Zynq RTEMS 5 SMP Crashing on call to connect in socket.h [Solved]
Misra, Avinash
Avinash.Misra at jhuapl.edu
Sun Jan 13 21:51:40 UTC 2019
Hi,
My issue turned out to be a configuration issue where I was using the incorrect scheduler. I was originally using #define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP when in fact I should have been using #define CONFIGURE_SCHEDULER_EDF_SMP. This thread (https://lists.rtems.org/pipermail/devel/2018-October/023349.html) made that very clear to me. However, I do wonder if this is documented as part of the BSD documentation and I missed it? Is this already well documented or is this something that should be included with the BSD/RTEMS Networking documentation?
Thanks,
Avi
From: devel <devel-bounces at rtems.org> On Behalf Of Misra, Avinash
Sent: Sunday, January 13, 2019 1:04 PM
To: rtems-devel at rtems.org <devel at rtems.org>
Subject: Zynq RTEMS 5 SMP Crashing on call to connect in socket.h
Hi,
I'm having a peculiar issue when running RTEMS in a SMP configuration and trying to call connect on a TCP Client Socket which is that RTEMS crashes when calling the system connect routine with the following error:
Fatal source: 10 <RTEMS_FATAL_SOURCE_SMP>
Fatal Code: 7 <0x00000007>
RTEMS version: 5.0.0.b3c624d8886db6e791babe5e0d4f8b28992e000a
RTEMS tools: 7.3.0 20180125 (RTEMS 5, RSB 9955b1a430677b12c04c77eb6502fae4bb6947b2, Newlib 08eab6396f678cf5e5968acaed0bae9fd129983b)
Executing Thread ID: 0x08a010003
Executing Thread Name: IRQS
This only seems to occur when I configure RTEMS to execute on both cores of the A9 processor (by setting #define CONFIGURE_MAXIMUM_PROCESSORS to 2). When I have #define CONFIGURE_MAXIMUM_PROCESSORS set to 1 the program runs as expected, connects to my TCP server and sends nominal data. Also, for what it's worth, the name of my task is not IRQS so I'm not sure why I keep getting this exception in the IRQS thread.
My system.hdf file and MMU setup code look as follow:
System.hdf:
[cid:image001.jpg at 01D4AB60.40D3CEE0]
MMU Configuration file:
#include <bsp.h>
#include <bsp/start.h>
#include <bsp/arm-gic-irq.h>
#include <bsp/arm-cp15-start.h>
#include <bsp/arm-a9mpcore-start.h>
BSP_START_DATA_SECTION static const arm_cp15_start_section_config
zynq_mmu_config_table[] = {
ARMV7_CP15_START_DEFAULT_SECTIONS,
.begin = 0xE0000000U,
.end = 0xE0300000U,
.flags = ARMV7_MMU_DEVICE | ARM_MMU_SECT_S
.begin = 0xF8000000U,
.end = 0xF9000000U,
.begin = 0x00000000U, /*RAM 0 START ADDR*/
.end = 0x0002FFFFU, /*RAM 0 END ADDR*/
.begin = 0xFFFF0000U, /*RAM 1 START ADDR*/
.end = 0xFFFFFDFFU, /*RAM 1 END ADDR*/
.begin = 0x41200000U, /*AXI GPIO*/
.end = 0x4120FFFFU, /*AXI GPIO*/
BSP_START_TEXT_SECTION void zynq_setup_mmu_and_cache(void)
uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
ARM_CP15_CTRL_A,
ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
ctrl,
(uint32_t *) bsp_translation_table_base,
ARM_MMU_DEFAULT_CLIENT_DOMAIN,
&zynq_mmu_config_table[0],
RTEMS_ARRAY_SIZE(zynq_mmu_config_table)
Does anyone have an idea of as to what may be going on here?
Thanks,
Avi
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190113/eb109bbf/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190113/eb109bbf/attachment-0001.jpg>
