clang-format Style for RTEMS
Mikail Yayla
myayla1245 at gmail.com
Sun Jan 13 21:36:45 UTC 2019
Hello,
to evaluate the effort needed to adapt clang-format for RTEMS, we are
currently trying to implement the option to put the ")" at the
end of a function declaration in a separate line, e.g.:
bool _Thread_Initialize(
Thread_Information *information,
Objects_Name name
) // <- in a new line
I asked for help in the clang mailing list, but it does not seem like there
is a person who is willing to mentor me in getting used to the clang-format
code and the tools it depends on. It looks like they don't have much
interest to invest time in a private patch.
Currently I am using QtCreator to load the LLVM cmake and build the
project. It is possible to use the Debugger to trace the execution of
clang-format.
In my view, with the help of QtCreator and the debugger it should be
possible to adapt clang-format for RTEMS in a reasonable amount of time.
But since it is an extensive project, it will take some time to understand
the code and to feel comfortable enough to implement new functionality.
Best,
Mikail
On Mon, Dec 17, 2018 at 1:44 PM Sebastian Huber <
> Hello Mikail,
> thanks for your summary. I tried a couple for C code formatters for
> RTEMS in the last couple of years and none delivered sufficiently good
> results. My hope was that we could use clang-format with some additions
> for RTEMS. However, it seems the hurdle to add new style options to
> clang-format is quite high:
> https://clang.llvm.org/docs/ClangFormatStyleOptions.html#adding-additional-style-options
> "The goal of the clang-format project is more on the side of supporting
> a limited set of styles really well as opposed to supporting every
> single style used by a codebase somewhere in the wild. Of course, we do
> want to support all major projects and thus have established the
> following bar for adding style options. Each new style option must ..
> * be used in a project of significant size (have dozens of
> contributors)
> * have a publicly accessible style guide
> * have a person willing to contribute and maintain patches"
> I am not sure if RTEMS would count as a project of "significant size".
> See also:
> http://lists.llvm.org/pipermail/cfe-dev/2018-December/060560.html
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190113/88b7b79f/attachment.html>
