RSB documentation
Gedare Bloom
gedare at rtems.org
Wed Jan 9 16:41:56 UTC 2019
I'm OK with this proposal. We used to include quite messy details about
how to bootstrap your own GCC in the user manual. This is a bit nicer. ;)
At the maturity of RSB now, merging the doco with the User Manual is
sensible.
On Wed, Jan 9, 2019 at 5:55 AM Sebastian Huber <
> Hello,
> the RSB has currently its own manual in the documentation set:
> https://docs.rtems.org/branches/master/rsb/index.html
> I think it would make sense to move the RSB documentation into the user
> manual as a chapter. If you are new to RTEMS, then dealing with the RSB
> is one of the first things you have to do. I think it is easier if you
> have every to get started in one manual (e.g. you can use documentation
> internal links).
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190109/e31916fa/attachment.html>
