Sources for fenv (ARM, PPC, x86, SPARC and RISC5)
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Thu Jul 18 03:15:23 UTC 2019
On Wed, Jul 17, 2019 at 11:42 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Jul 16, 2019 at 6:57 AM Joel Sherrill <joel at rtems.org> wrote:
> > Let's give preference to FreeBSD sources. Notes below.
> > On Wed, Jul 3, 2019 at 1:08 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >> Hello,
> >> I have found sources for fenv.
> >> 1.1) - ARM FreeBSD Source:
> >> - https://github.com/freebsd/freebsd/blob/master/lib/msun/arm/fenv.h
> >> - https://github.com/freebsd/freebsd/blob/master/lib/msun/arm/fenv.c
> >> 1.2) - ARM NetBSD Source :
> >> - https://github.com/NetBSD/src/blob/trunk/sys/arch/arm/include/fenv.h
> >> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/arm/fenv.c
> > For the ARM FreeBSD source, there are some ifdef's which appear to
> > be for architectural variations. Please check the gcc source for arm
> > (gcc-XXX/gcc/config/arm) to see if they are defined by gcc. If they
> > all are, then there is nothing to consider on how they get tripped.
> > For example, __ARM_PCS_AAPCS64 is one. That looks like a multilib
> > define.
> >> 2.1) - SPARC NetBSD Source :
> https://github.com/NetBSD/src/blob/trunk/sys/arch/sparc/include/fenv.h
> >> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/sparc/fenv.c
> > This looks good and may work for sparc64 as well as sparc. Check if
> > sparc64-rtems5-gcc defines __arch64 as used byL
> https://github.com/NetBSD/src/blob/trunk/sys/arch/sparc/include/fenv.h#L36
> >> 3.1) - PPC FreeBSD Source:
> https://github.com/freebsd/freebsd/blob/master/lib/msun/powerpc/fenv.h
> https://github.com/freebsd/freebsd/blob/master/lib/msun/powerpc/fenv.c
> >> 3.2) - PPC NetBSD Source:
> https://github.com/NetBSD/src/blob/trunk/sys/arch/powerpc/include/fenv.h
> >> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/powerpc/fenv.c
> > Sam advice on PPC. Looks OK, check ifdefs
> >> 4.1) - x86 FreeBSD Source:
> >> - https://github.com/freebsd/freebsd/blob/master/lib/msun/x86/fenv.h
> >> 4.2) - x86 NetBSD Source:
> >> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/x86_64/fenv.c
> > This is not i386 (e.g. 32-bit), it is for the 64-bit target. Good to
> merge it into
> > newlib but we don't have a fully functional port to test this with.
> >> 5.1) - RISC5 FreeBSD Source:
> >> - https://github.com/freebsd/freebsd/blob/master/lib/msun/riscv/fenv.h
> >> - https://github.com/freebsd/freebsd/blob/master/lib/msun/riscv/fenv.c
> >> 5.2) - RISC5 NetBSD Source:
> https://github.com/NetBSD/src/blob/trunk/sys/arch/riscv/include/fenv.h
> >> - https://github.com/NetBSD/src/blob/trunk/lib/libm/arch/riscv/fenv.c
> > Same advice.
> >> It's impossible to depend on either NetBSD or FreeBSD.
> > Yep. Give preference to FreeBSD but if it isn't in FreeBSD, use NetBSD.
> >> For some architectures, FreeBSD has code,
> >> for some, NetBSD has.
> >> For x86, Free BSD has explicit header
> >> and NetBSD has .c file.
> > These are all architecture specific files so do not go in a main include
> > or source directory. They go in an architecture specific subdirectory.
> > See
> https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=tree;f=newlib/libm/machine;h=9b2197b2660fd84c6b64ef265c1ec3b6e30c9074;hb=HEAD
> > And notice that arm, aarch64, riscv, and i386 are all already there.
> Looks
> > like you can focus on the ones not there (PPC and SPARC). Ignore x86_64
> > for now. If there is a ticket for the port, just add a comment to that.
> I don't
> > think we are setup to test that port right now.
> Since arm/riscv/i386 are there, you might be able to write an fenv
> test suite that can pass on one of those archs, and then use it with
> confidence to do TDD of other architectures.
Sure, I will move ahead with this.
Thank you!
> > Hope that all makes sense.
> > --joel
> >> Vaibhav Gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190718/a941b042/attachment-0001.html>
