[PATCH] psxhdrs: Add POSIX API Signature Compliance Tests for errno.h
Jacob Shin jacobshin313 at gmail.com
Tue Jan 8 04:14:21 UTC 2019
 testsuites/psxtests/psxhdrs/errno/errno.c | 44 +++++++++++++++++++++++
 1 file changed, 44 insertions(+)
 create mode 100755 testsuites/psxtests/psxhdrs/errno/errno.c
diff --git a/testsuites/psxtests/psxhdrs/errno/errno.c b/testsuites/psxtests/psxhdrs/errno/errno.c
new file mode 100755
index 0000000000..242d778019
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/errno/errno.c
@@ -0,0 +1,44 @@
+ *  @file
+ *  @brief errno API Conformance Test
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 Jacob Shin
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <errno.h>
+int test( void );
+int test( void )
+	return (errno == ERANGE);
\ No newline at end of file
2.17.1
