arm-rtems5-g++ -std=c++11 and -std=c++0x support
Mikhail Svetkin
mikhail.svetkin at gmail.com
Fri Jan 4 21:12:26 UTC 2019
Hi,
RTEMS supports only GNU extensions.
You can use -std=gnu++11
> On 4 Jan 2019, at 22:09, Misra, Avinash <Avinash.Misra at jhuapl.edu> wrote:
> Hi,
> Does the RTEMS 5 ARM G++ Cross Compiler support the –std flag? I’ve tried using –std=c++0x and –std=c++11 and both times I have gotten errors with type definitions in the standard includes. If the arm-rtems5-g++ cross compiler doesn’t support specifying which c++ standard to use then which standard is it using?
> Thanks,
> Avi
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
> http://lists.rtems.org/mailman/listinfo/devel <http://lists.rtems.org/mailman/listinfo/devel>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190104/ebd634d6/attachment-0001.html>
