RSB documentation
Wed Jan 9 23:51:38 UTC 2019
On 10/1/19 3:41 am, Gedare Bloom wrote:
> I'm OK with this proposal.  We used to include quite messy details about how to
> bootstrap your own GCC in the user manual. This is a bit nicer. ;) At the
> maturity of RSB now, merging the doco with the User Manual is sensible.
Agreed, this is sensible. I am fine with this happening.
> On Wed, Jan 9, 2019 at 5:55 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>
> wrote:
>     Hello,
>     the RSB has currently its own manual in the documentation set:
>     https://docs.rtems.org/branches/master/rsb/index.html
>     I think it would make sense to move the RSB documentation into the user
>     manual as a chapter. If you are new to RTEMS, then dealing with the RSB
>     is one of the first things you have to do. I think it is easier if you
>     have every to get started in one manual (e.g. you can use documentation
>     internal links).
>     Sebastian Huber, embedded brains GmbH
>     Address : Dornierstr. 4, D-82178 Puchheim, Germany
>     Phone   : +49 89 189 47 41-16
>     Fax     : +49 89 189 47 41-09
>     E-Mail  : sebastian.huber at embedded-brains.de
>     PGP     : Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
