[PATCH 03/10] user: Rework Prefixes section
Fri Jan 25 08:40:00 UTC 2019
On 24/01/2019 12:12, Chris Johns wrote:
> On 24/1/19 9:49 pm, Sebastian Huber wrote:
>> On 24/01/2019 11:47, Chris Johns wrote:
>>>> +:file:`/usr/local` on FreeBSD and Linux.
>>>> +You have to select a prefix for your RTEMS tool suite installation.  The RTEMS
>>>> +tool suite consists of a cross tool chain (Binutils, GCC, GDB, Newlib, etc.)
>>>> +for your target architecture and :ref:`other tools <HostTools>` provided by the
>>>> +RTEMS Project.  You build and install the tool suite with the
>>>> +:ref:`RTEMS Source Builder (RSB) <RSB>`.  By default, the RSB will use an
>>>> +operating system specific part plus :file:`rtems` plus the RTEMS version, e.g.
>>>    Specific part or path?
>> Ok, it is path, e.g. /usr/local on FreeBSD.
> Oh, what about:
>   by default, the RSB will start the prefix path with your host's default
>   operating system install path plus ...
Ok, I change it like this.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
