Error: undefined reference to ndbm functions
Vaibhav Gupta vaibhavgupta40 at gmail.com
Mon Jul 1 10:53:50 UTC 2019
Hello,
I am reading about memcpy to write it for newlib.
Should I also write wmemcpy along with it?
https://pubs.opengroup.org/onlinepubs/009695399/functions/wmemcpy.html
Regarding ndbm reference. RSB has not generated library files.
- but in newlib source tree, when I compiled newlib, while porting ndbm, it
generated *lib_a-ndbm.o* object file.
- I am planning to use that object file to compile ndbm testsuite.
When Object file and C file are present in same directory, we can use :
$ gcc trial.c mylib.o
But I am not able to find out, how to use this in Makefile.am.
LDADD replaces all global variables while compiling.
I tried various codes, but could not solve it. I just want to use the
object file (lib_a-ndbm.o)
created while building newlib, to compile ndbm testsuite.
I need guidance for this.
Vaibhav Gupta
On Fri, Jun 28, 2019 at 9:57 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Jun 28, 2019 at 7:20 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > On Fri, Jun 28, 2019, 6:19 PM Joel Sherrill <joel at rtems.org> wrote:
> >> On Fri, Jun 28, 2019, 8:40 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >>> On Fri, Jun 28, 2019, 5:57 PM Joel Sherrill <joel at rtems.org> wrote:
> >>>> You need to add the library to the gcc command that links the
> program. If the libndbm is in the library search path, add -lndbm.
> >>>> I don't recall the exact Makefile variable to set for this to show
> up. Look at the paranoia sample. It should be doing this with -lm.
> >>>> --joel
> >>> Okay, I will try this!
> >> The following web page is a pretty good description of building a
> library using a native GCC and linking it into a program. It includes some
> of the theory going on so this might help you.
> >> https://www.cs.swarthmore.edu/~newhall/unixhelp/howto_C_libraries.html
> >> Guys.. this comes up periodically, even though this is really basic
> tool usage to me, is this something we should provide some guidance on?
> > Actually, i tried this before, but I cannot find libndbm in my
> development directory. I guess it is not generated.
> > One thing I can do is, the newlib-cygwin i compiled while porting ndbm,
> it generated ndbm library. I can use that.
> Yes, the library should be 'bundled' with the updated compiler
> toolchain. You need to be sure you are using this toolchain. Is it
> what you installed to /home/varodek/development/rtems/5 ?
> Gedare
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190701/23d9af2e/attachment.html>
