GSoC Project | Basic Support for Trace Compass
Thu Jul 4 06:51:08 UTC 2019
On 04/07/2019 08:41, Sebastian Huber wrote:
> On 04/07/2019 08:36, Ravindra Kumar Meena wrote:
>>     This change isn't right. We want to use the file per CPU exactly
>> to get
>>     rid of this member.
>> https://github.com/rmeena840/rtems-tools/commit/582b999b135ddcbc1fc88a9ee2b302fe811382a7
>>      > I have added cpu_id in ctf_event so that babeltrace knows that
>> which
>>      > cpu_id is it reading.
>>     In your metadata you removed the cpu member from the event structure.
>> I removed it because the new binary stream file does not have CPU. It
>> has only three values ns, event, and data.
> In commit 582b999b135ddcbc1fc88a9ee2b302fe811382a7 we have:
> typedef struct ctf_event {
>    uint32_t                     cpu_id;
>    uint64_t                     ns;
>    rtems_record_event           event;
>    uint64_t                     data;
> } ctf_event;
> So, the new binary stream is not new, it still has the CPU member!
> The CPU member must move to the packet header. The packet header tells
> the consumer (e.g. babeltrace): the following events of this packet all
> belong to this CPU.
Your latest versions has a warning:
../misc/record/record-main.c: In function ‘main’:
../misc/record/record-main.c:135:59: warning: ‘input_file’ may be used
uninitialized in this function [-Wmaybe-uninitialized]
    fd = ( input_file_flag ) ? open( input_file, O_RDONLY ) :
    socket( PF_INET, SOCK_STREAM, 0 );
../misc/record/record-main.c:278:15: note: ‘input_file’ was declared here
    const char *input_file;
Do you see this warning in your build? If no, then we should find out,
why you don't see warnings. If yes, then you should fix the warnings
before a commit. If you don't know how to fix the warning, then ask on
the mailing list. I don't want to see a warning the next time I build
your program. I think I mentioned this a couple of times before.
Normally it should be enough to mention it once.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
