Status of RISCV port on sis
Jiri Gaisler jiri at gaisler.se
Sat Jan 12 23:09:18 UTC 2019
On 1/11/19 1:36 PM, Jiri Gaisler wrote:
> On 1/9/19 10:46 AM, Sebastian Huber wrote:
>> Hello Jiri,
>> could you please rebase your work to this RTEMS commit:
>> https://git.rtems.org/rtems/commit/?id=b9ffc41c9678fb3c5386c1a6ab394656ec85dbc6
> This works fine for me - I can now pass all uni-processor tests. On SMP, I still have a few fails but I think they are related to the simulator and the compressed RISC-V instruction set. I will investigate further ...
The atomic LR/SC instructions did not work as expected in the simulator, which caused the failures. After cleaning that up, all tests now pass. I have tested up to 4 cpus and various frequencies and time slots in the sim with no fails, so it seems fairly robust. I will clean up my bsp sources and post the patches on the list for review. I will also provide a patch for the RISC-V version of gdb-8.2 to add the new sim. Thanks for the help to get this going..!
$ rtems-test --rtems-bsp=riscv-sis riscv-rtems5/c/grlib/testsuites --log=all.txt
Passed:        630
Failed:          0
User Input:      5
Expected Fail:   0
Indeterminate:   0
Benchmark:       3
Timeout:         0
Invalid:         0
Wrong Version:   0
Wrong Build:     0
Wrong Tools:     0
Total:         638
User Input:
 monitor.exe
 termios.exe
 top.exe
 capture.exe
 fileio.exe
Benchmark:
 linpack.exe
 dhrystone.exe
 whetstone.exe
Average test time: 0:00:00.732410
Testing time     : 0:07:47.277261
