arm-rtems5-g++ -std=c++11 and -std=c++0x support
Misra, Avinash
Avinash.Misra at jhuapl.edu
Mon Jan 7 13:54:47 UTC 2019
Hi Sebastian,
Thanks for letting me know. Do you know which version fixes this?
I’m currently using commit fdd3b85022b3fb9484f36e3b4cf755b584093cb1 I believe.
Thanks,
Avi
From: Mikhail Svetkin <mikhail.svetkin at gmail.com>
Sent: Monday, January 7, 2019 4:17 AM
To: Sebastian Huber <sebastian.huber at embedded-brains.de>
Cc: Misra, Avinash <Avinash.Misra at jhuapl.edu>; rtems-devel at rtems.org <devel at rtems.org>
Subject: Re: arm-rtems5-g++ -std=c++11 and -std=c++0x support
Good to know. Thank you!
Best regards,
Mikhail
On Mon, 7 Jan 2019 at 07:24, Sebastian Huber <sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>> wrote:
On 04/01/2019 22:12, Mikhail Svetkin wrote:
> Hi,
> RTEMS supports only GNU extensions.
> You can use -std=gnu++11
This was fixed recently. It should work now with -std=c++11.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
E-Mail : sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190107/2c70cb5c/attachment.html>
