GSoC Project | Basic Support for Trace Compass
Mon Jul 15 09:40:02 UTC 2019
On 15/07/2019 10:54, Ravindra Kumar Meena wrote:
>      > The metadata file is in misc/record/ctf. The directory would look
>     clean.
>      > Isn't it needed?
>     Just store the stuff in the current directory. Later we may add a new
>     command line option to optionally specify an output directory.
> Okay
>     Write the packet header and context with all values set which you know
>     at startup, then write the events, then call fseek() to move the file
>     pointer to the begin of the file, write the packet header and context
>     again, with all values.
> Have made changes.
> https://github.com/rmeena840/rtems-tools/commit/9417aae5d19857489d93eba1c52bb94a7b2d67ec
> https://github.com/rmeena840/rtems-tools/commit/6581dd57225ba3171886973b0182487c409f35d2
> Have a look.
> I added the dummy data at the starting of the file. So that only this
> part of the file can be overwritten later after obtaining the relevant
> values.
You need timestamps per-CPU. Please don't use global variables. Add the
data you need to client_context.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
