[PATCH v2 08/10] user: Add "Test a Board Support Package (BSP)"
Mon Jan 28 12:27:10 UTC 2019
 user/start/bsp-test.rst | 66 +++++++++++++++++++++++++++++++++++++++++++++++++
 user/start/index.rst    |  1 +
 user/testing/index.rst  |  2 ++
 3 files changed, 69 insertions(+)
 create mode 100644 user/start/bsp-test.rst
diff --git a/user/start/bsp-test.rst b/user/start/bsp-test.rst
new file mode 100644
index 0000000..5278375
--- /dev/null
+++ b/user/start/bsp-test.rst
@@ -0,0 +1,66 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2019 embedded brains GmbH
+.. Copyright (C) 2019 Sebastian Huber
+.. _QuickStartBSPTest:
+Test a Board Support Package (BSP)
+You built a BSP with tests in the previous section.  We built the ``erc32`` BSP
+in :file:`$HOME/quick-start/build/b-erc32`.
+You should run the RTEMS test suite on your target hardware.  The RTEMS Project
+provides some support to do this, see the :ref:`Testing <Testing>` chapter for
+the details.
+On the ``erc32`` BSP we selected for this quick start chapter this is easy.
+Just run this command:
+.. code-block:: none
+    cd $HOME/quick-start/build/b-erc32
+    rtems-test --rtems-bsp=erc32 --rtems-tools=$HOME/quick-start/rtems/5 .
+This command should output something like this (omitted lines are denoted by
+...).  In this output the base directory :file:`$HOME/quick-start` was replaced
+by ``$BASE``.
+    RTEMS Testing - Tester, 5.0.not_released
+     Command Line: $BASE/rtems/5/bin/rtems-test --rtems-bsp=erc32 --rtems-tools=$BASE/rtems/5 .
+     Python: 2.7.15 (default, Jan 10 2019, 01:14:47) [GCC 4.2.1 Compatible FreeBSD Clang 6.0.1 (tags/RELEASE_601/final 335540)]
+    Host: FreeBSD-12.0-RELEASE-p2-amd64-64bit-ELF (FreeBSD Build_FreeBSD12 12.0-RELEASE-p2 FreeBSD 12.0-RELEASE-p2 GENERIC amd64 amd64)
+    [  1/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | sparc/erc32: dhrystone.exe
+    [589/589] p:574 f:0   u:5   e:0   I:0   B:3   t:0   i:0   W:0   | sparc/erc32: tmtimer01.exe
+    Passed:        580
+    Failed:          0
+    User Input:      5
+    Expected Fail:   0
+    Indeterminate:   0
+    Benchmark:       3
+    Timeout:         1
+    Invalid:         0
+    Wrong Version:   0
+    Wrong Build:     0
+    Wrong Tools:     0
+    Total:         589
+    User Input:
+     monitor.exe
+     termios.exe
+     top.exe
+     fileio.exe
+     capture.exe
+    Benchmark:
+     whetstone.exe
+     linpack.exe
+     dhrystone.exe
+    Timeouts:
+     pppd.exe
+    Average test time: 0:00:00.437773
+    Testing time     : 0:04:17.848557
diff --git a/user/start/index.rst b/user/start/index.rst
index 00a3644..a9c9a6a 100644
--- a/user/start/index.rst
+++ b/user/start/index.rst
@@ -22,6 +22,7 @@ applications on top of RTEMS.
     tools
     bootstrap
     bsp-build
+    bsp-test
 The following is a quick start guide that provides a basic set of commands to
 build the RTEMS Tools and Kernel. The quick start guide provides links to the
diff --git a/user/testing/index.rst b/user/testing/index.rst
index 4596339..7eefff1 100644
--- a/user/testing/index.rst
+++ b/user/testing/index.rst
@@ -2,6 +2,8 @@
 .. Copyright (C) 2018 Chris Johns <chrisj at rtems.org>
+.. _Testing:
 Testing
2.16.4
