GSoC Linux UIO driver for PRU
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Jul 16 13:47:31 UTC 2019
On 16/07/2019 15:35, Vijay Kumar Banerjee wrote:
> On Tue, Jul 16, 2019 at 6:57 PM Nils Hölscher <nilhoel1 at gmail.com
> <mailto:nilhoel1 at gmail.com>> wrote:
>     Thanks I have been able to resolve this.
>     But I have run into another issue.
>     RTEMS port of the character device switch table doesn't support
>     a .d_mmap entry.
>     https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/sys/conf.h#L199
>     And I am not certain how the
>     struct rtems_filesystem_file_handlers_r and the structs cdevsw are
>     related.
>     The current BSD driver uses two  cdevsw structs, one to manage
>     interrupts and one to manage io.
>     Should or can I switch them out?
> Hi Nils,
> I have recently worked on a patch to add d_mmap to libbsd. I couldn't
> send it to devel because
> it could not be tested.
> Christian, by the time the VT issue is resolved. I would like to prepare
> a separate clean patch
> for the mmap, what is your suggestion about this?
You create a clean patch only for mmap. Please don't forget to add a
test case to the libbsd devfs test. Although I would have preferred a
working driver to test it, it should be OK to be added without one if
the devfs test works.
Please send a preview of the patch (without devfs test) to the mailing
list so that Nils can already have a look at it and try it.
Best regards
Christian
>     Best,
>     Nils
>     On Tue, 16 Jul 2019 at 13:47, Joel Sherrill <joel at rtems.org
>     <mailto:joel at rtems.org>> wrote:
>         On Tue, Jul 16, 2019, 6:34 AM Nils Hölscher <nilhoel1 at gmail.com
>             Hi,
>             I am currently porting the pruss driver functions, that I
>             want to add in:
>             rtems_filesystem_file_handlers_r pruss_irq_handler.
>             But when I add  my functions like this:
>               .open_h =ti_pruss_irq_open
>             I receive the following compiler warnings:
>             ../../pruss.c:156:13: warning: initialization from
>             incompatible pointer type [-Wincompatible-pointer-types]
>                .open_h = ti_pruss_irq_open,
>             ../../pruss.c:156:13: note: (near initialization for
>             'pruss_irq_handler.open_h')
>             ../../pruss.c:158:13: warning: initialization from
>                .read_h = ti_pruss_irq_read,
>             Can anyone help please?
>         This usually means that either the prototype of the method has
>         not been seen before it is used or the method signature does not
>         match that expected of the indirect method pointer on the left
>         hand side. Make sure the signature matches.
>             The full source can be found here:
>             https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/pruss.c#L91
>             https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/pruss.c#L155
>             Best,
>             Nils
>             On Mon, 15 Jul 2019 at 10:15, Sebastian Huber
>             <sebastian.huber at embedded-brains.de
>             <mailto:sebastian.huber at embedded-brains.de>> wrote:
>                 On 15/07/2019 10:10, Nils Hölscher wrote:
>                 > Thanks this is very helpful.
>                 > But has anyone an existing example of a similar driver?
>                 > I wasn't able find one in /bsps, maybe I didn't search
>                 long enough.
>                 There are some in cpukit:
>                 cpukit/libcsupport/src/consolesimple.c:
>                 IMFS_make_generic_node(
>                 cpukit/libcsupport/src/termios.c:  rv =
>                 cpukit/libcsupport/src/consolesimpletask.c:
>                 cpukit/include/rtems/imfs.h: *   rv =
>                 cpukit/include/rtems/imfs.h:extern int
>                 cpukit/libfs/src/imfs/imfs_make_generic_node.c:int
>                 cpukit/dev/i2c/i2c-bus.c:  rv = IMFS_make_generic_node(
>                 cpukit/dev/i2c/i2c-dev.c:  rv = IMFS_make_generic_node(
>                 cpukit/dev/spi/spi-bus.c:  rv = IMFS_make_generic_node(
>                 cpukit/libblock/src/blkdev-imfs.c:      int rv =
>                 cpukit/libblock/src/blkdev-imfs.c:            rv =
>                 Sebastian Huber, embedded brains GmbH
>                 Address : Dornierstr. 4, D-82178 Puchheim, Germany
>                 Phone   : +49 89 189 47 41-16
>                 Fax     : +49 89 189 47 41-09
>                 E-Mail  : sebastian.huber at embedded-brains.de
>                 PGP     : Public key available on request.
>                 Diese Nachricht ist keine geschäftliche Mitteilung im
>                 Sinne des EHUG.
>             _______________________________________________
>             devel mailing list
>             devel at rtems.org <mailto:devel at rtems.org>
>             http://lists.rtems.org/mailman/listinfo/devel
>     devel mailing list
> devel mailing list
> devel at rtems.org
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
