BSP names
Sebastian Huber
Fri Jul 19 09:33:21 UTC 2019
Hello,
I worked a bit with Doorstop and found the YAML file quite interesting.
The file format is not without problems:
https://arp242.net/yaml-config.html
However, for simple configuration stuff it is easy to write, read and
process. Changes can be reviewed well in Git (content is spread over lines).
I experiment currently a bit with using a YAML file to define the RTEMS
build.
How should BSPs be identified in the future? Should a BSP name be unique
across architectures or do we want to use an "arch/bsp" tuple?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
