[PATCH] psxhdrs: Add POSIX API Signature Compliance Tests for errno.h
Joel Sherrill
joel at rtems.org
Tue Jan 8 16:02:37 UTC 2019
I committed this but had to make two changes.
+ tab -> 2 spaces
+ There was no addition to psxtests/Makefile.am
Thanks.
On Mon, Jan 7, 2019 at 10:14 PM Jacob Shin <jacobshin313 at gmail.com> wrote:
> testsuites/psxtests/psxhdrs/errno/errno.c | 44 +++++++++++++++++++++++
> 1 file changed, 44 insertions(+)
> create mode 100755 testsuites/psxtests/psxhdrs/errno/errno.c
> diff --git a/testsuites/psxtests/psxhdrs/errno/errno.c
> b/testsuites/psxtests/psxhdrs/errno/errno.c
> new file mode 100755
> index 0000000000..242d778019
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/errno/errno.c
> @@ -0,0 +1,44 @@
> + * @file
> + * @brief errno API Conformance Test
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2019 Jacob Shin
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <errno.h>
> +int test( void );
> +int test( void )
> + return (errno == ERANGE);
> \ No newline at end of file
> 2.17.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190108/e82a90a1/attachment-0002.html>
