arm-rtems5-g++ -std=c++11 and -std=c++0x support
Mon Jan 7 13:56:31 UTC 2019
Please try the current master with up to date tools. I think a Newlib
update was necessary for this.
On 07/01/2019 14:54, Misra, Avinash wrote:
> Hi Sebastian,
> Thanks for letting me know. Do you know which version fixes this?
> I’m currently using commit fdd3b85022b3fb9484f36e3b4cf755b584093cb1 I
> believe.
> Thanks,
> Avi
> *From:*Mikhail Svetkin <mikhail.svetkin at gmail.com>
> *Sent:* Monday, January 7, 2019 4:17 AM
> *To:* Sebastian Huber <sebastian.huber at embedded-brains.de>
> *Cc:* Misra, Avinash <Avinash.Misra at jhuapl.edu>; rtems-devel at rtems.org
> <devel at rtems.org>
> *Subject:* Re: arm-rtems5-g++ -std=c++11 and -std=c++0x support
> Good to know. Thank you!
> Best regards,
> Mikhail
> On Mon, 7 Jan 2019 at 07:24, Sebastian Huber
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 04/01/2019 22:12, Mikhail Svetkin wrote:
>     > Hi,
>     > RTEMS supports only GNU extensions.
>     > You can use -std=gnu++11
>     This was fixed recently. It should work now with -std=c++11.
>     Sebastian Huber, embedded brains GmbH
>     Address : Dornierstr. 4, D-82178 Puchheim, Germany
>     Phone   : +49 89 189 47 41-16
>     Fax     : +49 89 189 47 41-09
>     E-Mail  : sebastian.huber at embedded-brains.de
>     PGP     : Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
