RSB documentation
Wed Jan 9 10:55:18 UTC 2019
Hello,
the RSB has currently its own manual in the documentation set:
https://docs.rtems.org/branches/master/rsb/index.html
I think it would make sense to move the RSB documentation into the user
manual as a chapter. If you are new to RTEMS, then dealing with the RSB
is one of the first things you have to do. I think it is easier if you
have every to get started in one manual (e.g. you can use documentation
internal links).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
