Status of RISCV port on sis
Sun Jan 13 13:48:45 UTC 2019
----- Am 13. Jan 2019 um 0:09 schrieb Jiri Gaisler jiri at gaisler.se:
> On 1/11/19 1:36 PM, Jiri Gaisler wrote:
>> On 1/9/19 10:46 AM, Sebastian Huber wrote:
>>> Hello Jiri,
>>> could you please rebase your work to this RTEMS commit:
>>> https://git.rtems.org/rtems/commit/?id=b9ffc41c9678fb3c5386c1a6ab394656ec85dbc6
>> This works fine for me - I can now pass all uni-processor tests. On SMP, I still
>> have a few fails but I think they are related to the simulator and the
>> compressed RISC-V instruction set. I will investigate further ...
> The atomic LR/SC instructions did not work as expected in the simulator, which
> caused the failures. After cleaning that up, all tests now pass. I have tested
> up to 4 cpus and various frequencies and time slots in the sim with no fails,
> so it seems fairly robust. I will clean up my bsp sources and post the patches
> on the list for review. I will also provide a patch for the RISC-V version of
> gdb-8.2 to add the new sim. Thanks for the help to get this going..!
> $ rtems-test --rtems-bsp=riscv-sis riscv-rtems5/c/grlib/testsuites --log=all.txt
> Passed:        630
> Failed:          0
> User Input:      5
> Expected Fail:   0
> Indeterminate:   0
> Benchmark:       3
> Timeout:         0
> Invalid:         0
> Wrong Version:   0
> Wrong Build:     0
> Wrong Tools:     0
> Total:         638
> User Input:
> monitor.exe
> termios.exe
> top.exe
> capture.exe
> fileio.exe
> Benchmark:
> linpack.exe
> dhrystone.exe
> whetstone.exe
> Average test time: 0:00:00.732410
> Testing time     : 0:07:47.277261
This is really great. This is the second free simulator (the other is SIS) which is capable enough to run all tests successfully. We should think about making a RISC-V BSP the default in the documentation instead of erc32.
