[PATCH 03/10] user: Rework Prefixes section
Thu Jan 24 11:12:58 UTC 2019
On 24/1/19 9:49 pm, Sebastian Huber wrote:
> On 24/01/2019 11:47, Chris Johns wrote:
>>> +:file:`/usr/local` on FreeBSD and Linux.
>>> +You have to select a prefix for your RTEMS tool suite installation.  The RTEMS
>>> +tool suite consists of a cross tool chain (Binutils, GCC, GDB, Newlib, etc.)
>>> +for your target architecture and :ref:`other tools <HostTools>` provided by the
>>> +RTEMS Project.  You build and install the tool suite with the
>>> +:ref:`RTEMS Source Builder (RSB) <RSB>`.  By default, the RSB will use an
>>> +operating system specific part plus :file:`rtems` plus the RTEMS version, e.g.
>>   Specific part or path?
> Ok, it is path, e.g. /usr/local on FreeBSD.
Oh, what about:
 by default, the RSB will start the prefix path with your host's default
 operating system install path plus ...
