[PATCH 03/10] user: Rework Prefixes section
Thu Jan 24 10:49:46 UTC 2019
On 24/01/2019 11:47, Chris Johns wrote:
>> +:file:`/usr/local` on FreeBSD and Linux.
>> +You have to select a prefix for your RTEMS tool suite installation.  The RTEMS
>> +tool suite consists of a cross tool chain (Binutils, GCC, GDB, Newlib, etc.)
>> +for your target architecture and :ref:`other tools <HostTools>` provided by the
>> +RTEMS Project.  You build and install the tool suite with the
>> +:ref:`RTEMS Source Builder (RSB) <RSB>`.  By default, the RSB will use an
>> +operating system specific part plus :file:`rtems` plus the RTEMS version, e.g.
>   Specific part or path?
Ok, it is path, e.g. /usr/local on FreeBSD.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
