Status of RISCV port on sis
Hesham Almatary heshamelmatary at gmail.com
Tue Jan 15 18:25:08 UTC 2019
Sounds great. It might be worth it to add an entry for sis here [1]
[1] https://github.com/riscv/riscv-wiki/wiki/RISC-V-Software-Status
On Sun, 13 Jan 2019 at 15:30, Jiri Gaisler <jiri at gaisler.se> wrote:
> On 1/13/19 2:48 PM, Sebastian Huber wrote:
> > ----- Am 13. Jan 2019 um 0:09 schrieb Jiri Gaisler jiri at gaisler.se:
> >> On 1/11/19 1:36 PM, Jiri Gaisler wrote:
> >>> On 1/9/19 10:46 AM, Sebastian Huber wrote:
> >>>> Hello Jiri,
> >>>> could you please rebase your work to this RTEMS commit:
> >>>> https://git.rtems.org/rtems/commit/?id=b9ffc41c9678fb3c5386c1a6ab394656ec85dbc6
> >>> This works fine for me - I can now pass all uni-processor tests. On SMP, I still
> >>> have a few fails but I think they are related to the simulator and the
> >>> compressed RISC-V instruction set. I will investigate further ...
> >> The atomic LR/SC instructions did not work as expected in the simulator, which
> >> caused the failures. After cleaning that up, all tests now pass. I have tested
> >> up to 4 cpus and various frequencies and time slots in the sim with no fails,
> >> so it seems fairly robust. I will clean up my bsp sources and post the patches
> >> on the list for review. I will also provide a patch for the RISC-V version of
> >> gdb-8.2 to add the new sim. Thanks for the help to get this going..!
> >> $ rtems-test --rtems-bsp=riscv-sis riscv-rtems5/c/grlib/testsuites --log=all.txt
> >> Passed:        630
> >> Failed:          0
> >> User Input:      5
> >> Expected Fail:   0
> >> Indeterminate:   0
> >> Benchmark:       3
> >> Timeout:         0
> >> Invalid:         0
> >> Wrong Version:   0
> >> Wrong Build:     0
> >> Wrong Tools:     0
> >> Total:         638
> >> User Input:
> >>  monitor.exe
> >>  termios.exe
> >>  top.exe
> >>  capture.exe
> >>  fileio.exe
> >> Benchmark:
> >>  linpack.exe
> >>  dhrystone.exe
> >>  whetstone.exe
> >> Average test time: 0:00:00.732410
> >> Testing time     : 0:07:47.277261
> > This is really great. This is the second free simulator (the other is SIS) which is capable enough to run all tests successfully. We should think about making a RISC-V BSP the default in the documentation instead of erc32.
> Good idea. ERC32 is getting old and is not really known outside the space community. I still need to add the M, F and D extensions to the RISC-V sim though, so we can test all of the (32-bit) combinations. I should be able to do this next week and then I can post all patches for review and testing. Code coverage support is still on the list, it will follow once the sim has settled a bit ...
> devel mailing list
> devel at rtems.org
Hesham
