Target_m68k_Constructor },
> > { "powerpc", Target_powerpc_Constructor },
> > { "sparc", Target_sparc_Constructor },
> > + { "riscv", Target_riscv_Constructor },
> > { "TBD", NULL },
> > diff --git a/tester/covoar/Target_riscv.cc
> b/tester/covoar/Target_riscv.cc
> > new file mode 100644
> > index 0000000..3b2e221
> > --- /dev/null
> > +++ b/tester/covoar/Target_riscv.cc
> > @@ -0,0 +1,82 @@
> > + * RTEMS Tools Project (http://www.rtems.org/)
> > + * Copyright 2019 Vijay K. Banerjee (vijaykumar9597 at gmail.com)
> > + * All rights reserved.
> > + * This file is part of the RTEMS Tools package in 'rtems-tools'.
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> are met:
> > + * 1. Redistributions of source code must retain the above copyright
> notice,
> > + * this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> notice,
> > + * this list of conditions and the following disclaimer in the
> documentation
> > + * and/or other materials provided with the distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +/*! @file Target_riscv.cc
> > + * @brief Target_riscv Implementation
> > +#include <stdio.h>
> > +#include <stdlib.h>
> > +#include <string.h>
> > +#include <unistd.h>
> > +namespace Target {
> > + Target_riscv::Target_riscv( std::string targetName ):
> > + TargetBase( targetName )
> > + branchInstructions.push_back("beqz");
> > + branchInstructions.push_back("bnez");
> > + branchInstructions.push_back("blez");
> > + branchInstructions.push_back("bgez");
> > + branchInstructions.push_back("bltz");
> > + branchInstructions.push_back("bgt");
> > + branchInstructions.push_back("ble");
> > + branchInstructions.push_back("bgtu");
> > + branchInstructions.push_back("bleu");
> Is "bgtz" left out intentionally?
> No.
Thanks for pointing out. I'll add it in v3. :)
> > + branchInstructions.sort();
> > + Target_riscv::~Target_riscv()
> > + bool Target_riscv::isNopLine(
> > + const char* const line,
> > + int& size
> > + if (!strcmp( &line[strlen(line)-3], "nop")){
> > + size = 4;
> > + return true;
> > + return false;
> > + TargetBase *Target_riscv_Constructor(
> > + std::string targetName
> > + return new Target_riscv( targetName );
> > diff --git a/tester/covoar/Target_riscv.h b/tester/covoar/Target_riscv.h
> > index 0000000..112276c
> > --- /dev/null
> > +++ b/tester/covoar/Target_riscv.h
> > @@ -0,0 +1,98 @@
> are met:
> notice,
> notice,
> documentation
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +/*! @file Target_riscv.h
> > + * @brief Target_riscv Specification
> > + * This file contains the specification of the Target_riscv class.
> > +#ifndef __TARGET_RISCV_H__
> > +#define __TARGET_RISCV_H__
> > +#include <list>
> > +#include <string>
> > +#include "TargetBase.h"
> > +namespace Target {
> > + /*! @class Target_riscv
> > + * This is the class for the riscv target.
> > + class Target_riscv: public TargetBase {
> > + public:
> > + * Target_riscv constructor
> > + Target_riscv( std::string targetName );
> > + virtual ~Target_riscv();
> > + * This method determines nop instruction.
> > + * @param[in] line contains the object dump line to check
> > + * @param[out] size is set to the size in bytes of the nop
> > + * @return Returns True if the instruction is nop, False otherwise.
> > + bool isNopLine(
> > + int& size
> > + * This method determines if it's a branch instruction
> > + * @param[in] instruction
> > + * @return Returns True if the instruction is a branch instruction,
> False otherwise.
> > + bool isBranch(
> > + const char* const instruction
> > + private:
> > +#endif
> > diff --git a/tester/covoar/wscript b/tester/covoar/wscript
> > index a3730ea..e2644f6 100644
> > --- a/tester/covoar/wscript
> > +++ b/tester/covoar/wscript
> > @@ -105,7 +105,8 @@ def build(bld):
> > 'Target_lm32.cc',
> > 'Target_m68k.cc',
> > 'Target_powerpc.cc',
> > - 'Target_sparc.cc'],
> > + 'Target_sparc.cc',
> > + 'Target_riscv.cc'],
> > cflags = ['-O2', '-g', '-Wall'],
> > cxxflags = ['-std=c++11', '-O2', '-g', '-Wall'],
> > includes = ['.'] + rtl_includes)
> > diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini
> b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> > index 0000000..060bba7
> > --- /dev/null
> > +++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> > @@ -0,0 +1,40 @@
> > +# RTEMS Tools Project (http://www.rtems.org/)
> > +# Copyright 2019 Vijay K. Banerjee (vijaykumar9597 at gmail.com)
> > +# All rights reserved.
> > +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> > +# Redistribution and use in source and binary forms, with or without
> > +# modification, are permitted provided that the following conditions
> are met:
> > +# 1. Redistributions of source code must retain the above copyright
> notice,
> > +# this list of conditions and the following disclaimer.
> > +# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> > +# this list of conditions and the following disclaimer in the
> documentation
> > +# and/or other materials provided with the distribution.
> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
> CONTRIBUTORS BE
> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > +# POSSIBILITY OF SUCH DAMAGE.
> > +# The griscv BSP on sis with coverage
> > +[griscv-sis-cov]
> > +bsp = griscv-sis
> > +arch = riscv
> > +tester = %{_rtscripts}/run.cfg
> > +target = riscv-rtems5
> > +bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
> > +bsp_run_opts = -nouartrx -r -tlim 300 s -m 4 -cov
> > 2.17.2
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190205/c3b4f41c/attachment-0002.html>
