[PATCH 0/5] Fix task mode for CPU ports with robust thread dispatch
Sebastian Huber
Tue Jan 8 08:59:30 UTC 2019
Sebastian Huber (5):
Separate task mode checks
rtems: Allow to set ISR level 0 in SMP config
tests: Remove bogus RTEMS_INTERRUPT_LEVEL(31)
Adjust interrupt mode tests for some CPU ports
riscv: Enable robust thread dispatch
cpukit/rtems/src/taskmode.c | 33 +++++++++++++-----------
cpukit/score/cpu/riscv/include/rtems/score/cpu.h | 3 +++
cpukit/score/src/threaddispatch.c | 2 +-
cpukit/score/src/threadinitialize.c | 21 +++++++++------
testsuites/smptests/smpunsupported01/init.c | 2 +-
testsuites/sptests/sp01/init.c | 2 +-
testsuites/sptests/sp08/init.c | 23 ++++++++++++++---
testsuites/sptests/sp37/init.c | 10 ++++++-
testsuites/sptests/spcbssched01/init.c | 2 +-
testsuites/sptests/spedfsched01/init.c | 2 +-
testsuites/sptests/spfifo03/init.c | 2 +-
testsuites/sptests/spfifo05/init.c | 2 +-
12 files changed, 70 insertions(+), 34 deletions(-)
2.16.4
