[PATCH] Fix 'build_max_size_human' ref. before assignment
Fri Jan 18 09:08:13 UTC 2019
On 16/01/2019 07:05, Sebastian Huber wrote:
> On 16/01/2019 02:27, Chris Johns wrote:
>> On 15/1/19 11:31 pm, Sebastian Huber wrote:
>>> On 13/01/2019 23:17, Chris Johns wrote:
>>>> On 14/1/19 8:05 am, Chris Johns wrote:
>>>>> On 11/1/19 4:31 pm, Sebastian Huber wrote:
>>>>>> ----- Am 11. Jan 2019 um 0:11 schrieb Chris Johns chrisj at rtems.org:
>>>>>>> On 10/1/19 11:17 pm, Sebastian Huber wrote:
>>>>>>>> This patch resulted in this mail report issue:
>>>>>>>> Your mail to 'build' with the subject
>>>>>>>>       Build Linux: FAILED 6/rtems-epiphany on x86_64-linux-gnu
>>>>>>>> (epiphany-rtems6-gcc-76fb04650b2bacd33eaff257f08fabcc237ec885-newlib-fbd3835384fa586fd32ce80280d81bb51ab042ba-x86_64-linux-gnu-1)
>>>>>>>> Is being held until the list moderator can review it for approval.
>>>>>>>> The reason it is being held:
>>>>>>>>       Message body is too big: 1093190 bytes with a limit of
>>>>>>>> 256 KB
>>>>>>> Are you asking for the size limit on the list to be raised?
>>>>>> No, but is this the normal size for a failed report?
>>>>> It should not be. I will accept the post and then we can see the
>>>>> reason.
>>>> The report captures the last part of the build and it looks like
>>>> the lines in
>>>> the section of the libstdc++ library being built are long. The use
>>>> of full
>>>> length hashes in gcc and newlib has increased the path lengths.
>>>> I increased the number of lines captured a while ago because the
>>>> number of cores
>>>> being used when building meant distance in the output between the
>>>> error and the
>>>> end of the log can be a long way.
>>>> Maybe a smarter parser should be added and just the error logged?
>>> When I look for tool chain build errors I simply go to the end of
>>> the log file
>>> and then search backwards for "error:".
>> There are linker and I think assembler errors which do not work as
>> well ...
>> https://git.rtems.org/rtems-tools/tree/tester/rt/check.py#n447
> Ok, it is not that simple. I guess we have to improve this each time
> we see a 1MiB error log context.
It seems Ada build errors are quite difficult to identify. What worked
quite well is searching for "make.*Error" from the top of the file.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
