[PATCH v2 07/10] user: Add "Build a Board Support Package (BSP)"
Mon Jan 28 12:27:09 UTC 2019
 user/start/bsp-build.rst | 146 +++++++++++++++++++++++++++++++++++++++++++++++
 user/start/index.rst     |   1 +
 2 files changed, 147 insertions(+)
 create mode 100644 user/start/bsp-build.rst
diff --git a/user/start/bsp-build.rst b/user/start/bsp-build.rst
new file mode 100644
index 0000000..3b9eb15
--- /dev/null
+++ b/user/start/bsp-build.rst
@@ -0,0 +1,146 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2019 embedded brains GmbH
+.. Copyright (C) 2019 Sebastian Huber
+.. _QuickStartBSPBuild:
+Build a Board Support Package (BSP)
+You installed the tool suite in your installation prefix, cloned two RTEMS
+repositories and bootstrapped the RTEMS sources in the previous sections.  We
+installed the tool suite in :file:`$HOME/quick-start/rtems/5` and cloned the
+repositories in :file:`$HOME/quick-start/src`.  We also bootstrapped the RTEMS
+sources.
+You are now able to build :ref:`Board Support Packages (BSPs) <BSPs>` for all
+architectures where you have an RTEMS tool suite installed.  To build
+applications on top of RTEMS, you have to configure, build and install a BSP
+for your target hardware.  To select a proper BSP for your target hardware
+consult the :ref:`BSPs <BSPs>` chapter.  We select the `erc32` BSP.
+We configure, build and install the BSP in four steps.  The first step is to
+create a build directory.  It must be separate from the RTEMS source directory.
+We use :file:`$HOME/quick-start/build/b-erc32`.
+.. code-block:: none
+    mkdir -p $HOME/quick-start/build/b-erc32
+The second step is to configure the BSP.  There are various configuration
+options available.  Some configuration options are BSP-specific.  Prepend the
+RTEMS tool suite binary directory to your ``$PATH`` throughout the remaining
+steps.
+    cd $HOME/quick-start/build/b-erc32
+    export PATH=$HOME/quick-start/rtems/5/bin:"$PATH"
+    $HOME/quick-start/src/rtems/configure \
+        --prefix=$HOME/quick-start/rtems/5 \
+        --enable-maintainer-mode \
+        --target=sparc-rtems5 \
+        --enable-rtemsbsp=erc32 \
+        --enable-tests
+This command should output something like this (omitted lines are denoted by
+    checking for gmake... gmake
+    checking for RTEMS Version... 5.0.0
+    checking build system type... x86_64-unknown-freebsd12.0
+    checking host system type... x86_64-unknown-freebsd12.0
+    checking target system type... sparc-unknown-rtems5
+    config.status: creating Makefile
+    target architecture: sparc.
+    available BSPs: erc32.
+    'gmake all' will build the following BSPs: erc32.
+    other BSPs can be built with 'gmake RTEMS_BSP="bsp1 bsp2 ..."'
+Building the BSP is the third step.
+    make
+...).  In this output the base directory :file:`$HOME/quick-start` was replaced
+by ``$BASE``.
+    Configuring RTEMS_BSP=erc32
+    checking host system type... sparc-unknown-rtems5
+    checking rtems target cpu... sparc
+    checking for a BSD-compatible install... /usr/bin/install -c
+    checking whether build environment is sane... yes
+    checking for sparc-rtems5-strip... sparc-rtems5-strip
+    checking for a thread-safe mkdir -p... $BASE/src/rtems/c/src/../../install-sh -c -d
+    checking for gawk... no
+    checking for mawk... no
+    checking for nawk... nawk
+    checking whether gmake sets $(MAKE)... yes
+    checking whether to enable maintainer-specific portions of Makefiles... yes
+    checking for RTEMS_BSP... erc32
+    checking whether CPU supports libposix... yes
+    configure: setting up make/custom
+    configure: creating make/erc32.cache
+    gmake[3]: Entering directory '$BASE/build/b-erc32/sparc-rtems5/c/erc32'
+    sparc-rtems5-gcc  -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -B./../../lib/libbsp/sparc/erc32 -B$BASE/src/rtems/bsps/sparc/erc32/start -specs bsp_specs -qrtems -L./../../cpukit -L$BASE/src/rtems/bsps/sparc/shared/start -Wl,--wrap=printf -Wl,--wrap=puts -Wl,--wrap=putchar -Wl,--gc-sections -o spwkspace.exe spwkspace/spwkspace-init.o ./../../lib/libbsp/sparc/erc32/librtemsbsp.a ./../../cpukit/librtemscpu.a
+    gmake[5]: Leaving directory '$BASE/build/b-erc32/sparc-rtems5/c/erc32/testsuites/sptests'
+    gmake[4]: Leaving directory '$BASE/build/b-erc32/sparc-rtems5/c/erc32/testsuites'
+    gmake[3]: Leaving directory '$BASE/build/b-erc32/sparc-rtems5/c/erc32'
+    gmake[2]: Leaving directory '$BASE/build/b-erc32/sparc-rtems5/c/erc32'
+    gmake[1]: Leaving directory '$BASE/build/b-erc32/sparc-rtems5/c'
+    gmake[1]: Entering directory '$BASE/build/b-erc32'
+    gmake[1]: Nothing to be done for 'all-am'.
+    gmake[1]: Leaving directory '$BASE/build/b-erc32'
+The last step is to install the BSP.
+    make install
+by ``$BASE``.
+    Making install in sparc-rtems5/c
+    gmake[1]: Entering directory '$BASE/build/b-erc32/sparc-rtems5/c'
+    Making install in .
+    gmake[2]: Entering directory '$BASE/build/b-erc32/sparc-rtems5/c'
+    gmake[3]: Entering directory '$BASE/build/b-erc32/sparc-rtems5/c'
+    gmake[3]: Nothing to be done for 'install-exec-am'.
+    gmake[3]: Nothing to be done for 'install-data-am'.
+    gmake[3]: Leaving directory '$BASE/build/b-erc32/sparc-rtems5/c'
+    gmake[2]: Leaving directory '$BASE/build/b-erc32/sparc-rtems5/c'
+    Making install in erc32
+    gmake[2]: Entering directory '$BASE/build/b-erc32/sparc-rtems5/c/erc32'
+    Making install-am in .
+    Making install-am in cpukit
+    gmake[4]: Entering directory '$BASE/build/b-erc32/sparc-rtems5/c/erc32/cpukit'
+    gmake[5]: Entering directory '$BASE/build/b-erc32/sparc-rtems5/c/erc32/cpukit'
+    gmake[5]: Nothing to be done for 'install-exec-am'.
+     $BASE/src/rtems/c/src/../../cpukit/../install-sh -c -d '$BASE/rtems/5/sparc-rtems5/erc32/lib/include'
+    $BASE/src/rtems/make/Templates/Makefile.lib '$BASE/rtems/5/share/rtems5/make/Templates'
+     $BASE/src/rtems/./install-sh -c -d '$BASE/rtems/5/make/custom'
+     /usr/bin/install -c -m 644 $BASE/src/rtems/make/custom/default.cfg '$BASE/rtems/5/make/custom'
+    gmake[2]: Leaving directory '$BASE/build/b-erc32'
diff --git a/user/start/index.rst b/user/start/index.rst
index c4bb1ed..00a3644 100644
--- a/user/start/index.rst
+++ b/user/start/index.rst
@@ -21,6 +21,7 @@ applications on top of RTEMS.
     sources
     tools
     bootstrap
+    bsp-build
 The following is a quick start guide that provides a basic set of commands to
 build the RTEMS Tools and Kernel. The quick start guide provides links to the
2.16.4
