Sources for fenv (ARM, PPC, x86, SPARC and RISC5)
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Thu Jul 18 03:11:59 UTC 2019
On Tue, Jul 16, 2019 at 6:26 PM Joel Sherrill <joel at rtems.org> wrote:
> Let's give preference to FreeBSD sources. Notes below.
> On Wed, Jul 3, 2019 at 1:08 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> Hello,
>> I have found sources for fenv.
>> 1.1) - ARM FreeBSD Source:
>> - https://github.com/freebsd/freebsd/blob/master/lib/msun/arm/fenv.h
>> - https://github.com/freebsd/freebsd/blob/master/lib/msun/arm/fenv.c
>> 1.2) - ARM NetBSD Source :
>> - https://github.com/NetBSD/src/blob/trunk/sys/arch/arm/include/fenv.h
>> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/arm/fenv.c
> For the ARM FreeBSD source, there are some ifdef's which appear to
> be for architectural variations. Please check the gcc source for arm
> (gcc-XXX/gcc/config/arm) to see if they are defined by gcc. If they
> all are, then there is nothing to consider on how they get tripped.
> For example, __ARM_PCS_AAPCS64 is one. That looks like a multilib
> define.
Okay!
>> 2.1) - SPARC NetBSD Source :
>> - https://github.com/NetBSD/src/blob/trunk/sys/arch/sparc/include/fenv.h
>> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/sparc/fenv.c
> This looks good and may work for sparc64 as well as sparc. Check if
> sparc64-rtems5-gcc defines __arch64 as used byL
> https://github.com/NetBSD/src/blob/trunk/sys/arch/sparc/include/fenv.h#L36
>> 3.1) - PPC FreeBSD Source:
>> - https://github.com/freebsd/freebsd/blob/master/lib/msun/powerpc/fenv.h
>> - https://github.com/freebsd/freebsd/blob/master/lib/msun/powerpc/fenv.c
>> 3.2) - PPC NetBSD Source:
>> https://github.com/NetBSD/src/blob/trunk/sys/arch/powerpc/include/fenv.h
>> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/powerpc/fenv.c
> Sam advice on PPC. Looks OK, check ifdefs
>> 4.1) - x86 FreeBSD Source:
>> - https://github.com/freebsd/freebsd/blob/master/lib/msun/x86/fenv.h
>> 4.2) - x86 NetBSD Source:
>> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/x86_64/fenv.c
> This is not i386 (e.g. 32-bit), it is for the 64-bit target. Good to merge
> it into
> newlib but we don't have a fully functional port to test this with.
>> 5.1) - RISC5 FreeBSD Source:
>> - https://github.com/freebsd/freebsd/blob/master/lib/msun/riscv/fenv.h
>> - https://github.com/freebsd/freebsd/blob/master/lib/msun/riscv/fenv.c
>> 5.2) - RISC5 NetBSD Source:
>> - https://github.com/NetBSD/src/blob/trunk/sys/arch/riscv/include/fenv.h
>> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/riscv/fenv.c
> Same advice.
>> It's impossible to depend on either NetBSD or FreeBSD.
> Yep. Give preference to FreeBSD but if it isn't in FreeBSD, use NetBSD.
>> For some architectures, FreeBSD has code,
>> for some, NetBSD has.
>> For x86, Free BSD has explicit header
>> and NetBSD has .c file.
> These are all architecture specific files so do not go in a main include
> or source directory. They go in an architecture specific subdirectory.
Yah, so here was one confusion.
I was going through fenv sources of SPARC in NetBSD
NetBSD has defined two headers for fenv
1- https://github.com/NetBSD/src/blob/trunk/include/fenv.h
---This contains function prototypes
2- https://github.com/NetBSD/src/blob/trunk/sys/arch/sparc/include/fenv.h
---This defines macros
And hence, I will have to use either FreeBSD or NetBSD depending in the
architecture, I am planning for this approach:
I will make a generic header file, `fenv.h`, which will contain function
prototypes
and other data which are common in all architectures.
Then I will place architecture specific data in their respective `fenv.c`
file
along with the function definitions.
> See
> https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=tree;f=newlib/libm/machine;h=9b2197b2660fd84c6b64ef265c1ec3b6e30c9074;hb=HEAD
> And notice that arm, aarch64, riscv, and i386 are all already there. Looks
> like you can focus on the ones not there (PPC and SPARC). Ignore x86_64
> for now. If there is a ticket for the port, just add a comment to that. I
> don't
> think we are setup to test that port right now.
> Hope that all makes sense.
Yes, thank you!
> --joel
>> Vaibhav Gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190718/7bfb6b28/attachment.html>
